Pierre H.
Condo Mundorf 22000µF/63V
Pierre H.
Référence : 11175
Pierre H.
Référence : 11175
Bouton parfait, et bien fini.
Customers reviews - There are 19164 reviews.
Gilbert H.
Expédition rapide. Second achat de ces fiches, toujours excellente qualité.
Dirk V.
Round Vumeter Yellow Backlight dB Ø45mm (Pair) This round vumeter has a beautiful yellow backlight, ideal for use with an amplifier from 3W to 50W. A controller is already present at the rear, allowing simple wiring.
Nice meters but ...
Nice meters but sadly the background colors of the pair I received are quite different. One is more yellow , the other is rather orange. Next to each other it is a weird sight.
Christian E.
TINYSINE BT-TX Bluetooth Plug & Play Transmitter A2DP This BT-TX from TinySiny will allow you to transform your Bluetooth-free music source into a transmitter. This eliminates the need for cables to send music from your source to...
appairage
très déçu par le produit : impossible de l'appairer avec mon casque JBL et votre service technique n'a pas la solution
Si le module s'appaire normalement avec d'autres produits ce n'est pas lui le problème.
Le protocole est le même quel que soit la marque ou le constructeur.
Jose A.
Really good speaker cable
This is a really well made speaker cable. Very pliable and easy to handle and to install. I upgraded from an already pretty good Mission cable.
Jose A.
Not worth the price
Not worth the price: there are properly made Wíma, Panasonic, Kemet or Cornell Dubilier capacitors with the same size and less expensive
Jose A.
A DAC star
This DAC is really good: the sound is transparent, with well-defined highs, superb human voices and mids; the bass is deep and puts the amplifier's capacity to the test. I have this DAC connected to the USB 3.0 port of a fanless i86 SBC computer (runing the Daphile music server & player) and they both consume a total of 6W.
Jose A.
Aluminium Foot 20x10mm Black (Unit) This black Aluminium stand for HiFi devices will allow you to bring stability and shock absorption to your system, which is equipped with a rubber washer.
Small and stable feet
Aluminum feet well made and well finished, with a rubber washer underneath. They are very easy to install. I ordered 4 feet but only 2 of them came with fixing screws, I had to purchase 4 screws locally.
Gilbert G.
Excellent AOP
Un des meilleurs, si ce n'est le meilleur AOP à ce jour. Chaud mas pas dark, très chirurgical dans les détails représentés, d'une incroyable musicalité. La scène présentée est holographique. Un pur plaisir dont on ne se lasse pas.
Jose A.
Good price/quality ratio speaker terminals
Terminals well built in non-magnetic material.
They accept spade and banana terminals, and have an internal washer that also allows to tighten well bare cable.
MICHEL B.
Excellent appareil indispensable
Appareil très pratique à utiliser, réglage de la température rapide et précise. Cet appareil est parfaitement adapté pour fabriquer d’excellents câbles audiophiles avec des connecteurs soudés à la soudure argent à 10 %.
Indispensable pour les audiophiles passionnés et bricoleurs.
Gilbert M.
Un câble ethernet qui permet une amélioration visible de l'image sur mon téléviseur OLED et du rendu sonore de mon ampli casque. Indispensable pour ceux qui veulent optimiser les performances de leur appareil tant sur le plan sonore que vidéo. La différence perceptible est d'autant plus grande que les appareils connectés sont performants. Le rapport qualité prix est excellent.
Gilbert M.
Power Adapter IEC C14 3 Pole to IEC C7 2 Pole Flat Angled This AC adapter consists of a 3-pin IEC C14 (male) connector and a 2-pin IEC C7 (female) connector. It will therefore allow you to connect an IEC C13 (female) cable to devices...
utile
Cet adaptateur permet de brancher des câbles secteur de meilleure qualité et de grosse section sur une prise 2 pôles IEC 7.
Sur ma barre de son BW l'amélioration du son est sensible.
Igors K.
case for Khadas
quality product highly recommended seller very fast delivery
Tomas Z.
Tomas
For mini DSP DDRC-22D perfect, better dynamics, space
Gérard B.
Qualité de fabrication PITOYABLE
1) Des reprises "filaires" sur des pistes sous la face composants
2) Des selfs de filtrage qui bougent "au vent mauvais" (pas stables du tout) qui peuvent se toucher (par inadvertance ou non) ... je ne sais pas si le fil de cuivre est isolé par un vernis, mais ça peut faire "peur", et en tout cas n'est pas un gage de qualité de fabrication" !
