peter S.
peter S.
peter S.
Customers reviews - There are 19605 reviews.
Guillaume B.
TOPPING DX3 PRO+ DAC ES9038Q2M NFCA Headphone Amplifier Bluetooth 5.0 aptX HD LDAC XMOS XU208 32bit 768kHz DSD512 Silver Topping unveils its DX3Pro+, a direct evolution of the excellent DX3Pro, an excellent compact DAC also offering headphone amplification and preamplification functions. Embarking...
Satisfait de cet achat
Utilisé pour lire la musique de ma tablette, via la sortie USB, sur un casque Meze 99 Classics.
A la hauteur de mes attentes.
Produit compact et de bonne facture.
Guillaume B.
Joli support de casque
Produit parfaitement conforme.
Se marie bien avec un Meze 99 Classics
Benjamin G.
Multi-Strand Litz Wire PU Insulated 90x0.01mm 0,71mm² Litz wire is a conductor whose strands are insulated from each other by a layer of varnish to eliminate the skin effect. This copper conductor also provides excellent electrical...
Attention à la description
Êtes-vous sûr que les brins soient de 0.01mm? JE pense que c'est plutôt 0.1mm
Stefanos S.
NEOTECH NEI-1002 Interconnect Cable UP-OCC Silver Triple Shielding Ø11.5mm The Neotech NEI-1002 is a modulation cable consisting of two single crystal UP-OCC silver conductors. These conductors are maintained at equidistance thanks to the use of PE...
Great cable
Although i am a fun from the copper cables ,i did try the Neotech nei-1002 occ silver.
Absolutely top quality from Neotech, it sounds Crystal clear,with a large soundstage.
Audiophonics fast shipping as usual ,good package .
My only complaint is that Audiophonics sale cables only 1 meter size.
They should begin to sale cable's in 0,50 cm ,it wil be better for the customers and for the business.
 (9)
David S.
Mon premier vrai câble d'enceinte audiophile en remplacement d'un câble Norstone W250.
Suite à une montée en gamme de mon amplificateur (classe D remplacé par un ampli hybride lampes/transistors Lector audio) je songeait à remplacer mes enceintes Davis accoustic Balthus. Et bien non, ce câble furutech a révélé la capacité de tout mon système: le son délivré est précis et clair, des basses puissantes mais équilibrés, tous les instruments sont bien bien présents. Je partage les commentaires sur les aigus, mais impression qui s’estompe complètement si la source de l'enregistrement est propre.
Mécaniquement, je n'ai pas beaucoup d'expérience sur ce type de câble, mais l'isolation est très solide, il est blindé et l'âme en cuivre OFC est de très bonne qualité avec une petite rigidité à considérer pour disposer d'un rayon pour la connexion. (J'ai utilisé les connecteurs banane PANGEA XTREME)
David S.
validées
Débutant en en matière de tubes, je cherchait à remplacer les tubes electro harmonix montés d'origine sur mon pré-ampli phono qui commençaient à ronfler après environ 300h d'utilisation et qui n'étaient pas toujours précis dans les graves et aigus.
Je ne regrette pas le changement: tout est plus précis dès la première minute avec une dynamique améliorée et se bonifie à fur et à mesure du rodage.
Ces psvanes valent largement plus que leur prix.
Moyennement satisfait
Sur mon système, le DAC intégré au lecteur CD Shanling Tempo eC1B me donne plus de satisfaction auditive que ce DAC.
Essayé tous les filtres sans succès.
Cependant l'audition de chacun est différente ainsi que le système hifi.
Il n'y a qu'en comparant que l'on trouve son bonheur.
