Dominique R.
Hautement recommandé
Dominique R.
Marc J.
Customers reviews - There are 20173 reviews.
Alexandre G.
Matériel de qualité, solide et insataltion "facile", MAIS...
Livré dans une boite alu cylindrique. Matériel, facile à monté, bien que mon câble de diamètre proche du max admis m'a donné beaucoup de difficulté à l'installation. Visserie de qualité, matériel globalement robuste. Cependant, il est clairement indiqué sur l'embout de le prise, qu'il s'agit ici d'un 10A sous 250V et non 16A comme précisé sur le site. Quant à la qualité et la plus value à l'oreille … Je n'ai pas l'info, car j'ai modifié l'intégralité des éléments d'alimentations.
Il s'agit ici des limites de la certification CE.
La donnée constructeur est bien de 16A / 250V :
http://www.oyaide.com/ENGLISH/AUDIO/products_category/power_plugs_iec_connectors/pg472.html
P v.
Amazing price / performance
After being impressed by the performance of its bigger brother, the AMADEUS 5, which I use for power and speaker cable, I bought this cable to make a XLR cable. I used 1 strand per phase, so 1 m of this cable and 2 pairs of Neutrik gold plated XLR plugs was all I needed. A total of around Eu 65.
The sound is very similar to the AMADEUS 5. It creates a very nice 3D space with a very natural rendering of instruments and voices and nice layering. It is detailed but still very musical. Dynamics of my setup has improved, more slam and it has an excellent PRAT (pace, rithm and timing). This presents sometimes a new musical interpretation of some recordings I heard already many times in the past. Amazing... I also compared this cable to some commercial XLR cables I had laying around (some of them 10 - 20 times more expensive) and it beats most of them or plays at least on an equal level.
Highly recommended!
(probably it will also perform very similar to the AMADEUS 5 when used as speaker or power-cord but I did not use it like that so I can't comment on it.)
Connecteur Pile 9V
Très bien.
M'a permis de réparer un équipement dont le coupleur de pile était hs
alexis P.
Quelle Découverte ce FDA _ L'essayer c'est l'adopté !
Pour 95% des enceintes Hi-Fi, si votre source principale est numérique, c'est l'ampli de référence.
2 écoutes m'ont suffi pour enterrer un atoll dac 100se et un marantz pm90se.
La clarté du signal est vraiment palpable. C'est instantané, l'image stéréo est meilleure. La musique plus agréable !
Pour le prix, je recommande cet ampli à tous mes amis !
Les petits + :
+ L'entrée auxiliaire analogique
+ La sortie Sub
+ La personnalisation des couleurs d'affichage
+ Les presets DSP pour donner une coloration au son
+ La sortie casque
Les moins - :
- La taille des borniers HP petit, obligé de passer avec des connecteurs bananes si vos câbles font plus de 1.5mm.
- Le manque de puissance pour des enceintes gourmandes inférieures à 90db de rendement.
alexis P.
Top ! caisson clos de 29l
Vraiment top le caisson clos ! Je voulais un sub home cinéma qui soit propre niveau diffusion. Les modèles basses reflex ne m'ont jamais convaincu. L'autre avantage est la petit taille du caisson, pour une surface émissive d'un 30 cm.
J'ai réalisé la caisse en CP de 22mm avec renforts internes, sans matériaux amortissant. Cote 36 x 36 extérieur. plan Speaker Box Lite.
Le HP est bien fini et a une belle allure si l'on parle d'esthétique.
Je l'ai également utilisé en Hi-Fi sur des sons Electro ! Ça remue vraiment bien tout en restant propre. Top !
Frederic S.
VIABLUE STONE Braided Sleeve 5-13mm This Viablue Stone braided sleeving accepts cables from 5mm to 13mm in diameter, providing effective protection against mechanical stress. Its fine braiding ensures a totally...
The Classe
Il est très beau, il est flexible et facile à à travailler, top.
Frederic S.
Superbe erreur
Acheté pensant que c'était du câble pour relier un élément hifi à une barrette; en fait c'est plutôt fait pour courir derrière les murs "mono brin", j'ai quand même décidé de le monter sur tout mon système: préamp tube/cd drive/alim de DAC, vers barrette.
