Jean-Claude F.
Très bon câble HP
Jean-Claude F.
Yvain C.
J’ai hâte de la...
Gilles C.
Bien lire la description
Superbe rendu sur câble de 13mm.
Je confirme, la longueur finale dépend aussi du diamètre.
Commandé 2m, couverture 1,35m.
Prévoyez un bon 50cm sur grosse section.
Gilles.
Matthew K.
DAC
I wasn't sure whether to buy this DAC but Idecided to take a punt.
When I first plugged this in and switched it on I was dissapointed to the point of returning it, as it must be faulty. That said I had read elsewhere that these ladder dac need time to settle in to your system. With this in mind I left it switched on, with my cd player on repeat but my amp off. After 5 hrs it sounded good, after 20 - 30 hrs it sounds sweet, very, very nice. smooth, detailed and accurate, with some drama thrown in too. I am very pleased with this. I havent tried the headphone amp yet as I don't have any. This has transformed my cd player and I have never heard cd's sound this good on my system.
Patrice V.
Solide
ce connecteur est solide, T° du fer 300 impeccable. ne craint pas d'être dessouder et souder à nouveau à plusieurs reprise. je suis ravi.
Christophe v.
FX-AUDIO BOX02 Phono MM/MC Preamplifier NJM2068 TL071 The FX-Audio BOX02 is a low-cost phono preamplifier, offering a very high quality design. It supports the board with MM and MC cells, a switch under the device to select one of...
Preampli phono
Entierement satisfait de ce petit preampli. Bon son, bon dynamisme.
Très bon rapport qualité/ prix.
Anders L.
PANGEA Premier XL RCA Interconnect Cable 0.6m (La Pair) PANGEA Premier XL cables benefit from technologies rarely encountered in this range. An excellent alternative to the market leaders offering high quality affordable design,...
Open and transparent
Very good analogue cables at any price. I bought these as a "reasonable" comparison for my DIY-cables. Straight out of the box I was struck by their very transparent nature. They convey a pleasant 3D scene with plenty of characteristics for voices and instruments. Even the bass instruments have very clear individual timres. I will certainly enjoy listening to more music with these as I do like a transparent sound reproduction.
André G.
cable audiophonics CANARE AES/EBU
Câble très bien conçu, présentant de belles qualités musicales et d'un excellent rapport qualité prix. A recommander sans hésitation.
joel H.
"Pas assez cher, mon fils"
Franchement pourquoi payer plus cher.
On m'a prêté plusieurs câbles optiques de différents marques, j'ai pris celui la pour dépanner, finalement c'est celui qui va rester.
joel H.
quand c'est bien
J'ai depuis 2 ans le mème en rca-bnc pour relier mon lecteur réseau au DAC.
Suite à l'achat d'un transport Cyrux, je n'ai pas cherché bien loin pour choisir sa connexion .
A conseiller
Patrick C.
Fonctionne parfaitement.
Patrick C.
Bon produit facile à monter.
A mon avis pourrait peut être convenir au Raspberry Pi 4
Jean Pierre g.
smsl dac 500
Acheter pour système secondaire, je possède déjà un dac ampli casque beaucoup plus cher avec juste des sorties analogiques en plus.
Franchement pour le prix je ne m'attendais pas a être aussi agréablement surpris.Tout y est, transparence, dynamique, scène large ,extinction des notes .Aussi bien que mon dac ,casque principal 3,5fois plus cher.
Ecoutes majoritairement au casque,qobuz etc.....
Demande une petite semaine de rodage.
Une entrée analogique aurait été le bienvenu.
Pour ma part très bon dac casque surtout a ce prix.
Mariage pas très heureux !
j'ai échangé des cables premier prix en 2,5 par les neotech en 4 mm et ma chaine m'a sortie un son trop bas, grave très désagréable à l'écoute. mon système se compose d'un ampli denon dra1000 (22 ans déjà) hp infinity alpha 40, d'un dac advance mdx600 et d'une platine cd Yamaha, bref avec une longueur de cable d'environ 6 mètres (meuble hifi décalé à gauche) entre l'ampli et les enceintes j'ai voulu monté en gamme et en diamètre !!! je ne pense pas que ce soit la longueur mais plutôt les cables eux meme (rodage peut-être). j'aimerais avoir un avis de "pro" à ce sujet si possible, je vais essayer avec du 2,5 norstone surement plus neutre . MERCI par avance...
