John T.
Brilliant device!
Siegfried F.
Ivan S.
IvanS
Customers reviews - There are 19264 reviews.
Arthur S.
Best amplifier I've had the pleasure of owning
This is Topping's statement amplifier as a response to the THX AAA amps like the 789 and the 887. On high gain, the A90 is as clean as those but more powerful. On low and medium gain, it is a lot cleaner than the THX ones, essentially beating the $3000 Benchmark HPA4. This is a BARGAIN. I also really like the smooth, big knob. It's perfect :)
About the sound. You can push any headphone without any distortion, especially the bass is really impressive. I use low gain for IEMs and low gain maxed, or medium gain, for dynamic and planar headphones. The sound is sublime, I can't fault it in any way.
Tech wise, it is based on a common texas instruments amplifier, but with composite feedback that essentially nullifies practically any and all distortion. It sounds simple but no one has achieved this performance so far, especially at this price.
Finally, it supports SE in SE out, SE in BAL out, BAL in SE out, BAL in BAL out. The power is internal, it has two separate power supplies for each channel, again really impressive considering the price point of this amplifier. This gives the unit some heft, as well as saving you from any bulky supplies in the power outlet.
sang c.
very good....
sang c.
very good.....
good service..
sang c.
very good.....
Bonjour, je cherchais une carte usb ou hdmi pour un pc daphile...... Le choix pour l'hdmi est limité à la Pink Faun qui n'était pas mon budget. J'ai donc commandé la Matrix. Installé sans problème. Allumé. Ecouté.
Grande différence avec le port usb de la carte mère, tout en finesse, les instruments bien à leurs places. Les graves ne coulent pas. J'ai l'impression d'avoir un nouveau dac bien superieur et je me demande comment j'ai pu m'en passer.
Du coup j'ai commandé un nouveau dac de la même marque.
Héee oui ça n'a s'arrête jamais.
Jérôme V.
Très bon câble, bien fabriqué, très souple vu son diamètre, les différents isolants sont très faciles à découper pour le montage sans couper celui d'en dessous. Si j'avais du budget, j'en reprendrai 50m pour toute la maison :D
Jérôme V.
Jérôme V.
Jérôme V.
Jean Michel P.
Excellente prise IEC
Raphael M.
compact et fonctionnel
André M.
Borniers WBT-0703Cu
Patrick L.
Bertrand B.
Super connecteur
Bertrand B.
WBT-0435 Crimping Tips for Cable 4mm² (x10) Crimping sleeves in 24k gold-plated OFC Copper, for 4mm² cable cross-section. These can be used to assemble up to two sets of cables or to replace a missing crimp.
Bon rapport qualité/prix
Les douilles sont de trés bonne qualité. La longueur est suffisante pour les connections. Le plaqué or ne s'effeuille pas.
Bertrand B.
Pendant le sertissage, il se peut que le plaqué s'effeuille. Les WBT-0435 sont meilleurs, mais coûtent plus du double.
Bertrand B.
Parfait rapport qualité/prix
Il faut faire attention au point de vu effilochage. Je confirme la remarque: En fonction du diamètre du câble, la longueur de la gaine peut réduire jusqu'à 20%. D'abord enfiler le cable dans la gaine et ensuite couper à la longueur. Je l'ai utilisé pour du ELECAUDIO CS-331B. La gaine fait bel effet.
Emmanuel l.
bon cable
bon câble de modulation j'ai enlever une étoile car les fiche rca sont a mon goût trop serre dur a retirer si non il y a une net amélioration par rapport a des câbles amazon basics le petit plus les fiches rca sont démontable
Espen K.
Very happy with the quality and features of the DAC/amp
The unit feels solid and it has rubber feet so it won't be "dragged" by heavy cables. I use mine connected to my computer via USB and Chromecast Audio via optical. Sometimes I use my phone over bluetooh, but I can cast music to he GCA instead of that usually. On the outputs I have my stereo amp connected to the XLR outputs and my HD600 connected to the 1/4" connector in the front.
Not about the remote; the included remote is made of plastic and says "TOPPING RC-15A" on the bottom. It is slightly longer than, but with the same button layout as, the aluminium Topping remote sold on this site.
You can not use the remote as much of an angle. I have not tested how far the remote works, but it seems to be fine if you use it "normally" and not at an angle like I have it placed (my room is small and combines desktop for computer, a stereo and bedroom).
