Antonio C.
It’s a no brainer.
Tibor H.
Didier T.
En un mot... Majestueux !
Et pour peu...
Customers reviews - There are 19037 reviews.
Antonio D.
Efficaces!
Au regard de la taille requièrent une certaine dextérité des doigts.
Font leurs job.
David O.
Exceptionnel
Un DAC complet, facile d'utilisation et surtout d'une transparence magistrale.
Top.
Lars A.
Preamplifier Volume Control OPA2604 This preamplifier is both simple and efficient, and benefits from a robust and high-performance design that provides high-quality, transparent and accurate audio reproduction.
Lars
The reason for buying this item was impedance matching between DAC and active speakers in my desktop/2nd setup used for Tidal streaming and playing local Flac files. In this case RME ADI-2/Teddy Pardo LPS and Airpulse A100/REL sub. Right out of the box this little preamp sounds really good. It is dynamic, transparent with a soundstage that is quite impressive for the pris tag. This unit also offers the opportunity for opamp rolling. After consulting Audiophonics I change the default opamps to Sparkos and Muses which increased the sq to a higher level. The soundstage is wider and deeper. Transparency is much better with a slight warm midrange. Bass is more dynamic. The presentation is much more musical. This little "no name" preamp is with or without opamp rolling insane good value for the money. It also highlight the importance of a good preamp/impedance matching in a hifi system. Highly recommended. The unit has replaced a Yaqin buffer with Psvane 6SN7 tubes. Other equipments in the setup are Asus router with LPS, Asus ROG miniITX/Ubuntu Studio/Paul Pang USB card with LPS. JCAT USB isolator. Bada power conditioner. Rca
cables are SKW OCC and Inakustik Excellence. USB cables are SKW OCC and Inakustik Excellence/Reference. Powe cables are Audioquest and Supra/rhodium connectors.
Petr M.
4.5 stars
+ good looking, seems to be solidly build
+ no background noise present (up to e.g. -20db gain I've to put my ear directly to the speaker to hear some noise] - I was afraid of the noise quite often being problem of class D amplifiers so I'm really happy it is bot the case of this one
+ usable for driving speakers in small living room way below maximum possible power
+ APTX-HD and AAC bluetooth codecs
- USB DAC resolution (16bit/48khz) is not what one would expect from today's products (otherwise I would give 5 stars)
Jean-Pierre R.
avis positif mais un bémol
ce filtre apporte un gain indéniable en qualité de son, ce qui est le premier objectif...gain en aération globale et surtout incroyable gain de tension du grave (système en bi-amplification active)
par contra impossible de faire fonctionner le repérage de phase, l'indicateur de phase restant toujours allumé quelque soit la position de la prise....!
Redoutable
Simple dans sa conception, ce câble monté avec des prises béryllium plaquées argent soudure mundorff argent 10%,m’a réellement bluffé.
Je le compare à des câbles très très cher avec 3 chiffres minimum.
Je ne vais pas étaler tous les superlatif sur les qualités de ce câble, non, je vais juste vous recommander de l’acheter et de le tester.
Après 20/30 heures d’utilisation, laissez vos impressions en commentaires.
Inutile de vous dire non plus que son RQP, est a ce jour, le meilleur de ce site.
IMPRESSIONNANT
Bref, pour une somme dérisoire, avec ce câble, vous allez vraiment vous faire plaisir et redécouvrir vos cd préférés.
Patrick
Henrik E.
Works magnificent, but has a major flaw.
The board works just fine, but when the computer goes to sleep and then wakes up, there is no signal out. But I found that this only happens on the spdif outputs. The I2S output seems to work.
I would give it five stars if it wasn't for this.
Imre S.
Good screws
I'm sure it's good, but unfortunately I ordered 1 size smaller, so unfortunately I couldn't use it, but it looks good. It might come in handy at some point.
Marek S.
