SMSL AO10 Integrated Amplifier
The SMSL AO10 is a Class D stereo amplifier equipped with two Texas Instruments TPA3116 chips, delivering 2×70W into 4Ω. It features Bluetooth 5.3 connectivity with support for SBC and AAC codecs for wireless use, as well as a 12V trigger input and output system for optimal integration into your HiFi system.
Reference : 21344
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 02-06-2026.
SMSL AO10 Integrated Amplifier Class D TPA3116 2x70W 4 Ohm
SMSL AO10 : Front view
The SMSL AO10 is a Class D stereo amplifier equipped with two Texas Instruments TPA3116 chips, delivering 2x70W into 4Ω. It features Bluetooth 5.3 connectivity with support for SBC and AAC codecs for wireless use, as well as a 12V trigger input and output system for optimal integration into your HiFi system.
SMSL AO10: TPA3116 dual chip
The AO10 is based on a Class D amplification architecture with dual TPA3116 chips. This configuration delivers 2x70W of power into 4Ω, or 2x100W into 2Ω. An electronic volume control replaces the traditional mechanical potentiometer, eliminating contact noise and ensuring channel balance across the entire attenuation range.
SMSL AO10 : amplifier with speaker
SMSL AO10 : Bluetooth connectivity
SMSL AO10: Bluetooth 5.3 connectivity
The AO10 features a Bluetooth 5.3 receiver chip and supports AAC and SBC codecs. This allows you to easily enjoy audio sources such as your smartphone for remote use. In addition, for optimal ease of use, the AO10 includes a 12V trigger input and output, allowing you to synchronise it with the rest of your audio system.
Product typeIntegrated amplifier
Inputs1x Stereo RCA
Bluetooth
OutputSpeaker terminals
Frequency response20Hz-20kHz
Bass and treble adjustment range-10dB ~ +10dB
Total harmonic distortion more noise (THD+N)0.02%
Channel separation-103dB
Input sensitivity500mVrms
Output power2x100W @ 2Ω
2x70W @ 4Ω
Power supply voltage100-240V AC
Consumption36W
Dimensions190.4 x 46 x 163.2mm
Weight840g
Package1x SMSL AO10
1x Remote control
1x Power cable
1x 3.5mm jack cable, 1m
Channel2 (Stereo)
Amplifier chipTPA3116
Power (W)70.0
Remote ControlYes
Download
The SMSL AO10 is a Class D stereo amplifier equipped with two Texas Instruments TPA3116 chips, delivering 2×70W into 4Ω. It...
