TOPPING P50 Regulated Linear Power Supply Ultra Low Noise 2x 5V 1A + 15V 1A Silver
This regular linear power supply Topping P50 offers excellent performance and allows a HiFi system to be powered properly and thus promotes the sound reproduction quality of the latter. Particularly practical, the P50 has 2 USB-A outputs of 5V 1A and 1 DC 5.5/2.1mm jack output of 15V 1A. It is therefore possible to supply several devices with a single power supply.
Reference : 14047
129,00 €tax incl.
107,50 € tax excl.
Last items in stock !
Shipping date: 16-07-2025.
Topping P50
Topping P50 Alimentation Linéaire Régulée Ultra Faible Bruit 2x 5V 1A + 15V 1A
Topping P50 Alimentation Linéaire Régulée Ultra Faible Bruit 2x 5V 1A + 15V 1ATopping P50 Alimentation Linéaire Régulée Ultra Faible Bruit 2x 5V 1A + 15V 1A
Effective associations
The P50 can be associated with a wide range of devices, with output voltages of 15V and 5V being very common for HiFi devices. The power supply is of course an ideal choice to power the brand's other products, such as the DX3 Pro, the D50s, or the D50s and the A50 at the same time.
Switchable input voltage
The power supply is compatible with the input voltages AC220-240V 50/60Hz but also AC100-120V 50/60Hz and can therefore be used anywhere in the world. A 230V/115V switch is used to select the input voltage.
Be sure to select the input voltage corresponding to the voltage supplied by your electrical system before connecting it to your power outlet.
Sealed toroidal transformer
The P50 uses a high quality, custom sealed toroidal transformer, ensuring low magnetic losses and a very low noise level. In addition, the transformer has been designed to eliminate noise and residual interference, in order to provide the cleanest possible signal.
Large energy reserve
The 15V power supply circuit integrates a series of capacitors for a total capacity of not less than 10000µF and the 5V rails have 8000µF. A significant energy reserve to ensure stable output signals.
Ultra low noise linear regulators
The P50 uses 3 ultra-low noise linear controllers TPS7A4700. These chips are capable of high accuracy and therefore perfectly suited for HiFi use and make them an excellent choice for analog circuits.
Aluminium case
All the components of this P50 power supply are integrated in a beautiful and robust Aluminium housing. It is CNC machined in a single piece of metal for better mechanical performance and reduced interference.
Dimensions
Package content
Product typeRegulated linear power supply
Input voltageAC110V/AC220V, 50Hz/60Hz
Input connectorIEC C14
Output voltages2x 5VDC 1A
15VDC 1A
Output connector2x USB-A
1x Jack DC 5.5/2.1mm
Noise< 1mVrms
Dimensions11 x 11 x 5.2cm
Weight0.88kg
Case materialCNC machined Aluminium
ColorSilver
InputIEC C14
OutputJack DC 5.5/2.1mm
ColorSilver
Output voltage (V)5.0
Output voltage (V)15.0
Output current (A)1.0
Input voltage (V)115.0
Power SupplyRegulated Linear Power Supply
2 reviews
Very good power supply
I bought this power supply in combination with the Topping D50s DAC. The build of this PSU is superb. It is small, but very heavy!
Very happy with it sofar.
This review has been posted for TOPPING P50 Regulated Linear Power Supply Ultra Low Noise 2x 5V 1A + 15V 1A Silver
Ottimo alimentatore
Ottimo alimentatore che porta il topping D50 (l'ho accoppiato così) a livelli ben più alti d'altri dac dal costo anche oltre i 1000 euro. L'uso dei questo alimentatore permette al topping D50 di non surriscaldarsi come faceva prima. Inoltre è aumentato il dettaglio, il soundstage, la dinamica, la discesa in basso. E' un incremento notevole di qualità. Lo trovo "quasi" migliore di un altro mio dac dal costo di 2000 euro. in realtà è leggermente inferiore in separazione dei canali e posizione strumenti in profondità. Ma si parla di pochissimo. Con la mia attuale configurazione il D50+P50 in realtà è molto più musicale e piacevole all'ascolto. Proverò a cambiare cavo segnale RCA in modo di ottimizzare di più il dac più costoso. D50+P50 li ho testati anche nel mio impianto principale, composto da amplificatore Bartolomeo Aloia, pre krell 4 telai, linea alimentazione dedicata con cavi furutech da 150-180 euro al metro (fino al contatore). ciabatta in alluminio pieno con schuko furutec, tutti i cavi alimentazione sono fututech con spina oxiade. La stessa alimentazione del topping P50 avviene con furutech e oxiade. Uso cavi segnale RCA in argento oro al 99.999%. Cavi potenza in rame ofc 7n.
Diffusori da 25 mila euro.
Lo sconsiglio vivamente. Se portato in un impianto serio non sfigura.
Se invece nell'impianto c'è un componente scarso potrebbe limare di molto la qualità del dac.
Per quanto riguarda l'enfatizzazione delle alte frequenze è un cosa che si perde ben oltre le 120-250 ore di utilizzo del D50.
Viene totalmente persa grazie al P50.
Accoppiate assolutamente P50 e D50 ed avrete un dac nuovo che vale ben oltre i 1500 euro.
Se pensate d'andare nell'usato dovreste comunque spendere almeno 800-1000 euro per pareggiarlo.
This regular linear power supply Topping P50 offers excellent performance and allows a HiFi system to be powered properly and thus promotes the...