3) des connecteurs face arrière positionnés n'importe comment ; le connecteur d'alimentation au ras de la carte ... les connecteurs RCA dépassant d'au moins 1cm à 1,5 cm !! Où est la cohérence de fabrication ??
NB : 1 point positif (à mon avis), des dissipateurs pour les circuits d'amplification classe D.(TPA3116, à priori). Toutefois, pour ma part, j'ai préféré vérifier et rajouter de la pate thermique.
Je ne parle ici, que de la qualité de fabrication, pas de la qualité de restitution, qui à priori ne peut être que moyenne (voire passable au vu des composants utilisés).
Je vais l'essayer sur des enceintes de 8 Ohm ... on verra bien
A suivre ...
Gérard B.
tout est dans le titre ..!
Pas encore utilisé pour d'éventuelles réserves à l'utilisation
Gérard B.
Produit conforme
Rien de particulier à dire ... sijnon que ça remplit bien le rôle annoncé ... !
Cela empêche vraisemblablement la poussière de rentrer à l'intérieur du boitier s'ils sont en position.
Ils tiennent bien sur les connecteurs RCA !
Gérard B.
Thermal silicone glue ST922 for radiator 5g The thermal glue type ST922 offers real efficiency for power transistors or dedicated audio controllers. Offering a thermal conduction of 0.671 W/m-k, it will find its place in...
Produit conforme, c'est bien une colle
Par contre, elle sèche très vite dans le tube ... même bien rebouché !
Il faut à chaque usage différent déboucher le tube pour enlever la partie durcie de la colle qui en empêche l'utilisation normale !
francois R.
le meilleur des Canare coax spdif
au dessus des canare coax. Pas de brillance. Il est la reference en asie dans le milieu high end. Je confirme apres test que ce soit en sortie d'interface XMOS208, Amanero ou CM6631A, toutes isolées galvaniquement en sortie sur le coax par transfo Pulse (important pour ne pas fausser le test)
francois R.
tres bien pour tout cable DC
un incontournable pour la realisation des cables DC d'alim à base de fils AWG16 cu/ag plated + PTFE.
francois R.
Hexagon Socket Round Head Screw M3x6mm 10.9 Steel Black (x10) These hexagon socket round head screws are in M3x6mm format. Made of 10.9 steel, they guarantee a high durability.
couleur bronze et pas noire
Décu car la couleur n'est pas du tout noire comme indiqué. Il s'agit d'une couleur bronze, donc inutilisable pour mes faces avant. Il manque au catalaogue Audiophonics de vraies vis CHB 3x8-3x10mm inox noire de qualité
Olivier M.
presque parfait
les +
petit ampli efficace pour alimenter des JBL control one, il s'en sort parfaitement.
design sobre et efficace.
nombreuses connectiques pour le prix au vue de la concurrence.
les -
le volume se fait par pallier, c'est dommage.
Et on finit par le moins bien, il n'y a pas de vrai bouton on/off, bref on ne coupe jamais le courant de cette ampli qui reste en veille et chauffe tout le temps. Voilà clairement un problème de conception qui aurait pu être évité.
tres bon produit !
bonne prise de trés bonne qualité! le corp est trés rigide , ce qui facilite le maintient de cables de gros diamètre (yarbo 8000 ! )
couleur élégante et plutot discrete !
Bon RQP !
utilisées sur rallonge sur barrette , platine vinyle , boitier d'alim séparé, dac oppo ! excellent avec le yarbo !
de la BOMBE !!!
je l'ai acheté pour mettre sur mon pré -ampli pier audio à tubes , couplé à deux Viborg VE et VF 512 R (excellentes elles aussi !) en remplacement d'un wireworld electra 7 ; l'effet à été quasi immédiat plus transparent ,plus de matière plus de profondeur ,la durée et l'extinction des notes également améliorées de pas mal !!!
Après une dizaine de jours ,je viens de le passer sur mon lecteur cd pier audio 800 se qui est un monstre de détails , d'impacts de transparence etc et sur lequel j'avais mis le très très bon Yarbo 8000 armé de furutech FI E 11 (lequel avait déjà remplacé avantageusement un autre électra 7 ! ) ! Alors là , encore un cap de franchi , c'est énorme ; le rendement du cd est encore meilleur notamment les timbres et les extinctions et les durées ,de notes ,la fluidité est encore meilleure ainsi que la scène avec une certaine douceur en plus quand c 'est nécessaire (le rhodium des Viborg sans doute !) !