There are several output modes to choose from. I only used the remote and not the volume wheel to select modes.
To choose headphones out you press the "headphone" icon. To choose the outputs on the back you press "Line Out". There are three combinations for output on the back; XLR, RCA or XLR+RCA. To cycle trough them you press "Line Out" to get the desired option. To combine headphones and output on the back you press the middle button with no icon.
For each of the modes you choose (headphones, output in the back or headphones + output in the back) there are separate volumes. I have the headphones set to a comfortable volume, but my XLR only output is set to 0.0 as my stereo amp has it's own volume control. Having separate volume for each mode is amazing and it makes it seamless to switch between them all.
All in all I am very happy with the product. I also want to say I am very happy with Audiophonics. It is the first time I bought from them. I had a question about VAT before I made my order, and the response was fast and clear. When I made the order it did not take long for the order to be processed and the day after it was shipped. The shipping time was very long (a little over a month), but I blame the Norwegian postal service and not Audiophonics or the France postal service. The package tracking said it was sent from France the 30th of April, and it was not registered in Norway until 28th of May. I am sure they have kept it in the backlog in customs for all that time.
alexandre d.
super boitier mais application pas au point
le boitier est plutôt bien fini, tous les câbles nécessaires sont présent. Enfin presque, le boitier d'alimentation n'est pas en norme française, impossible à brancher... j'ai utilisé un vieux chargeur de téléphone. Ensuite l'application iwoofer nécessaire pour le faire fonctionner plante sur mon téléphone android. Étrange, avec une vieille tablette tout va bien. niveau utilisation, quelques beug sont présent sur l'application. Elle semble plutôt optimisée pour un iphone visiblement. Et c'est dommage car les corrections qu'on peut apporter sont très efficaces. J'ai utilisé le logiciel rew avec un micro calibré et j'ai réussi à parfaitement lisser la courbe de mon gros caisson focal. On peut enregistrer plusieurs courbes et les charger rapidement. J'essayerai à l'occasion de l'utiliser avec un iphone pour voir si c'est mieux ou pas.
Pierre B.
Tube pour ampli casque
J'ai acheté ces tubes pour remplacer un tube 6N3J d'un ampli casque. Heureusement qu'il y en avais deux, car avec un des des tubes il y a un ronflement très important sur la voie gauche.
Envoyé info au SAV, pas de réponse !
Theo V.
Good and affordable but electric not OK.
A good and affordable amplifier in combination with an Rpi HifiBerry DAC RCA+ combination in the garage. No opponent for my old Onkyo Integra A8800 and Infinity RS4003 speakers.
Unfortunate is the amplifier delivered with an C13/Nema 14/1 cord and not an C13/CEE 7/7. C13 (Kl I single insulated) isn't according with Nema 14/1 (Kl II or double insulated). The Power supply has an IEC14 inlet and need an earth.
The photo show an KL II power supply with C8 inlet. Then is an CEE7/16 to C7 cord needed.
plus un avis qu une critique .
à 3 euros le mètre ce câble réunit beaucoups de qualitées , les différents avis sont justes il degraisse beaucoup surement dû à sa section ? mais dans mon cas celà aura été sa force , du coup les voix en pâtissent aussi et ont moins de poids ( dans mes conditions d écoute bien sur ) c est mon seul regret .
pour le reste il est très transparent , extrêmement rapide , avec un medium très limpide .
je possède comme beaucoup plusieurs câbles à x dizaines d euros qui ne souffrent pas la comparaison .
la preuve est faîte qu un bon câble reste basique dans sa conception . le reste n est que du vent .
à tester d urgence !
Laurent M.
Étonnant
A 13 euros le mètre avec des fiches d'entrée de gamme de chez Audiophonics .
Ce câble peut vous éviter un changement de source tant il est équilibré.
Quel confort de pouvoir monter le volume sans aigus tranchants et médiums " gueulards " .
C'est une philosophie bien opposée aux câbles chers , spectaculaires et agressifs .
Laurent M.
Branché avec de simples rca neutrik de base le son est très doux , pas de medium projeté .
C'est ce que je recherchais.
Dans l'absolu l'écoute est bien moins fatiguante que les câbles "commerciaux" plus ou moins haut de gamme que j'ai pu tester .
Par contre j'ai préféré souder la tresse de blindage des 2 côtés .
Ross B.
