yann r.
6 moi utilisation
Michel V.
Musical et costaud !
Customers reviews - There are 19151 reviews.
Joerg P.
recommandation d'achat
Un des meilleurs Dacs que je possède. Son très clair et discret, graves profonds et très nets. La seule chose qui est ennuyeuse, c'est la LED bleue qui clignote constamment.
Andy H.
Nice XLR Connector
Hi, Salut, Nicely made simple connectors. Inexpensive, easy to work with and light weight aluminum body. **Care must be taken when soldering. Be quick as the contact support plate can be melted easily**
Andy H.
Nice XLR connectors
Andy H.
Excellent IC Cable
Hi, Salut,
Pros: A very smooth, highly detailed cable. Excellent value for your money. Light and flexible. Small outer diameter
Cons: Not as easy to work with as some cable. Each conductor is wrapped in teflon tape under its PTFE insulation. It is somewhat difficult to remove for soldering. Cotton filler time consuming to trim back.
Patience is also required for it to sound it's best. Allow 100+ hours for it to break in.
Thierry B.
Très bon état, aucune rayure.
Parfait état.
Ce coffret semble solide.
Le montage n'est pas immédiatement intuitif.
Thierry B.
Très bon produit. Bonne fabrication. Facile à travailler.
Correspond à sa description.
Bastian B.
Good product - could be better
I really enjoy my new miniDsp DHS Studio. I use it as a roon endpoint. In my opinion it sounds not much better than my digi one. But the room correction is the key. This really improved my sound experience. I was looking for such a product for quite some time. And I am really happy with it.
I hope that miniDSP will improve the shd studio over time. There are quite a number of features missing. E.g. no way do dim the display and almost no configuration of the unit at all. Basically it is just "select source", "activate dirac", "select diract preset". Other products in the price range have much more configuration options.
The build quality is ok. But not amazing. I am not totaly happy with the volumne knob.
In total I am happy with my purchase. But there is room for improvement. Nevertheless, it does what I bought it for and it does it well. Therefore 5 stars.
jean-pierre a.
bt60w v2
bon tout petit ampli
Exceptionnel
Après 24 h sur le tuner pour le rider, j’ai associé ce câble avec des prises pur cuivre.
Le rendu est franchement exceptionnel sur l’ensemble des paramètres qui nous font apprécier un câble.
Je le compare avec des câbles type Siltech ou YBA et ce câble est franchement de même qualité voir peut-être mieux dans le haut du spectre qui me paraît plus fin moins métallique.
En 2x 1.50 m avec des fiches Rca moyenne game le coût final est 75€ avec une soudure argent 10%.
Je vais en recommandé pour équiper tout mon ensemble.
Il n’existe rien à moins de 3/400€ pour rivaliser
Faites vous plaisir
Patrick
Pour le prix c’est vraiment une très bonne affaire
Facile à souder et très bon contact avec les prises rca ampli/cd
Je recommande vivement
Rafail P.
Furutech FT-111
Livraison rapide et soignée. Le produit et relativement facile à monté - à condition d'avoir un peu d’expérience. J'ai monté les connecteur sur du cable QED Reference Audio 40. Résultat- plus de profondeur surtout pour les basses, sur de enceintes Audio Physic Spark et ampli Thule 60.
michel d.
excellent produit qui apporte réellement un plus; connecté a mon Xperia XZ3, le son est plus claire et détaillé plus dynamique quand au niveau de sortie c'est le top ....
Tomas C.
Excellent connectors
I am upgrading higher grade equipment (McIntosh, Musical Fidelity, Arcam, Kenwood (Trio)..) and was looking for great connectors to match level of equipment. Initially I thought WBT is something I have to have regardless of price. They are good but overpriced IMHO. If you check specification of WBT conenctors you will easily find that they are based on brass material - cheapest material that can be found on connectors with price of 1 dollar from China. It is so hard to find connector that is based on copper. These connectors fullfil my needs, very well manufatured and working amazing when restoring good old hifi components. Their price is also amazing. I highly recommend them! No need of looking for WBT anymore!
Marc T.
Métal mince : j'ai choisi de les sertir simplement sur le câble. Un peu délicat, mais on y arrive avec une déformation minime de la partie à insérer.
Les souder ? peut-être, mais au moins à l'argent : penser à la connectivité des métaux.
Pourquoi s'offrir des câbles en cuivre de très haute qualité si c'est pour terminer par de l'étain ou du plomb ?
Marc T.
Fourches économiques, pratiques, faciles à bloquer, mais :
-faire confiance au fabricant, car le cuivre me semble un peu blanc si on gratte...