Primo; j'étais assez septique sur le possible rendu d'un câble secteur, ayant acheté auparavant un sois disant "bon câble", kapton, pour ne pas le citer....Rien: ni sur l'ampli ni sur le préamp ne changeait le son.
Celui-ci, si on accepte un manque de souplesse/torsion assez acceptable, a réellement changée la donne dans mon cas; articulation dans le secteur bas, contrastes sur tout le spectre,simplement.
Thierry B.
Jack 4 pôles
Parfait pour raccorder un micro électrostatique en sortie de préamp (alim phantom) sur l'Ipad de mon fils. J'ai même rajouté un jack femelle en parallèle pour récupérer la sortie casque. Mon fils est ravi !
Le câble de 60cm est un peu court. 30cm de plus eut été parfait !
Et l'équipe Audiophonics toujours au top et très réactif. Merci
Marc V.
Super performance
The iBasso IT01 produce great sound and solid base. Not exaggerated but good.
My only comment: If you have narrow ear canals, you may need to try many of the eartips in order to get a good fit. For my ears, there should be smaller tips included. This is the reason for the 4 stars.
Marc V.
Great result
Excellent little gizmo to upgrade sound on your phone or tablet or computer. If you have spent + € 100,- on headphones or IEM, then the DC02 is a wise investment.
Marc V.
Excellent result for improved audio performance!!
These cables deliver a significant / audible improvement on audio quality: Wider soundstage - more detail - more smooth base, mids & highs.
Overall the cable have a very good build quality. My only remark is that the connectors to the DAC and amp are a bit loose fitting. They don't "snap" in. (That is why I give only 4 stars.)
IMO: if you have a hifi system (dac + amp + speakers) of over € 2.000,- then it is worth to invest an extra 10% in quality power cables.
Fabrice V.
Produit de très bonne facture
Produit reçu rapidement dans un emballage parfait.
Ce da
georges h.
DAYTON AUDIO RS225-8 Reference Speaker Driver Woofer 80W 8 Ohm 87dB 28Hz - 2400Hz Ø22cm DAYTON AUDIO's Reference Series single-handedly redefines the concept of value for money in the ultra-competitive ultra-high-performance loudspeaker market. By combining a...
excellent produit,bon rapport qualité/prix
Grzegorz B.
Good quality product, very useful
They are very good to use for confection on power supply cable to connection with power supply plugs, specially for IEC plugs where is screw and screwed washer.
Grzegorz B.
Very good quality product
It looks great, works fine and allow for really good connection. In my opinion are better than WBT spades in sound. You have to cover by sleeves against accidental short circuit.
Fred d.
Fred
Great performance! What goes in comes out. In combination with a good pre-amp you have a beautiful sound.
Eric P.
1877PHONO EVANJEL MK2 3.5-RCA Jack 3.5mm to RCA Modulation Cable 1.5m A remarkable evolution of its predecessor, the EVANJEL MK2 distinguishes itself by a choice of high quality materials and particularly meticulous finishes.
VIABLUE NF-S1 RCA-PHONO Jack 3.5mm to 2x RCA Stereo Cable 1m
Viablue et zavfino
Il est bien qu'audiophonics distribuer des câbles ésotérique comme ces deux marqued réputées, ils complètent deux Real câble iplug BTR aptx, le résultat diffère selon le câble, mais dans les deux cas le résultat est exceptionnel de clarté et de définition.
Niccolò P.
No power supply and broken remote
The amplifier sounds great (I've listened with Indiana Line 240 speakers) but I received the box without power supply and the remote control is not working at all.
I have already received the "incident ticket", but it's really annoying to go back to post office ... and hope that it will be sorted out.
Claude F.
Il ne faut pas avoir eu de FDA avec un Chip ST326 avant...
Tout d’abords merci à Audiophonics pour nous permettre de tester tous ces petits amplis à des prix compétitifs.
