FANGSOUND PROMETHEUS Portable DAC Headphone Amplifier
The FangSound Prometheus is a portable DAC in dongle format, designed to provide high-resolution audio conversion and powerful amplification in a compact form factor. It is based on the ESS ES9039PRO chip, renowned for its high level of precision, wide dynamic range, and low distortion. Compatible with audio streams up to PCM 32bit 768kHz, it allows you to enjoy Hi-Res files from a computer, smartphone, or tablet via USB-C.
By buying this product you get 55 loyalty points
Reference : 21765
559,00 €tax incl.
465,83 € tax excl.
Shipping date: 24-11-2026.
Fangsound Prometheus Portable DAC Headphone Amplifier ES9039PRO 32bit 768kHz
Its amplification stage delivers up to 2x1W under 32 ohms, with a maximum output voltage of 6Vrms, allowing it to efficiently drive many headphones and earphones. In terms of connectivity, it features a 3.5mm single-ended headphone output as well as a 4.4mm balanced headphone output, making it suitable for different cables and uses. Its technical performance includes THD+N of 0.0004%, a signal-to-noise ratio of 128dB, and a dynamic range of 128dB (A-weighted).
Its CNC-machined aluminum chassis ensures durability and efficient heat dissipation while maintaining a lightweight design of only 33g. Supplied with a USB-C to USB-C cable, the FangSound Prometheus is a compact solution for improving the audio quality of both mobile and desktop sources.
Connectivity of the FANGSOUND PROMETHEUS
Technical Specifications
Product typePortable DAC / Headphone amplifier
DAC chipES9039PRO
InputUSB-C
Output1x 3.5mm single-ended jack
1x 4.4mm balanced jack
Supported sample ratePCM up to 32bit 768kHz
Dynamic range128db (A-wt)
SNR128db (A-wt)
Output voltage6Vrms
Output power1W @ 32Ω (1%),THD+N 0.0004%(4Vrms)
Power supplyVia USB-C
Weight33g
Dimensions13.5 x 8 x 3cm
Packaging1x FangSound Prometheus
1x USB-C to USB-C cable
OutputJack 3.5mm
OutputJack 4.4mm
DAC / ADC ChipES9039PRO
Max sampling rate768kHz
ColorGray
FANGSOUND PROMETHEUS Portable DAC Headphone Amplifier ES9039PRO 32bit 768kHz
The FangSound Prometheus is a portable DAC in dongle format, designed to provide high-resolution audio conversion and powerful amplification in a...
