JANTZEN AUDIO AIR CORE WIRE COIL 000-1204 Coil 4N Copper 20AWG 0.35mH 0.38 Ohm
Jantzen Audio Air Core Wire Coil are made from high-purity copper wire, perfectly wound to create a distortion-free inductor for all audio applications. Their low inductance tolerance of +/-3% and high power handling make them the most versatile coils on the market.
Reference : 21497
6,90 €tax incl.
5,75 € tax excl.
Shipping date: 24-11-2026.
Jantzen Audio Air Core Wire Coil 000-1204 Coil 4N Copper 20AWG 0.35mH 0.38Ω
The Jantzen Audio Air Core Wire Coil coils are made from high-purity copper wire, offering distortion-free inductance. They are therefore suitable for all audio applications. These coils feature a modern, self-supporting design with low inductance tolerance (±3%). Power handling depends on the wire used and more particularly on the thickness of the copper wire. The greater the thickness, the higher the power capacity. Jantzen Audio Air Core Wire Coils are therefore among the most versatile on the market.
Product typeAir core coil
Material4N copper
Inductance0.35mH
Tolerance±3%
DCR0.38Ω
Wire diameter0.8mm
Wire Section20AWG
Dimensions & Weight
Outer diameter30mm
Inner diameter15mm
Height15mm
Inductance (mh)0.35
Jantzen Audio Air Core Wire Coil are made from high-purity copper wire, perfectly wound to create a distortion-free inductor for all audio...