Bref il y aurait encore bcp à dire sur la qualité de ce câble !
je ne regrette pas du tout mon investissement ; au passage merci Elecaudio pour la petite rallonge , 10 cms à ce prix c'est vraiment un geste appréciable et vue la rigidité c'est une bonne chose ( un mètre aurait été surement trop délicat à courber entre la barrette et le lecteur ! )
le son est vraiment énorme ! L'apport est tout bonnement incroyable !
A conseiller sans modération sur les sources ; je vais surement en commander un autre morceau pour mon pré ampli du coup !
Xavier G.
ALLO Aluminium Case for Allo Boss DAC + Raspberry Pi 3 B/B+ Black To protect and enhance its Boss DAC coupled with a Raspberry Pi 3 B/B+, Allo offers a superb 100% Aluminium and CNC machined case. Already drilled, it will allow you to dispose...
Très bien !
Beau boiter bien usiné et facile à assembler, même sans instructions jointes. Petit bémol : l'obligation de fixer les pieds avec du silicone au dessus des vis de serrage pour qu'ils tiennent. Je trouve que ça tient quand même un peu du bricolage... Ceci dit, une fois le boîtier fermé, il ne devrait pas être nécessaire de l'ouvrir souvent puisque même la carte micro SD est accessible (fût-ce avec une pince à épiler...).
beau produit ,trés belle qualité !!
comme dit dans le titre , c'est vraiment de la qualité ! c 'est costaud , et très beau également ! plutôt agréable à monter ,le serrage des bagues alu est sur et facile ! couplé avec un câble furutech nano se c'est vraiment plus qu'excellent !!
A recommander sans hésitation (sur ce câble notamment !)
très très bon rqp ! le rhodium semble apporter un
sur-crois d'amplitude de profondeur de matière ; mais difficile de faire la part des choses avec l'apport du câble ; mais les deux se complètent parfaitement en tous cas !!!
même constat pour l'iec VF 512 R naturellement !
nb : encore une fois très bonne qualité du service , merci encore !
Romain M.
expédition super rapide, et l'emballage est sur secur. Continuer comme ça !
Ronan b.
très bon resultat
Petits hp large bande fonctionnant très bien sur petite enceinte bluetooth avec juste un petit filtre RC série
Furkan G.
Not Silver Plated
it isn't silver-plated OFC cable. Just copper
Hi,
Yes unfortunatly, despite his name this product is not silver plated
joachim v.
Topping D90
Received the Topping D90 and hooked it up to my Auralic Streamer and ran Tidal MQA, through my 2A3 SET monoblocks. Fantastic!
I am very pleased!
Denis L.
Super rapport qualité prix
Je confirme la qualité du son, mon meilleur dac dans cette gamme de prix. Son en 3 D analogique precis et reposant. Mon streamer bluesoundnode 2 I fait un pas de géant. Class A oblige !
Je redecouvre mes cd Cet appareil mérite un câble coaxial haut de gamme. Déçu par le canare bnc je suis parti avec un audioquest pour pas le nommer. La position nos est top.
J'enlève une étoile car prise coaxial et bnc sont sur une entrée commune.
Penser à éteindre l'appareil qui n'est pas en service !
Indiquer sur la façade la source par un chiffre bof
Mais audio-gd est pardonné quand je me régale avec la musique.
Christopher S.
Great Op-Amp, disappointing packaging
Awesome Op-Amp tested with Aune X8 DAC, Fiio AM3E Amp and Drop x Hifiman HE4xx and
compared to NE5532:
Sounds more neutral, extended highs without any sibilance (noteworthy as HE4xx tends to be sibilant).
Significantly louder (more gain), more punch, increased timbre.
Now the disappointment:
The device came in bubble wrap inside a bubble wrapped envelope. That’s it..no case include to really offer any protection against pressure. That is why the pins of this new product where bent On arrival.
For more than 80€ incl delivery I would expect a simple hard case to protect the product.
dominique d.
câbles pour cellule
câbles ZAVFINO de bonnes qualités , satisfait de mon achat .
Daniel M.
Alimentation lecteur réseau D-STRAM
Nette amélioration du son.
Meilleur spatialisation et plus de dynamique.
Yann L.
Pointes à l'efficacité redoutable
Pointes Soundcare à l'efficacité redoutable, mises sous des enceintes LINN Espek à la place de celles d'origine, ainsi que sous un Subwoofer Mosquito . Sons plus précis notamment au niveau des basses plus fermes , différentes fréquences médium , aigues, mieux étagées , et place à la musique . Service qualité d' Audiophnoics ainsi que la communication exceptionnel, un grand merci à toute l'équipe ! Hautement recommandable *****
gael s.
