Ludovic P.
Efficace mais manque un interrupteur on/off
Utilisé entre une alimentation linéaire 5v Audiophonics et un Ifi Audio LAN ipurifier pro, ce filtre améliore sensiblement la...
Eric E.
Remarquable !
La neutralité et la transparence sautent tout de suite aux oreilles. Le son est limpide et détaillé, les plans sonores sont...
David D.
Ampoules led bleu
J'ai bien reçu mes ampoules led bleu pour mon tuner Pioneer , elles sont bien compatibles parfait pour moi merci
Customers reviews - There are 19579 reviews.
John Kenneth W.
Pi Power Management Module PI-SPC V2
It's not clear from the add, but this is not a purely electro-mechanical solution and requires scripts to be loaded and config file edits on your SBC before it will work.
The scripts and edit instructions provided by support, were not compatible with my Pi4B/MoOde 6.5.2 combination, so I could not get the unit to function at all and I gave up on it in the end.
Hi,
It's pretty clear for us and every other customers who have bought this solution has a stand alone product or as a feature on our DACs
ex : "The functions of this card are natively supported by the following software solutions: DietPi, Max2Play, piCorePlayer."
"function available without script"
"Installing the script"
"You will find on our forum the indications concerning the manual installation of the script on our forum:" etc ...
you have total right to doesnt read a product page but please dont blame us for that.
Best regards
John Kenneth W.
TOPPING D90 Balanced DAC AK4499 XMOS XU208 I2S 32bit 768kHz DSD512 Bluetooth 5.0 Silver A direct successor to the D70 Topping, the D90 benefits from the same refinements as its big brother while updating its DAC with a newer and more efficient version, the AK4499...
Topping D90 Review
Excellent sounding DAC with plenty of input options.
Lots of detail coming out of a jet Black background.
LAURENT L.
Parfait pour le quotidien
A ce prix à il est impossible d'avoir mieux, livré en plus avec tous les adaptateurs nécessaires. Parfait pour le quotidien !
LAURENT L.
INTENSO Memory Card Micro SDXC Class 10 64Gb This Micro SD memory card has a storage capacity of 64GB. An essential memory card to accompany and provide storage space at your SBC such as a Raspberry Pi or Allo Sparky. Of...
Fonctionnement un peu aléatoire
Bon produit mais régulièrement lorsqu'on le met dans le baladeur HIDIZS AP80 acheté en même temps, la carte n'est plus reconnue ou il est demandé de la reformater (ce qui st très ennuyeux).
LAURENT L.
HIDIZS AP80 DAP HiFi DAC ES9218P 32Bit/384kHz DSD Bluetooth aptX Gray With its AP80, Hidizs offers a DAP in a really small format to accompany you throughout your day, while ensuring excellent audio performance. Indeed, the portable player...
Superbe rapport qualité / prix
Excellent appareil, compact, très belle qualité sonore, un rapport qualité prix exceptionnel !
Boitier alu DIY
Bon boitier, robuste, spacieux.
Adapaté pour plusieurs projets DIY : double Mono, TPA32XX , IRS2092, etc... on peut tout loger dedans )
Burson V5i
Bons OP Amps... mais franchement, les OPA1656 font mieux et valent 4X moins chers ! Certes, les OPA1656 sont introubales en DIP8 mais avec une petit adaptateur le tour est joué )
PSU 36V / 6A
Fonctionne à merveille avec un TPA3251. Mesurée exactement à 35V / 6A au Multimètre. Elle est de bonne facture.
marc V.
bande passante étendue, dynamique correcte et stabilité intéressante du grave à l'aigu, il a bien magnifié un lecteur CD et un lecteur réseau, c'est un excellent rapport qualité qui prix mérite largement son qobuzissime.
Un audiophile de 50-60ans qui améliore depuis 25 ans son système en fonction des opportunités avec un petit budget.
Emmanuel S.
Impressionant
J'ai eu des amplis de classe A, de classe AB, à lampes, à transistors, à 500 euros, à 3000 euros.
Pour ne pas mourir idiot je me suis dit qu'il fallait que je teste un classe D. Après recherche je me suis dirigé vers celui-ci, les modules ncore semblants être parmi les plus réputés, en me disant qu'au pire il fera power pour mes arrières s'il est moyen.
Que dire... J'ai été bluffé !
Il se retrouve à amplifier des klipsh Cornwall depuis un an, et pas de changite en vue.