Je voulais essayer un Chip Texas TAS5342 car je disposais de plusieurs FDA à base de Chip StMicro ST326 et après avoir lu tout et son contraire je voulais me faire mon avis. Côté fabricant, j'avais confiance en Fx-Audio car j'étais enchanté par son modèle D802.
Mon environnement : En source, un Raspberry Pi sous Volumio2 avec une carte Digi. En sortie, des Qacoustics Concept 20 et un caisson de basse Elipson Planet Sub.
J’ai ressenti une grosse différence avec le Fx-Audio D802 ou le Sabaj A3 sur toutes les fréquences (Basses, Medium, Aigus) et un rendu vraiment moins riche à mes oreilles. Bref dans ma configuration, il ne faut pas avoir eu avant un FDA à base de ST326. J'aurai testé ce D502 après mon Yamaha, le résultat m'aurait sans doute convaincu.
Je ne vais pas renvoyer ce Fx-Audio D502, il vient de prendre la place d'un D802 qui était dans la voiture et que je préfère conserver pour une éventuelle panne sur mon système principal. Avec des HP à 50€ ça passe suffisamment bien, par ailleurs le méchant poc qu’il envoie à la mise sous tension ne me fait plus peur !
Alessandro V.
Very good preamplifier
I have combined this preamplifier with the amplifier FX-AUDIO FX1002A and a Fiio M3K to driver my home made full-range speakers based on the Tang-Band w3-871 and a DCAAV load.
The system work very well and the audio quality is very high compared to the cost of the whole system.
I advice this preamplifier at all people that would like to build a cheap, but good well sounding audio system!
Alessandro V.
Very good amplifier
I have combined this amplifier with the 6J1 FX-Audio TUBE-01 and a Fiio M3K to driver my home made full-range speakers based on the Tang-Band w3-871 and a DCAAV load.
The amplifiery drive easily this two little speakers.
I advice this amplifier at all people that would like to build a cheap, but good well sounding audio system!
david P.
Upgrade Esoteric
En remplacement de la fiche d'origine (furutech rhodium) cette fiche est de construction plus robuste et surtout les résultats sont bien supérieurs en terme de présence sonore.
david P.
Remplacement
Très bon condensateur, par contre si on veut vraiment évoluer, il faut en mettre partout pour obtenir un son homogène.
david P.
Remplacement
david P.
NICHICON KZ MUSE HiFi Audio Capacitor 100V 22μF The capacitors of the KZ Muse series can be used in particular for the processing of audio signals in devices requiring the best possible quality. They offer excellent performance.
Remplacement
david P.
Remplacement
david P.
Remplacement.
david P.
DAC GOLDMUND
En remplacement numérique et analogique sur un dac Goldmund très haut de gamme : on passe à la vitesse supérieure sur tout les paramètres. Un vrai plus en supplément de remplacement des condensateurs audio ds ce dac!!!
romuald s.
J’adore
J’ai revivre mes veilles enceintes, je redécouvre des musiques que je connais pourtant très bien.
Facile à installer et la commande est arrivée dans les temps, parfait.
Alan J.
Good quality RCA jacks
I had first purchased some similar jacks from Ebay, but they were fragile and were a problem to work with. I replaced them with these, which are of much higher quality. Highly recommended.
Gavin H.
NEOTECH STDCP-16 Hook-Up Wiring Multi Strands UP-OCC Copper PVC 16AWG / 1.31mm² Neotech offers high-quality STDCP wiring products using UP-OCC monocrystalline copper.
Good wire and easy to work with
Gavin H.
Good
Exactly as described, good quality
Gavin H.
Gets the job done, but that's about it
Looks as described, but it feels cheap. The fact that there are no instructions for assembly, the included feet are the cheapest plastic you can imagine and all of the screws are not labeled, so you have to work it all out for yourself. Not that difficult to put together, but still for this money it should be better.
Gavin H.
No screws supplied
If you're spending 19 Euro on a IEC inlet I would have hoped they'd include screws, but no. It's very annoying to then having order more parts elsewhere - how am I support to find a good match - black, countersunk head, m3.5. Product itself is ok, I can't say that I'm amazed for 19 Euro though.