Peter P.
Must have amplifier!
I have ordered 2 of these amps as I have a 4.0 setup (Nubert nuVero 140 in the front and nuVero 50 in the back)
I have replaced a Crown CT8150 amplifier that I previously had
I must say that it was definitely an "awwwwwwe" experience when I first listened to these beasts....the sound is totally amazing
It is as transparent as possible, it sounds as clean as I have never heard before (not just at home but also anywhere else)
The words "dynamic range" and "stage" have a new definition now: Hypex
Space has opened up in all 3 dimensions but in a scale I still cannot believe
Also it is worth noting that I hear instruments/sounds that I have not heard before - and believe me it is not my imagination playing tricks with me...
Warning: If you are looking for "warm" sound and all that audiophile BS please do not buy these amps as the are fully linear; they will not add any coloration or distortion; they will produce exactly what is in the recording - and that is what a proper amplifier should exactly do!
I am extremely satisfied and I would very strongly recommend these amps to anybody looking for a dynamic, linear and transparent sound
A side note: I have asked Audiophonics to remove the RCA inputs and the input selector switch which they did so congratulations to them for being flexible and customer-oriented
Thank you
Pascal F.
Sceptique
J'étais franchement sceptique quant à l'utilité d'un cable secteur sur une installation Hi-Fi quand toute la partie amont de l'installation reste la même.
En changeant un preampli phono j'ai ramassé de la ronflette avec un niveau somme toute acceptable mais quand même !
J'ai donc achete çe cable secteur audiophonics. La réalisation est magnifique et les composants de grande qualité. Je ne m'attendais pas à cela en commandant.
J'ai connecté çe cable et la, plus de ronflette c'est incroyable.
Le prix de çe cable est tout à fait acceptable si l'on compare avec d'autre marques.
Je suis emballe et le conseille à tous.
Transparence
Raccordé sur mon tuner Magnum Dynalab FT101A Etude et écoutant des émission en direct sur France Musique, on est transporté dans le studio, tout est très défini, le moindre petit détail est présent, on situe aisément tous les musiciens, les timbres des instruments sont très naturels
bon, bref, je ne sais pas ce que peuvent donner des câbles secteurs à des prix stratosphériques, mais celui ci à permis de faire un grand bond en avant à mon systeme Haut Rendement, tout lampes, 300B pré SRPP 6SN7
de plus, le rapport qualité/prix est très très bon
Ce kit cable secteur est très facile à confectionner
Si vous voulez du très bon, foncez
Merci à Audiophonics de proposer celui ci
Lionel M.
Bien mais.....
Bien mais j'aurais aimé recevoir la pochette qui figure sur la photo plutôt qu'un banal sachet plastique.
Minh N.
Excellent appareil porte-drapeau de la nouvelle technologie « Full Digital Amplifier » « simple » par le concept et grâce aux circuits intégrés poussés. Cela donne une taille d’une main !
Le son est clair, fouillé, avec de la présence qu’on peut relever par un subwoofer grâce à une sortie en RCA mono (si votre woofer a une entrée jack 3,5 mm stéréo - pour relayer le son à des enceintes - prenez un câble RCA-jack 3,5mm stéréo dont vous utiliserez le connecteur RCA blanc ; raison : il y a une différence d’épaisseur entre jack stéréo et mono constaté sur mon matériel).
L’appareil est beau, très proprement construit et il est de conception et fabrication chinoises ! Cela change de leurs produits bas de gamme qui illustrent l’adage « Plus on achète à bas prix, plus on risque de gaspiller son argent ».
Le prix de ce SMSL Q5 Pro chez Audiophonics est imbattable ! Dommage que les comparateurs (dont il faut se méfier) sur Internet l’ignorent.
Lors de mes échanges, le service d’Audiophonics s’est montré impeccable et ce site mérite d’être consulté en priorité pour ses achats.
