This section presents all our midrange, midbass and full range speakers. Many brands are represented allowing everyone to find a model that will suit their project. The filters on the page allow you to make a more precise selection according to your needs.
Dayton Audio's Design Series has been designed to give loudspeaker designers access to high-quality drivers. Featuring a cast aluminum frame, an anodized aluminum cone and polyimide coating, they can deliver a wide range with incredibly low distortion.
This Dayton Audio CE32A-4 mini speaker is designed to meet a variety of needs with a wide frequency response range. It is particularly suitable for small DIY designs
The Fountek FE86 is a small, wideband speaker with a generous ferrite magnet system covering a frequency range of 95Hz to 20kHz. An ideal model for small speaker design.
This Fountek FW168K bass/midrange driver with aluminum cone and protective grille allows the restitution of frequencies from 70Hz to 4500Hz. Ideal for mounting multi-way speakers.
The Fountek FW222 is a Ø20.3 "cm (8") midwoofer driver incorporating an anodised aluminium cone with an inverted dome and integral grille. The bowl is fully open under the spider for minimal compression at high output levels.
This loudspeaker is a classic of the German designer. An expressive and articulate midrange sound with an output of 94dB, ideal for three-way speaker design. Inverted suspension, high temperature Kapton voice coil, low moving mass for optimal impulse behaviour make this model an ideal choice for high performance loudspeaker design.
This large diameter loudspeaker weighs only 1.8kg at 135mm depth and has a power handling of 200W RMS at a resonance frequency of 43Hz. It is ideal for the design of lightweight, high-performance stage loudspeakers.