John G.
Excellentt!
Excellente qualité sonore. Facile à installer. Mon seul point négatif est que le bouton d'alimentation clignote et c'est ennuyeux. Voir le projet sur ma chaîne YouTube (hélas en anglais). https://www.youtube.com/watch?v=WJsnQq3P-kQ
Pour éviter ce phénomène, installez le script d'alimentation :
https://github.com/audiophonics
Ou l'une de nos images modifiées :
https://www.audiophonics.fr/fr/blog-diy-audio/23-mise-en-route-raspdac-rasptouch-raspdac-mini-avec-une-image-pre-configuree.html
Yves B.
Bornier de belle fabrication
Belle finition, dimensions précises, bon contact électrique
Plastique de bonne qualité mécanique (et acoustique)
Il y a un Joint derrière le bornier pour étanchéité (et absorption des vibrations), c'est appréciable
Les fils internes de l'enceinte sont faciles à souder sur les cosses lors du montage, et le plastique du bornier résiste bien au chauffage des cosses métalliques
Ne pas oublier que le bornier est de petite dimension et il n'est pas très facile de serrer ou desserrer les bornes
Simon R.
Recommended
This is a pretty good amp! I'm pretty impressed. Relatively closely related to my tube amp in sound, only a bit more crisp with a touch less sweetness. Three-dimensionality is airy and really good. All in all nice and neutral with a nice musical flow. The reminiscence to the Nelson Pass concept seems to be really successful!
To be noted: I've increased the capacity of the power supply about 2.5 times for better stability. This with smaller capacitors to shorten the charging time. I also approximately doubled the heatsink area. I bypassed the Ero MKT capacitors at the input with small micas, which is a nice little mod for improved detail.
Conclusion: This thing is fun!
Cheers!
Dominique C.
XDUOO XD05 PLUS Battery-Powered Portable Headphone Amplifier AK4493EQ XMOS 32bit 384kHz DSD256 Black Direct successor to the XD-05, the xDuoo XD-05 Plus headphone amplifier with built-in DAC, it takes over the best features of its big brother while improving sound performances...
Maestria
Je ne sais pas comment faire l'éloge de cet appareil qui mérite bien mieux que mon simple commentaire.En fait, c'est très simple : je n'ai pas trouvé mieux que ce "XD-05 plus" et je ne pense pas même vouloir trouver mieux. Je suis totalement bluffé par le gouffre qui existe entre l'écoute de mon Hifiman HE4xxx avec cet ampli et les appareils que j'ai essayé jusqu'ici (portables ou non) dont aucun n'ont réussi à me convaincre très souvent par manque de puissance ou alors un son sans vie, plat, étouffé avec pas ou peu de spatialité, ou alors un mauvais placement des instruments, pas ou peu de séparation, un manque de dynamique, etc... Ce Xudoo m'a scotché : le son est parfait à mon gout, d'une pureté et d'un cristallin peu commun! Comment mieux vous le décirire que vous dire que les médiums ont une pêche incroyable sans pour autant tomber dans l'agressivité, les aigus filent avec un délié exceptionnel entre les notes et une "tenue" rassurante qui embelli systématiquement le rendu des instruments, dont les cuivres, le piano, les guitares, sans jamais tomber dans un rendu artificiel, tout au contraire. Les basses ne sont vraiment pas en reste et la réserve de dynamique (sur toute la gamme de fréquence d'ailleurs) est simplement incroyable, à tel point que je ne reconnais plus mon hifiman dans ce registre. Quelle maestro ! Nul besoin d'être un audiophile pour s'en rendre compte et ça c'est un vrai gage de qualité pour moi. On a affaire à un tout grand à un prix ridicule. Ce Xduoo me comble car il est polyvalent, à l'aise sur tous les genres de musique que j'étoute, à savoir que je privilégie entre autres le pop, le rock, la chanson française, le Jazz et tous les genres "électro". C'est un appareil "Premium" également au niveau de son apparence, il est bien fini et donne l'impression d'avoir dans les mains du très haut de gamme. Je vais tout de même tenter les AOP Burson, juste par curiosité car j'en demande vraiment pas plus. Très bon achat pour le moment, j'espère juste qu'il va fonctionner sans problème pendant de nombreuses années.
