Discover our range of portable headphone amplifiers, designed for use both at home and on the move, thanks to a compact form factor and an adapted design. Enjoy the best sound quality, wherever and whenever you want.
The DC07PRO is the new version of iBasso's portable DAC/headphone amplifier. This compact device is equipped with 4 CS43131 chips and a custom-built FPGA, enabling it to read files up to PCM 32bit 768kHz and DSD512. Its low power consumption and high output level of 430mW+430mW at 32Ω make it the perfect travel companion.
The iBasso Nunchaku is a balanced portable DAC and headphone amplifier based on two CS43198 chips coupled to an FPGA to handle signal conversion up to 32bit PCM and DSD512. As for the amplification stage, you can choose between operation using power tubes for a warm sound or more traditional Class AB operation for a more neutral sound with improved...
The iBasso PB5 is a portable analog headphone amplifier based on a balanced structure and the use of audiophile components. Its preamplification stage is based on Nutube 6P1 tubes, while its amplification stage uses OPA827 and VCEsat transistors. A hybrid design, it offers the smoothness and warmth of tubes coupled with the power of more modern components...
With the Go Bar Kensei, iFi Audio offers its most powerful USB DAC and ultraportable headphone amplifier. With its particularly compact format, it can accompany you on all your travels, providing high quality listening at all times, whether from a smartphone, tablet or computer.
The iFi Audio Go Blu is an ultra-portable DAC and headphone amplifier combo designed to give you the best sound quality anywhere, anytime! It offers both the best wired sound quality and the convenience of wireless with its Bluetooth 5.1 connectivity. With a particularly small size and a weight of only 26g, the Go Blu will be quickly forgotten, leaving...
With the iDSD Diablo 2, iFi Audio is offering a portable DAC and dual-mono headphone amplifier with an output power of up to 5180mW and which supports signals up to PCM 768kHz, DSD512 and MQA. The latter is equipped with a Qualcomm Bluetooth 5.4 chip supporting the new aptX Lossless codec and has been designed to be compatible with xMEMS driver technology.
With the xDSD Gryphon, iFi Audio unveils an excellent balanced portable DAC and headphone amplifier combo, showing a careful design, capable of incredible sound performance. Its Ultra-Res digital stage includes a Burr-Brown MultiBit DAC and its PureWave analog power section, capable of developing no less than 1000mW!
The Ikko ITM05 is an ultra-portable balanced headphone amplifier and DAC combo, integrating high quality components in an extremely compact and lightweight format. It's the perfect companion for your smartphone to give you the best sound experience wherever you are. Practical, it slips easily into a pocket or bag.
The Ikko Zerda ITM01 is a headphone amplifier and portable DAC combo enjoying a beautiful design and playback quality. It has a 3.5mm jack output and a magnetic Lightning cable. Its conversion stage is based on a high performance ES9298 DAC chip.
The Khadas Tea is an ultra-compact, high-performance portable DAC headphone amplifier. Featuring an ES9281AC Pro DAC chip and a QCC5125 Bluetooth receiver chip, it is capable of supporting high-resolution PCM 32bit 384kHz, DSD256, Apple Lossless (ALAC) and MQA rendering via its USB-C input, as well as...
The Kiwi Ears Allegro Mini portable DAC / headphone amplifier is a small device that can support high-resolution streams up to PCM 32bit 384kHz and DSD128, and is capable of delivering up to 30mW under 32Ω. This means you can enjoy high-resolution files and drive a wide range of headphones and earphones available on the market.
The Kiwi Ears Allegro Pro portable DAC / headphone amplifier is a small device based on the use of two ES9603 headphone amp chips. It supports high-resolution streams up to PCM 32bit 384kHz and DSD128, and is capable of delivering up to 170mW under 32Ω. This means you can enjoy high-resolution files and drive a wide range of headphones and earphones...
An evolution of the famous Dawn Pro, the Moondrop Dawn Pro 2 balanced portable DAC headphone amplifier benefits from numerous improvements. In particular, it features two new CS32198 DAC chips and a HiFi USB interface that supports high-definition sampling rates up to PCM 32Bit 384kHz and DSD256.
With the Dawn Pro, Moondrop unveils a high-performance, affordable portable symmetrical DAC headphone amplifier. Two CS43131 DAC chips enable the Dawn Pro to support high-resolution sampling rates up to PCM 32bit 384kHz and DSD256.
The OEAudio HA2 is a compact, high-performance balanced DAC and headphone amplifier based on two Cirrus Logic CS43131 chips, with a USB-C input and a 2.5mm jack output. Its design allows it to provide a rich sound and a beautiful sound stage.
The Questyle M15C DAC headphone amplifier is a high-end-looking device based on audiophile components. It is based on a CS43198 DAC chip and its proprietary “Current Mode Amplification”.
