DOUK AUDIO NS-13G MAX Class D Stereo Power Amplifier Phono
The Douk Audio NS-13G MAX is a compact stereo power amplifier featuring a built-in MM phono preamplifier, designed to efficiently drive a wide variety of passive speakers while allowing the direct connection of a turntable. Based on the TPA3255 amplification chip, it delivers up to 2x120W into 4Ω at THD+N=1%, ensuring powerful, dynamic, and controlled sound reproduction with excellent energy efficiency.
Reference : 21928
139,00 €tax incl.
115,83 € tax excl.
Shipping date: 01-12-2026.
Douk Audio NS-13G MAX Class D Stereo Phono Power Amplifier TPA3255 2x120W 4 Ohm
Douk Audio NS-13G
The Douk Audio NS-13G MAX is a compact stereo power amplifier featuring a built-in MM phono preamplifier, designed to efficiently drive a wide variety of passive speakers while allowing the direct connection of a turntable. Based on the TPA3255 amplification chip, it delivers up to 2x120W into 4Ω at THD+N=1%, ensuring powerful, dynamic, and controlled sound reproduction with excellent energy efficiency. It also integrates a NE5532P operational amplifier combined with RUBYCON and WIMA capacitors, contributing to precise and musical sound reproduction with a low level of distortion.
The NS-13G MAX features an RCA line input as well as an MM phono input, allowing the direct connection of a turntable without an external preamplifier. It offers speaker outputs via binding posts, as well as a 3.5mm AUX output delivering a 2.4V output level, ideal for connecting an additional amplifier, an active subwoofer, or active speakers to create a 2.1 or multichannel system. Compatible with 4Ω to 8Ω speakers, it provides a signal-to-noise ratio greater than 107dB, a frequency response from 20Hz to 20kHz (±1dB), and extremely low distortion of 0.005% at 1kHz.
The device also integrates bass/treble tone controls (±6dB) as well as a Tone / Bypass switch, allowing either adjustment of the sound signature or complete bypass of tone correction for a pure and unprocessed audio signal. Its replaceable op-amp socket also allows the NE5532P to be replaced with other compatible dual operational amplifiers such as the OPA2604, OPA2134, or MUSE02, offering additional sound customization possibilities. Powered by 24V to 48V DC and supplied with a 48V / 5A power supply, the NS-13G MAX benefits from an optimized thermal dissipation system with side and bottom ventilation effectively limiting heat and dust accumulation. Its CNC-machined aluminum chassis ensures robustness, compactness, and easy integration into a desktop or home HiFi environment.
Overview of the Douk Audio NS-13G
1Power On / Phono-RCA Input Selector
2Power Indicator
3Tone/Bypass Switch
4Bass Adjustment
5Treble Adjustment
6Volume Control
7RCA Input
8RCA Phono Input
93.5mm AUX Output
10Speaker Binding Post Output
1124V-48V Power Input via DC Jack
Technical Specifications
Product TypePower amplifier
Amplification ChipTPA3255
Op-AmpNE5532P
Input1x RCA
1x RCA MM Phono
Output1x Speaker Binding Posts
1x 3.5mm AUX Output
Output Power2x 120W into 4 ohm (THD+N=1%, 48V 5A)
2x 250W into 4 ohm (THD+N=1%, 48V 10A)
2x 300W into 4 ohm (THD+N=10%, 48V 10A)
Output Impedance4Ω-8Ω
Bass/Treble Adjustment±6dB
Input SensitivityRCA: 2V
Phono 5mV
THD+N0.005% @ 1kHz
SNR≥107dB
3.5mm AUX Output Level2.4V
Frequency Response20Hz-20KHz (±1dB)
Power Supply24-48V DC via DC Jack
Dimensions130x102x38mm
Weight513g
Package Contents1x Douk Audio NS-13G MAX
1x 48V 5A Power Supply
InputPhono
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTPA3255
Power (W)250.0
Power (W)120.0
DOUK AUDIO NS-13G MAX Class D Stereo Phono Power Amplifier TPA3255 2x120W 4 Ohm
The Douk Audio NS-13G MAX is a compact stereo power amplifier featuring a built-in MM phono preamplifier, designed to efficiently drive a wide...