Les écoutes sont très naturelles, transparentes, avec des basses bien péchue et profondes, pas trainantes. Les aigus sont détaillés mais pas agressifs. Très équilibré, exactement ce que je demande à un ampli. Neutralité, transparence, pêche.
En plus c'est minuscule, ça ne prend pas de place, royal.
Du top, ne vous fiez pas au prix.
Pour du HR ça va impeccable, pour du rendement plus faible prenez la puissance supérieure si vous aimez les écoutes musclées.
Je recommande chaudement.
William H.
Bill
Waited 2 weeks to be in stock, took 3 weeks to deliver.
I wanted to check out company and products.
Amp is first rate. You get what you pay for!
Very happy with it!
Jean-Joseph R.
Très propre !
Après avoir lu les commentaires enthousiastes des précédents acheteurs au sujet de ce DAC et, surtout, les mots particulièrement enjoués du test Qobuz dau sujet de la V1, je me suis décidé à tenter l'expérience. En un mot : admirable.
J'arrive d'un FXAUDIO FX01. Pour son prix, ce dac minimaliste présentait déjà des qualités très intéressantes.
Avec ce SMSL, on ne joue plus dans la même cour : image stéréo élargie, précision des timbres, séparation des instruments, basses "mieux" présentes, plus définies, globalement, grande richesse de proposition sonore.
( sur Arcam + B&w)
stéphane P.
Très bon résultat
Avec une alimentation (exemple smsl pour AD18 24V 5A) cela donne un petit ampli de 50 W pour 8 Ohms ectrement logeable et pour moins de 50€.
Chez moi, il alimente de bonnes vieilles JBL L50 sans aucun problème. Parfait !
Gérard B.
erreur de livraison. Après réclamation, j'ai reçu les bonnes pièces. Merci Audiophonics
Lucijan B.
Excellent heart of a system
The DX7 Pro combined my speakers and headphones with my PC (toslink), laptop (usb), TV ( added a toslink to coax adapter and then coax on DX7Pro) and phone (BT) effortlessly. The build quality and sound quality are amazing! Such a complete little device. The headphone amp section is driving my HD650 with a bit more volume to spare, it's less powerful than some amps but it gets loud enough. XLR out for my speakers is whisper quiet unlike my past sources RCA.
Very satisfied with my purchase at Audiophonics!
Pierre-Marin L.
Mieux que mon cable Atohm
Moins de coloration, plus de détails, d'équilibre et de transparence. Ce cable apporte un bon changement à mon système : plus de naturel !
Helge V.
Amplifier Soft start
Have traded two soft starts of this type in the past and are very pleased. These last two that are in order have been delayed in the mail because of the pandemic we are struggling with in the global community for the time being. But they will probably hold the same standard as I do. Can be recomended.
Frank S.
AUDIOPHONICS TPA-M50 Class D Mono AmplifierTPA3116 1x60W 4 Ohm Black The Audiophonics TPA-M50 is a compact amplifier with a low price but very good sound performance. The TPA-M50 is based on an amplification chip TI TPA3116D2 capable of...
Bon produit, conforme à la description
Léger bruit résiduel en absence de signal à l'entrée surement lié à la classe D de l'ampli.
Dommage que l'alimentation 230AC/24DC ne soit pas livrée avec (frais de port doublés si oubli) et que le bloc recommandé soit si imposant (bien plus volumineux que l'ampli car pouvant délivrer 6A alors que 3A seraient peut-être suffisants).
MATTHIEU F.
EXCEPTIONNEL
Tout simplement le meilleur câble que j'ai eu.
Naturel, aucune mise en avant d'un registre plutôt qu'un autre.
Beaucoup de transparence, la musique nous parvient avec facilité.
AUCUNE agressivité, la musique coule de source, ENFIN.... :)
MATTHIEU F.
Trés bon rapport Qualité / Prix / Performances
Aprés une petite période de rodage, et quelques heures d'écoutes, je suis entièrement satisfait de ce DAC abordable.
Trés belle scène sonore, résolution en hausse (par rapport à mon lecteur CD), et en fait, le plus important à mes yeux il sonne naturel et musical !!!
Un soupçon de chaleur qui profite aux voix et aux timbres, un peu plus froid via USB cependant.
Robert G.
Très bien pour le prix
Pour information fonctionne aussi avec les Raspberry 2b
Patrick s.
Très satisfait à tous points de vue (produit, service).
Pour le prix, c'est un très bon appareil. Je n'ai pas encore testé le changement d'AOP (pour du Sparkos) et reviendrais donc sur ce sujet.
