TONEWINNER AD-1PA+ Class A Power Amplifier Black
Powerful Class A stereo power amplifier, the Tonewinner AD-1PA+ benefits from a high quality balanced architecture that allows it to develop significant power while ensuring a dynamic and precise sound reproduction. Its careful and intelligent integration, proof of the attention paid by the brand to their product, results in a powerful and musical device, respecting the audio signal to reveal every detail.
By buying this product you get 359 loyalty points
Reference : 18657
3 590,00 €tax incl.
2 991,67 € tax excl.
Tonewinner AD-1PA+ Power Amplifier Stereo Class A 2x300W 8Ω Black
Tonewinner AD-1PA+ Amplificateur stéréo Class A 2x300W 8 Ohm
Tonewinner's AD-1PA is back in a "+" version with an optimized circuitPowerful Class A stereo power amplifier, the Tonewinner AD-1PA+ benefits from a high quality balanced architecture that allows it to develop significant power while ensuring a dynamic and precise sound reproduction. Its careful and intelligent integration, proof of the attention paid by the brand to their product, results in a powerful and musical device, respecting the audio signal to reveal every detail.
Tonewinner AD-1PA Amplificateur stéréo Class A 2x300W 8 Ohm
Tonewinner AD-1PA+: A Class A amplifier as powerful as it is efficient
The amplifier stage of the Tonewinner AD-1PA+ embeds 8 pairs of high power transistors TTC5200 and TTA1943 within a Class A. These allow the amplifier to deliver a consequent power of 300W RMS per channel under 8Ω.
Tonewinner AD-1PA Amplificateur stéréo Class A 2x300W 8 Ohm Tonewinner AD-1PA Amplificateur stéréo Class A 2x300W 8 Ohm
Tonewinner AD-1PA+: Class A/AB switch
The Tonewinner AD-1PA+ has three operating modes: Class A, Class AB or Auto. A switch allows you to select the most suitable mode according to your needs and your installation. The Auto mode automatically switches from Class A to Class AB when the temperature of the unit reaches a certain limit and switches back to Class A if the temperature drops.
Tonewinner AD-1PA+: Bi-wiring possibility
With its dual speaker terminals, the Tonewinner AD-1PA+ offers the possibility of bi-wiring. This method of connecting to speakers can offer an improvement in sound quality by reducing the magnetic interactions of the cables.
Tonewinner AD-1PA+: A large power supply
In order to deliver such a power, the Tonewinner AD-1PA+ is equipped with a large power supply, including a high performance toroidal transformer of no less than 1200W. 16 large filter capacitors with a total capacity of 180,000µF ensure a clean and stable electrical signal. In addition, the left and right channels are independently power supplied.
Tonewinner AD-1PA+: Perfect isolation
The internal design of the AD-1PA+ has been thought to physically separate the different sections of the device and thus ensure a very good isolation. This design effectively limits interference and noise.
Product typePower amplifier
ChannelsStereo (2)
Amplification typeClass A
Class AB
Inputs1* Single-ended stereo RCA
1* Balanced stereo XLR
OutputsSpeaker terminals
TriggerInput and output
Output power300W RMS/channel @ 8Ω, 20Hz-20kHz, THD < 0.1%, two driven channels
500W RMS/channel @ 4Ω, 20Hz-20kHz, THD < 0.1%, one driven channel
320W RMS/channel @ 8Ω, THD < 0.1%, one driven channel
Pure class A output power100W @ 8Ω
Impedance8Ω
Channel separation≥ 80dB
Bias selectionClass A
Class AB
Auto
Speaker output modeA
B
A+B
Frequency response10Hz-100kHz (+1/-3dB)
THD+N< 0.008% @ 1kHz
SNR≥ 108dB (A-weighted)
Recommended minimum load impedance (per channel)2Ω
Damping factor> 200 @ 8Ω
Input sensitivity1.6V @ rated power, 8Ω
Gain29.5dB ±1dB
Supply voltage110-240V AC 50/60Hz
Dimensions444*294*449
Net weight43.4kg
Housing materialAluminum
Package1* Tonewinner AD-1PA+
1* Power cable
InputXLR
OutputSpeaker terminal
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipTransistors
Power (W)300.0
Excellence tout simplement
Certainement un des meilleurs RQP du marché.
Utilisé sur les voies médium de mes infinity IRS Béta dites tueuses d'ampli initialement en mode pure classe A qui tenait très bien mes enceintes mais un peu montant le passage en A vers AB glissant a permis une amélioration immédiate.
Puis le rodage aidant plus de 80 heures actuellement je suis repassé définitivement en classe A et je confirme l'excellence de cet ampli beauté des timbres scène sonore large et profonde dynamique harmonique tout y est.
J'ajoute comme déjà écris que cet ampli est sensible au câble secteur mais bon je n'ai pas encore croisé un matériel qui ne l'est pas, même le digital l'est.
Je peux donc confirmer sans risque que cet ampli pour son tarif est vraiment équivalent à d'autres très grosses bêtes à presque 6 fois ce tarif et qu'il fait mieux chez moi.
Musicalement
This review has been posted for TONEWINNER AD-1PA+ Power Amplifier Class A Stereo 2x300W 8 Ohm Black
Powerful Class A stereo power amplifier, the Tonewinner AD-1PA+ benefits from a high quality balanced architecture that allows it to develop...
