AIYIMA A20 Class D 2.1 Amplifier
The Aiyima A20 is a Class D amplifier based on a TPA3255 chip, designed for stereo or 2.1 use. It offers 250W output power under 4Ω per channel, a built-in high-pass filter and a bypass mode, making it a great choice for many Hi-Fi setups.
Reference : 21311
179,00 €tax incl.
149,17 € tax excl.
Shipping date: 17-06-2026.
Aiyima A20 Class D 2.1 Amplifier TPA3255 2x250W 4 Ohm
Aiyima A20 : Front view
Aiyima A20 : TPA3255 chip
Aiyima A20: 250W amplification
The Aiyima A20 is a Class D amplifier based on a TPA3255 chip, combined with a post-filter feedback loop (PFFB), reducing distortion and stabilising frequency response. This architecture ensures neutral reproduction, with a THD+N of only 0.002% and a signal-to-noise ratio of 116dB. The A20 delivers up to 250W per channel into 4Ω when paired with a 48V/10A power supply.
Aiyima A20: Complete connectivity
The A20 offers two input modes: unbalanced RCA and balanced XLR, each selectable on the front panel. An additional +3 dB gain can be applied to the RCA input to optimise the level according to the source. Outputs include speaker terminals and a dedicated SUB OUT output for integrating an active subwoofer. The A20 also features a 12V trigger input for synchronising its power-up with the rest of your Hi-Fi system. Finally, a bypass mode allows the A20 to be used as a pure power amplifier, bypassing its internal volume control.
Aiyima A20 : Trigger connection
Aiyima A20 : SUB output and bypass
Aiyima A20: 2.1 amplifier
The A20 includes an adjustable high-pass filter, designed to relieve the main speakers of low frequencies and transfer this range to an active subwoofer. This internal management simplifies the setup of a 2.1 system without the need for an external filter or additional DSP.
Aiyima A20: Flawless build quality
In order to deliver the most faithful sound reproduction possible, the A20 uses renowned components such as Rubycon and WIMA capacitors, as well as LME49720 OPAs mounted on DIP8 to ensure interchangeability. The printed circuit board has a total of four layers, all of which are gold-plated. Finally, the aluminium chassis ensures excellent heat dissipation, contributing to the overall reliability of the amplifier.
Aiyima A20 : Replacement of an OPA
Review of the Aiyima A20 by Audio Science Review
" ... a very power full amplifier, with low noise and mostly, low distortion. Combine it with good looks and nice functionality such a proper high pass filtering for subwoofer use and you have a winner here. "
Logo ASR
Product type2.1 amplifier
Amplifier typeClass D
Inputs1x Balanced stereo XLR
1x Single-ended stereo RCA
OutputsSpeaker terminals
1x RCA for subwoofer
Amplification chipTPA3255
RMS output power 36V/6A2x 170W @ 4Ω
2x 100W @ 6Ω
2x 94W @ 8Ω
RMS output power 48V/5A2x 120W @ 4Ω
2x 110W @ 6Ω
2x 100W @ 8Ω
RMS output power 48V/10A2x 250W @ 4Ω
2x 210W @ 6Ω
2x 150W @ 8Ω
Total harmonic distortion more noise (THD+N)0.002%
Signal-to-noise ratio (SNR)≥ 116dB
SINAD≥ 95dB
Dynamic range≥ 110dB
Frequency response20Hz-20kHz (±0.4dB)
Supply voltage24-48V DC
Dimensions190 x 142 x 46mm
Weight1.1kg
Package1x Aiyima A20
Mains adapter 48V/5A
InputXLR
OutputSpeaker terminal
OutputSubwoofer
Channel2.1
Amplifier chipTPA3255
Power (W)250.0
AIYIMA A20 Class D 2.1 Amplifier TPA3255 2x250W 4 Ohm
The Aiyima A20 is a Class D amplifier based on a TPA3255 chip, designed for stereo or 2.1 use. It offers 250W output power under 4Ω per...