Pour l'instant, une certaine "aggression" dans le haut medium est perceptible, ce qui, je l'espère, sera réglé avec le changement d'AOP.
Entretemps, j'ai cherché à comprendre le rôle de chacun des filtres dispos. Echec:
En effet, le vocabulaire employé dans l'article recommandé à la lecture par Audiophonics ne correspond pas au vocabulaire qui apparaît sur l'écran du DAC. Une correspondance des effets n'est alors pas possible.
Une aide est elle possible?
Merci d'avance.
Stefanos S.
Neotech NEP-3001iii powercord
I order the cable and after few days arrived in my house.
Very nice package, Audiophonics well done!!
I terminated the cable with connectors from IeGo 8055 pure copper,
In a system that is correct set up, the cable offer dynamic, powerful sound and good resolution.
Is the best value for money cable.
Peter P.
Stereo cable 3,5mm
...perfectly match with trigger 12V 230V...
Peter P.
Trigger 12V 230V
...it does its job perfectly...
Karl R.
Flexible, high-performance with minor usability annoyances
I do not have the equipment to measure the performance so I'm gonna refer to AudioScienceReview for that:
https://www.audiosciencereview.com/forum/index.php?threads/review-and-measurements-of-topping-dx3pro-dac-and-headphone-amp.4967/
Summarizing the performance: it has great performance, as good as many units at 2-3x the price.
Things I noticed about the sound:
1. Noise is waaay lower. Quiet sounds are much easier to hear.
2. A slight shift in frequency response which I assume is down to by previous (integrated) hardware having high resistance (while Dx3 Pro has 1Ohm, which is excellent).
3. Noise from the PC is mostly gone. Previously I could hear faint noise when moving my mouse. That is no longer the case. I can still hear noise when pushing my PC hard, playing games, but I'm not sure if that's due to my motherboard having poor isolation. And this noise can only be heard in headphones, not through my speakers (Line Out in DAC-only mode).
Finally, my main gripes:
1. The volume knob is nice and clicky but can sometimes skip back the other direction at a slight touch; it's not as precise as I would have liked.
2. Even when setting Line Out as DAC-only in the settings it will use the Amp when you have Headphones AND Line Out active at the same time.
Overall a great piece of hardware with minor issues. Highly recommended.
alexandre s.
Et la musique prend place !
Je l'utilise depuis une dizaine de jour, ce dernier ne doit pas être encore tout a fait roder.
J'ai testé plusieurs câble RCA et jusqu'a présent c'est le meilleur!!!!
Ce qui saute vraiment aux oreilles et j'insiste énormément sur ce fait, sont avant tout la qualité naturel des instruments et le du timbre.
Du grains, belle spatialisation et un jolie médium.
Je dirai aussi que c'est un cable doux et chaleureux, je peux écouter plusieurs morceaux différents sans aucune brillance et pourtant j'ai des tweeter à ruban.
Tout est bien distingué !!!
Si il y aurait une phrase à dire je dirai que la musique sonne vrai et juste !!!!!!
alexandre s.
Cela apporte de suite de meilleurs basses, avec une meilleure résolution donc plus de petits détails.
La spécialisation est aussi améliorée, mes Monitor Audio Gold 100 sont plus libérées .
Ils seraient dommage de s'en passer vu le prix
Pour le prix il serait dommage de s'en privé !!!
Barrette secteur
Je me suis confectionné une barrette secteur avec 8 embases ABL câblées en étoile avec ce câble OCC: https://www.audiophonics.fr/fr/fils-de-cablage/elecaudio-fc125tc-fil-de-cablage-cuivre-occ-fep-25mm-rouge-p-6273.html, sur une embase IEC :https://www.audiophonics.fr/fr/fiches-secteur-connecteurs-iec/viborg-vi-06bc-embase-iec-c14-cuivre-pur-red-copper-o6mm-p-12745.html
celle ci raccordée a la prise murale : https://www.audiophonics.fr/fr/fiches-secteur-embases-schuko/furutech-fi-e30-ncf-r-embase-schuko-cuivre-pur-plaque-rhodium-p-11336.html
par un cable secteur : https://www.audiophonics.fr/fr/kits-cables-secteur/kit-cable-diy-elecaudio-secteur-ofc-3x35mm-c7-15m-p-10925.html
j'ai gagné en tout points, bande passante + large, scène sonore élargie, définition accrue, présence des musiciens dans mon salon. Je ne sais pas si cela vient du câblage, des embases ou du câble secteur, mais je recommande vivement, l'apport d'une barrette secteur de qualité apporte vraiment un plus. Merci à Audiophonics de nous proposer ces produits de très grande qualité pour un tarif très très raisonnable.
