AUDIOPHONICS Amplifier 2.1 Class D TPA3116D2 2x 50W +100W 4 Ohm Silver
Class D amplifier with right / left and low output. Treble and bass separately adjustable, adjustable subwoofer volume, adjustable low-pass filter.
4.3 / 5
Reference : 12676
64,90 €tax incl.
54,08 € tax excl.
Class D Amplifier with TPA3116D2 chip
Interface amplificateur D TPA3116D2 volume and filters option
This 2.1 class D amplifier TPA3116D2 offers high quality audio reproduction in a solid and compact format
It delivers 2x 50 Watts with an additional output for subwoofer 100W at 4 ohm. A controlled power that adds to the precision and the musical qualities that it shows.
Its interface is very complete since it allows to adjust separately
  • the treble of the stereo output
  • the bass of the stereo output
  • the volume of the subwoofer
  • the low pass filter of the subwoofer (80 à 180Hz)
  • the general volume
Versatile and very easy to implement, it is the ideal base for the realization of small systems or office amplification quality. Its options and settings will compensate for minor inaccuracies if the configuration of the space does not allow to position the speakers optimally. It is therefore a good amplifier for a first very honorable audio system or for mounting a secondary installation.
Moreover, it benefits from a Bluetooth 5.0 reception, compatible with the codecs aptX HD, aptX Adaptive or LDAC allowing to reach a very good audio quality in Bluetooth. This Bluetooth reception is associated with a DAC PCM5102A in charge of the digital / analog conversion.
The Bluetooth pairing code is: 0123
Warning: power supply not included.
TypeClass D amplifier
Power2x25W + 50W  8 Ohm / 2x50W + 100W 4 Ohm
Volume ControlYes
Yield90%
THD + N<0.1%
Signal / noise102dB
Sensibility270mV
InputsRCA Stereo
Bluetooth 5.0
OutputsSpeakers 2x + Subwoofer
PowerDC 15-25V (DC Jack 5.5 / 2.5mm) not included
Dimensions180 x 100 x 36 mm
Weight520 g
OutputSpeaker terminal
Channel2.1
Amplifier chipTPA3116D2
Power (W)50.0
7 reviews
Fonctionnel
Pour le prix, un ampli peu puissant, avec réglage basses aigu, et caisson de basse, du bluetooth. Le son est agréable, réaliste.
Par contre, l'alimentation est abscente, 22€ à ajouter. La puissance 2*50W, ça va pour des hauts parleurs de 10cm, mais pas plus. Il a pas de réserve. Je n'ai pas utilsé de caisson de basse. Les connections de câbles sont minuscules et rapprochées.
Pour moi, idéal comme ampli de dépannage, de test ou pour donner un fond musical et la radio.
This review has been posted for AUDIOPHONICS TPA-SW25F Amplifier 2.1 Class D TPA3116D2 Bluetooth 5.0 2x 50W + 100W 4 Ohm Black
Code Bluetooth 0000
Si le code pour l'appairage Bluetooth n'est pas 0123 alors essayez : 0000
Très bien !
J'aurais vraiment aimé voir quelques graphes dans la description !
Sinon vraiment pas mal. J'ai monté un 2.1 avec du matos de récup : deux enceintes 30w JVC et un sub Samsung. Très content du résultat. Il faut juste penser à l'alimentation non fournie. Je n'ai pas réussi à me connecter au bluetooth mais je n'ai pas acheté pour ça alors, attention si c'est important pour vous !
Bonjour,
Le code pour l'appairage Bluetooth est : 0123
bon rapport qualité-prix.
fabrication de bonne qualité(façade et boitier métalliques, entrée et sorties correctes), cet ampli correspond bien à la fonction de remplacement d'une amplification HS dans un système audio pc" Creative T3". petits bémols, la diode de façade est allumée en permanence , pas d'info sur le potentiomètre réglage de la fréquence voie grave et quid de la fiabilité dans le temps?
Fonctionnel et efficace
J'ai fait l'acquisition de cet ampli afin de pouvoir rattraper un kit 2.1 (Gigaworks T3) tombé en rade. Il fait le job et bien câblé, il me permet donc de réutiliser les satellites et sub de Creative. Néanmoins, je trouve qu'il chauffe un peu, et malgré les 96W de l'alim, je n'ai pas l'impression d'avoir récupérer la puissance que j'avais avec les originaux. Pour la qualité du son non plus. Pas de mode d'emploi en effet pour le réglage des différentes plages, même si j'ai tenté de le faire à l'écoute.
Bref, un boitier qui fait le travail et qui permet de ne pas jeter votre kit si jamais son électronique tombe en panne.