INCOMPARABLEMENT MIEUX QU'UNE ALIM A DECOUPAGE STANDARD
C'est en essayant cette petite alim dite "faible bruit" qu'on comprend ce qui pèche avec les alimentations à découpage standard fournies avec beaucoup d'appareils audio (DAC, amplis numériques, lecteurs...). J'étais frustré par mon DAC qui pourtant embarque une puce de compétition Asahi Kasei 4493: manque de transparence, timbres entachés d'un caractère électronique... Toutes ces réserves se sont évanouies avec l'I Power mk2. C'est comme si un voile s'était retiré. La transparence est désormais excellente et les timbres d'un réalisme constant, la dynamique à l'avenant! Un essai avec une alimentation linéaire régulée a, de façon peu équivoque, donné l'avantage à l'I Power. Le produit n'est certes pas donné, mais ses résultats en matière d'audio sont des plus intéressants. Un produit étonnant!
Thierry S.
Tout simplement le meilleur rapport qualité-prix que je connaisse.
Le rendu à un petit quelque chose d'analogique...
Thierry S.
JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 0.68µF Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system to reproduce every nuance, every...
Thierry S.
Elisee B.
Parfait pour une installation haute-fidélité !
Utilisé en USB sur une installation haute-fidélité, ce simplissime DAC est parfait; neutre, dynamique, il est meilleur que son petit frère le Topping E30 qui ne suffira pas dans ce contexte.
Si vous n'avez pas besoin d'option supplémentaire, telle qu'une connexion bluetooth par exemple, cet appareil est celui qu'il vous faut.
Elisee B.
Ne convient pas pour un système haute-fidélité
Si vous recherchez un DAC simplissime pour une utilisation haute-fidélité, celui-ci ne conviendra pas; préférez le Topping E50.
Elisee B.
Ne conviendra pas pour un système haute-fidélité
Si vous recherchez un DAC simplissime pour une utilisation haute-fidélité, cet FX-AUDIO FX01 ne conviendra pas.
Préférez-lui à minima un Topping E50, plus cher, mais incontestablement meilleur.
Thierry C.
Je confirme les avis élogieux généraux : Petit Dac AKM 4493 donnant une grande qualité d'écoute ...de l’ampleur , excellente séparation des instruments , son détaillé , Basses amples ...une grosse différence avec le Dac intégré à mon Denon AVR -1603 et un net mieux qu'un petit Dac Ess9018 usb (Hifime) pourtant assez excellent .
Pour ce prix en plus , oui je recommande !
Thierry C.
OK
A priori cables de qualité et assez souples
Bon Ampli de puissance
Premières écoutes...
Cet ampli est excellent si on prend le soin de le configurer avec des éléments de qualité en amont et en enceintes.
Très satisfait sur des enceintes Kef Référence 205 qui ont un rendement de 90Db.
Pas totalement satisfait sur des enceintes au rendement de 85Db.
Enfin au vu du prix, il est réellement bon.
Jerome t.
Hexagon Socket Cylindrical Head Wood Screw M4x16mm 8.8 Steel Black (x10) These hexagon socket cylindrical head screws are in M4x16mm format. Made of 8.8 steel, they guarantee a high durability.
Vis m4
Bon produit. J ai eu une vis dans le paquet avec un rare défaut. Audiophonics m a tout de suite renvoyé une autre. Je les remercie pour leur professionnalisme.
Fabien M.
A ce prix Y a pas de mot Ecoutez
Le 1er acheté en 2017 fonctionne a merveille et pour avoir une sortie de qualité sur mon pc j'en ai acheté un 2nd en 01/2022.
Je n'avais jamais utilisé la sortie casque - ici avec un Focal Esprit - à 48€ je n'ai rien entendu qui reproduisait la musique avec autant de naturel.
Je l'utilise sur un systeme Linux-Debian 11 et audacious avec le fichier config comme suit (NB hw:2,0 c'est là que se trouve ma sortie usb donc cela peut varié chez vous NB2 pour une qualité sonore plus précise j'écoute via le terminal avec la commande " audacious -Hp "):
[alsa]
mixer=
mixer-element=
pcm=hw:2,0
[audacious]
always_resume_paused=FALSE
clear_playlist=FALSE
enable_clipping_prevention=FALSE
enable_replay_gain=FALSE
leading_zero=FALSE
metadata_fallbacks=FALSE
net_buffer_kb=1024
output_bit_depth=24
output_buffer_size=610
record=FALSE
record_stream=0
resume_playback_on_startup=FALSE
show_filepopup_for_tuple=FALSE
step_size=3
James G.
