By buying this product you get 34 loyalty points
The ALSOZONE PAM152 is a class D stereo power amplifier designed to drive speakers in Hi-Fi and home cinema installations. Each channel integrates a TPA3251 chip in PBTL configuration and delivers up to 150W; the GaN power supply and 3eAudio's PFFB technology help maintain a stated distortion of 0.0003% into 8Ω.
Intended for systems requiring several amplification channels, it combines balanced and unbalanced inputs, two-level gain adjustment and several power-on modes, including 12V trigger and automatic activation on signal detection. Its modular design and built-in protections make it easier to integrate and maintain in a multichannel installation.
The ALSOZONE PAM152 is a multichannel power amplifier designed for Hi-Fi, home cinema and professional audio installations. Each channel relies on a TPA3251 chip configured in PBTL and delivers up to 150W, while the high power density GaN power supply provides the current required by the speakers. ALSOZONE specifies a total harmonic distortion of 0.0003% into 8Ω, in order to preserve signal detail at high listening levels.
Using an independent TPA3251 chip per channel allows each amplification output to be managed separately. This architecture supports a 2Ω impedance and a stated output current of 34A, making it easier to pair with various speakers and multichannel configurations. 3eAudio's PFFB technology complements the power stage by targeting a stable response, for controlled reproduction in Hi-Fi listening as well as in home cinema.
The PAM152 accepts balanced differential and unbalanced inputs, allowing it to integrate with consumer sources as well as professional equipment. The balanced connection helps reject noise induced on cables, particularly in installations with several devices or long connection distances. A two-level gain adjustment allows the amplifier's sensitivity to be matched to the source's output level and the various components of the system to be better balanced.
Three control modes allow operation to be adapted to the installation: power-on via button, 12V trigger or automatic activation upon detection of an audio signal. The 12V trigger input and output facilitate integration into a complete HiFi system, while the automatic mode switches the unit off after 20 minutes of inactivity. This management limits standby consumption and reduces heat generated when the system is not in use.
The modular design allows individual amplification modules to be repaired or upgraded without replacing the entire unit. According to the manufacturer, this approach can reduce long-term maintenance and upgrade costs by 30 to 40%. The PAM152 also integrates microcontroller-driven protections against overvoltage, overcurrent and excessive temperatures, as well as a power supply compatible with various mains voltages to facilitate deployment.
Technical specifications
| Specifications | |
| Product type | Power amplifier |
| Channels | 2 |
| Inputs | 2x RCA 2x Combo XLR/Jack 6.35mm |
| Outputs | 2x Speaker terminal output |
| Amplification chip | TPA3251 |
| Amplification type | Class D |
| Output power | 2x 275W @ 2Ω THD+N = 1% 2x 150W @ 4Ω THD+N = 1% 2x 80W @ 8Ω THD+N = 1% |
| Frequency response | 20Hz-30kHz |
| THD+N | Unbalanced input: 0.0005% @ 4Ω / 0.0004 @ 8Ω Balanced input: 0.0004% @ 4Ω / 0.0003 @ 8Ω |
| SNR | Unbalanced input: 122dB Balanced input: 125dB |
| Dynamic range | Unbalanced input: 122dB Balanced input: 125dB |
| Input sensitivity | Unbalanced input: 2V/1Vrms Balanced input: 4V/2Vrms |
| Crosstalk | Unbalanced input: -110dB Balanced input: -120dB |
| Gain Low | Unbalanced input: 21dB Balanced input: 15dB |
| Gain High | Unbalanced input: 27dB Balanced input: 21dB |
| Recommended speaker impedance | 2-16Ω |
| General | |
| Supply voltage | 100-240V AC, 50/60Hz |
| Dimensions | 260 x 265 x 90mm |
| Weight | 3.0kg |
| Color | Black |
| Package | 1x ALSOZONE PAM152 1x Power cable |
| Input | Jack 6.35mm |
| Input | RCA |
| Input | XLR |
| Output | Speaker terminal |
| Color | Black |
| Channel | 2 (Stereo) |
| Class | Class D / T |
| Amplifier chip | TPA3251 |
| Power (W) | 150.0 |
| Remote Control | No |