Audiophonics HPA-S400ET Sparkos Ed. plus Topping PRE90
Après l’acquisition du Topping Pre90 que j’ai utilisé avec un ampli de puissance américain de petite taille bien connu, que je ne vais pas nommer ici, je cherchais quelque chose de mieux. J’ai donc commandé après la lecture des bonnes opinions sur l’Audiophonics HPA-S400ET SPARKOS EDITION. Nous parlons donc ici du couple Topping – Audiophonics.
Le reste de la chaine : Tannoy d700 de 1995, lecteur YBA MP100SE et cd Primare DVD30 utilisé comme transport via le DAC du YBA. Câbles hp sont les Duelund cotton, liaisons XLR Atelier Acoustik (ebay), alimentation – mes propres montages.
L’effet est superbe ! Voici mes impressions – subjectives, bien entendu.
Sur le cd de Mercury Living Presence « 22 Classic Hits » les détails sont sublimes, des silences remplis de bruits de membres de l’orchestre (hors musique) – toucher des archets, changement de pages des partitions, mouvements de toute sorte. La dynamique, l’image stéréo, la place de chaque instrument est précise, le toucher et le souffle des archets sur des cordes – tout ce qui donne la sensation de vérité, cet air entourant l’orchestre.
La voix de Sinatra sur « Only the Lonely » est comme elle doit être en termes de timbre, placée juste devant sur le fond de l’orchestre bien lisible derrière.
D’autres voix (Peppe Servillo de Avion Travel, Claudio Baglioni, Marie Michele Desrosiers sur tous ses disques... ) restent très autentiques, gardant leur charactère propre, sans colorations ni sibilantes (fréquentes sur d’autres amplis).
L’étendue de fréquences à l’air complète – du grâve profond et bien articulé, par les médiums sensationnels jusqu’aux aigus cristallins. L’attaque et extinction des notes – superbes. Chose importante pour moi - à bas niveau ça continue et procure un grand plaisir tard le soir. A par ça – silence absolu !
Je connais un ampli intégré danois coutant plus de dix fois le prix du HPA-S400ET et là, j’ai été épris par l’authenticité qui me rappelle cet nouvel achat. Bon, les conditions d’écouté, les hp et le reste de l’équipement – tout est différent. Sans aucune possibilité de faire une comparaison directe, je reste avec mes bons souvenirs mais subjectivement je reste épaté.
Câble haut niveau
Je reviens sur mon avis précédent
Câble utilisé en tant que câble pour le grave sur des enceintes FH
Laisse tout passer avec un grave et un bas medium bien maîtrisé
Du Oyaide !
Yannis G.
Amplifier / Speaker Protection Module 220V 30A This protection module for amplifiers and loudspeakers includes 2 relays with a nominal voltage of 12V DC, a resistance of 155 Ohm, a power of 0.93W and a switching current of...
Module de Protection Amplificateur / Haut-Parleur 220V 30A
Ce module de protection HP fonctionne a merveille , installer sur un ampli de puissance QUAD 520 plus aucun ploc a l'allumage et a l'extinction mais les borniers de connexions sont un peu a l'étroit pour le (GND) sinon ça vaut largement son prix espérons qu'il dureras dans le temps
claude N.
ELECTRO-HARMONIX 6H30PI Gold Pin Tube Twin Triode (Unit) The 6H30PI Gold Pin from Electro-Harmonix is a double triode tube. Its low plate resistance combined with excellent linearity and a dissipation of 4W per plate make it a prime...
Mon ampli intégré acheté récemment Hybride Consonance a 120 Son tube Sovtek 6H30 HS au bout de 10 jours..étant en rupture de stock chez Audiophonics..J'ai commandé le Electro-Harmonix pour 10€ de plus..Mais quelle surprise..Je trouvais l'ampli pas assez chaleureux et légèrement remontant..Avec le Nouveau Tube EH..c'est superbe..chaleur..aigu à sa place..Médium fabuleux..
Frederic G.