HIFIBERRY DIGI2 PRO Digital Interface SPDIF for Raspberry Pi 24bit 192kHz The HiFiBerry Digi2 Pro is a stereo SPDIF interface module designed to work with a Raspberry Pi. The assembly is very simple. In addition, the Digi2 Pro offers very good...
Non compatible avec Raspberry 4 + Picoreplayer
N'est pas reconnu par Picoreplayer avec un Raspberry Pi 4. Est par contre reconnu si on remplace le Raspberry Pi 4 par un Raspberry 3b ou 3b+.
Voir le fil de discussion: https://forums.slimdevices.com/showthread.php?115381-HifiBerry-Digi2-Pro
Nicolas D.
parfait !
J'écoutais mes jmr Bliss avec un nad 326bee, c'était pas mal ... je suis passé à un smsl a18... et bien le nad je l'ai donné à une amie.... Sur mes jmr evolution 3 dans le salon j'ai collé un FX-AUDIO D2160 ... pour moi c'est fini la prise de tête des association amplis enceintes.les FDA ça marche, ça amplifie, c'est droit, ça tient le grave c'est tout ce que je demande.
Sylvain P.
Courant de commutation trop faible
L'appareil est donné pour 8A ce qui est un peu léger pour connecter plusieurs amplificateurs plus une série d'appareils hifi.
Dommage car c'est rare sur le marché. Un modèle 16A serait plus adapté.
Excellent pour le prix
Apporte une amélioration sur le plan de la netteté et des détails sans agressivité . Pour le prix c'est une aubaine comparé à des systèmes beaucoup plus onéreux et pas forcément meilleur .
jean-marie b.
Merci Audiophonics d'avoir réalisé cette alim. J'ai le modèle 12V et 13A et à priori, y en a pas des masses. J'ai également changé les fusibles et le gap est encore énorme. Livraison en temps et en heure, parfait ! On dirait qu'on a à faire à des pros ;-)
Yasin C.
Don't use larger than 2.5mm2 cable your vintage equipments
@Christophe C.
its very usual.. cos Vintage equipments dont like large gauge cables.. cos they did tuning with maximum 1,5mm2 cables while producing.. It's normal to dislike relatively thicker cables.
Max A.
Un super petit appareil. Très simple d'utilisation, l'écran Oled montre la piste jouée, le codec utilisé ainsi que le débit de lecture. Branché sur mon ampli kenwood ka 7002 de 1971, reconnu et appairés immédiatement à mon téléphone huawei p30, la connexion est très stable, aucune latence et le son est juste excellent en LDAC.
Le package aurait pu être un poil plus fourni avec au moins un câble rca et un bloc d'alim. Seul un câble usb-c est fourni.
Très satisfait de mon achat.
Marc C.
Une pure merveille !
D'un naturel toujours méfiant en regard des critiques dithyrambiques notamment basées sur la technique que l'on peut trouver ici ou là, je me suis quand même laissé tenter par cet ampli casque il y a maintenant plus d'un an pour driver un Sony MDR Z1R et un Sennheiser HD600S et bien m'en a fait ! C'est le moins que l'on puisse dire !
Je m'attendais à un ampli symétrique très analytique à la limite du froid et du chirurgical... Et bien tout faux. Cet ampli est tout bonnement très musical au contraire, jamais épuisant même si je l'utilise des heures durant mon télétravail et ce malgré des écoutes de musiques assez électroniques.
La partie préampli n'est pas en reste non plus et ferait rougir certaines boites plus grosses et impressionnantes.