-pourquoi laisser dessous une fente aussi large ? Perso, je les ai resserrées à l'étau
-peu adaptées à des câbles de moins de 2,5 mm2. J'ai rempli les vides avec d'autres bouts de cuivre...
J'attends un autre jeu pour comparer.
Trés bonne qualité de fabrication. Robuste, esthétiques et efficaces.
Marc H.
Quelle pureté du son fourni par cette voie centrale.
Audiophonics est une société sérieuse. Les délais de livraison sont au top.
philippe D.
Fait le job !
Je m'en sert depuis 3 jours. Aucun pb, il fait le job.
A voir sur la durée s'il tient sur la longueur, mais pour l'instant c'est parfait.
gilles b.
Un super outil
Après avoir téléchargé volumio dédié à cette version de rapsdac la mise en route est un jeu d'enfant.
Volumio se prends bien en main, il manque quelques fonctionnalités, à voirie si on the peut les rajouter, côté son : comparé à mon couple dac drive cd linn le rapsdac fait très bien le travail, un son droit avec une bande passante très étendue à comparer au linn il lui manque juste un peu plus de " présence" de "matière",
À voir ce que apporte une bonne alim sur ce rapsdac.
Aucun regret donc d'avoir acheter ce modèle, je recommande vivement cette solution.
Dominique P.
IKKO ZERDA DAC Adapter USB-C to Jack 3.5mm / Optical Mini-Toslink CS43198 32bit 384kHz DSD256 The Ikko Zerda is a USB-C adapter with integrated DAC, ideal for audiophiles who want to use their new generation smartphone (and without hardware analog output) as a high...
Excellent Produit
Branché en USB sur PC puis vers la sortie optique du Dac SMSL Q5 Pro
avec Enceinte DALI.
Application Foobar2000, Plugin WASAPI shared
Excellent son.
Pierre B.
Bon câble
Arrivé bien emballé et bien présenté, ce câble se révèle à l'usage transmettre une belle image et un bon son. Les connecteurs sont de belle qualité et la connection se fait parfaitement. Excellent rapport performance/prix.
Rodolphe D.
Exellent produit
Super petites cosses que j'ai utilisé pour le recablage interne de mes enceintes ,le son est parfait .Je suis content de mon achat Bravo
Jean B.
Possédant déjà le RT10 Rhodium-Argent pour la liaison Ampli-streamer et étant plus que satisfait, j'ai acquis le GT10 pour la liaison ampli-lecteur Blu-ray. Toujours le même plaisir avec une définition vraiment au-dessus du lot. Cette marque US assez confidentielle en France se signale aussi par une qualité de fabrication hors-norme.
Françis S.
Françis S.
En remplacement d'un cable standard tout à fait insatisfaisant , fonctionne non comme un filtre, mais dans l'ordre et d'une manière cohérente . Une bonne surprise face à mon septisme pour la musique qui sort d'un ordinateur . Un très bon produit .
Suite à un premier achat d’un potentiomètre commuté valant plus de 50€ .. j’ai essayé ce modèle bien moins cher ... et bien conclusion il es largement aussi bon ..piste ferme. Beaucoup de transparence . Un rapport qualité exceptionnel ..un très bon produit .
Upgrade du 05BL précédent
Ayant testé les deux extensions Bluetooth sur le XD05 Plus, sur cette 05BL Pro j'obtiens bien la liaison en LDAC 96 kHz. Est-ce que cela apporte réellement à l'écoute comparé à l'APTX sur le 05BL précédent?
À mon avis pas énormément... un peu quand même.
Ça et l'ajout de l'AOP Burson V5i propulsent le XD05 Plus vers des écoutes vraiment agréables, addictives j'ai du mal à me décoller de cet appareil!
Si vous voulez l'extension Bluetooth sur le XD05, pour le même prix choisissez plutôt la BL Pro, pour le nombre de codecs compatibles. Elle a une prise usb-c pour la charge batterie, une autonomie un peu supérieure j'ai cru comprendre.
Très convaincant
Monté sur le XDuoo XD05 Plus. Cet appareil n'offre pas beaucoup de place pour monter d'autres AOP, un Sparkos Labs ne rentre pas par exemple.
Le Burson par rapport à l'AOP d'origine modifie pas mal l'écoute, en bien.
Le niveau de sortie est augmenté, je suis obligé de baisser nettement la commande de volume, avec le même casque.
Je trouve que ce Burson apporte de la dynamique, en même temps j'aime bien ses qualités de restitution générales, la finesse dans le médium aigu, l'équilibre. Les basses par exemple sur de l'électro comme Brol de Angèle sont bien là.
La spatialisation est très bonne également.
En comparaison, l'AOP d'origine qui est déjà très bon privilégie davantage le médium et me semble moins fin dans le médium aigu. Je n'ai pas envie d'y revenir, prenant vraiment du plaisir sur ce XD05+ avec le Burson!