Beauty and the Beast
The Master 19 is a real beast of a headphone amplifier but the sound it delivers is beautiful. The design of the power supplies, buffers, discrete amplification stages and, last but not least, the wonderful volume control are truly impressive. The overall build quality and selection of premium components is first class. I see no reason why it wouldn’t be an excellent preamplifier too.
It drives my HiFiman HE 1000v2 headphones with plenty of gain to share. The sound quality is breathtaking and is both neutral and natural. Bass is dynamic, strong and with very good tone colours. Mids and the top end are full of detail, texture, micro dynamic timing and spatial information and air set against a jet black background but are never overly aggressive. Every bit of dynamic, textural, tonal and timing information is laid bare but pulled together in such a way that it all fits together into a well integrated musical whole that just makes you listen to more and more music. No matter if you are into the intellectual beauty of chamber music, the full grandeur of romantic symphonies, the wonder of Ella Fitzgerald’s vocals our you just want to bath yourself in the despair of Black Sabbath, this is the headphone amplifier for you.
Carlos J.
Tomaž F.
Good
stuff
Anders L.
ALPS 50KA2 Stereo Potentiometer High Quality 50kΩ The ALPS 50KA2 is a high quality stereo potentiometer with a resistance of 50kΩ and a logarithmic progression curve. Its smooth shaft has a diameter of Ø6mm and a length of 25mm.
King of pots
This is the king of volume pots. The first option, if it fits.
Silvio L.
iBasso IT04
J'ai associé ces écouteurs au lecteur iBasso DX220.
Tous mes fichiers sont au format ALAC.
Mes genres musicaux vont du classique au rock en passant par la chanson française.
Je peux vous assurer que tout le spectre
est reproduit de manière claire est précise.
C'est en tous points parfait !
Alain V.
Mundorf caps
Excellent quality - good prices and reasonably fast delivery during Corona times...
Alexandros M.
Improved sound by reducing noise.
I was having issues with noise coming from the USB when I was connecting my ifi zen DACto my gaming desktop. As soon as I connected the external power supply from ifi, the noise was almost reduced to zero (I still hear some noise but I believe is from the non balanced output and I am waiting for balanced cables to test this theory). Having said all the above, the external power supply offers the best choice of separating power and audio input to my ifi zen DAC. However, it depends how much you value noise reduction, if you think your sound is already great I do not think buying this will improve the performance of the DAC in terms of power but improve the sound quality because of the reduction in noise.
Joost B.
A mirracle
Moneywise this is the best purchase I have ever done in my entire 40 years as an audio connaisseur. Incredible sturdy product with high end quality components. Sound is excellent, on par with a Chord Hugo 2 I had in my system (Avalon speakers, Densen amplifiers). Sound is very analogue and natural. This DAC is insanely good for the money! Excellent service of Audiophonics, speedy delivery within 5 days to the Netherlands.
Perttu-juhani H.
Good for Money
Good amp. Swapped the opamps to OPA2134.
The original opamps are probably fake. At least they look
different from real Texas Instruments NE5532
(the logo is smaller).
Tom B.
Semble très correct
Ce dac semble très bien, la conception fait robuste et le son très bon (c'est mon premier je ne saurais pas donner d'avis avancé). Le fait d'avoir une télécommande est relativement inutile pour ma propre utilisation mais ça peut servir pour d'autres.
Par contre un problème selon moi, tout le packaging, y compris la notice est celui du sanskrit MkI et pas celui du MkIi, je suppose que ça réduisait les frais de faire ça. Mais du coup il n'y a pas la moindre façon de vérifier qu'on nous a vendu la bonne version! (Je pourrais le démonter pour vérifier la puce mais la garantie serait annulée...). Je fais confiance à audiophonics pour vérifier ses produits mais c'est tout de même inquiétant.
Jean-Michel G.
bornier
très bon produit, rien à redire.
Jean-Pierre L.
Très bonne conductibilité, serrage par vis plaquées, donc finition parfaite. Je m'en suis servi non pour fixer les câbles HP, mais pour introduire et tenir les fiches bananes d'un câble de grande qualité. Tenue parfaite et résultat tout à fait audible. Je recommande...
Jean-Pierre L.
Bonne tenue et conductibilité parfaite
Daniel D.
cable HP elecaudio HP 250 occ,ofc
Possesseur d'un système THDG à plusieurs dizaines de milliers d'euros acheté patiemment d'occasion, je fonctionnais jusqu'à présent avec des cables HP supermaxitrans (+ esprit Lumina et MPC Abyss evo en modulation).