The Questyle M15i is a DAC headphone amplifier featuring an ES9281AC DAC chip with integrated class G headphone amplifier, enabling it to support sampling rates up to PCM 32bit 768kHz and native DSD up to DSD512. This DAC chip is coupled with two CMA (Current mode amplification) circuits, i.e. transistors that extend frequency response and reduce...
Questyle's M18i is a DAC and headphone amplifier featuring a dual SABRE ES9219Q DAC chip and Current Mode Amplification technology to deliver 28mW of output power at 300Ω and support for signals up to 32bit 384kHz PCM and DSD256. Its CNC aluminium body houses a beautiful OLED display so you can access all the information about your track playback....
Shanling unveils its Onix Alpha XI1, a balanced portable DAC featuring high-quality components. It incorporates 2 CS43198 DAC chips, enabling it to support high-resolution sampling rates up to PCM 32bit 384kHz and native DSD up to DSD256 via its USB input.
Shanling's Mystic XP1 is a state-of-the-art portable amplifier and DAC capable of converting signals up to PCM 32 bit 768kHz and DSD512. It has been designed to follow you everywhere and adapt to every situation, from driving small earphones when you're on the move to more demanding headphones for sedentary use.
With the UA1 Plus USB-C DAC and portable headphone amplifier, Shanling is unveiling an ultra-compact, affordable device that will let you play high-resolution audio files anywhere, without taking up too much space. The successor to the UA1 Pro, the UA1 Plus incorporates two CS43131 DAC chips and a CT7601 USB processor, enabling it to decode up to PCM...
With the UP4 2022, Shanling offers an efficient, compact and modern portable headphone amplifier and DAC combo that will allow you to enjoy your music at home or on the go.
With the UP6, Shanling presents a portable balanced headphone DAC and amplifier based on two ESS ES9069Q chips and two SGM8262 OPAs to offer conversion up to PCM 32bit 768kHz and DSD512 and an output power of 195mW at 32Ω single-ended and 626mW at 32Ω balanced.
The SMSL D10 is a high-performance portable headphone amplifier/DAC. It is based on the use of two Cirrus Logic CS43131 chips, enabling it to support sampling rates up to PCM 32bit 384kHz and DSD256. These chips also provide substantial headphone amplification, with output power up to 500mW @ 32 ohm and a dynamic range of 121dB.
The SMSL DS20 is a portable DAC and headphone amplifier distinguished by its cutting-edge audiophile performance and singular aesthetics. It is based on an advanced architecture incorporating four CS43131 DAC chips and an XMOS XU316 USB interface. This combination enables it to handle high-resolution audio streams up to PCM 32bit 768kHz, DSD256, and MQAx8...
The Tanchjim Stargate 2 is a portable DAC and headphone amplifier with USB-C male and Jack 3.5mm female connectors. It's ideal for enjoying high-quality listening on a smartphone without a 3.5mm headphone output.
Topping presents with the G5 a compact and powerful portable headphone amplifier and DAC. This one integrates a powerful NFCA amplifier stage, a powerful DAC chip ES9068AS and allows a wireless connection via Bluetooth.
Particularly compact to accompany you in all your movements, the xDuoo Link2 BAL also offers very beautiful sound performances, thanks to a carefully balanced architecture and quality components. It will allow you to enjoy a rich and precise sound during your headphone listening.
The new XDUOO XD05 BAL 2 portable DAC headphone amplifier is a device capable of delivering excellent performance for a highly enjoyable listening experience. It relies on no less than two ES9038Q2M DAC chips and an XMOS XU316 interface for its conversion stage, while its preamplification stage features two...
The xDuoo XD05 BAL is an enhanced version of the portable headphone amplifier XD05 PLUS. Its digital/analog conversion stage has been updated, its Bluetooth wireless connectivity is now directly integrated and it now benefits from a balanced output.
xDuoo presents with its XD-05 Basic a small, affordable yet extremely powerful portable headphone and DAC amplifier. Indeed, low price doesn't always rhyme with economy of means and the brand proves it here by offering a complete, robust, versatile device capable of delivering a powerful and rich sound.
With the XD05 Pro, xDuoo unveils a high-performance, robust and versatile portable DAC / headphone amplifier. It features high-quality components such as an ESS ES9039SPRO DAC chip and two dual TI OPA1612A. The XD05 Pro's design allows these components to be replaced to provide a listening experience tailored to your preferences. Thanks to its Class A...
The xDuoo XD05T portable DAC and headphone amplifier is a high-performance device where cutting-edge technology meets vintage. Indeed, it's based on the use of tubes machined in the 60s, coupled with transistors for its amplification circuitry, while the digital-to-analog conversion stage uses two ES9039Q2M DAC chips, an XMOS XU316 USB interface and an FPGA.
The xDuoo XP-2 BAL is a portable amplifier and balanced DAC that is easy to carry and offers great performances with your high definition audio files. It uses an ESS ES9018K2M conversion chip working in a decoding circuit supporting sample rates up to 32bit 384kHz / Native DSD256, Bluetooth 5.0 with aptX-HD & LDAC and works with a USB interface XMOS XU208.
