DAYTON AUDIO CE48-4 Full-Range Speaker Driver
The Dayton Audio CE48-4 is a 2-inch (5.08cm) full-range speaker designed for compact applications, DIY projects, commercial integrations, custom audio devices, and artistic installations.
Reference : 22407
7,90 €tax incl.
6,58 € tax excl.
Shipping date: 01-12-2026.
DAYTON AUDIO CE48-4 Full-Range Speaker 5W 4 Ohm 79dB 120Hz -20KHz Ø5.08cm
DAYTON AUDIO CE48-4
The Dayton Audio CE48-4 is a 2-inch (5.08cm) full-range speaker designed for compact applications, DIY projects, commercial integrations, custom audio devices, and artistic installations. Despite its compact size, this 4Ω transducer offers a power handling of 5W RMS and 10W maximum, with a frequency response of 120Hz to 20kHz and a sensitivity of 79dB (2.83V/1m), allowing for clear and precise audio reproduction.
It uses a rubber surround and a steel basket, with a total outer diameter of 2.55" (64.8mm), a depth of 1.4" (35.6mm), and 4 mounting holes, providing suitable integration for projects where available space is limited. With its compact size, balance between footprint, cost and performance, and full-range design, the Dayton Audio CE48-4 is a suitable solution for manufacturers and DIY enthusiasts looking for a versatile transducer for their audio projects.
DAYTON AUDIO CE48-4
Technical Specifications
Product typeMiniature full-range speaker
Nominal diameterØ5.08cm (2")
PowerRMS: 5W
Max: 10W
Impedance4Ω
Frequency response120Hz-20KHz
Sensitivity79dB 2.83V/1m
Voice coil diameterØ16.002mm (0.63")
Thiele-Small Parameters
Resonant frequency (Fs)151Hz
DC resistance (Re)3.5Ω
Voice coil inductance (Le)0.37mH
Mechanical quality factor (Qms)11.03
Electromagnetic quality factor (Qes)1.04
Total quality factor (Qts)0.95
Equivalent air volume compliance of the moving assembly (Vas)0.002ft³ (0.0566L)
Mechanical compliance of the suspension (Cms)0.59mm/N
Force factor (BL)2.48T·m
Diaphragm moving mass (Mms)1.9g
Maximum linear excursion (Xmax)1.2mm
Diaphragm area (Sd)9.1cm²
Materials
Surround materialRubber
Basket materialSteel
Mounting Information
Total outer diameterØ64.77mm mm (2.55")
Cutout diameterØ35.56mm (1.4")
Mounting holes4
PackagingSold individually
Speaker Power (W RMS)5.0
Speaker TypeFull range
Impedance (Ω)4
Loudspeaker diameter (mm)50.0
Diaphragm typeN/A
Efficiency / Sensitivity (dB)79.0
Max Linear Excursion (Xmax) (mm)1.2
Lowest frequency (Hz)120
Highest frequency (Hz)20000
DAYTON AUDIO CE48-4 Full-Range Speaker Driver 5W 4 Ohms 79dB 120Hz–20kHz Ø5.1cm
The Dayton Audio CE48-4 is a 2-inch (5.08cm) full-range speaker designed for compact applications, DIY projects, commercial integrations, custom...