Bref que du bon et du meilleur encore !
Chapeau topping car depuis j'ai acquis le DAC D90SE, le meilleur DAC que j'ai eu en ma possession pour le moment.
Pourquoi donc je me ruinerais à aller voir ailleurs ?
Marc C.
Réellement bluffant !
Tout d'abord un grand merci à Audiophonics avec qui cela se passe toujours bien et pour importer du matériel hélas peu courant dans nos contrées.
Pour ce qui est de ce topping D90SE et bien que dire de plus que ce que l'on peut lire sur le net ?
D'accord il est petit et peut paraitre fragile, ce n'est pas un très beau châssis monobloc en alu anodisé à protection galvanique avec un bel écran Oled couleur. Et alors ?
Vous regardez souvent votre matériel lorsque vous écoutez de la musique ?
Car il s'agit bien là du point majeur de cette petite boite : Il transcende la musique dans le meilleur sens qui soit à savoir, dynamisme, clarté des timbres, très méticuleux dans le respect de la répartition spatiale des instruments et des voix.
J'ai eu de (très voire trop, bien trop) chers DAC qui ne faisaient pas le même boulot ... Regarder vers une certaine marque canadienne par exemple... dont le lecteur réseau / DAC / preamp dépasse les 7 000 € !
Alors oui il faut lui adjoindre un très bon lecteur réseau pour profiter de cette petite bombe... Moi c'est un SOtM ultra avec son alim dédiée et c'est un pur régal.
Cette petite boite n'a pas à rougir vraiment !!!! A ce prix c'est à peine croyable... Félicitations
M A.
nice built power supply and precise
nicely built power supply and exactly what I needed for my philips nos dac, namely a positive and negative voltage.
exact voltage can also be set nicely via the trimpods.
jean-françois v.
Excellent produit !!
Excellente station d’accueil pour qui veut isoler galvaniquement son Raspberry de son Dac ou Recloker. En ce qui me concerne j’ai fait aussi l’acquisition du Recloker de la même marque et cette station d’accueil m’a été fort utile. Le produit comme tous les produits de la marque sont de très bonne facture, cela respire la qualité malgré un prix un peu élevé.
jean-françois v.
AOP de rêve - Le Nirvana existe !!
Excellent AOP que ce ss2590, tout simplement bluffant !! Pour info, J'ai des enceintes haut rendement DIY à base de Altec 414 et de Moteur TAD - TD 2001+ pavillon DIY rendement 100 db. Pour la source, j'ai un boitier DIY avec Raspberry PI 4 + Alimentation Ian Canda et Rockloker de la même marque + filtre actif Najda le tout relié exclusivement en I2S. Après avoir testé le SS3602 (voir avis sur le sujet), j'ai décidé de faire l'acquisition de 2 AOP SS2590 en espérant obtenir un petit gap au niveau des résultats. Bien que certains disent qu’il y a un petit gain entre ces deux AOP je ne suis pas du tout d’accord. Pour moi, bien que le SS 3602 soit excellent ici on atteint le Nirvana !!! Parlons changements, dès le début il y a un grave comme je n’ai jamais entendu (mes Altec 414 sont devenu des 416), l’impression d’avoir des 38 cm au lieu des 30 cm, est plus que sympathique. Pour faire simple cet AOP à la même signature sonore que le SS 3602 mais avec un niveau de fous normal il fonctionne toujours en pur Class A !! Les transitoires sont là avec un niveau de fous et les silences se font silence comme jamais. Toute la bande sonore est très naturelle, dynamique, sans artefacts, colorations ou agressivité dans les aigus. Cela amène mon préampli +filtre numérique à un niveau de fous !! je n’ose même pas imaginer quel serait le prix dans le commerce de mon préampli surement entre 6 et 10 000€. Vive le DIY et un grand merci à Audiophonics pour leurs conseils et leur disponibilité.