Tube GZ 34
Remplace avantageusement une valvo
Frederic G.
Quad Tung sol
Tube tre musical ,un son détaillé et plus doux que mes précédents tubes nos S....
jevgenijs S.
FURUTECH FT-SDS (G) Power Plug Schuko Type F for Power Distributor Gold Plated This Schuko Furutech FT-SDS(G) sub-base is intended for installation in a power distributor. The high quality pure copper contacts with gold plating ensure excellent electrical...
significant change
SQ has significantly changed in comparison with an older wall socket. Base got deeper and mid top region got the second dimension. Fully satisfied with purchase. Big thanks to Vlad form Unison audio saloon in Riga Latvia for installing this socket!
Peter M.
PANGEA AC-14SE MKII Power Cable Triple Shielding Cardas Copper / OFC 3x2mm² 1m Based on a mix of sale strands and Litz wires, this cable is especially designed for your audio sources. The Pangea AC-14SE MKII cable is specially designed for source...
Solid Power Cord
I find this power cordHello,
I have replaced all my (common / freebie power cords that usually come with units) with Pangea (one by one).
I done it in several purchases (different lenghts).
I find this power cord(s) quite suitable for my stereo system, myself and my wallet.
(I have avrage components: Denon, Audio technica, Focal)
????I like:
well build construction
flexible cable (behind rack and furniture)
elegant connector in to audio unit (turntable, CD player, .. )
compact and bulky connector in to (wall socket, power strip, ..)
afordable price
nice looking design
It work nicely,
delivering electricity to units and protect from unwanted disturbances.
They serve me well and I am very happy with those.????
Of course, there are also others power cords on market if you desire:
better structure, better materials, better ... ,
... with better/higher price! ????
Francois g.
tres bons jumper
Ces jumpers ont remplacé du basic ohelbach avec bonheur. Cest cohérent, consistant, bref c'est bien mieux sans se ruiner.
Francois g.
pas facile a souder
Si vous dever souder un fil avec la tresse de protection, alors il faudra vous armer de patience car il ny a pas assez d'espace. Sinon pas de problème si on ne souder pas la tresse. Sur les Neutrik pas de soucis....
JEROME P.
DAYTON AUDIO DCS165-4 6-1/2" Classic Speaker Driver Subwoofer Kevlar 100W 4 Ohm 87dB 36Hz - 1100Hz Ø16.5cm This 16.5cm subwoofer speaker has a 36hz cutoff frequency. It allows the design of small subwoofers of quality and affordable. A simple amplifier in class D of 100W RMS RMS or 4...
Service client parfait
Commande livrée en 24 heures. Matériel conforme mais mal traité par le transporteur donc arrivé abimé.
Création du litige et renvoi du nouveau le jour même. Echange reçu sous 24h !
Bravo pour le service client. Au top!
Merci.
arnaud g.
bon matériel
FIni bien le cable zef speaker.
AUDIO-GD A-2 Headphone Amplifier Preamplifier Class A Discrete ACSS 2500mW The Audio-GD A-2 is a Class A headphone amplifier and preamplifier combo that takes advantage of totally discrete analog stages to offer a high quality sound reproduction that...
Casque mais aussi préamp ligne exceptionnel ...
Son chaud, beaucoup de matière et présence, belle transparance et définition, spatialisation 3D
Très surprenant pour le prix ... !
Je revends les autres pré achetés précédemment ...
Ils ne tiennent pas la comparaison ...
Me rapelle mon regretté Musical Fidelity F2, mais l'Audio GD va plus loin en terme de transparence, comme le F2, on penserait qu'il y a des tubes ... et bien non ... !!
Juan C.
FURUTECH FT-SWS-D NCF (R) Dual Power Plug Schuko Type F Rhodium Plated Copper NCF The Furutech FT-SWS-D NCF (R) is a dual wall socket with Schuko high-end connectors. Its high design quality allows it to provide an undegraded AC electrical signal that greatly...
