LOXJIE A30 Class D Amplifier Infineon MA12070 Bluetooth 5.0 2x50W 4 Ohm
With the A30, Loxjie offers an excellent Class D amplifier that is powerful, compact and affordable. It features excellent components for great sound reproduction and full connectivity for easy integration into the vast majority of audio systems.
4.9 / 5
Reference : 14817
169,00 €tax incl.
140,83 € tax excl.
Shipping date: 09-06-2026.
Loxjie A30
Loxjie A30 Amplificateur Class D Infineon MA12070 Bluetooth 5.0 2x80W 4 Ohm
Infineon Merus MA12070 amplifier
The amplification circuit is based on an Infineon Merus MA12070 chip. This allows to develop a consequent power of 2x50W under 4Ω, while ensuring a very low distortion, an excellent efficiency and a complete protection system.
The chip's power management algorithm automatically adjusts switching frequency and modulation to limit power loss and EMI interference.
Subwoofer output
The A30 has a suwboofer output on RCA connector. It is thus possible to use the amplifier to power a 2.1 system and enjoy a rich reproduction with deep bass.
Bluetooth
Convenient, the Loxjie A30 allows you to receive your audio files remotely, in Bluetooth, directly from your smartphone. The Bluetooth 5.0 standard combined with the aptX protocol allows for a stable and high quality transmission.
EQ Mode
To suit your listening style and your audio system, the A30 offers no less than 7 preset equalizers as well as a customizable equalizer. The bass and treble levels can be adjusted in 1dB steps from -10dB to +10dB.
Complete connection system
The A30 has full connectivity to integrate with the vast majority of audio systems. The A30 has stereo RCA, Coaxial, Optical and Micro USB inputs. This last input supports sample rates up to PCM 32bit 384kHz. On the output side, there are speaker terminals on the back and a 6.35mm headphone output on the front.
Coaxial input and RCA input share the same interface and therefore cannot be used at the same time.
Quality components
The entire Loxjie A30 benefits from a careful design, based on components known for their audio quality. While the A30 features the very good Infineon MA12070 amplifier chip, the A30 also includes a 24-bit ESS ES9023 DAC with an integrated 2Vrms AOP. The latter uses HyperStream architecture and Time Domain Jitter Eliminator technology to significantly reduce jitter and provide a dynamic range of 112dB.
Volume and tone control is entrusted to an NJW1194 chip, ensuring low distortion and low noise with a ladder resistor system.
Robust and elegant
The components of the A30 are housed in an elegant and robust aluminum case, offering excellent rigidity that also eliminates case vibration, while limiting the impact of electromagnetic interference on the circuits. The screen is protected by a highly transparent tempered glass pane.
Diagram
1Screen
2Jack 6.35mm Headphone output
3Volume / Power button
4Coaxial / RCA right channel input
5RCA left channel input
6Bluetooth antenna
7Optical input
8Subwoofer output
9Micro USB input
10Speaker terminals
11Power connector 24VDC
Test du Loxjie A30 par Audio Science Review
" The Loxjie A30 is an attractive, solid performance with excellent measured and subjective sound quality. Inclusion of a USB DAC and Coax/Toslink input eliminates the need for a DAC for less clutter "
Product typeAmplifier
Amplifier typeClass D
Inputs1x Micro USB
1x Coaxial
1x Stereo RCA
1x Optical
Bluetooth 5.0
OutputsSpeaker terminals
1x Subwoofer output
1x Jack 6.35mm headphone output
Amplification chipInfineon Merus MA12070
DAC chipESS ES9023
Volume control chipNJW1194
THD+N (A-Weighted)0.003%
SNR (A-Weighted)108dB
Power2x 50W @ 4Ω
Headphone output power100mW @ 32Ω
Housing materialAluminum
Consumption35W
Dimensions151 x 170 x 38mm
Weight520g
ColorGrey
Package1x Loxjie A30
1x Remote control
1x Bluetooth antenna
1x USB cable
1x Power supply (24V / 6.75A)
THD+N / Output power (4Ω)
THD+N / Output power (8Ω)
Frequency response
OutputSubwoofer
OutputJack 6.35mm
OutputScrew terminals
ColorGray
Channel2 (Stereo)
Channel2.1
Amplifier chipInfineon MA12070
Power (W)50.0
Remote ControlYes
20 reviews
Bon petit ampli avec sortie casque meilleure que prévu.
Cet ampli viens remplacer un SMSL Q5 Pro que j'utilise depuis plusieurs années dans mon bureau.
Je souhaitais avoir une sortie casque sur l'ampli, or, le Loxjie dispose d'une telle sortie.
Je pensais être déçu par l'utilisation au casque après avoir lu certaines critiques.
Eh bien ! je dirais que c'est la bonne surprise. Que ce soit avec un AKG K702 ou un Hifiman Sundara, la puissance de sortie est suffisante et le son n'est pas mauvais du tout, au contraire.