Amplifier Module TPA3116D2 with Tone Control 2x25W 8 Ohm This small complete amplifier module is based on a TPA3116D2 amplifier chip. This allows it to deliver a power of 2x25W under 8Ω. In addition, the architecture of this chip...
Bon rapports qualité prix
cet ampli fait bien le job les corrections graves aigus sont efficaces, il chauffe pas trop.
On peut même brancher un seul hp sur le + d'un côté et le - de l'autre et on a une diffusion en mono avec les 2 canaux melangé ( la masse doit être commune) mais pas de fonction bridgé.
Un petit "ploc" se fait entendre à l'allumage et l'extinction de l'ampli.
Une led rouge s'allume lors de la mise sous tension.
Baudouin V.
Baudouin Vanderhaeghe
I bought PROJECT S2 DAC (€350) a couple of years ago. Connected on my WIN7 PC with USB was a huge step forward in sound quality. Now bought the ALLO USBRIDGE SIGNATURE + ALLO SHANTI combo, instead of the PROJECT STREAM BOX S2 ULTRA. (€700). Same Huge step forward, the reviews of Hans Beeckhuyzen and John Darko are not exaggerated. Very satisfied!!
Gilles H.
Musical, simplement musical !!! Bravo.
Bon, comme d'habitude pas de mauvaise surprise !!!!
C'est très aérée et dynamique. respectez bien la phase (sens de la prise). et alors c'est un régal...
Rapport qualité prix imbattable, en plus c'est tout mimi.
Bravo l'équipe.
A+ Gilles
Pascal T.
Un beau rendu
Installées sur des QEDs Révélation signature ,
Très bel effet et résistance au poids des câbles pour le remplacement des fiches QEDs signature spiral déjà déformées.
Merci à AUDIOPHONICS pour la qualité de leurs produits .
Pascal T.
Très belle prise
Dixième prises que je me procure chez audiophonics jamais rencontré de problèmes
Pascal T.
Très belle prise
Onzième prise que je me procure en dix ans chez audiophonics aucun problème de vis ou autres ,
Je suis très très satisfait.
Pascal T.
Barrette BADA porte avions
Très belle barrette, pour info les côtes gauche Et droite sont en tôle finition aluminium, le voltmètre et bien en couleur bleu et non pas rouge En indiquant 243/248 Volts ( merci EDF
Jean Noel B.
excellent à ce prix
Très bon rapport qualité prix , aucun souci de fonctionnement avec PC sous win 10, pas de problème avec télécommande , parfaitement satisfait.
Gestion de la commande et envoi très rapide, bravo a votre équipe.
benoit D.
Erreur de livraison
Le modèle reçu ne correspond pas aux photos
Celui reçu correspond en tout point à votre référence 7020
Pouvez vous procéder à l'échange svp
Je peux vous faire suivre une photo si besoin
cordialement
dirk V.
Klipschorns & Purifi
Klipschorns are very difficult Loudspeakers because they have an impedence curve from 1-30 (!!) Ohm and are at the same time very sensitive with 104dB/W. I have tried a lot of different amps: class A, 300B tube SET amp, AB, JFET Mosfet etcetc. Finaly with the Purifi amps everything is knitted together and the KHorns really sing. They need timealignment and Dirac but these amps make all the difference. Really happy!
Audiophonics input board make it possible to bypass the opamps. Can't hear much difference though so that's also testament for a fine configuration. It is also dead silent.
BTW it is fascinating how many countries worked together to get this done. Start counting.
jean christophe r.
reçu rapidement , produit top , tuner marantz superbement bleuté
Alexandre P.
Je n'ai pas d'élément de comparaison car je l'ai acheté avec le petit dac usb audiophonics Usabre et la cart Elfidelity interne filtre usb.
très bonne qualité, très satisfait.
Merci à vous de nous proposer des produits au rapport qualité prix lmbattable.
Alexandre P.
Simple, efficace et pas cher
Il a toutes les qualités!
Je suis passé du chipset intégré à mon htpc à ce petit dac alimenté par la carte Elfidility AXF-100 PRO III Filtre Alimentation USB, et gros changement! Spatilalisation très nettement améliorée, qualité sonore au rendez vous.
Super. Y'a plus qu'à attendre le même en 24bits/192kHz.
Merci Audiophonics pour ce petit boitier qui permet d'avoir un très bon son sans se ruiner.
Alexandre P.
5 étoiles
Par rapport au prix c'est un très bon achat. Avant j'utilisais le chipset de l'ordi. J'ai acheté cette carte pour alimenter le petit dac audiophonics U-sabre LTE usb, et le résultat est là.
Alexandre P.
Très bon rapport Q/P
