Paul R.
Shanling EC3
6CA7
EL34PH
Customers reviews - There are 19681 reviews.
Bart D.
Detailed Sound and Power: Fosi ZA3 Amplifier Review
Seamless Performance and Detailed Sound: Fosi ZA3 Amplifier Review
I recently purchased the Fosi ZA3 amplifier after reading glowing reviews about the V3 model. While the V3 lacked in delivering the desired subwoofer experience, I’m thrilled to report that the ZA3 performs exceptionally well, syncing flawlessly with volume adjustments. Paired with my B&W CDM-1 speakers (88dB SPL 8ohm 150w), I was amazed by the considerable enhancement in sound quality. This amplifier easily powers these speakers placed just a meter away from me.
One of the most impressive aspects is the amplifier's intricate level of detail in sound reproduction. Furthermore, it operates at a relatively low temperature, a feature I appreciate. Some users have lamented the absence of a dedicated power on/off button, but personally, the 3-second press of the volume knob isn't a hassle.
Additionally, the convenience of switching between XLR and RSA inputs is noteworthy. I did notice that the XLR connection produces significantly louder sound compared to both connections using the Topping DX5 Lite, although this discrepancy might be attributed to the Topping unit itself.
In conclusion, I highly recommend the Fosi ZA3 amplifier. The only feature I wish it had was a remote control. Also, it's worth mentioning that the transitions between XLR/RSA and powering on/off are impressively smooth, devoid of any popping sounds.
Volker R.
TOPPING MX5 Amplifier Merus MA12070 Class D NFCA XMOS Bluetooth aptX HD 2x55W 4Ω 32bit 384kHz DSD256 Black The Topping MX5 is a combo amplifier and headphone amplifier with integrated DAC ESS ES9018. Particularly versatile and powerful, it benefits from a Bluetooth reception thanks...
Volker R.
the Topping MX5 at PC just works super.
With ELAC BSU5 quit loud enough, no noise!
The Headphoneamp has enough power for every headphone fron 30Ohr till 600 Ohm.
The only bad thing... for every Change you need the remote control...not so funny!
LUDOVIC C.
Très bon produit et très bien réalisé.
Commander pour la réalisation personnelle d'un amplificateur Audio de Sonorisation de ma propre conception de 2X350W sous 8 ohms que ce soit bien clair, je possède des amplis Audio puissant réalisé avec sérieux, le transformateurs sur mesure que ma fournis Audiophonics est parfait ! C'est le moins que l'on puisse dire, il réalisé avec un grand sérieux, les tensions sont stable et correcte d'un enroulement à l'autre je le précise car c'est le principale problème que j'ai pu rencontrer sur des transformateurs d'autres marque pour lesquels j'ai du ajouter du fil rigide par tour aux enroulements pour non seulement avoir les tensions recherchés, mais quelle soit identique d'un enroulement à l'autre, ça se joue à quelques volts, parfois à 1 ou 2 volts mais pour les spécialistes lors d'un test de puissance et au bout de l'amplificateur, cette différence devient importante.
Bref produit de qualité et correctement livré si bien que j'en ai commandé un autre puisque tout ampli audio conçu sérieusement se doit d'avoir ses deux alimentation totalement séparés ;)
Pascal A.
Diabolique ce truc
Assis sur mon derrière, toutes mes références sont tombées. Je croyais que pour choisir un ampli, il fallait qu'il soit tres lourd et très cher. Ce truc de moins de 2 kilos, tout petit, enterre des amplis à 4 chiffres tranquille. Les idiophiles ont de quoi s'inquiéter les grands constructeurs aussi. Choisir des bons cables et une bonne source, ca ne pardonne rien.
Christian D.
connecteur de qualité
J'ai réalisé 3 cordons secteur avec les connecteurs VIBORG VE502G shuko et connecteurs VIBORG VF502G iec, ainsi que du câble OYAIDE VONDITA .
Les connecteurs sont de qualité et acceptent même des câbles de forte section.
le premier cordon alimente un distributeur secteur AUDIOPHONICS MPC6V2, le second mon lecteur et le troisième mon préamplificateur.
Je n'avais auparavant que de simples câbles et multiprise, effectivement le son de ma chaine s'est améliorer à tous les niveaux, un voile se lève.
Thierry C.
ISOACOUSTICS ZAZEN I Vibrations Absorber Platform 432x381x30mm 11.3kg The IsoAcoustics zaZen, named after a method of sitting meditation, is a vibration-absorbing platform designed to be paired with vinyl turntables, tube amplifiers or other...