Patrick d.
USB Black Cable USB-C Male TO USB-C Male 3.1 15cm This high-quality male / male C-type cable allows you to connect any tablet or smartphone with a USB type-C or any type of C-type input.
Works fine as OTG Cable
Great cable, good quality and works like a charm, absolutely worth the money .... had other (so called) cheaper OTG cables, they didn't do the job properly. Used as audio interface cable Mac to MOTU, works great .... testing other options.
Jean-Claude F.
MUNDORF SUPREME SILVERGOLD OIL Capacitor 1000V 0.1μF The metallization of the MCap Supreme SilverGold capacitor foil is composed of pure Silver mixed with 1% very pure Gold. Gold modifies the crystal structure of silver and...
La meilleure série de Mundorf
Excellent condensateur, apporte un plus à l'écoute. Un peu cher tout de même mais les résultats sont là.
Fernand B.
Installée depuis une semaine, cette interface m'apporte plus de détails. Installation sans soucis, très bien.
Stephane I.
cable hp canare
Surprenant vu sa taille et son prix ,homogène et réaliste ,ne privilégie aucun registre ,étagement honnête ,un bon produit ,j 'en recommande et je vais essayer leur modulation qui à l'air efficace ,un peu brouillon sur la première heure et après le top .
Stephane I.
prolongateur dip 8
Fragile et cher ,ne peut pas être courbé,sinon il casse ,s' utilise seulement droit ,tenir compte de la hauteur du coffret.
Le prolongateur peut être courbé, mais de façon délicate et avec précaution.
Stephane I.
pieds bumpon
Parfait pour découpler des enceintes bibliothèques et pas abîmer ses meubles .
Jean-Pierre L.
Concluant
Produit de très bonne facture.
Utilisé avec MathAudioEQ/Foobar2000. Très facile d'utilisation. Notice simple et claire. 2 fichiers de calibration spécifique du micro à télécharger sur le site "MiniDSP" avec le No de Série. Un pour réglage de son stéréo (position micro horizontale), 1 pour réglage de son multi-canaux (position micro verticale).
M'a permis effectivement de régler l’acoustique stéréo d'une pièce avec des enceintes Focal Chorus 726.
Résultat probant.
Livraison : bon suivi de la part d'Audiophonics concernant le délai de livraison un peu long mais indiqué à la commande. Estimations demandées et respectées.
Didier f.
Agréablement surpris.....
Suite à une panne de mon ampli Marantz ( pm95 ) j'ai voulu profiter de l'occasion pour le remplacer par un ampli 'FDA'.
Quel surprise :
Belle finition, connectiques sans failles.
Côté écoute :
Nouvelle surprise, il en a sous le coude (puissance).
Source dématérialisé et enceintes jmr evo 3.
Le mariage se fait bien. Dynamique, ouverture, profondeur, bref tout y est.
Petit bemole le cordon d'alimentation fourni n'est pas à la hauteur de l'ampli.
jean paul d.
le deuxième.
Pour compléter mon installation audiophile entre le Nas et la box.
très bonne qualité, en rodage, merci de nous proposer des produits de qualités au juste prix.
Michel D.
Mon dac Mytek Liberty est déjà très bon a la base , écoute très analogique, mais là avec cette alimentation haut de gamme , je ne pensais pas atteindre un tel niveau de réalisme ,mes Mulidine chantent comme jamais, avec beaucoup plus d'ouverture.
Les informations du produit sont parfaitement exactes.
Je conseille fortement l'achat de cette alimentation qui de plus est abordable par rapport à sa très grande qualité
michel H.
J'étais sceptique
Excellant cable monté entre oppo 103 et projecteur Sony via darbee en full hd: couleurs plus intenses et gain sur la netteté . Dommage que vous l'ayez pas en 5m
Hervé F.