Que demander de plus ? Je suis un audiophile très satisfait.
Nicolas T.
très bon matériel
très bonne qualité, il rempli parfaitement sa fonction
Paulo P.
que demander de plus !
je possède beaucoups de fiches bananes . de materiaux , de mode de serrage différents ect ... mais surtout de prix parfois délirants et sans jamais constater de differences audibles à l écoute .
ce produit est de très grande qualité de part sa simplicité mais surtout son exellent couple de serrage . sans parler de son RPQ sans égal . pourquoi dépenser plus . la recette gagnante réside dans le panneau acoustique qui fait passer une installation milieux de gamme à très haut de gamme .
C'est là que votre argent doit être investi .
Anders L.
Good dampening and stability
These rubber feet are of good manufacture. They provide the right amount of dampening and stability for loudspeakers. I use them for floor-standing loudspeakers that weigh around 20 kg apiece. The rubber feet are better for them than spikes or dampening pads, which I tried first.
Frederic S.
incroyable
Acheté en dépannage après l'achat d'un Nuprime STA-9, je ne m'attendais pas à autant de qualités venant d'un appareil à 30€.
Grosse surprise, il tient très bien la route; son chaud avec les tubes d'origine, voir un peu trop mais deux 5456w NOS ont changé la donne pour un son plus clair et surtout, cerise sur la gâteau; le fameux son holographique, celui qui fait disparaitre les murs ;)
J'attend d'autres tubes NOS russes et américains pour d'autres expériences sonores. Bref, un dépannage qui va durer.
fabio M.
ottimo dac economico
Ho avuto molti dac sui miei 3 impianti, in due impianti hi end uso dac costosi dalle 10 alle 20 volte questo D50.
Lo sto provvisoriamente alimentando con un carica batteria samsung s5. Quindi nulla di degno. Aggiungo che il dac suona in modo ottimale specie per la spesa. Ha battuto diversi dac sulla fascia di prezzo 300-1500 euro già con una alimentazione non adeguata. La frizzantezza sugl'alti la noto pur io però solo a volumi elevatissimi, vicino ai meno 20 db misurati da fonometro. Il dac ha bisogno di molto rodaggio per predere asprezza ed enfatizzazioni, direi almeno 100 ore e suona bene e musicale dopo un bel po di tempo. Prima di far ascolti importanti di valutazione l'impianto era ben caldo, 2 ore direi. I primi 30 minuti suona sempre tutto più duro.
Per quanto riguarda l'enfatizzazione sulle altre, ho provato il topping d50 nel mio impianto migliore. Costituito da krell preamplificazione up-gradato e rifatto in modo importante e finale bartolomeo aloia st2000. Cavi rca in argento oro al teflon, cavi potenza argento oro, cavi alimentazione furutech da 180 euro al metro e schuko iec furutech da 300 euro cad'una. Ciabatta in alluminio pieno con schuko furuteck oro e cavi rame 7n.
In questo impianto che così composto arriva a quasi 40 mila euro tutto compreso l'enfatizzazione delle alte frequenze è nulla. Solo si fa sentire quando nei picchi il fonometro segna meno 10-20db. Volumi che preoccupano i muri di casa.
Starei attento a quali elettroniche abbiamo in casa ed i cavi segnale usati. negl'ultimi anni per far sembrare suonar bene gl'impianti e creare sound stage sia la sorgente, che i preamplificatori che i finali che i cavi enfatizzano le alte. Se associamo il topping d50 la cosa potrebbe farsi sentire. ma ciò non succede in un impianto ottimo.
Lo consiglio vivamente. E' un best buy.
ora lo tengo nel mio impianto minore ed ho ordinato la sua alimentazione topping. spero arrivi presto e aggiornerò.
Jean Luc m.
Correctif
Je voudrais signaler que les deux avis précédents ne sont pas dans l’ordre chronologiques.
Lire le 2 en premier.
Jean Luc m.
Je fini mon avis écourté par une fausse manœuvre.
Je disais donc que ayant acheté un premier cordon de cette ref j'ai décidé d'en acheter un deuxième pour relier la box au boitier CPL et là encore amélioration.