La cerise sur le gateau
Je pensais avoir déjà atteins l'optimum sur mon installation. He bien cette prise Furutech m'a détrompé. Plus de diaphonie, un équilibre et une sérénité dans la reproduction incroyable. La musique apparait tout simplement naturelle et évidente. Je recommande.
Pascal A.
J'ai remplacé le cable bricomarché de mon enceinte centrale, pas ce cable. Les dialogues sont devenus d'un seul coup plus clair, et l'effet woofie de l'enceinte centrale à disparu. Surprenant à ce prix.
Harry H.
up occ copper cables
I ordered this cable after having very good results with the NEI 3004 interlink cable. I used for this cable the AECO pure copper RCA plugs.
I am curious what the NEMOI 3220 with AECO ARP-4045 RCA plugs will do in my setup. I will come back as soon as the interlink is ready and is listen at.
I have not been listening to it
Jean-Marie L.
pins trop fins
La matière employée est robuste (céramique) mais attention à ne pas la laisser tomber sur du carrelage, elle pourrait se casser comme du verre. Cela dit, on peut souder du câble sur les pins sans que tout ne se mette à fondre autour ... le problème est que les pins (broches) sont de diamètre # 1,75 mm, alors que les ceux des EL34 sont de # 2,30mm. Donc l'enfichage sur les embases de tubes de mon ampli à lampes est trop lâche et source de mauvais contacts (risque d'arcs). Il doit être possible de rattraper la différence en recouvrant les pins avec de la soudure, mais ce n'est qu'un pis-aller. Dommage ...
GONZALEZ POZO J.
Dinero recompensa de fidelidad no utilizada
Yo hice este pedido pero lo anule por falta de stock del producto. Utilice el dinero de la recompensa de fidelidad pero en realidad al anular el pedido no lo utilicé. Ahora voy a comprar y no veo este dinero. Por favor me gustaría recuperarlo para utilizarlo en la siguiente compra. Gracias
En rodage
Câble monté sur le hp du grave
Besoin de rodage mais prometteur
william l.
AUDIOPHONICS HPA-S600NC Power Amplifier Class D Stereo NCore NC500 2x600W 4 Ohm The HPA-S600NC is an impressive stereo amplifier. It is designed to meet power and precision requirements. Based on a duo of Hypex NCORE NC500 modules, this Class D amplifier...
Appareil reçu dans les temps dans un emballage sérieux.
Le boîtier et la connectique sont de qualité, l'éclairage du bouton marche/arrêt gagnerait à être plus discret.
Les performances de cet ampli sont impressionnantes, clarté et puissance sont au rendez-vous, pas le moindre souffle dans les hp et l'ampli ne chauffe pas.
Un grand merci à David et Grégory pour les conseils et leurs patiences face à toutes mes questions.
Leandros B.
Nice cable
Nice cable in a reasonable price
Leandros B.
A bargain
Probably one of the top vfm IEC
Leandros B.
NEOTECH STDCT-18 Hook-Up Wiring Multi-Strands UP-OCC PTFE 0.8mm² The STDCT cable wire is a very high quality multi-core cable with 99.99998% pure UP-OCC copper conductor and PTFE insulation. Ideal for efficient internal wiring.
Excellent cable
Crystal clear and punchy sound. I use it for connecting the PSU with the phono preamp of a Lehmann silver phono.
Morgane M.
DAYTON AUDIO HTA100BT Hybrid Tube Amplifier BT5.0 Phono 2x50W / 4 Ohm The HTA100BT stereo amplifier provides the roundness and richness of tube amplifiers while taking advantage of a completely up-to-date connection including no less than a...
