MINIDSP AMP-8 8-Channel Amplifier
With the AMP-8, MiniDSP presents an 8-source, 8-channel amplifier, enabling the creation of a complete multi-zone audio system. It is based on an ICEPower amplifier module capable of delivering 300W per channel under 4 ohms, while boasting an impressive signal-to-noise ratio of 123dB and a SINAD of 102dB. The amplifier module is complemented by an ICEPower switching power supply offering 1500W of continuous power and up to 2400W of peak power. The result is a multi-channel amplifier with impressive performance in a compact format.
By buying this product you get 289 loyalty points
Reference : 21430
2 890,00 €tax incl.
2 408,33 € tax excl.
miniDSP AMP-8 8-Channel Amplifier IcePower 8x300W 4 Ohm
MINIDSP AMP-8 : Front view
With the AMP-8, miniDSP presents an 8-source, 8-channel amplifier, enabling the creation of a complete multi-zone audio system. It is based on an ICEPower amplifier module capable of delivering 300W per channel under 4 ohms, while boasting an impressive signal-to-noise ratio of 123dB and a SINAD of 102dB. The amplifier module is complemented by an ICEPower switching power supply offering 1500W of continuous power and up to 2400W of peak power. The result is a multi-channel amplifier with impressive performance in a compact format.
Product typeMulti-zone amplifier
Inputs8x XLR
Outputs8x Speaker terminal
Amplification module4x IcePower 300A2
Output power8x300W @ 4Ω
8x150W @ 8Ω
Input impedance38kΩ
Input sensitivity2Vrms
Frequency response20Hz-20kHz (±0.5dB)
Signal-to-noise ratio (SNR)123dB
12V TriggerInput / Output
Power supply voltage85-264V AC
Dimension442 x 336 x 90mm
Package1x miniDSP AMP-8
1x Power cord
Rack mounting bracket
InputXLR
OutputSpeaker terminal
Channel8
Amplifier chipIcePower 300A2
Power (W)300.0
MINIDSP AMP-8 8-Channel Amplifier IcePower 8x300W 4 Ohm
With the AMP-8, MiniDSP presents an 8-source, 8-channel amplifier, enabling the creation of a complete multi-zone audio system. It is based on an...