Pour la sortie sur les enceintes je suis un peu surpris des données du constructeur qui indiquent 2x80w sous 4ohms dans la notice d'emploi. Le SMSL était donné pour 2x45w sous 4ohms et à mon avis il est plus puissant que le Loxjie. Simplement, je pense qu'il faut se méfier des données techniques du constructeur. Le chiffre de 2x50w sous 4 ohms donné par Audiophonics, me semble plus réaliste, mais sans doute légèrement optimiste encore.
Quoi qu'il en soit ce n'est pas dramatique car la puissance est plus qu'amplement suffisante pour piloter mes Q Acoustics 3020i dans un espace restreint. La puissance délivrée doit être suffisante pour sonoriser une pièce de moins de 20m2, sauf à vouloir reproduire la sono du stade de France.
Je ne suis pas déçu globalement par cet ampli, le son est de bonne qualité au moins sur de la musique que j'écoute (classique et jazz).
Je ne suis pas certain qu'il y ait une amélioration sensible par rapport au Q5 Pro, je manque encore de recul (3 jours d'utilisation) pour en juger, mais ce n'est pas moins bon.
Quelques points gagnants: la télécommande fonctionne beaucoup mieux que celle du SMSL, l'affichage et la navigation dans les menus sont aussi supérieurs.
Enfin, l'aspect extérieur est sympa, la qualité de fabrication semble vraiment correcte.
Tarif, rapidité et qualité de livraison Audiophonics sont impeccables.
This review has been posted for LOXJIE A30 Class D Amplifier Infineon MA12070 Bluetooth 5.0 2x50W 4 Ohm
Rapport taille / flexibilité / look / son / qualité de fabrication hallucinant.
J'admets volontiers être un idiophile, avec un système pratiquement dans chaque pièce de la maison et un amour de l'équipement haut de gamme et de l'écoute la plus parfaite possible. A priori pas le client pour l'A30.
Sauf que j'avais besoin d'un petit système annexe pour le salon, qui permette 1) à ma femme d'écouter ses podcasts favoris sans se - et me - reuiner les tympans avec son téléphone; 2) à tout le monde d'utiliser notre vieux piano droit numérique, toujours impeccable niveau clavier mais mort niveau sono embarquée, et qui dispose d'une sortie audio; 3) accessoirement, de passer de la musique de fond pendant les dîners entre amis, sans faire chauffer les blocs mono classe A pour ça (qui plus le système principal qui les inclut est trop loin de la table). Vu les chroniques dithyrambiques, le prix réduit et la politique de retours d'Audiophonics, j'ai tenté le coup avec l'A30, et je suis ravi.
1. On le voit à peine : il est MINUSCULE.
2. Le peu qu'on voit est plutôt très élégant.
3. La qualité de fabrication extérieure est impeccable. C'est plutôt nettement mieux fini que tous les autres amplis "mini" que j'ai pu voir, qu'il s'agisse de marques chinoises ultra abordables ou de marques comme Nad et Musical Fidelity, que pourtant j'aime beaucoup, mais dont les amplis petit format font cheap.
4. La flexibilité des connexions est dingue. Bluetooth - ultra stable et franchement de très bonne qualité; USB (avec câble micro, mais bon); entrée analogique (dont je me sers pour le piano, ce qui veut dire ni Subwoofer ni entrée coaxiale dispo) - le truc est un vrai couteau suisse.
5. Qu'est-ce que ça sonne ! J'avais une paire d'enceintes de JVC EX A1 en rab - les single drivers avec cônes en bois : avec un peu de travail sur l'eq de l'ampli, on obtient un son clair, plein de pêche, sans agressivité, légèrement chaleureux et très détaillé. La scène sonore est un peu étroite et pas ultra profonde mais très cohérente; avec une belle image centrale; et les voix (podcasts et autres) passent super bien, avec un joli bas médium un peu arrondi.
Franchement, pour un desktop ou un système polyvalent télé / ordi / bluetooth dans un petit espace, le truc est bluffant.
Super petit ampli
Je cherchais un petit ampli classe D et peu encombrant pour alimenter à la fois des Eltax monitor 3 et des Highlands Aingel dans deux pièces différentes. je suis bluffé par le résultat et du coup j'en ai acquis un second. Merci Audiophonics.
rapport qualité prix
question puissance, c'est vraiment correct (je ne connaissais pas les classe D).
Le son de base est un peu criard dans les médium. Il faut jouer du régl
A great amp, unbeatable for the price
Extremely clean, crisp and analytical sound. No discernible noise, even if you hold your ear directly to the tweeter. This also speaks in favour of the high quality of the power supply unit. Its treble is a little too strong for me personally, but I easily reduced it using the tone control. Operation is very simple and the workmanship is very high quality. Thank you, Audiophonics, for the fast and safe delivery.
With the A30, Loxjie offers an excellent Class D amplifier that is powerful, compact and affordable. It features excellent components for great...