Une belle surprise
J'ai beaucoup hésité à acheter cet ampli. Mon précédent appareil dont j'étais si satisfaite, je cherchait quelque chose de joli, qui sonne bien avec des connectiques diverses. Ce petit Dayton Audio cochait toutes les cases : design rétro comme j'aime avec le préampli à lampe, un encombrement optimal, une entrée phono, une optique, une RCA et une connexion Bluetooth. Tout cela pour moins de 300 euros… J'ai cherché des avis mais n'en ai trouvé que sur Amazon.uk et le produit n'était plus disponible. Les avis étaient plutôt positifs. Grâce au retour possible sous 14 jours du site Audiophonics, je me suis laissée tenter.
Le suspens était à son comble : 30 jours pour un réapprovisionnement de l'article mais le service client du site est actif et réactif, ce qui m'a rassurée.
Le colis arrive enfin en parfait état (merci au transporteur). Je l'ouvre : connectique anglaise ! Encore un peu d'attente pour le brancher avec un shuko.
Première écoute : plutôt pas mal pour le prix ! J'ai entendu mieux mais super dynamique sur les enceintes Sony vintage APM22ES. Des aigus plutôt clairs et timbrés. Il manque un peu de détail dans les médiums. Les basses sont rondes et dynamiques. La couleur est assez chaude grâce à la pré amplification à lampe. L'ensemble est vraiment bien pour ce prix et mon ensemble est un régal pour les yeux. Du coup, j'ai branché ma Technics MK2, ma box internet en optique (associée à mon vidéoprojecteur pour l'image, c'est du bonheur sans problème de latence), ma platine CD en RCA et le gros plus : la connexion Bluetooth est parfaite et Deezer sur mon téléphone tourne en continu avec un son assez bluffant.
Les petits bémols (oui, ii y en a mais ils sont anecdotiques) : Pas de télécommande : il ne faut pas avoir des problèmes de dos s'il est installé près du sol. Une fois le canal sélectionné, l'ampli se reconnecte au Bluetooth de l'appareil appairé systématiquement une fois donc il faut resélectionner le canal initial. Le sélecteur de canal sur la face avant est blanc froid alors que les lampes et les vu-mètres sont jaunes.
En conclusion : très belle surprise auditive et esthétique pour cet achat au prix raisonnable eu égard aux diverses connectiques et à la bonne qualité sonore.
Rachid C.
WONDOM JAB3+ AA-JA32173 Amplifier Module Class D Bluetooth 5.0 DSP ADAU1701 2x50W 4 Ohm The Wondom JAB3+ is an amplifier module capable of developing a power of 2x50W, supporting Bluetooth 5.0 (aptX HD) and integrating an ADAU1701 DSP for an all-in-one audio...
Trés agréablement surpris
Le rapport qualité prix est très intéressant. Acheté à l'origine pour un projet d'enceintes portable, je le trouve tellement bon que je l'utilise désormais à la maison. Couplé au module de programmation (ref AudioPhonics 15703) et au logiciel SigmaStudio, il est possible de faire des configuration spécifique pour chaque enceintes ou lieux d'écoute. Le kit de câble très complet qui va bien, référence Audiophonics 15065.
Rachid C.
Pour le prix, ce petit DAC remplis très bien sont rôle.
vincent M.
SHANLING M6 ULTRA Digital Audio Player DAP 4x AK4493SEQ Bluetooth 5.0 aptX HD LDAC WiFi 32bit 768kHz DSD512 MQA Black The long-awaited new version of the Shanling M6 Walkman, the M6 Ultra, is finally here, bringing not only an upgraded Android platform, but above all marking the return of AKM...
top
J’ai un peu d’expérience en casques / audio ayant démarré il y a plusieurs années avec un Grado PS 1000, puis focal, puis D8000 et maintenant un Meze Elite.
Donc reçu ce matin le M6 Ultra, un peu galère pour l’utilisation en mode DAC USB -il n’accepte pas la connexion directe en usb-c, et il y a de la latence entre le PC et le lecteur, mais rien de bien grave.
Mise à jour du firmware, installation de spotify, upload de flac et dsd et je troue la synergie franchement réussie entre le Meze et le Shanling (prise en 4.4mm). tout est vraiment bien détaillé, sans être analytique, bonne pèche sur tout le spectre, parfait pour mon écoute / musique électronique / rock / classique ou hard-rock.