Danielle a.
cables d'enceintes
parfait envoi très rapide très bon emballage materiel de très haute qualité
Jean-Marc F.
Du rapide!
Matériel reçu en 48h, pour une première commande, parfait. Concernant le produit, j'ai un bon ressenti, j'ai fait plusieurs changements en même temps sur mes câbles qui ont été absolument incroyables en terme de résultat, l'élément majeur ayant été mes câbles hp (Esprit Eterna ! ), mais ce câble a contribué au résultat final sans aucun doute. Je regarde maintenant si j'investis dans une barrette BADA pour le secteur!
Stéphane B.
Super efficace
Les PANGEA (mega et pico) sont sans aucun doute les accessoires les plus simples, les moins chers et les plus efficaces que j'ai pu utiliser en HIFI.
Ici, pas de grigri inventé par un géotrouvetout de pacotille et vendu plusieurs centaines ( ou milliers) d'euros, tout est dans la matière.
Je confirme tout ce qui a déjà été dit, à savoir que le sorbothane est redoutablement efficace pour découpler tous les appareils HIFI. J'ai placé des MEGA sous mes enceintes et mon ampli/dac et des pico sous mon drive. Le résultat est sans appel, plus de résonances désagréables dans les basses fréquences, graves plus propres et donc une sensation d'aération accrue. Super produit !
M. S.
AUDIOPHONICS HPA-S400NC Power Amplifier Class D Stereo NCore NC400 2x400W 4 Ohm This block constitutes an amplification solution with a formidable reserve of power (up to 400W / channel) while fully respecting the amplified signal. It is ideally suited for...
Excellent!
A remplacé très avantageusement un Atoll in200.
Très bon son, beau boitier, ne chauffe pas, prix correct. Qui dit mieux?
Bruno l.
Extraordinaire !!!!
Je l’ai branché entre mon PC qui pilote l’audio avec foobar et un dac Audio GD nfb 29, sur une chaîne en multi amplification classe D (Audiophonics!) avec des hauts parleurs extrêmes ( 38 multi aimant / medium iso dynamique / tweeter à ruban ).
Habituer à faire des centaines d’essais pour toujours progresser petits pas par petits pas, là je suis sur le cul ! Pas la peine de ramer, en 5 secondes sur la première intro de musique on prend une claque, c’est comme si on ouvrait les rideaux pour regarder dehors, tout est plus défini, plus large, plus profond, plus net, plus rythmé et mieux timbré.
Impressionnant ! Bravo à IFI
Rene V.
Ce microphone est immédiatement reconnu par le logiciel de mesure REW.
Le fichier de calibration, disponible sur le site du fabricant, ne corrige que relativement peu la courbe de sensibilité, preuve de la qualité de l'objet.
Aucun point négatif à signaler.
Rene V.
Bon hardware mais software étrange ...
Sur le MiniDsp en tant que tel, j'ai un avis très positif.
Le filtrage, bien réglé, apporte un plus indéniable sans amener trop d'inconvénients.
Le bruit de fond est inexistant et la résolution très satisfaisante.
Seul le volume de sortie (...) est en effet un peu faible même si les cavaliers sont correctement placés.
Par contre, où sont tous les plug-in promis dans le mode d'emploi ?
Vérifiez sur le site si le plug-in que vous recherchez existe toujours avant d'acheter.
Le logiciel peut avoir des réactions étranges comme confirmer une commande reset avec le MiniDsp non connecté !
Dans l'ensemble cela fonctionne bien.
Hervé B.
Un dac d'exception
Que dire..... Et bien que du positif hormis un seul point de cette magnifique oeuvre technologique.
Actuellement, je possède un XDUOO-TA10, et tout ce que je peux affirmer est que la on joue dans une autre cour. La reproduction sonore ainsi que la musicalité est sans compromis. On sent bien le matériel pro dans toute sa splendeur.
Un bémol cependant concernant la navigation dans les menus qui relève du parcours du combattant! Mais rassurez vous, on s'y fait petit à petit.
Bref, tous ceux qui achèteront cette merveille ne seront point déçus !
A recommander sans réserve aucune. Un best-off.
Jean Yves P.
Amanero usb 384 kHz
Colis bien emballè , merci .Mais fort mécontent du produit reçus car ne correspond pas à la documentation ni aux avis émis a savoir l'implémentation déjà faite de la puce d'alimentation. Je me retrouve donc hors de mes compétences et donc produits partiellement inutilisables .
Il semble en effet qu'il y ai un problème sur la dernière livraison.
Mes collaborateurs du SAV vont prendre en charge votre soucis dans la journée.
