Installation sur un Mini PC I9, elle a remplacé l'alimentation d'origine haut la main et contribue au silence électrique de la sortie USB et réseau du logiciel HQPlayer.
Quelque peu imposante tout de même...
This LHY Audio LPS160VA regulated linear power supply provides great stability for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this power supply dedicated to audio and it will work perfectly with your HiFi equipment operating at 19V.
This power supply includes a 160VA toroidal transformer resulting from cooperation between Noratel and Talema, coupled with an OP177 OPA to stabilise and control the voltage with furthermore precision. An RFI filter is also included to eliminate interference created by AC current. Furthermore, Rubycon capacitors stabilise the current reliably, providing a clean, continuous signal with noise levels of no more than 29µV. Finally, the power supply benefits from an aluminium alloy case for efficient heat dissipation and two GX16 aviation outputs.
Please use the GX16 cable supplied. If you use another cable, make sure that the polarity of the two pins is correct.
| Specifications | |
| Product type | Regulated linear power supply |
| Input voltage | 230V |
| Output Voltage / current | 19V 7A |
| Input | IEC |
| Outputs | 2x GX16 aviation connectors |
| General | |
| Case material | Aluminium alloy |
| Dimensions | 140 x 260 x 90mm |
| Weight | 4.5kg |
| Package | 1x LHY AUDIO LPS160VA 1x GX16 to DC 5.5/2.1mm male jack cable 1x Power supply cable |
| Input | IEC C14 |
| Output | GX16 |
| Color | Black |
| Output voltage (V) | 19.0 |
| Output current (A) | 7.0 |
| Input voltage (V) | 230.0 |
| Power Supply | Regulated Linear Power Supply |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
François C.
Sven B.