Gilles G.
AUDIOPHONICS DIGITAL AUDIO Male USB-A to Male USB-B Cable 4N OFC Copper PTFE 0.5m The Audiophonics Digital Audio USB cable is a digital cable developed by the Audiophonics team and assembled in our workshops. The objective is to obtain a high level USB cable,...
Découverte de l'importance de la qualité du câble USB à l'écoute.
Avant que de commander ce câble USB Audiphonics, j'ai lu pas mal d'avis sur l'efficacité de câbles de bonne qualité sur le son. En fait j'étais perplexe et le suis resté jusqu'à ce que je remplace le câble USB d'origine de mon combo DAC/AMP Audio GD NFB 1138 Performance. le plaisir Audiophile pourrait être décrit en comparant une boisson acide au citron avec la même dans laquelle on aurait ajouté du miel et du rum. Depuis j'attends que le câble secteur Pangéa AC14 SE MK2 soit à nouveau en stock chez Audiophonics et je change celui d'origine sans hésitation. Bravo Audiophonics, cohérence de la qualité sonore audiophile dans tous les éléments de la chaîne sonore.
Benjamin H.
Top end device
This device is something special and sounds great! Excellent build quality and hefty weight makes it feel every bit as high-end as its sound performance. The price is up there but as far as I'm concerned this might very well be the last DAC I'll own. Using XLR connections to squeeze every bit of performance out of it. Built-in volume control is a bit finicky. Topping drivers enable Windows Volume control in both ASIO- and WASAPI-mode. I Hope this review and the many others on the Internet help you in your purchasing decision :-)
Gilles G.
Audio GD NFB 1138 Performance Edition
Avant de commander ce combo, je me suis documenté pendant deux mois. J'ai abouti à une "short list" de 10 appareils, et c'est là que David d'Audiophonics m'a considérablement aidé à faire le choix définitif.
Ce combo a un prix qui pourrait aisément être au double sinon au triple si l'on fait un comparatif avec le matériels existants du marché ainsi qu'un bilan performances/prix.
J'ai perso un casque Grado PS500e, 32 Ohms qui détaille la musique, large bande 19htz/29 Khz, scène sonore très large et précise. Je voulais un dAC au top et un ampli digne de ce nom pour ne rien perdre des qualités de mon casque. Je suis comblé, je ne m'attendais pas à une écoute aussi performante, détaillée et coulante à la fois. Quant au préampli, je le pousse en général au quart de ses possibilités et ça cartonne ! Si vous privilégiez l'écoute à l'esthétique, foncez, vous ne le regretterez pas. Livraison en 3 jours parfaitement protégé. Que désirer de plus ?
Michel B.
R-CORE Transformer 30VA 2x115V to 2x15V 1A This R-Core transformer is ideal for powering a DAC or preamplifier. It has one primary 2x115V and two secondary 15V 1A
Bien mais phases des secondaires non repérées
Plutôt bien, mais les phases des 2 secondaires de 15V ne sont pas repérées.
Si on les utilise en //, par exemple pour alimenter une alimentation stabilisée, l'absence de repérage des phases peut entraîner une surchauffe du transformateur même à vide (et l'alim peut ne pas fonctionner) comme dans mon cas.
Pour retrouver un fonctionnement normal, il suffit d'inverser un des 2 secondaires, mais il est regrettable que les phases ne soient pas repérées !
Un point qu'Audiophonics devrait faire corriger au fabricant..
A part ça RAS: Audiophonics au top côté livraison comme d'habitude.
Denis B.
bonne amélioration
Voulant améliorer un peu l'exploitation d'un tweeter kevlar double ferrite Davis, j'ai tenté de remplacer le condensateur existant (filtre DIY) déjà ancien par celui ci. J'avoue avoir été étonné du résultat, notamment dans un gain de précision (équipés d'appareils auditifs c'est une partie sensible chez moi : intelligibilité des paroles notamment). ils ne sont pas donnés, mais je suis pleinement content du résultat !
Denis B.
Efficace comme attendu
Utilisé pour (mieux) alimenter un dac Pro-ject pre box s digital, précédemment alimenté par l'USB de mon PC, le gain est notable sur la dynamique globale et la définition. ça n'en fait pas un "dac de course" quoique de bonne qualité déjà, mais l'effet attendu est atteint ;o) !