J'ai vraiment l'impression d'avoir changé de système,d'avoir monté en gamme.
Je ne pensais pas qu'un cordon puisse avoir autant d’influence sur qualité sonore.
Jean Luc m.
Excellent.
Très grande qualité de transmission des datas.
Mon système hifi lecteur réseau est relié à la box par prises CPL.
Dans un premier temps j'ai branché le lecteur avec le cordon fourni mais pas totalement satisfait j'ai acheté un cordon Audiophonics rj 45 en un mètre et là,super résultats sonores,finesse des aigus,graves magnifiques, fermes,rapides,sans boursouflures,les médiums sont très présents sans agressivités.
Si je devais résumer je dirais que ce cordon a beaucoup de classe et de raffinement.
Au vues des premiers résultats j'ai décidé de remplacer l'autre cordon(un QED) entrel
Henri V.
RCA au top
Facile à souder, facile à monter et... des résultats. Si les KLEI ne sont pas données, elles sont selon mes essais de différentes fiches RCA celles que l'on recommande dans tous les sens du terme.
michael m.
90 ° Angled HDMI Adapter - Male Female Capable of meeting the connection constraints of modern flat screens, this adapter is particularly useful in confined spaces.
90 ° flat angle HDMI adapter - Male Female Capable of meeting the connection constraints of modern flat screens, this adapter is particularly useful in confined spaces.
GPIO Extender cable male female 40 Pin for Raspberry Pi A+ / B+ / Pi 3 / Pi 2 20cm
fonctionne tres bien
Branchés sur un raspberry, fonctionne a merveille.
Francois-Xavier A.
RAS
Fonctionne comme specifie. Tres bon rapport qualite / prix. Cable sur un Linkplay A31 et le rendu sonore est tres honnete!
Carol F.
Génial
Génial pour rebooster une sortie son un peu légère sur un smartphone. De plus, facile à transporter, très petit et léger. Parfait.
Jean Michel e.
cheap pour le prix!
En fait, on ne paie que le cuivre plaqué or....le reste est très très basique pour le prix! pas d'indication de phase, même si ce n'est pas très important, et plastiques ordinaires; prend beaucoup de place à l'arrière d'un ampli.
Pour 2 euros de plus, ceci est vraiment mieux
https://www.audiophonics.fr/fr/fiches-secteur-connecteurs-iec/elecaudio-pi-24gc-connecteur-secteur-iec-c15-plaque-or-24k-3-o165mm-crystal-p-6585.html
jean michel
La phase dépendra de la façon dont votre câbles est conçu (même les plus grande marques ont tendance à ne pas proposer de câbles droits) mais aussi de la façon dont vous allez le câbler en interne.
Son format est standard.
Bien pour l'électronique de la chaine hifi.
Personnellement, je les utilisent pour former un support "anti-sismique" en les plaçant sous une plaque de marbre de 3cm d'épaisseur, sur laquelle est posé un ampli, un DAC ou une source. Sur internet, ils sont parfois critiqués pour leur grincement. C'est vrai si on appui dessus à la main. Mais je n'ai jamais été embêté par ça au cours des années en écoutant ma chaine!
Jean-Christophe N.
Parfait pour un cable haut parleurs
Aspect sensationnel avec un cable haut parleur de 7 mm de large. Le diamêtre mentionné l'est pour un cable rond mais avec un cable qui ne l'est pas le diamêtre est amplement suffisant, presque trop grand, bien qu'il facilite la pose.
Le rendu, avec la matière coton est, malgré cela, parfait!
Régis A.
Très bonne qualité perçue pour ces fiches femelles, mais...
Il est cependant dommage qu'aucune clef haleine ne soit fournie pour le démontage. Tout le monde n'a pas d'aussi petites clefs dans son outillage. Ceci peut constituer un gros handicape pour certains et ainsi rendre le produit inutilisable.
Hervé N.
Fourches de haute qualité
Elles sont lourdes, robustes, et les vis Tork permettent un serrage efficace du câble hp.
Fiches absolument à recommander pour systèmes de qualité.
Hervé N.
Fiche banane d'excellente qualité.