Un apport immédiatement perceptible
En hifi, il est la plupart du temps indispensable de roder les éléments. Avec cette plateforme Isoacoustics, point n'est besoin d'attendre des dizaines d'heures pour entendre la différence. Située sous ma Rega Planar 8, elle permet de globalement nettoyer le son, de le poser de manière plus naturelle et, surtout, plus apaisée. Les graves en ressortent encore plus profonds, les détails plus apparents, les aigus moins agressifs. Un investissement raisonnable sur un sujet essentiel, trop souvent sous-estimé : l'importance du découplage de tous les éléments de votre installation. Un apport qui aura également le redoutable inconvénient de souligner les éventuels défauts de votre installation...
Pavle J.
SENDY AUDIO PEACOCK HiFi Headphone Planar Magnetic Circumaural 50 Ohm 103dB 20Hz-40kHz Exceptional sound quality, comfort, high-end materials and sublime design, these are all elements that make the Sendy Audio Peacock an excellent planar magnetic headphone to...
Excellent…
I was looking for planar magnetic headphones and chose Sendy peacocks. Now I am listening last 4 days intensively via Hafler HA75 tube headphone amp and can’t tell you how how I am satisfied. Sound as well as build quality is excellent. Well done Sendy!
Thank you Audiophonics for super accurate delivery!
Christian M.
AUNE SC1 Clock 10MHz OCXO Sine Signal / Square Signal Black The Aune SC1 is a high performance external clock embedding an optimized audio architecture, including the use of an OCXO oscillator and an FS-1 frequency synthesizer designed...
Indispensable!
Si vous possésez un dac (même ht de gamme) qui possède un entrée world clock, je vous recommande fortement l'achat de l'horloge Aune SC1...votre dac sera transcendé !
Attention, il faut attendre quelques heures avant de porter un jugement, et surtout ne jamais l'éteindre, sinon il faut réattendre quelques heures pour qu'elle soit à son optimum !
Utilisée perso sur mon Teac UD701n
Paul C.
FX-AUDIO D502BT Amplifier FDA TAS5342A Subwoofer Output Bluetooth 5.0 2x60W 4 Ohm Black The FX-Audio D502BT is, as its name suggests, the successor to the D502. The D502BT takes over its base and components, but this time it comes with a Bluetooth 5.0 receiver,...
Achète pour remplacer l’ampli d’une mini-chaine Denon D-M33, et utilisé pour la TV en optique, le Bluetooth et l’USB (adaptateur Lightning vers USB indispensable sur iPhone). J’en suis très satisfait, rapport qualité prix impressionnant.
Ludo B.
commande de divers cables de modulation
Commandé en fin de nuit trés tot, produits indisponibles. Mail dans la matinée m'indiquant disponibilité et envoi dans l'aprés-midi. Reçu le lendemain au relais !!! Nous étions Samedi aprem. Relais probablement fermé !? Et non, exceptionnellement ouvert pour les fétes... Audiophonics, c'est ma 3éme commande. Ils sont parfaits !!!!!!!!!
Claude S.
Lecteur de CD au top
Ce lecteur de CD présente un excellent rapport qualité/prix avec une reproduction audiophile audible, généralement présente sur des produits au moins deux fois plus onéreux, le choix du chargement par le haut nous évite les aléas du tiroir forcément plus stable et plus précis, la lentille du lecteur optique est très accessible permettant un dépoussiérage sans risque. Enfin ce lecteur peut être utilisé comme un DAC de qualité ou inversement comme transport. Je suis parfaitement satisfait !!!
Stéphane t.
Bof
À ce prix je m'attendais à un appareil avec zéro défaut, le bouton est "dur", on dirait qu'il y a du sable dans le mécanisme quand on le manipule, 89 balles pour une simple boite... imparfaite... j'suis déçu.
Alain M.
Du gold .
Je suis surpris de la qualité du produit je vous le conseil,
j'ai l'impressions d'avoir changer d'ampli , c'est cher mais sa vaux
le coup .
Sasha V.
Wonderful device.
Very well built enclosure with a nice, smooth finish, with a tactile and linear volume pot. I did also experience some hum through my speakers but that was fixed by removing the earth connection in the power cable. There is no need to open up the preamp to disconnect the earth. Now it is silent.
