Vraiment bon, surtout pour ce prix Vraiment une très bonne surprise : -très bon son ! très ample dans les graves sans aucune exagération et sans devoir ajuster...
Very good preamplifier for the money It is pretty transparent even with the stock OPAs (in my case LM49720). Highly recommended (for the money). It is difficult to...
We offer a very wide range of Jack connectors. Jack plugs are essential in the audio world, and are available in different formats, materials, plating, or in different ways: crimping, soldering, or clamping. Among our numerous jack connectors, discover the recognized brands such as Furutech, Elecaudio, Neotech, or 1877PHONO.
This Monacor MZT-223 6.35mm stereo jack jack is perfect for PCB mounting. It will allow you to simply integrate a female connector for headphones, for example, on a DIY creation. Its gold-plated contacts ensure very good conductivity and resistance to oxidation.
This Neutrik NP2XX-SILENT jack connector is a 6.35mm mono connector. This 2-pole connector features gold contacts for corrosion and oxidation resistance, and a rubber body. It incorporates a built-in short circuit system to eliminate noise and POP when changing the connection of a loaded instrument such as a guitar.
This rugged 6.35 male stereo jack connector is ideal for professional cable design. While remaining thin, the connector uses materials that ensure durability at all times, including a zinc body.
This 3.5mm NTP3RC-B jack connector from Neutrik has 3 poles with gold plated contacts, ensuring good conductivity but also excellent oxidation resistance. The connector body is made of metal (Zinc) and is angled at 90°, ideal for use in confined spaces or for more convenient cable orientation, depending on the situation.
This 3.5mm stereo male jack connector benefits from a beautiful quality design with gold plating of the contacts, promoting conductivity and resistance to oxidation. The connector accepts cables up to Ø8mm diameter.
This Neutrik Rean NYS231LBG connector features a beautiful design with gold-plated contacts, ensuring good conductivity and resistance to oxidation, as well as an anodized metal body. The connector accepts conductors up to 6mm in diameter.
This gold-plated 3.5mm male mono jack connector from Rean Neutrik is dedicated to DIY cable assembly for Hi-Fi equipment, headphone cables or repairs. It's easy to solder and has good mechanical strength.
This connector set offers a practical solution for adapting a cable to different device connectors. It's a set of interchangeable connectors, including a 2.5mm jack, a 3.5mm jack and a 4.4mm jack. The contacts are gold-plated to ensure good conductivity and resistance to oxidation.
This high-quality, female 3.5mm jack connector features gold-plated contacts, ensuring good transmission quality and excellent resistance to oxidation. Robust, the connector also benefits from a metal body. It accepts cables up to 6mm in diameter.
This male Jack 3.5mm connector of good quality benefits from gold plated contacts, ensuring a good transmission quality and an excellent resistance to oxidation. It accepts cables up to 6mm in diameter.
