LADDER CHOPIN II Preamplifier Silver
The LADDER CHOPIN II is a fully discrete and balanced R2R line preamplifier, operating in pure Class A, designed to provide precise and transparent control of the analog signal in stereo Hi-Fi systems.
By buying this product you get 154 loyalty points
Reference : 22422
1 549,00 €tax incl.
1 290,83 € tax excl.
LADDER CHOPIN II Discrete Balanced Class A R2R Preamplifier Silver
LADDER CHOPIN
The LADDER CHOPIN II is a fully discrete and balanced R2R line preamplifier, operating in pure Class A, designed to provide precise and transparent control of the analog signal in stereo Hi-Fi systems. Its fully balanced differential architecture is combined with a 60-step relay volume attenuator, controlled by a microprocessor and equipped with precisely matched resistors to ensure excellent channel matching. The CHOPIN II features 2 XLR inputs and 1 RCA input, as well as XLR and RCA outputs, allowing it to be integrated with various sources and power amplifiers. Its power supply is based on a 65W toroidal transformer combined with several independent regulated power supplies and high-end capacitors. With unity gain of 0dB, a frequency response of 10Hz to 80kHz (-0.3dB), THD+N below 0.0006%, a signal-to-noise ratio of 120dB and a dynamic range greater than 121dB, the LADDER CHOPIN II is a compact solution designed for demanding two-channel audio systems.
LADDER CHOPIN II: 60-Step Relay Volume Control
The LADDER CHOPIN II replaces the traditional potentiometer with a 60-step relay attenuator controlled by a microprocessor. This architecture allows precise volume adjustment while maintaining excellent channel matching across the entire volume range. The resistors used are precisely matched to preserve stereo balance and minimize distortion. The fully discrete analog circuit operates in pure Class A and uses a fully balanced differential topology. The CHOPIN II therefore provides unity gain operation (0dB), an input impedance of 60kΩ in balanced mode and 12.2kΩ in unbalanced mode, as well as an output impedance of 400Ω in balanced mode and 200Ω in unbalanced mode.
LADDER CHOPIN II: Balanced Connectivity and Linear Power Supply
The LADDER CHOPIN II features two balanced XLR inputs and one unbalanced RCA input, while its outputs are available as balanced XLR and unbalanced RCA. The outputs reach 4.0 Vrms via XLR and 2.0 Vrms via RCA respectively, providing compatibility with various components in the Hi-Fi chain.
Its power supply uses a 65W toroidal transformer, combined with eight regulated power supplies and ERSE capacitors to provide stable power to the analog circuits. The preamplifier is housed in an aluminum alloy chassis measuring 336 × 374 × 66mm, with a net weight of 6.5kg. A remote control is also included, allowing remote control of power, input selection, mute function, and volume.
LADDER CHOPIN: Balanced Connectivity and Linear Power Supply
Technical Specifications
Product typeBalanced R2R Preamplifier
Preamplifier typeClass A
Circuit designBalanced differential
Volume control60-step relay attenuator with microprocessor control
Inputs2x Balanced XLR
1x RCA
Output1x Balanced XLR
1x RCA
GainUnity 0dB
Output levelRCA: 2.0Vrms
XLR: 4.0Vrms
Input impedanceXLR: 60kΩ RCA: 12.2kΩ
Output impedanceXLR: 400Ω RCA: 200Ω
Frequency response10Hz–80kHz (-0.3dB)
THD+N<0.0006%
SNR120dB
Dynamic range>121dB
Stereo crosstalk-110dB
Power supply100–240VAC, 50/60Hz
Power consumption1W in standby
20W operating
Dimensions320 x 330 x 60mm
WeightNet: 6.5kg
ColorSilver
Packaging1x LADDER CHOPIN II
1x Remote control
1x Power cord
InputXLR
ColorSilver
ClassClass A / AB
Remote ControlYes
LADDER CHOPIN II Discret Class A Balanced R2R Preamplifier Silver
The LADDER CHOPIN II is a fully discrete and balanced R2R line preamplifier, operating in pure Class A, designed to provide precise and transparent...