It requires a few days of break-in, thereafter the sound becomes much more refined and spacious. It is a really enjoyable listen, smooth and non-fatiguing with excellent detail retrieval and well controlled transients. Tonal timbre is also excellent.
Digging a little deeper, this board appears to be based on an Accuphase C3850 design, although I can't be 100% certain. Nothing to complain about here, it sounds fantastic.
It has a lot of gain - so much so that I reduced my pc output gain by -8db otherwise you don't get to use more than 1/4 of the volume pot sweep range.
My front end consists of toslink from pc feeding into a Audiophonics DigiRescue reclocker toslink to coax converter, a SMSL SU-1 dac fed via coax and rca out to this preamplifier going into active studio monitors with rca cables. This combination is the finest sounding front end I've ever owned. The law of diminishing returns applies here and I feel I would need to spend multiples more to improve my front end.
The preamp on its own is already a great improvement to sound quality, but if you can rig it up like I did you will be in for a surprise. This is my best hifi find for 2023 and I can highly recommend it. Thanks!
Sasha V.
Great.
Does what it says on the box. Keeps rca plugs from oxidising. I can't comment on noise reduction as I don't have that problem in my system.
Sasha V.
A cable for life.
I use 2 of these to feed my dac and preamp. They are very well made and seem durable. The cable is a little stiff but manageable. They also helped to reduce the noise floor a little. I think for the money they are brilliant and I can recommend them wholeheartedley.
Clarice C.
AUDALYTIC AH90 DAC AK4499EX XMOS XU316 LAN DLNA Roon 32bit 768kHz DSD512 MQA Silver The Audalytic AH90 is a DAC offering excellent decoding performance and precise sound reproduction, thanks to a careful and intelligent design. And it's reasonably priced for...
Updated review - Gustard Audalytic AH90
The AH90 is unique: It is the only device that can act as a DAC, Headphone Amo, and Steamer at this price point and this level of quality. The competition does not offer all 3 in one. Furthermore, after and update the unit is able to output to speakers DSD signals natively rather than converting them. That only works to speakers and for the odd recording that is DSD coded, which are rare in the market.
As a professional musician my sensitivities are not limited to volumes but to being able to hear what people do. This unit has been a joy. Regardless of what type of music and musicians are involved I can hear things. Status Quo was famous for changing guitars to create different sounds durng concerts. This unit will let you hear the difference. As an opera singer, the acoustic of a stage like Munich can make you aware of things you do as a singer that you do. Some houses make a musician reach into their bag of tricks. Think of Queen at Wembley and listen to it on a unit like this and listen to it with this unit: made me smile. No tricks of voicing. My previous SMSL bumped up the bass but never sounded as natural.
If you connect it to your LAN for Upnup or Streaming, you may not need a WiiM unit at all. I still own a WiiM Pro but am sure over my internal system the Gustarender software will sound better.
This is a special machine at this price point. It receives my highest recommendation. It has flexibility the Matrix Mini 4 does not have and is way cheaper than buying several machines to do what this unit does a 3 in !.
David n.
TONEWINNER AD-1PA+ Power Amplifier Class A Stereo 2x300W 8 Ohm Silver Powerful Class A stereo power amplifier, the Tonewinner AD-1PA+ benefits from a high quality balanced architecture that allows it to develop significant power while ensuring a...
Première écoute déconcertante tellement c’est détaillé sur tout la bande passante avec superbe image stéréo tant en largeur (180° sur certains morceaux) qu’en profondeur (+ étagement des plans).
Je retrouve effectivement tous les attributs cités dans l’article de Remusic.
Les instruments / voix se détachent distinctement (effet 3D) dans l’espace sonore.
Les basses sont amples, profondes, moelleuses et timbrées.
Médiums transparents, avec de la matière.
Aigus naturels, fins et cristallins qui semblent flotter en haut du mur du fond sur certains enregistrements.
Le tout dans une cohésion impeccable.
Ampli réactif au secteur (ligne dédiée symétrisée Gigawatt chez moi + terre indépendante) et donc au câble d’alimentation.
Le meilleur chez moi étant pour l’instant un Tunami V2 Shuko Charlin et IEC C004 pour une belle articulation (particulièrement dans le bas), rapidité et neutralité générales.
Sensible également au support (Finite Element Spider dont un avantage est d’être totalement ouvert pour refroidissement naturel)).
Le résultat me satisfait beaucoup (en classe A pure (bien chaud mais sans surchauffe), mais aussi en mode automatique (tiède)) et me fait oublier mes anciens amplis dont un à + de 13000€.