Miltiadis M.
Perfect little box
Clear and powerful enough to power my 90W RMS passive monitors. I have connected it to my DX7 Pro and the sound is great. Good value for money too.
Vitor B.
Great idea
It does what it says. Great set of cables. It is more practical to use it with Mojo than Poly. Navigation could be improved as well as manual but for the price - equivocally a 5 star product.
Alberto M.
ALPS RK09712100AV 2 Ways Potentiometer 50k 20% This ALPS RK09 linear potentiometer has two channels, a resistance of 50 kOhm and a tolerance of 20%. Particularly useful for DIY assemblies or as a replacement for a similar...
potenziometro
tempi di consegna rapidi,
artcolo come da descrizione
Francois P.
Exceptionnelle
La série 50 est vraiment un cran au dessus de la série 48. Encore plus d'aération, plus de contrôle, de maîtrise, scène sonore plus précise!
Utilisée avec une IEC 50 sur un câble secteur Furutech 055N, l'effet est impressionnant sur l'appareil électronique sur lequel ce câble secteur est installé!
Cher certes mais efficace!!
johann g.
mouais
on va faire bref.. ne fait pas mieux qu'un câble à 8€ acheté sur amazon.. passez votre chemin
Pascal E.
Livraison rapide malgré le confinement, trés bon adaptateur, aucun bruit parasite.
Antonios S.
antsam
Value for money DAC. I am using optical and coaxial inputs in my system.
Clear, precise, neutral with open stage.
Useful remote control.
Excellent at this price
Pierre-Marin L.
RQP hors norme
Bon ampli, tient des enceintes complexes (petites Proacs) Offert à mes beaux parents pour un système au rqp imbattable et très plaisant à l'écoute...
Pierre-Marin L.
Un bon DAC
Bon RQP. Offert à mes parents qui ont très apprécié l'amélioration sur leur système.
Pierre-Marin L.
Sublime...
C'est mon deuxième. Le premier est placé en entrée de la barrette, un très bon achat la qualité ayant augmenté de manière impressionnante.
J'hésitais à m'offrir un autre DAC et puis le WAF a pas suivi... Résultat, à titre de petite amélioration je m'achète un second ifi purifier, espérant une petite amélioration sans trop y croire : et là la claque absolue : le deuxième entre l'ampli et le DAC fait faire à mon système un bond stratosphérique, même pas celui que j'espérait en changeant de DAC. Que dire, c'est un produit fabuleux et le deuxième est pour mon système indipensable. Merci !
Arnaud K.
Pas des plus évident à câbler proprement mais avec de la minutie on y arrive
Christoffer P.
Terrible banana plugs
The banana plugs on these cables are terrible. I was plugging them in to my Audiophonics amp (MPA-S250NC), so far so good. Then I unplugged them and the "shell" of the banana plugs got stuck in the binding posts of the amp. I had to use tweesers to remove the small metallic parts from the amp and was scared that I would damage the amp.
Otherwise the cable itself is OK. Very thick but pretty flexible.
Christoffer P.
Excellent amp
I have been using this amp for a few weeks now and can only praise it. It has plenty of clean power to drive my system and no audible distortion. XLR connections work nicely.
Package was wrapped very good with nothing moving around.
Took more than two months after order to get, but that was more to do with the current COVID situation. Customer service answered my questions well enough when order took longer than anticipated. But a little more information without having to ask would be nice.
christophe S.
TRES BON
Se connecteur est neutre avec des timbres juste sans le coté blanc de certain connecteurs,musical et sans dureté ,le rhoduim n est pas montant ,comme beaucoup, de personnes le pense ,tous dépend de son systéme.Si vous avez un son montant ,le rhoduim étant neutre va ciblé se déséquilibre,car cette matiére est sans compromis.Par contre si vous avez un son équilibré elle vous délivrera un message musical et vocal réaliste ,avec une bonne tenue général .Convient tres bien avec un son mat aussi .
TESTER avec Cable tunami V2 OYADE ou tc31
FURUTECH iec viborg R et schuko viborg R Musicalement a tous.
Frank d.
New power supply
My old SMSL broke down which meant no music in my garden shed.
I found the right replacement at Audiophonics which was delivered to the Netherlands in about 4 working days. Excellent service.
And the product works fine with my SA-50 amplifier.
