DAYTON AUDIO CLASSIC B40 Bookshelf Speakers Wood
The Dayton Audio Classic B40 bookshelf speakers are passive speakers featuring a 10.16cm woofer and a 2.54cm silk dome tweeter, able to support up to 30W RMS power at a 6-ohm load (60W max.). They have the advantage of being able to be placed anywhere and are ideal for near-field listening.
Reference : 21690
79,90 €tax incl.
66,58 € tax excl.
Dayton Audio Classic B40 Bookshelf Speakers 30W 6 Ohm 82dB 75Hz-20kHz Wood (Pair)
Photo of the Dayton Audio Classic B40
The Dayton Audio Classic B40 bookshelf speakers are passive speakers featuring a 10.2cm woofer and a 2.54cm silk dome tweeter, able to support up to 30W RMS power at a 6-ohm load (60W max.). They have the advantage of being able to be placed anywhere and are ideal for near-field listening. The Classic B40s benefit from a sealed enclosure that reduces distortion in the low frequencies. Their sensitivity of 82dB and frequency response of 75Hz to 20kHz make them excellent speakers, offered at a more than reasonable price. On the rear panel, there is a gold-plated terminal block and a very practical wall-mount bracket for easy integration into any space.
The key features of the Dayton Audio Classic B40 speakers:
  • 10.2cm woofer for low frequencies
  • 2.54 cm silk tweeter
  • 30W RMS power handling @ 6 ohms
  • Vintage design and sealed box
  • Wall mounting brackets
  • High-quality speaker terminals with gold-plated contacts
  • Two speaker cables included (3 metres long)
The components of the Dayton Audio Classic B40 speakers
Photo of the Dayton Audio Classic B40 woofer
Woofer
The robust 10.2cm woofer delivers deep bass.
Photo of the tweeter on the Dayton Audio Classic B40
Silk dome tweeter
The tweeter delivers detailed high frequencies for a smooth and clear reproduction of vocals.
A suspended acoustic structure
The sealed-box suspension design significantly reduces distortion at low frequencies.
Dayton Audio Classic B40: Vintage design
The Classics B40 feature a delightful vintage look, allowing them to blend seamlessly into a complete audio system.
Photo of a Dayton Audio Classic B40 without the front grille
Photo de l'arrière d'un Dayton Audio Classic B40
Dayton Audio Classic B40: Significant advantages
The Dayton Audio B40 features gold-plated terminals for improved conductivity and resistance to corrosion and oxidation. In addition, a wall-mount bracket makes it easy to integrate them into a home cinema setup, allowing them to be installed on either side of a screen quickly and easily. Finally, two speaker cables are included so that the speakers are ready for immediate use.
Product typeBookshelf speakers
Type of speakersPassive
Number of ways2 ways
WooferPolypropylene 10.16cm
Tweeter2.54cm silk dome
Frequency response75Hz-20kHz
Sensitivity82dB
Potential output95dB
Power handling30W RMS
60W max
Recommanded power amplification10W-50W
Nominal impedance6 Ohms
StructureSealed (acoustic suspension)
Crossover frequency5kHz
Dimensions140 x 241 x 145mm
Weight1.94kg/speaker
ColorWood
Package1x Pair of Dayton Audio Classic B40 bookshelf speakers
2x Front grilles
8x Foam adhesive feets
2x Speaker cables
ColorWood
Impedance (Ω)6
Efficiency / Sensitivity (dB)82.0
Lowest frequency (Hz)75
Highest frequency (Hz)20000
Power (W)30.0
Number of ways2
Number of loudspeakers2
Speaker typePassive
Speaker form factorBookshelf speaker
DAYTON AUDIO CLASSIC B40 Bookshelf Speakers 30W 6 Ohm 82dB 75Hz-20kHz Wood (Pair)
The Dayton Audio Classic B40 bookshelf speakers are passive speakers featuring a 10.16cm woofer and a 2.54cm silk dome tweeter, able to support up...
