This blows my former A/B amp out of the water. No reason to spend more. Incredible headroom and no distortion. Very fast delivery.
By buying this product you get 109 loyalty points
This unit is supplied with a 230V AC power supply as standard. If you require a 110V input voltage, please select this using the switch on the underside of the unit before connecting it to the mains.
Power amplifier NCore NCx500 2x600W 4 Ohm
We are proud to present the Audiophonics LPA-S600NCX, a Class D stereo power amplifier based on two NCore NCx500 modules. Electronically similar to the HPA-S600NCX, this version is housed in a more compact enclosure, making it easier to use in environments where space is at a premium. Its architecture also limits the length of the internal connections.
This ready-to-use, pre-assembled model is aimed at audiophiles looking for a foolproof amplification solution with a considerable power reserve and impeccable definition. NCore modules are among the most rigorous Class D amplification solutions on the market, with simply exceptional measured performance.
The whole package delivers a high level of sound reproduction, ideal for use with demanding loudspeakers, in large listening rooms or in studio applications requiring considerable headroom without compromising on the precision and richness of the audio message.
All the components are housed in a sober, robust, stylish and compact 100% aluminium enclosure. The enclosure has apertures to promote heat dissipation. Its design also limits the impact of interference on the signal.
Each channel of the Audiophonics LPA-S600NCX features its own Hypex NCore NCx500 amplification circuit with high efficiency and low output impedance, distortion and noise. This new module has greatly improved performance in terms of distortion and output impedance. Each amplifier module is capable of delivering 700W of power at 1% THD. The integrated 1200W HYPEX power supply enables them to simultaneously deliver 600W at 0.01% THD into 4Ω.
Particular care has been taken with the internal wiring and assembly of the amplifier, using large-section power supply wires, Canare input signal cables and PTFE-insulated speaker cables.
The SMPS1200 switching power supply is a very high efficiency model capable of developing a rated power of 1200 Watts in an extremely small footprint. It has been specifically designed and developed by Hypex to supply the 2x85V voltage required to operate the most demanding amplifier modules.
This high-quality, low-noise power supply meets the power requirements of the amplifier modules in every respect. What's more, the modules themselves have an excellent ability to reject power supply noise. As a result, the LPA-S600NCX is extremely insensitive to imperfections in the electrical network and to voltage/current variations that can cause parasitic noise.
The 2 modules are controlled in phase opposition, to cancel the "Power-Supply Pumping" effect. This makes the power supply more stable, distributing the current draw alternately on each rail, thereby increasing its capacity.
We opted for 2-level voltage regulation, to optimise the power supply to the AOPs and the auxiliary voltage supplied to the modules.
One Audiophonics OPA1656 PDU is used per channel. These are very low distortion PDUs offering the greatest transparency with very low THD. They are mounted on a DIP8 socket, allowing them to be replaced if necessary.
To suit all applications, we have opted for 4 gain settings, switchable via switch on the underside of the unit :
Designed for easy integration, the LPA-S600NCX has both balanced (XLR) and unbalanced (RCA) stereo inputs. Bipolar selectors make it easy to change input sources and even allow independent control of channels.
On the output side, BP-207 carbon / 24k gold insulated terminals (Ø5.5mm) provide an excellent connection to loudspeakers.
| Specifications | |
| Type of product | Power amplifier |
| Type of amplification | Class D |
| Amplifier modules | 2* Hypex NCore NCx500 |
| Channels | 2 (Stereo) |
| Inputs | 1x Stereo RCA 1x Balanced XLR 3-pin |
| Other connectors | Trigger 5-12V |
| Technology | NcoreX |
| Power | 2x500W under 2Ω @ 1kHz THD=0.01% 2x600W under 4Ω @ 1kHz THD=0.01% 2x300W under 8Ω @ 1kHz THD=0.01% |
| THD+N @ 20Hz-20kHz, 4Ω | Typ : 0.0006% Max : 0.001% |
| SNR | 137dB |
| Output noise | 7µV |
| Frequency response | 0Hz - 70kHz @ +0/-3dB |
| Gain (selectable) | Bypass : 11.5dB 19dB 25dB 31dB 33dB |
| Efficiency (full power) | 92% |
| Dumping factor | 1600 @ 1khz 2000 @ full band |
| General | |
| Supply voltage | 110-230VAC (default: 230V) |
| Max. power consumption | 1300W |
| Chassis | Sand-blasted aluminium |
| Total dimensions (WxDxH) | 191 x 386 x 82mm |
| Net weight | 3.17kg |
| Package | 1x Audiophonics LPA-S600NCX 1x Power cable |
| Input | XLR |
| Input | RCA |
| Output | Speaker terminal |
| Color | Black |
| Channel | 2 (Stereo) |
| Class | Class D / T |
| Amplifier chip | Hypex Ncore |
| Power (W) | 600.0 |
| Remote Control | No |
Average votes 5.0 / 5 13 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
michel d.
Stephen G.
Serge M.
Jacek Z.
Maik B.