MATRIX ELEMENT X Streamer DAC ES9038PRO XMOS WiFi Femtoclock 32bit 768kHz DSD1024 Matrix presents the Element X, a high-end network drive that is versatile, powerful and aesthetically pleasing. It opens the doors of high-fidelity music streaming and...
C.R d’écoutes Matrix ElémentX, A1 d’Audio-GD, etc
C.R d’écoutes d’un système composé d’un Matrix ElémentX, A1 d’Audio-GD, etc.
Tout d’abord, un grand Merci à l’équipe Audiophonics pour les conseils et échanges nombreux afin de choisir les équipements venant remplacer les anciens (d’origine LINN et qui font des heureux chez leurs nouveaux propriétaires). Sans eux, pas de Matrix ni d’Audio-GD.
Les éléments qui ont été achetés chez Audiophonics sont: L’ElémentX, L’A1, les câbles de modulation, secteur, les filtres actifs et la multiprise Filtrée/non filtrée.
Je ne peux pas séparer les différents équipements pour donner une note à chacun. Tous comptent, à un niveau différent, mais sont un tout. Par exemple, j’ai changé de meubles dans la pièce d’écoute entre deux et j’ai été obligé de changer des éléments d’amortissement pour retrouver le « même » son/rendu qu’auparavant !
CR d’écoute système composé de :
Pièce d’écoute semi-réverbérant 40m2, en L avec un mur latéral semi-ouvert sur le reste de la maison. Distance d’écoute ~ 3.5m
Sub-Woofer PV1 (B&W) branché sur les enceintes Elfe (LEEDH) avec câbles LEEDH. Réglage d’intervention, 50Hz-20Hz. Ajusté en volume/fréquences pour couplage/raccord fréquences avec enceintes.
Enceintes Elfe (LEEDH) reliées à l’ampli A1 (Audio-GD) avec câbles doublés LEEDH 1.5m et isolés extérieurement. Placement : Ecartement, 1.7 m légèrement pincées vers la zone d’écoute et à 0.7m des angles de la pièce.
Ampli A1 (Audio-GD) relié à l’ElémentX (Matrix) en XLR symétrique avec 1877PHONO FUSION PURE XLR MKII Câble de Modulation 1.5m. Câble secteur 1877PHONO LEGION Blindé OFHC, Schuko IEC C15, 3x3.31mm² d’ 1.5m. Branché sur multiprise avec ifi Audio AC iPurifier, filtre secteur actif avec détection phase et terre. Le A1 est seul sur cette multi. Terre retirée sur prise Schuko au départ vers A1.
ElémentX (Matrix) relié au réseau en rj45 et à un HD USB directement (sans câble) par adaptateur/convertisseur USB A/B mâle/mâle avec un Jitterbug (Audioquest) entre l’entrée de l’ElémentX et l’adaptateur USB. Câble secteur PANGEA AC-14SE MKII triple blindages cardas Copper / OFC 3x2mm² 1.5m. Banché sur un port filtré Schuko, terre retirée, de la multiprise DYNAVOX X4100. Sur un port de la multiprise est branché un autre ifi Audio AC iPurifier. La multiprise est reliée au secteur par un câble secteur blindé OLFLEX 110CY 3x2.5mm².
Tous les équipements sont en phase «électrique/acoustique», sans terre, par test avec multimètre et/ou écoutes. Tous sont sur des supports essayés, cônes amortis, pointes en haut ou pointes en bas, amortisseurs en sorbothane, etc. Et le choix c’est fait sur le résultat d’écoutes, évidemment partagé par plusieurs.
Je n’ai testé de l’ElémentX que l’entrée HD USB. Il sert de DAC et de préampli pour l’A1 avec un gain à +10dB
Réglages paramètres internes autres que par (défaut) de l’ElémentX.
PCM Fiters =7(1) ; Dither =Off(On); Jitter Eliminator =Off(On) – Choix résultants d’écoutes.
Dernière chose que je ne m’explique pas. J’ai essayé le mode Bluetooth. N’y arrivant pas avec ma tablette, j’ai ajouté un dongle Bluetooth Motorola, que j’avais, sur le port USB HD libre, ça ne marchait pas (normal). J’ai oublié de le retirer et lors de l’écoute suivante, c’était mieux… ???. Il est resté depuis sur le 2ème port USB.