Nul besoin de soudure, les 2 vis de serrage suffisent.
L'enfichage dans la borne de l'enceinte ou de l'ampli se fait à force.
Donc aucun risque de voir la fiche quitter malencontreusement son emplacement. Le contact est par voie de conséquence optimum.
De plus, cuivre tellurium. Pour systèmes de qualité.
Jaap B.
Great case for Khadas dac
Patrick J.
Qualité chinoise
Matériel de très médiocre qualité mais facile d’utilisation. Tarage aisé. Le résultat semble précis. On espère juste que cette précision apparente n’est pas à la hauteur (!) de la qualité de fabrication... Mais à ce prix très doux, difficile d’espérer avoir mieux !!
Attention, les piles LR43 ne sont pas les plus faciles à trouver dans le commerce. Il en faut deux.
Patrick J.
Beaucoup trop fragile, à éviter !
Porte cellule basique mais a priori de bonne facture, sauf que les connecteurs des cables de liaison sont beaucoup trop fragile ! Le premier cable que j’ai essayé de connecter à ma cellule s’est immédiatement cassé en amont du connecteur ! Je n’ai pourtant pas été brutal !
Bref, ce n’est pas cher, mais ça ne vaut pas son prix...
Philippe H.
Rapport qualité-prix ahurissant
Acheté pour une utilisation nomade (améliorer la diffusion en cours d'analyse musicale), ce minuscule DAC (la paume de la main)offre une somme de qualités impensables vu son prix … Bien sûr, en comparaison directe avec mon Hegel HD30, les écarts restent significatifs, mais dans l'absolu l'écoute proposée respecte le message musical (timbres, sens du rythme, image ), et procure avec Foobar + wasapi un plaisir sans commune mesure avec la sortie "native" du PC portable. A recommander sans aucune réserve, pour qui cherche une réelle compacité (sinon, le Sanskrit 10th anniversary va encore plus loin !)
Michel P.
Esben T.
This card replaced my cheap hifiberry-clone and the sound is noticeably better. Most significantly there's much less jitter.
sylvain a.
très bon boitier
Boitier très soigné
Produit conforme a la description
Livraison rapide , emballage impeccable
Réponse rapide ma question avant l'achat
Transaction parfaite :)
Marcastel m.
m'a permis de doublet les sorties de mon pré-ampli
Marcastel m.
Fait son travail et respecte la finesse du son de ma chaine HIFI
Fabrication sérieuse
les pines ne corresponde pas à la carte de mon pré-ampli PHONOPHONE mais avec du fil téléphonique j'ai adapté le montage.
Son nickel
Marcastel m.
Bon complément pour les basses si l'alimentation associée est de qualité
Acheté pour sa partie subwoofer et dynamiser les basses.
les plus : réglages du volume et de la fréquence de coupure
les moins : alimentation et ajouter au prix d'achat
donc produit moins attractif après achat de l'alimentation.
L'alimentation proposé sur le site (alim à découplage très bruyante cliquetis et souffle donc non-adaptée à la sono et à la HIFI)
vu le prix d'une alimentation de qualité ce module n'est pas attractif,
mais ça fonctionne une fois la bonne alimentation trouvée :
après trois essais une alimentation de12v 48VA est suffisante pour le fonctionnement du subwoofer
à voir à l'usage concernant la longévité du produit
Marcastel m.
NICHICON KZ MUSE HiFi Audio Capacitor 100V 220μF The capacitors of the KZ Muse series can be used in particular for the processing of audio signals in devices requiring the best possible quality. They offer excellent performance.
Bon produit adapté au traitement du son
Volumineux : mais mon préampli PHONOPHONE la intégré sans problème dans l'étage phono.
Scène sonore dynamique et détaillée
Alain j.
TEK 5 Way Remote Source Selector Stereo With this source selector, the signal is switched directly to the circuit to avoid passing it through to the selector in order to limit interference as much as possible.
TEK Sélecteur de source déporté
Sélecteur de qualité mais impossible de choisir le nombre de palier
Alain j.
boitier HIFI 2000 ECO
boitier de qualité
Alain j.
axe 80 X 6