Jean-François.
Vincent F.
Cable très bien finie et de qualité mais à ma grande surprise au déballage, le rouge et le noir ne sont pas de même section ? question est posée au Sav Audiophonics....
Vincent F.
VIABLUE Heat-shrink tubing for speaker Bi-wiring (Set x4) These heat-shrinkable sleeves are ideal to finish speaker cables cleanly. They also have markings to indicate the cables.
Conforme
Bien mais attention à la section de vos cables HP et de vos fiches bananes, presque trop juste par ex pour des fiches Pangea tellurium...
D'autre part je ne voie pas trop l'intérêt de mettre un + Low et un - Low ?? porte à confusion, pour moi le rouge est tjrs positif
jean-françois v.
Excellent AOP - Attention au rodage important !!!
Excellent AOP que ce ss36602 bien que j'ai sauté le pas vers le modèle au-dessus !!! Pour info, J'ai des enceintes haut rendement DIY à base de Altec 414 et de Moteur TAD - TD 2001+ pavillon DIY rendement mesuré + de 100 db. Pour la source, j'ai un boitier DIY avec Raspberry PI 4 + Alimentation Ian Canda et Rockloker de la même marque + filtre actif Najda le tout relié exclusivement en I2S. j'ai fait l'acquisition de 2 de ces AOp pour les sorties de mon filtre actif Najda et là quel changement dès le début il y a plus de présence un grave bien tendu des voix plus charnel et une spatialisation de la scène sonore. Attention, il faut bien 2 ou 3 jours pour que cet AOP révèle toute sa splendeur. En effet, au début je suis resté un peu sur ma faim concernant le haut médium aigu qui était bien en retrait mais après rodage tout est rentré dans l'ordre. A acheter les yeux fermés cela vaut le coup et puis si vous en avez les moyens allez sur le modèle au -dessus c'est bluffant !!!
Jean-François
Vincent F.
Comme déja dit, remplace avantageusement une embase IEC, pour ma part j'utilise des Wago ensuite et le tour est joué !
jean-françois v.
Excellent AOP - Attention au rodage !!!
Vincent F.
Fabrication top
bon produit avec matériaux de qualité mais à assembler soi même, il faut compter environ 4h de boulot pour concevoir ce boitier avec embases et cablages, Une * de moins juste pour ce côté à faire soi même (monter et visser la boite
Vincent F.
Une embase Schuko simple avec accès direct aux serrages lorsque monté à la différence des Furutech....à utiliser en attente ou pour des prises secondaires sur sa barette
Bernard c.
Terrible
Ce DAC est incroyable. Transparence, dynamique, scène profonde et large, une avalanche de détails sans être froid ou trop analytique. Les timbres sont exceptionnel, y compris sur les basses (une première sur mon système).
Pour moi c'est le le régulateur directement intégré dans la nouvelle puce ES9068AS qui fait la différence, avec un pour chaque canal, le résultat est bluffant.
Seul défaut, Gustard a volontairement rendu l'écran illisible (son et canal minuscule) pour ne pas déposition le X18 et en théorie vendre le X16 en combo casque avec le H16.
Sur un ampli de puissance il est meilleur seul qu'avec le préampli H16 malgré le contrôle de volume analogique sur ce dernier.
Sous -30db il est peu moins bon il perd un peu de rapport signal bruit du fait du volume digital (non destructeur sur les ESS 32 bits). J'ai acheté un atténuateur pour être le plus proche de la dynamique maximale à mon volume d'écoute.
Benoit s.
KLEI ABSOLUTE HARMONY Pure Silver RCA Connectors KL Formula Ø9.5mm (Set x4) KLEI Absolute Harmony RCA connectors are designed with nothing left to chance to provide maximum conductivity. To do this, the brand uses pure silver contacts with KL Formula...
une amélioration étonnante
j'ai placé ces fiches sur un câble duelund en remplacement de fiche RCA duelund gold qui sont déja de très bonne qualité et je suis assez impressionné par le gain obtenu. Meme si le prix peut parait assez élevé, il est totalement justifié
David S.
je rejoins les avis ci dessus, (je suis novice en système audiophile, mais dispose d'une certaine expérience en matière de "contact" électrique.)