Difficile à accepter ? L’évidence est là pour moi.
Aucune fatigue à l’écoute, au demeurant très agréable et d’autant plus intéressante qu’on peut y percevoir les particularités des enregistrements.
Venant du monde studio pro, j’aurais pu le prendre en ampli d’écoute principale.
Environ 300 heures d'écoute au moment de cet avis, sur Streamer Antipodes EX (Switch ethernet Uptone) + Ayon Stealth en Dac / pré-ampli, et Harbeth M40.2 en HP avec connectique générale (XLR et RCA) Driade Flow 808 et secteur avec Amadeus (panachage FI-E48 et 50R + Charlin). Pièce d’écoute dédiée de 40m2 légèrement traitée en acoustique.
L’aspect résolvant et neutre de cet ampli révèlera la qualité de votre système en amont.
Et comme toujours, superbe qualité / rapidité de service / envoi d’Audiophonics. Bravo !
P. V.
Raphaël B.
Très bons produit, belle qualité, montage facile, serrage optimum, excellent rapport qualité/prix. Dorénavant, je n'achèterais que ce produit.
Raphaël
Jean-Baptiste D.
Très facile. On branche en USB sur un PC, on installe REW ou équivalent sur son PC.....et on a tout ce qu'il faut pour mesure et corriger/améliorer son système....avec un rapport qualité/prix au top et un micro calibré.
Jean-Baptiste D.
Bon ampli FDA - mais
Globalement il fonctionne très bien. Je l'ai utilisé d'abord avec une paire d'enceinte passive (coas tpx musikit). Impec, à la hauteur d'un marantz pm7200 100 fois plus lourd.
Enceinte, j'en ai pris un second et un dsp minidsp pour piloter une paire d'enceinte active....et là ça a été plus compliqué. Un peu de bruit de fond apparent sur tous les HPs et surtout une tenue en puissance très faible. Je soupçonne une sensibilité aux impédances basses (mais HP était des 4 ohm) vu qu'il n'y avait pas de filtres passif, pas de correction de courbe d'impédance. Je vois que ça.
Donc pour utiliser avec une paire d'enceinte passive adaptée à son champ d'application, c'est parfait. Faut faire attention aux utilisations un peu plus exotiques.
Jean-Baptiste D.
Bon ampli fda
Franchement, un rapport son/prix imbattable. Aucun bruit de fond, belle patate, bon son, franchement bien. Je ne suis pas de ceux qui parlent du son d'un ampli comme d'un grand vin. Je n'attends rien de plus d'un ampli que de faire ce qu'on lui demande. Il le fait parfaitement bien tant qu'on reste dans son terrain de jeu.
Jean-Baptiste D.
HYPEX FUSIONAMP FA251 Plate NCore Amplifier 1x250W DSP ADAU1450 DAC AK4454 The Hypex FusionAMP FA251 amplifier will allow you to design a one-way active speaker or a sub active subwoofer. This is based on an NCore module capable of developing 250W RMS.
Pour piloter un caisson
L'ampli fonctionne très bien. Parfait pour un caisson. Tout est parfait, en revanche, pour initiés. L'interface graphique du logiciel permettant de régler le DSP de l'ampli est très complète et efficace....mais on peut pas vraiment dire que l'ergonomie soit son point fort! Avec quelques connaissances en audio ou de l'aisance à fouiller sur les forums spécialisés, on s'en sort, rien d'infaisable.
Jean-Baptiste D.
DAYTON AUDIO RSS210HO-4 Speaker Driver Subwoofer Aluminium 300W 4 Ohm 86dB 30Hz - 1500Hz Ø20.3cm The RSS210HO-4 is a subwoofer from Dayton Audio's  Reference Series  range, and has the same high quality and performance criteria that have made the success of...
Utilisé pour faire un caisson clos d'environ 12l avec un ampli hypex ncore 250. Parfait, puissant, malléable, ça transfigure une installation avec un grave profond rapide et sans trainage....en effet, il existe très très peu d'enceinte du marché capable de vraiment bien reproduire le grave. Avec ce genre d'HP, c'est possible avec un peu d'effort. Excellent rapport qualité prix
Jean-Baptiste D.
ARYLIC A50+ Amplifier FDA STA326 WiFi DLNA UPnP Bluetooth 5.0 2x50W 4Ω The Arylic A50+ is a versatile, high-performance FDA amplifier based on an STA326 chip and capable of developing 2x50W of power at 4Ω. It benefits from extensive...