Lecture uniquement de fichiers en *.FLAC, 16 à 24 bits – 44.1 à 192 KHz. Tous les genres, avec 50% de Jazz, Bleues… 20% Pop, Rock, Variété… et 30% Classique, Lyrique, Symphonique….Je suis allé écouter de très nombreux concerts (l’absolu mieux).
Ouf, on passe à l’écoute (faite avec plusieurs personnes qui connaissent bien mon système, celui d’avant et le petit nouveau)
Résumé : Sublime !
L’illusion du réel est « pratiquement » parfaite
Détails :
Image grandiose, jamais projetée, toujours différente, selon la prise de son, mais plutôt derrière les enceintes.
Détails ultras fouillés, jamais « imposés » mais présents juste comme il faut, avec, par exemple, une respiration pour les chanteurs/chanteuses inouïe de naturelle. Aucun « léger voile ressenti » comme j’ai pu le lire sur un CR du net.
Une restitution incroyablement proche des timbres des instruments, qui pour moi, est souvent absente et de toute façon très difficile à obtenir fidèlement. Faire sonner un Steinway comme un Steinway et un Bosendorfer comme un….Bosendorfer. Bah, ce n’est pas du 100% (rien n’équivaut le réel), mais j’en suis véritablement très proche. A tel point, qu’un de mes amis a dit : j’aimerai faire jouer un saxo ici pour voir s’il y a une différence. Y-en-a une, mais elle est ténue maintenant.
La dynamique, fantastique, parfois on pourrait croire que la corde de guitare jouée par Eric Clapton va cassée, tellement la note arrive vite. Tout le toucher de l’artiste s’en trouve éclairé, aucune note s’additionne entre elles, mais elles se superposent, comme pour les voix dans les cœurs, chacun est entendu, c’est magnifiquement proche du réel. Tant que l’artiste ne décide pas d’arrêter une note jouée, la note jouée s’éteint lentement avec toutes les harmoniques de la note qui l’accompagnent. C’est beau.
Des exemples sur des morceaux avec anecdotes dites par les auditeurs :
Hadouk Trio - Touneblues – Baldamore En public au cabaret Sauvage.
Le pied !!! Qu’ils sont bons ces musiciens ! Sur le morceau, Tourne blues, j’ai failli vouloir ramasser la toupie qui « chante » au début du morceau et lorsque la chanteuse s’y met, ça voix est véritablement un instrument de plus dans le trio. Je ne comprends pas sa langue, mais elle berce mon cerveau.
Petrucciani – Jean-Philippe Herbien - Conférence de Presse Vol1.
En deux notes, on sait que c’est Petrucciani qui joue, avec son Steinway, aux aigus claquants et clairs ! Quelle énergie dans son jeu, totalement ressentie. Le piano entre entièrement dans la pièce avec sa dimension. La scène est holographique.
Eric Clapton - Drifting’ Blues – Slowhand At 70 Live At The Royal.
Formidable on s’y croirait, mais c’est drôle, je n’ai pas vu Eric entrer chez toi.
Nemanja Radulovic – Les 5 saisons – Vivaldi
Jamais entendue une version aussi jolie, avec un violon qui pétille de sonorités, fruité, quelles attaques, et ce ressenti du grain de l’archet sur les cordes, comme en vrai !
Natalie Dessay - Les contes d’Hoffmann Acte. III - Monte Carlo Philharmonique Orchestra
Planque tes verres en cristal, elle va tout prêter et je comprends toutes les paroles, d’habitude, ce n’est pas le cas.
Pink Floyd – If – Atom Heart Mother (MFSL)
Ah, je n’avais pas remarqué qu’ils chantent à trois, dès le début du morceau, je ne les entendais que sur la dernière reprise, où ils chantent clairement à trois !
Voir suite sur le Blog Audiophonics : https://www.audiophonics.fr/fr/blog-diy-audio
