TANCHJIM SODA In-Ear Monitors IEM
TANCHJIM SODA are high-quality hybrid in-ear monitors (IEMs) designed for demanding audiophiles seeking balanced, detailed, and comfortable sound reproduction. Featuring a multi-driver architecture of 1 DD + 4 BA + 2 passive units per ear (one DMT5 dynamic driver, four balanced armature drivers, and two Silk System units), it effectively covers the entire audio spectrum with depth, precision, and smoothness.
By buying this product you get 30 loyalty points
Reference : 21483
309,00 €tax incl.
257,50 € tax excl.
Shipping date: 12-06-2026.
Tanchjim SODA Hybrid IEM In-Ear Monitors 15.5 Ohm 120dB 8Hz-48kHz
xxx
Tanchjim SODA are high-quality hybrid in-ear monitors (IEMs) designed for demanding audiophiles seeking balanced, detailed, and comfortable sound reproduction. Featuring a multi-driver architecture of 1 DD + 4 BA + 2 passive units per ear (one DMT5 dynamic driver, four balanced armature drivers, and two Silk System units), it effectively covers the entire audio spectrum with depth, precision, and smoothness. The internal design is optimized with a high-precision 3-way HPFD-Seg crossover, ensuring consistent integration between the different drivers. The ergonomics have been designed for long listening sessions, with lightweight, contoured ear cups and a pressure reduction system. In terms of connectivity, the SODA comes with a detachable premium high-purity silver-plated copper cable with interchangeable 3.5mm single-ended and 4.4mm balanced terminations for maximum compatibility with any audio source.
Tanchjim SODA: Hybrid sound architecture with 7 drivers
At the heart of the Tanchjim SODA is a sophisticated hybrid configuration combining:
  • A 10 mm DMT5 dynamic driver for fast transient response and deep, controlled bass.
  • Four PURE balanced armatures dedicated to precise mids and detailed highs.
  • Two passive Silk System units tuned specifically to high frequencies for smoother, more natural treble reproduction.
This unique combination delivers balanced, detail-rich sound while maintaining natural timbre and extended frequency response.
L'architecture des TANCHJIM SODA
Tanchjim SODA: Optimized sensitivity & impedance
Tanchjim SODA headphones offer remarkable technical performance with an impedance of 15.5 Ω ± 15% and sensitivity of 120 dB/Vrms, making them easy to drive with a wide range of audio devices, from portable players to dedicated DACs/amplifiers. Their 8 Hz – 48 kHz frequency response ensures well-defined bass extension, clear mids, and open highs without listening fatigue, for accurate music reproduction across all genres.
TANCHJIM SODA : des écouteurs optimisés
TANCHJIM SODA : des écouteurs ergonomique
Tanchjim SODA: Designed for long listening sessions
The ergonomics of SODA have been carefully designed to offer optimal comfort even during long listening sessions. The compact, lightweight ear cups, combined with pressure-balancing T-APB ear tips, reduce pressure sensations in the ear canal. A patented pressure relief system helps minimize ear fatigue while ensuring a more stable fit and consistent audio performance.
Tanchjim SODA: Premium connectors & accessories included
SODA headphones come with a detachable, high-end silver-plated Litz copper cable, ensuring excellent conductivity and clean signal transmission. Thanks to the interchangeable connector system, you can easily switch between a 3.5mm single-ended connection and a 4.4mm balanced connection depending on your needs. The box also includes:
  • One pair of SODA IEMs
  • Detachable 0.78mm 2-pin cable
  • Pressure-balanced T-APB ear tips (6 pairs)
  • 3.5mm & 4.4mm connectors
  • PVC leather carrying case
This complete set ensures a high-end listening experience from the very first use and easy integration into any portable or stationary audio setup.
TANCHJIM SODA : une connectique polyvalente
Product typeIn-ear monitors (IEMs)
Configuration drivers1x 10mm dynamic driver
2x PURE Mid BA
2x PURE Hi BA
2x SS passive units
Dynamic driver technologyDMT5
Diaphragm materialDLC Pu Surround composite dome diaphragm
THD0.5% (@1kHz 94dB)
Impedance15.5Ω (±15%)
Sensitivity120dB/Vrms
Frequency response8Hz-48kHz
Detachable cable
IEM connectorsCIEM 0.78mm
Cable terminaisonInterchangeable: 4.4mm balanced angled jack & 3.5mm angled jack
Cable structureHigh-purity silver-plated copper, densely braided coaxial Litz structure
ColorTransparent / Blue
Package1x Pair of Tanchjim SODA IEMs
1x Detachable 0.78mm 2-pin cable
6x Pressure-balanced T-APB ear tips (6 pairs)
1x 3.5mm & 4.4mm connectors
1x PVC leather carrying case
ColorBlue
ColorTransparent
Impedance (Ω)15.5
Efficiency / Sensitivity (dB)120.0
WirelessNo
Cable terminationJack 3.5mm
Cable terminationJack 4.4mm
Phone call featureNo
Noise reductionNo
TANCHJIM SODA In-Ear Monitors IEM Hybrid 15.5 Ohm 120dB 8Hz-48kHz
TANCHJIM SODA are high-quality hybrid in-ear monitors (IEMs) designed for demanding audiophiles seeking balanced, detailed, and comfortable sound...