William R.
Réactivité et disponibilité au niveau des conseils de l'équipe (que je remercie au passage), expédition sans faille et produit impeccable. Parfait sur toute la ligne.
Aurelien G.
J'ai des enceintes compacte klipsch rp 160 avec un ampli onkyo, il étaient fatiguant voir agressif avec un câble lambda de 2.5. Franchement je ne croyais pas trop au miracle et après avoir essayé un hp avec l'ancien et l'autre avec le mogami le jour et la nuit doux dans les aigus des médium plus précis/percutant j'ai redécouvert mes morceaux préférés.
Marc A.
De par sa conception: supérieur au Binary 234 MK2 du même constructeur que j'utilisais en AES/EBU pour transmettre les signaux audio numériques sur plus de 4 m.Apporte beaucoup plus de définition au signal (il a été conçu pour les studios et le Broadcast , et pour des distances importantes.);
Marc A.
NEUTRIK NC3MX-SOM 3 Pins Male XLR Connector Gold Plated Ø8mm (Unit) The Neutrik NC3MX is a 3-pole male XLR connector with zinc body and gold plated contacts. It is easy to assemble and consists of only 4 parts with a robust die-cast shell,...
Qualité Neutrik fabriqué pour Sommer afin d'utiliser leurs câbles de Diamètre 8 mm. Contacts plaqués Or.
Marc A.
Qualité de fabrication Neutrik pour Sommer.permet l'utilisation de câbles jusqu'à 8,7 mm de Diamètre.Bon contact :fiches plaquées Or.
Marc A.
EXCELLENT
Utilisé pour connecter câble coaxial 75 ohms en sortie BNC 75 Ohms d'un transfo d'impédance 110/75 ohms Neutrik. Excellent contact; permet l'utlisation de câble de diamètre important. Evite l'emploi d'adaptateurs BNC/ RCA qui peuvent engendrer des pertes de signal
Jean L.
Couplé avec un chrome cast audio appli qobuz android en optique, ou en usb w10 avec pilote smsl et asio4all et audirvana son excellent pour une chaîne nomade avec en direct des petites enceintes multi amplifiées tannoy 402, la télécommande volume son top très utile, petite taille du dac idéale pour cette chaîne.
Je l ai aussi essayé sur chaîne principale amplification marrantz pm 7005 enceintes Rogers ls7t(des vrais loupes neutres pas de coloration le son change avec changement d un element de la chaîne) très bon aussi son clair monte bien dans les aigus sans coloration ou agressivité bon timbre.
Je ne monte jamais en gamme de prix pour les dac,les produits evoluant actuellement très vite, ce dac me conforte dans cette stratégie....
alim du dac suite à lecture différent forum :energizer usb adapter
Lionel K.
Placés sous les pointes de mes enceintes, ces contrepointes apportent une réelle amélioration (son mieux défini, grave plus propre).
Philippe A.
DAYTON AUDIO PA165-8 Speaker Driver Woofer / Midbass 75W 8 Ohm 92.9dB 80Hz - 5kHz Ø15.2cm This Dayton Audio PA165-8 has been designed to support a high output level for a speaker of this size. It is a perfect model for designing HiFi speakers as a woofer / midbass...
OK
Fais ce pourquoi je l'ai acquis, bon prix et livraison rapide.
Philippe A.
CYK Stereo Cable XLR-3 Female / RCA Male Gold plated 24K OFC Copper 2m This affordable RCA male to XLR female CYK cable is ideal for ensuring good conductivity to your signal with its OFC copper conductor.
OK
livraison OK materiel OK cependant voie droite et gauches indistinctes, obligation d'utiliser un multimetre pour connection droite- droite et gauche-gauche. sinon pas de soucis
Philippe A.
JANTZEN AUDIO Wave Guide Audax TW034X0 (The pair) This pair of Jantzen Audio wave guide is suitable for mounting Audax TW034X0 tweeters (made in Denmark). They allow an efficient diffusion of the frequencies reproduced by these...
pas de notice utilisateur ni de d'explications concernant cette pièce vendu fort chère pour savoir vraiment comment l'utiliser .
Ivan L.
Great cable
Quick delivery, nice package and great product. Connected to the Rotel amp, sound is much better. Thanks!
Jean-Pierre B.
Bon et pas cher
Polyvalent (banane et poussoir) et Pour le tarif, rien à redire !
Jean-Pierre B.
Excellent Rapport qualité/prix
Rien à rajouter de ce qui a déjà été dit, je confirme la bonne surprise pour un tarif attractif. Fait le job aussi bien que 3 à 4 x plus cher !
Un petit bémol sur la longueur de réserve entre le point chaud et la couronne de maintien du câble et de la masse.