Avec mon équipement mes grosses Thiel CS 3.7 chantent parfaitement sauf que je cherche à gonfler légèrement les basses car pas assez profondes à mon gout (sans me ruiner pour autant car la hifi ça coute cher et dans les câbles c'est la jungle).
J'ai essayé le cable HP Mogami 3103 réputé un poil sombre auquel je reconnais certaines qualités dans les graves malheureusement les extinctions de notes sur les cymbales et les cordes sont inexistantes, peu être dû à un manque de transparence. Tezl quel ça ne matche pas
Je viens d'essayer les Elecaudio 250 OCC. Non rodé ils ne semble pour l'instant pas répondre à mes attentes spécifiques dans les basses (peut-être que cela va venir). Par contre il est absolument indéniable qu'au tarif proposé ces câbles sont particulièrement performants, une tuerie comme disent les jeunes.
En fait pour moi, et sur mon équipemen,t ils sont actuellement au même niveau que les supermaxitrans pour un tarif dérisoire (merci audiophonics de marger avec modestie et dans le respect de la clientèle).
Beauté des timbres, extinctions de notes, largeur et profondeurs de scène, rapidité et aussi très grande transparence, tout y est. Pour ceux qui hésite je confirme les très, très grandes qualité du produit au regard du tarif et ne comprends pas les 1 ou 2 commentaires indiquants que le son pouvait être bouché (peut-être diamètre de câble trop gros sur des enceinte bibliothèques).
Je vais faire encore tourner tout ça et m'orienter sur des athom zef max ou du DIY si je n'arrive pas à mes fins.
François M.
Simple et efficace
Etant novice en matière de DSP j'ai acquis ce minidsp pour apprendre et me faire la main.
J'ai été rassuré par la simplicité de son plugin ainsi que son efficacité.
Je ne l'ai utilisé dans un premier temps que comme filtre afin d'intégrer le mieux possible un vieux, mais excellent caisson KLIPSCH SW12 II, au sein d'une paire de KLIPSCH HERESY III.
Je suis très satisfait du résultat.
Je verrai ultérieurement pour utiliser la partie égalisateur de ce minidsp.
Sa performance tient en partie à son traitement exclusivement numérique.
Pas de double conversion ADC et DAC dégradant inévitablement le signal traité.
Kostas K.
DIY Box
Very good. From packaging one allen screw was missing from the front.
Vincent b.
excellent lecteur
j'ai comparé ce lecteur à un ensemble lecteur + dac 20 fois plus onéreux mais plus ancien et force de constater que le gap
n'est pas énorme : le tempo a une qualité rare de rendre jusqu'a l'infra grave bien défini et de ne mettre aucune partie du spectre sonore en avant (du coup j'ai réalisé que le manque de grave ne venait pas des enceintes) et que certain dac externe priorise le medium sur le reste
Henrik K.
Excellent cable at bargain price
I made two 1m rca cables , using this one and Elecaudio RC-602 rca connectors . From cd to preamp and from preamp to power amp - Rotel RTC-940AX , Rotel-RB970BX . So 40€ for 2 pairs of excellent cables ! You just can't beat this ! Well , maybe Sommercable Carbocab ? That's what I'll try next...
Henrik K.
Cheap but effective
They might look like door stoppers , they might need some excessive rubber trimmed , but they do their job perfectly . I put the under my vintage Rotel RCD-945AX CD player . Instead of using screws , I glued them with silicone . Highly recommended !
Christian A.
Amazing performance - great match with tubes
I ordered this device based on the good reviews on linearity and the ability to provide power across the impedance range of a loudspeaker (also difficult loads). I always felt that this could be a limiting factor to my KEF LS50 loudspeakers.
Transparency and punch are just amazing. It outperformed a number of A/B Class amps with ease, even devices which cost 2-5 times more. What I particularly like is the (perceived) linearity and clarity. I sometimes felt that matching a preamp with an amp is a bit of a gamble, very much depending on the specific character of each device. With the MPA-S125NC I just stopped worrying about that as I think that it's so revealing and neutral.
I can now fully focus on tube rolling with my Schiit Freya preamp without the fear that what I hear will be a mix of factors. It´s amazing how the amp is able to reveal (yes again) even the slightest difference in a tube or source quality. Holography of tubes is directly transformed into the listening room now.
