MOONDROP BLESSING2 In-Ear Monitor IEM Triple Speakers 22 Ohm 117dB 20Hz - 20kHz
With the Blessing2, Moondrop offers exceptional in-ear headphones with a rich and precise sound reproduction. The IEMs incorporate no less than three different drivers, each of which is responsible for the reproduction of a defined frequency range. A particularly effective triple filter allows these frequency bands to be distributed according to each transducer.
By buying this product you get 36 loyalty points
Reference : 16495
369,00 €tax incl.
307,50 € tax excl.
Moondrop Blessing2
Moondrop Blessing2 Écouteurs Intra-Auriculaires IEM Triple Haut-Parleurs 22 Ohm 117dB 20Hz - 20kHz
1DD+4BA, Triple hybrid filter
Physical 3D printed bandpass and lowpass crossover conduits, along with a resistor-capacitor crossover, form a triple hybrid crossover. Two Knowles SWFK tweeters handle the highs, a proprietary Mid-BA driver handles the mids, and a 10mm paper diaphragm dynamic driver handles the lows. This design provides smooth highs, accurate mids and deep lows for an immersive and faithful sound reproduction.
3D printed filter tube
The physical crossover system of the Blessing2 includes a bandpass and a lowpass filter. The former is used to modify the response range of the bass and midrange drivers, while the latter is used to limit the Q value of the midrange and treble drivers. This particular design requires extreme precision in the manufacturing process but allows for incredible sound quality.
A design and robust body
In order to accurately manufacture the complex structure of the Blessing2s without any errors, Moondrop enlisted the help of 3D printing company HeyGears. This partnership leverages DLP-3D printing with medical-grade UV resin to produce reliable, accurate, and robust complex-structured housings.
Stainless steel front panel
The Blessing2 faceplates are crafted from medical grade stainless steel using a precise CNC milling process and then brushed. Assembled with the transparent 3D printed shell, the whole set offers a beautiful aesthetic, both modern and sober.
Perfectly optimized sound reproduction
The triple-crossover structure uses both acoustic filters and a resistive capacitor filter, preserving phase coherence across most of the audible spectrum while ensuring that each driver operates at its respective frequency. In addition, this method provides incredibly transparent and accurate reproduction.
Moondrop Blessing2 Écouteurs Intra-Auriculaires IEM Triple Haut-Parleurs 22 Ohm 117dB 20Hz - 20kHz Moondrop Blessing2 Écouteurs Intra-Auriculaires IEM Triple Haut-Parleurs 22 Ohm 117dB 20Hz - 20kHz
Product typeIn-Ear Monitor (IEM)
TransducersTreble: Knowles SWFK
Medium: Softears D-MID-A
Bass: Dynamic transducer 10mm paper membrane
Impedance22Ω @ 1kHz (±15%)
Effective frequency response20Hz - 20kHz (IEC60318-4)
Sensitivity117dB/Vrms @ 1kHz
THD< 1% @ 1kHz
Speaker configuration1DD 4BA par côté, triple filtre
Channel mismatch±1dB @ 1kHz
IEM connectors0.78mm 2 pins
CableComes with 3.5mm jack to 2x 0.78mm 2 pin cable
ColorSilver
Impedance (Ω)22
Efficiency / Sensitivity (dB)117.0
Lowest frequency (Hz)20
Highest frequency (Hz)20000
With the Blessing2, Moondrop offers exceptional in-ear headphones with a rich and precise sound reproduction. The IEMs incorporate no less than...