En application hifi, très étonnant !
reçu aujourd'hui et installé. Utilisé avec des dali oberon wall.
Niveau amplification, ça fonctionne en gros comme un fxaudio 802. donc ça fait le job comme un fda. Autrement dit, c'est propre, dynamique, ras. Pour ce type d'enceinte à rendement à peu près standard (85dB) avec une écoute à moins de 3m en appartement, ça suffit large. Je serai plus sceptique avec des très haut rendement (léger bruit de fond, aucun pb avec des enceintes à 85db, pas garanti avec des HD à 105db) ou alors pour remplir une pièce de 60m2 avec une écoute à 5m....on peut pas demander la lune à un ampli de 30W sur 8 ohm.
Donc bilan qualité du son, tant qu"on est sur son terrain de jeu c'est parfait.
......mais c'est sans compter sur son ENORME point fort ! ACPworkbench, pour 20€ de licence supplémentaire, on accède à quasi tous les paramètres de réglage du DSP intégré er là c'est un truc de fou. On peut tout faire et en particulier 4 équalisers paramétriques 10 bandes : 1 général, 1 gauche, 1 droite, 1 sortie subwoofer. On peut faire tous les réglages qu'on veut ou presque. Pour peut qu'on ait un peu de savoir faire, un micro, un logiciel de mesure (genre REW), et on peut régler ça aux micro poil. Pour le prix, c'est juste énorme et ça mache du tonnerre. En 10mn, j'ai corrigé le pic vers 200Hz causé par l'endroit ou sont installées les enceintes, coller un pass haut sur les dali et un pass bas sur le caisson maison (HP 22 dayton et ampli ncore250).
Pour l'appli de controle, simple fiable RAS, le pilotage à partir de deezer fonctionne très bien en airplay (attention aux spec, deezer n'est pas intégré à l'ampli, il passe via airplay ou bluetooth). Lecture du contenu d'un nas freebox via l'appli mconnecte sans pb avec protocole upnp.
Bilan final, à ce prix, avoir un ampli fort convenable, facilement connecté via 2-3 applications sur mobile et un dsp complet totalement paramétrable.....c'est Noël !
Damien C.
Très bon DAC pour le prix
Satisfait de cet achat.
Son clair et précis, construction qui paraît solide, montage qualitatif.
Branché sur un PC Windows 10, sans pilote, avec câble optique (S/PDIF), le tout relié à un ampli Marantz;
Testé aussi avec USB, fonctionne parfaitement (sans pilote);
Appairage Bluetooth sans difficulté.
Seul bémol, le câble d'alimentation électrique très rigide et surtout très court. Sa longueur ne permet pas d'atteindre une prise au sol depuis une console/meuble de hauteur standard. J'ai dû le remplacer par un câble d'alimentation PC classique et identique mais plus long.
Audiophonics : livraison rapide et emballage de qualité; La notice jointe en français n'était pas celle du C200 (mais celle du DO100). La notice originale en anglais est de toutes façons très succincte.
Christian D.
Cable secteur
J'ai réalisé 3 câbles secteur .
1 pour le distributeur secteur AUDIOPHONICS mpc6 v2
1 pour mon lecteur PIONEER PDP LX800
1 pour mon préamplificateur LECTRON PA 50
L’écoute des disques cd est plus détaillée sur tout le registre sonore du grave aux aigus, tout en étant beaucoup plus agréable.
Les graves sont mieux tenus .
Tous les câbles sont équipés de fiches shuko VIBORG VE 502G et connecteur iec VIBORG VF 502G.
Le résultat est très surprenant.
Étant donné le résultat je pense que la version avec les connecteur en argent pur VIBORG VE504AG doit être exceptionnel .
Si quelqu'un désire fabriquer ce câble avec des fiches VIBORG VIBORG VE504AG en argent pur il vaut mieux acheter la version réalisé par AUDIOPHONICS qui est moins chère de 160€.
Si vous avez une bonne chaine ne pas hésiter
Elom G.
Très bon casque pour un usage domestique
Acheté en remplacement de mes akg studio k240, le son est plus doux et plus équilibré (basses, medium et aigus).
Fonctionne correctement avec la sortie casque de mon smartphone, mais c'est encore mieux avec un petit ampli casque (pour moi, le earstudio de Radson).