On the downside, the box seems sturdy, but the front panel paint easily gets wiped off (be careful when cleaning). The form factor is a bit strange - but works well for me. Clarity can be a big plus, but you might want to feel the urge to upgrade other parts of the chain soon though, this little box is able to unsurface weaknesses ;)
Strong recommendation! Especially the combination with KEF LS50 and the Schiit Freys Preamp in my case. Love it!
Dirck C.
Carte livrée en 48h, bien emballée. Ça change l’approche de la hi-fi que j’avais pour le moment ... là je retrouve vraiment une super qualité de son. Sur volumio impossible de trouver le bon driver, du coup j’ai testé avec moode et là tout fonctionne parfaitement le tout avec une tite appli iPhone et c’est parfait ou même par le navigateur de la TV ... très bon achat. Pour 80€ on peut se faire une solution au résultat très honorable !!!
Sous volumio vous pouvez utiliser tout driver générique (RPI DAC, ES9023, Hifiberry DAC etc...) Moode est un bon choix et est sensiblement plus stable.
philippe C.
L'incarnation du tube.
Ce module intelligent permet de changer la sonorité du DX220 selon le domaine musical à reproduire.
Il a la fluidité et l'incarnation du tube. Le son est encore plus analogique.
Un peu...( je dis bien : un peu) plus rond et analogique que le module d'origine du DX qui est très neutre et de référence.
Il est hélas aussi assez énergivore pour la batterie.
philippe C.
XDUOO X-SK1 Adhesive Pad for Mobile Devices The xDuoo X-SK1 is an extremely useful adhesive pad for combining two mobile devices such as a headphone amplifier and DAP for example, and therefore limiting the space required.
Pour associer deux appareils nomades sans les abîmer.
C'est intelligent comme un poulpe de poche...
philippe C.
XDUOO X20 DAP Digital Hifi Music Player DAC ES9018K2M 32bit 384kHz DSD256 Bluetooth aptX xDuoo comes back with a new DAP, the X20. It offers particularly comprehensive functionality and quality-based component design for excellent audio reproduction. On the program,...
C'est un fidèle Ami de musique
Ce petit DAP est très facile à vivre.
La musique qu'il délivre est puissante, linéaire, plutôt neutre, et soyeuse. Il a le registre grave magnifique et tendu qui semble être la signature de la marque et il place une scène sonore dense sous un éclairage aux teintes chaudes, lisses mais texturées. Très belle musique: incarnée. Il permet des écoutes longues et sans fatigue, dénuées d'artefacts numériques.
Chez XDUOO on semble proche des mondes de la musique pro: on reste neutre, concentré et on ne cherche pas à enjoliver les choses.
Le son est surpuissant quand il le faut ...et acoustique et neutre quand cela l'exige.
Il mérite un très bon casque.
Son utilisation est aisée, son association avec ses camarades de jeu est fluides. Il télécharge sur OS sans soucis et se manipule au doigt et à l'oeil par petites touches car il n'a pas d'écran tactile.
Il est magnifiquement sobre construit pour durer avec une batterie suffisamment puissante.
J'aime beaucoup cet appareil et il est devenu un fidèle ami de balades.
philippe C.
Un vrai "baroudeur"
La sonorité que délivre ce petit amplificateur est dense, faite de plénitude, de matière, avec des teintes chaudes et fauves jamais fatiguantes même en écoute prolongée.
Le médium est charnu, doux et varié. Les aigus n'en font jamais trop et restent bien intégrés à la façon d'un "Large bande". Avec lui la musique est retransmise avec neutralité sans accident. Il reste assez droit et énergique et ne cherche jamais à être surdéfini.
Le registre grave est absolument magnifique. On n'attend pas d'un si petit objet autant de grandeur dans le bas et le milieu de l'espace sonore. Quelle santé ! Quel coffre ! C'est grandiose, sombre à souhait quand il le faut et plein de saveurs. Il ne recule pas devant une cathédrale de sons énorme et sait donner des couleurs à un quatuor à cordes.
Avec lui, la musique a quelque chose de soyeux, de très séduisant et d'élégant parce qu'elle semble provenir d'un objet d'où l'électronique et le numérique sont absents.
Le mariage sans fil ou Bluetooth avec ses petits camarades se fait le plus simplement du monde et reste extrêmement stable.
Son format et son ergonomie sont proches de l'idéal pour la hifi nomade. Il est taillé pour l'aventure...
Formidable !!
