DAYTON AUDIO CE70PR-4 Midrange / Full-Range Speaker
The Dayton Audio CE70PR-4 is a 6.35cm (2.5") full-range speaker, designed to reproduce the entire audible spectrum in a particularly compact format. Its 20 W power handling and 4 Ω impedance make it easy to pair with many amplifiers, while its rugged design meets the requirements of commercial installations as well as DIY projects.
Reference : 22470
11,90 €tax incl.
9,92 € tax excl.
Shipping date: 24-11-2026.
DAYTON AUDIO CE70PR-4 Midrange / Full-Range Speaker 20W 4 Ohm 85dB 85Hz-13kHz Ø6.35cm
DAYTON AUDIO CE70PR-4: Front view
Intended for manufacturers, integrators and designers looking for a space-saving component, it delivers a clear and balanced reproduction while integrating easily into restricted spaces. This versatility makes it suitable for custom equipment as well as artistic installations and audio applications where the balance between size, cost and performance is a central factor.
DAYTON AUDIO CE70PR-4: Dimensions and measurements
Technical specifications
Product typeMidrange / Full-Range speaker
Impedance4Ω
Sensitivity85dB 2.83V/1m
Frequency response85Hz-13kHz
Voice coil diameter1.98cm (0.78")
Nominal diameter6.35cm (2.5")
PowerRMS: 20W
MAX: 40W
Thiele-Small parameters
Resonance frequency (Fs)109Hz
Cone surface area (Sd)24.6cm²
Voice coil inductance (Le)0.31mH
DC resistance (Re)3.13Ω
Mechanical quality coefficient (Qms)3.5
Electromagnetic quality coefficient (Qes)0.77
Total quality coefficient (Qts)0.63
Force factor (BL)3.11T·m
Total moving mass + air load on the cone (Mms)3.5g
Mechanical compliance of suspension (Cms)0.61mm/N
Compliance equivalent volume (Vas)0.018ft³
Max linear excursion (Xmax)4mm
Weight360g
PackageSold individually
Speaker Power (W RMS)20.0
Speaker TypeFull range
Impedance (Ω)4
Loudspeaker diameter (mm)63.5
Diaphragm typeN/A
Efficiency / Sensitivity (dB)85.0
Max Linear Excursion (Xmax) (mm)4.0
Lowest frequency (Hz)85
Highest frequency (Hz)13000
DAYTON AUDIO CE70PR-4 Speaker Driver Midrange / Full-Range 20W 4 Ohm 85dB 85Hz-13kHz Ø6.35cm
The Dayton Audio CE70PR-4 is a 6.35cm (2.5") full-range speaker, designed to reproduce the entire audible spectrum in a particularly compact...
