LAIV AUDIO CRESCENDO BEAT Linear Power Supply Black
The LAiV Audio Crescendo BEAT is a linear power supply designed to provide a stable DC voltage to Hi-Fi and electronic devices. It features two outputs that can be used simultaneously, delivering respectively 15V / 2A and 5V / 3A, in order to power two devices from a single unit.
By buying this product you get 53 loyalty points
Reference : 22394
539,00 €tax incl.
449,17 € tax excl.
Shipping date: 24-11-2026.
LAiV Audio Crescendo BEAT Dual Output Linear Power Supply 15V / 5V Black
Photo du LAIV AUDIO CRESCENDO BEAT Linear Power Supply Dual Output 15V / 5V Black
Designed for installations combining several devices requiring a DC power supply, the Crescendo BEAT relies on a 70VA toroidal transformer, 17990µF filtering, and a linear architecture designed to limit electrical disturbances. Its two outputs thus allow the power supply of several elements to be centralized within a single system.
LAiV Audio Crescendo BEAT: toroidal transformer and linear regulation
The power supply uses a 70VA toroidal transformer, combined with Schottky diode rectification and a total filtering capacitance of 17990µF. This architecture conditions the current before it passes into a two-stage linear regulation, applied separately to the two outputs. The first stage reduces the ripple and variations resulting from rectification, while the second refines the voltage delivered to the connected devices. The output noise thus reaches ≤ 10µVrms at no load and ≤ 50µVrms at full load, with a ripple rejection greater than 82dB.
LAiV Audio Crescendo BEAT: Interior overview
LAiV Audio Crescendo BEAT: Photo of the outputs
LAiV Audio Crescendo BEAT: outputs and integrated protections
The Crescendo BEAT simultaneously delivers 5V 3A and 15V 2A. The 5V output uses a DC 5.5 / 2.1mm connector and the 15V output a DC 5.5 / 2.5mm connector, while two 50cm DC cables are supplied for connecting the devices. The power supply integrates protections against overcurrents, overvoltages, overheating, and short circuits in order to limit the risks associated with abnormal operating conditions. The IEC C14 mains input accepts networks of 100 to 127V or 220 to 240V, at 50 or 60Hz, while a T2A fuse completes the electrical protection.
LAiV Audio Crescendo BEAT: aluminum chassis and passive cooling
The Crescendo BEAT adopts an aluminum chassis combined with passive cooling, without a fan. This design avoids adding mechanical ventilation noise and allows its integration into a Hi-Fi installation where the power supply remains placed near the connected devices. Available in black or silver finish, it combines two DC power supplies in a single enclosure to simplify the organization of an audio system.
LAiV Audio Crescendo BEAT: Photo of the front
Product typeLinear power supply
Outputs1x DC 5.5 / 2.5mm connector
1x DC 5.5 / 2.1mm connector
Output voltage / current5V 3A output
15V 2A output
Ripple noise≤10µVrms at no load
≤50µVrms at full load
Supply voltage100–127V and 220–240V at 50/60Hz
Enclosure materialAluminum
Dimensions168 x 167 x 70 mm
Weight2.33kg
Package1x LAiV Audio Crescendo BEAT
1x 50cm 5.5/2.1mm power cable
1x 50cm 5.5/2.5mm power cable
InputIEC C14
OutputJack DC 5.5/2.1mm
OutputJack DC 5.5/2.5mm
Output voltage (V)5.0
Output voltage (V)15.0
Output current (A)2.0
Output current (A)3.0
Input voltage (V)240.0
Power SupplyLinear
Que dire.
J'ai hésité à l'acheter car 550 euros, je trouvais cela cher, mais en fait, je comprends pourquoi c'est cher, de la qualité pur, de la fabrication à l'utilisation ; cette alim ne joue pas dans la même cour que les autres. Je l'ai acheté pour alimenter un crescendo Verse et c'est un combo jouissif. Ce beat est tellement bon et beau, que j'en ai acheté un 2eme pour alimenter le reclocker UDCC sur mon main.
This review has been posted for LAIV AUDIO CRESCENDO BEAT Linear Power Supply Dual Output 15V / 5V Black
The LAiV Audio Crescendo BEAT is a linear power supply designed to provide a stable DC voltage to Hi-Fi and electronic devices. It features two...