Cette fiche dispose d'une excellente qualité de construction.
Le serrage sur le fil du câble est vraiment top et la fiche s'insère parfaitement dans les connecteurs coté ampli et enceintes sans forcer, tout en assurant en contact vraiment ferme.
Tweeter spécial
Ce tweeter a une sonorité chaleureuse, organique et dynamique ... et il offre l'avantage assez unique à ce prix de pouvoir être opéré en dipole.
Anne b.
olflex cable secteur 2.5
cable rigide haute qualité pour cordon secteur platine CD le grave sonne beaucoup mieux c est un cordon équilibré a chaque étage
Anne b.
fil de cablage cuivre argent
fil de cablage de tres bonne qualité pour refaire cablage sur platine vinyle ITT avec montage RCA vraiment bien pour ce cable cuivre argent je le conseille
Andoni G.
LINDY Ethernet RJ45 Cable Cat 8.1 S/FTP LSZH Gold Plated 1m The RJ45 Ethernet cable takes advantage of the latest Cat 8.1 standard to support bandwidth up to 2000MHz. The cable has an S/FTP structure, where the twisted pairs are shielded...
Good and afordable
Just a normal Ethernet wide cable with good enough connectors
I have some cables from this brand and all works perfect under a small price, great quality
Romulus H.
Very good for heavy cables. Audio quality signal is preserved
This bananas are amazing. And I am not talking about the sound quality that is preserved unaltered. It's very good made, thick and very resistant gold plating.
One of the best thing is the angle of the cable connection. Due to this angle, a heavy cable will not put pressure on binding post or on bananas.
Do I need to mention that the screw-in clamping mechanism is very strong and efficient?
There is nothing minuses to mention about those bananas.
Andoni G.
Ethernet to Optical Fiber Converter (Pair) Jack DC Power Supply These devices are delivered in pairs and convert a 10/100/1000Base-T Ethernet signal to 1000Base-SX/LX optical fiber. This allows the signal to be isolated from the rest of the...
Work perfect
It comes with Asian power suply no need to buy another just adapter
Ir works perfect
Trevor J.
KHADAS TONE BOARD VIM EDITION ES9038Q2M DAC Module USB XMOS U208 SPDIF 32bit 768kHz DSD256 Khadas' Tone Board uses an ES9038Q2M decoding chip. This is not only the flagship ESS product, but also one of the best current hardware solutions for high-fidelity audio...
Good for something but not music
Strong clear bass and treble but the sound stage and image are non existing. The sound is just on the speakers.
Vic T.
Does The Job
Has a nice finish, similar to other silver stereo components I own so fits in well. The footprint is larger than I would like, given that all the box is meant to do is select between 4 different inputs and nothing more -- no other electronics on board. But it does serve a purpose, acting as a counterweight to 5 pairs of cable tugging at its back, allowing it to stay in place. Personally, I would have preferred something smaller but with the same weight. The walls and faceplate are already fairly thick (5 mm), so additional weight might be achieved by adding a thicker bottom. The selector switch itself is nice looking, but I would have liked more distinct increments; the switch has rather soft settings instead of stiffer click-stops. Having said all that, I don't regret purchasing this item. It's doing what it's supposed to. My streamer/amp only has one RCA input and I have several components that need to share that input. The selector looks good with the rest of the equipment, is holding its own against all of the cables that are being routed through it, and I've grown accustomed to the soft switching.
Fantastique
Fantastique, exceptionnel pour son prix.
J'espère que dans le temps il va perdurer.
Merci à Audiophonics pour leur conseil et pour leur envoi en temps et impeccable.