Franchement pour le prix c’est un super lecteur portable, simple d’utilisation et bien fini mais qui peut (dans mon cas) remplacer un setup dédié de desktop.
Bertrand S.
FX-AUDIO 502E-L Class D Amplifier CS8673E Bluetooth 5.0 2x65W 4 Ohm Black The FX-Audio 502E-L offers an efficient, compact and low-cost amplification solution. Taking advantage of a high-efficiency Class D architecture, its amplifier stage uses a...
Compact et efficace, Bluetooth hs
Utilisé pour des enceintes de bureau faites maison pour alimenter des Hp de voiture de 40 w RMS montés dans des caisson. ca marche super bien câblé, Pour ce qui est du Bluetooth, impossible de le faire fonctionner.
l'appareil est détecté par mon téléphone mais impossible de l'appairer. il indiquent dans la notice une application pour le faire fonctionner mais qui est ecrite tout en Chinois et impossible de faire une traduction, amoins que vous sachier le parler et l'écrire, c'est inutilisable.
il est important de souligner la taille du produit sur le site, ou je m'atendait a beaucoup plus gros, a ma grande surprise il fait 10.5 cm par 9.5 cm sur 3 cm de hauteur.
Pour conclure, compact, efficace rendu du son ok, bluetooth ne fonctionnant pas. bien construit tout en métal.
rien a dire en cablé.
Laurent C.
Très bon mais pas parfait sur ma configuration
Ça fait des années que j'utilise des Qed signature revelation (très bon et pas agressifs malgré une pièce assez claire, un manque dans les infra graves) sur divers amplificateurs et des Focal aria926. Les atohm comblent ce manque avec des basses bien pleines et imposantes. J'ai écouté c 2 câbles en même temps un à droite un gauche.. c le top !!! Le qed apporte clarté et grande profondeur (ce qu'il manque un peu sur atohm) et lui le grave. J'ai plus qu'à trouver le câble qui m'apportera tout à la fois...
Jorge m.
Muy bien
He comprado esto desde España en dos días lo tenía en casa. El aparato funciona muy bien y es muy práctico lo de los dos interruptores
Pavel J.
SINGXER SA-1 Headphone Amplifier Preamplifier Class A Balanced The Singxer SA-1 is a high-performance, full-featured headphone amplifier and preamplifier based on Class A architecture and discrete, fully balanced circuitry. Completely...
Excellent discreet balanced amplifier in the price/performance ratio.
The SINGXER SA-1 is an excellent headphone amplifier and preamplifier for active speakers.
Its quality surpasses, for example, the cheaper Schiit Jotunheim 2 or MONOLITH THX AAA-887. If you want a better amp, go for more expensive ones like Burson Audio Soloist 3X Performance or HeadAmp GS-X Mini.
If you are going to use the SINGXER SA-1 in combination with a DAC, I recommend choosing one with enough power to drive the SINGXER SA-1 amplifier. I use it with the powerful RME ADI 2 DAC FS via balanced XLR cables and I am extremely satisfied. Other recommended DACs are Denafrips Ares II, GUSTARD X26 PRO.
I use HiFiMAN Ananda Stealth and HiFiMAN Sundara headphones. Other headphones I would highly recommend for this amp are the more expensive HiFiMAN Arya Stealth, Audeze LCD2 and LCD-X or Focal Clear Mg.
The sound of SINGXER SA-1 is very very clean (almost dead silent), detailed, smooth and warm with a lot of space, separation of instruments and soundstage.
I highly recommend this amp for purchase at a great price!!!
Rene C.
Best buy
Reasonable priced, high quality EMI filter
Rene C.
Best buy
I recommend the use of this cable in all solid installations, fx. inside wall sockets, to and from or inside power strips .......
Viorel S.
Station solder Blanko ZD-931
Come fate a dire che questa stazione saldante è una professionale? Io l'ho comprata qui da voi è non a neache un anno di vita è già non funziona più, le punte dopo 2 giorni di utilizzo, li devi buttare perché si consumano rapidamente. Una stazione pessima meglio la mia 100 volte che l'ho pagata 20 euro. I soldi adesso chi me li ridà? Ovviamente nessuno. Ma così fatte soltanto figuracce rispetto alla gente. Già siete poco seri ero un vostro cliente ho dovuto cambiare strada.
Iulian M.
Verry good opamps
Replaced the default JRC 5534 's in burson playmate 2.
Very good transparency.
Vivid's reveal rough edges in the audio setup so if you can't stand to listen with them then you have some more work to do on your setup.
Jose l.
plus de clarté
brancher sur l'alimentation indépendante de ma box, je vais en reprendre pour mes amplis.
Jürgen K.
Excellent!
The cable is really fabulous, hasn`t fully broken in yet, however the quality is already noticeable. Compred to Neotech NES 3002, which is not bad at all, I noticed clear superiority of RAMM in female vocal. Absolute clarity and no sizzle in "S". As well as bass is well defined, sharp and weighty. All in all a lot of value for money. Great PRAT, snappy, airy, detailed. Bravo!
Emmanuel A.
FIIO FD1 In-Ear Monitor IEM Beryllium Plated Dynamic Drivers With the FD1, Fiio offers high-quality in-ear headphones at a reduced price. They benefit from a careful design to offer a rich and immersive sound reproduction, as well as an...
Ecoute très agréable, équilibrée.
Tres confortable, avec un spectre étendu ( non mesuré ) qui semble préservé. Une belle dynamique.. Par rapport a d'autres marques pour ce meme budget, les graves descendent bien, les médiums ne débordent pas, et les aigus, voix, cymbales, sont claires et précis. L'essentiel est surtout d'offrir une belle musicalité.
Samuel B.
QULOOS QA690 FDA Power Amplifier 24bit 192khz 2x100W / 8 Ohm The Full Digital Amplifier FDA QULOOS QA690 is the worthy successor of the QLS QA-100, the first affordable FDA amplifier on the market that is unanimously acclaimed by its users.
1er FDA pour moi, donc la comparaison ne se fait qu'avec des amplis analogiques (NAD C 356, Hegel H 80 de mémoire) et il les surpasse aisément. Je le trouve excellent, son limpide, détaillé, et bien équilibré. Je sens aussi une grande réserve de puissance, ce que je cherchais (à 25 sur 78 très exactement, c'est déjà énorme pour ma pièce d'env 60m2, et je sens que l'on peut encore monter sans saturation/distorsion).
Très content!
nicolas s.
Excellent ampli FDA !!
Rapport qualité prix incroyable. Cet ampli procure vraiment du plaisir. Précis et suffisamment puissant pour une majorité des enceintes et pièces d'écoute. Je me permets de partager un test audio réaliste pour donner une idée du rendu, à écouter avec un casque ou écouteurs : https://youtu.be/jVVeyU2VsB0. Bonne écoute et merci à Audiophonics pour leur service et conseils.
Stephane N.
Utilisé pour la réalisation de câble XLR modulation, sans blindage extérieur supplémentaire, le rendu est excellent ( liaison ampli NCore et Dac Sabaj ).
Énormément de détails sur tout le spectre.
Vraiment un must.
Stephane N.
NEOTECH BRDCC-20 Braided Flat Wiring Cable UP-OCC Copper Litz Wire 20AWG 0.5mm² Neotech BRDCC wire is an excellent UP-OCC Copper solution. Professor Ohno's UP-OCC process is recognized in the manufacture of high quality HiFi cables. Cotton (70%) and...
Bonne idée mais…
Impossible pour moi d’insérer les câbles Neotech argent SOST 22 au delà de 5 cm.
Déçu.