Attention : c'est un casque ouvert, donc plutôt pour un usage domestique, dans le métro ou dans la rue, le bruit ambiant rend l'écoute assez décevante voire désagréable.
Elom G.
Bon produit, de bonne qualité et bien fini. Je n'avais pas besoin de l'insert, je l'ai acheté juste pour récupérer les pointes de découplage pour une paire de colonnes Elipson Prestige 3.
J'en suis très satisfait.
Excellente qualité générale, mais...
Bons contacts bien francs, câblage intérieur intéressant, on adore l'absence d'interrupteur, de disjoncteur, de témoin lumineux, qui sont des catastrophes pour le son ou l'image. Mais... Rien pour fixer cette belle barrette, ni pattes, ni trous filetés, dommage. Il faudra donc la coller sur son support (Scotch double face ou pâte ou gel). Sinon, les prises auraient pu être un peu plus écartées entre elles, étant donné qu'elles ne sont pas orientées à 45°. Donc certains blocs secteurs condamneront deux prises, dommage.
Câble impressionnant
Bien réalisé, on dirait presque un EAT, un peu rigide mais sans excès,
la fiche murale est surdimensionnée, ça pèse lourd sur la prise et ses contacts, et cela dépasse beaucoup, il faut de la place... Est-ce techniquement nécessaire, ou est -ce une astuce marketing pour impressionner ? Bien moins cher qu'un EAT et le son est propre, les contacts sont francs.
Patrice H.
Excellent sélecteur d entrées RCA
Très bon sélecteur qui a le bon goût de fonctionner dans les deux sens. Selection d'entrée ou sélection d amplificateur de sortie.
Dommage que la sortie et l'alimentation soient en face avant pour l'intégration. Sinon avec la petite télécommande, les sélections sont très faciles.
Gorazd K.
Medium quality. I put it on a 3 m cable without much effort, but you have to be very gentle, because the individual threads like to pull out. Probably the price reflects the quality. Otherwise, as always, excellent in terms of packaging and delivery.
Bruno B.
Ouaouh à peine croyable
En remplacement des contrepointes Elecaudio sd25, les Audio Bastion X-PAD + II ont amené une amélioration sonore considérable pour un simple accessoire. Transparence, aération, dynamique sur l’ensemble des fréquences.
Mon vieux système basé sur l’intègré Vincent SV238 couplé à des BW 804 N a pris un sacré coup de jeune.
Merci Audiophonics pour votre habituelle rigueur dans la qualité de vos envois.
Richard C.
ARYLIC BP50 Preamplifier DAC ES9023P Bluetooth 5.2 aptX HD aptX Adaptive 24bit 192kHz Arylic proposes with its S50 Pro+ a connected stereo preamplifier, having the particularity to take advantage of a complete connectivity with WiFi and Bluetooth 5.0 reception....
Connecte sur Chromecast audio pour alimenter mc intosh2205je préfère utiliser le dac du Chromecast plutôt que celui de arilic que je trouve agressif.
Cédric F.
Aop qualitatif
Mis en place dans un modeste Aiyima Dac-A5 max acheté à un prix de 69 euros pendant le black friday, les NRJ Muses l'ont transformé. Plus de dynamique, plus de détails, une scène sonore élargie et une écoute naturelle. Il est au niveau d'un Topping E30II, très très proche et difficile de trouver des différences même avec une écoute au casque. Très satisfait du bon qualitatif pour une somme raisonnable.
Cédric F.
Pour une sonorité chaude
Mais en place dans un modeste Aiyima Dac-A5 max équipe d'une puce sabre, le son est devenu chaud, sonorité Burr-brown en somme. Le bas medium à pris de la consistance, le medium bien à sa place et les aigus doux. L'Aiyima est devenu en terme de son proche de mon audio GD avec ses wolfsons. Pas l'aop le plus détaillé mais agréable à écouter.
ATAUDIO SILVER Male USB-C to Male USB-B Cable Pure OCC Silver 0.75m The ATAudio Silver USB cable offers exceptional build quality for optimal transmission performance. It features eight pure silver conductors that are insulated and braided...
Très beau câble
La fabrication du câble est vraiment de belle qualité. Sur le plan audio c'est très équilibré du grave à l'aigu. Le rapport qualité/prix est parfait, il ne tombe pas dans le délire des prix totalement déraisonnables de certains câbles.
Service après-vente
Mon alimentation est arrivée avec un petit défaut cosmétique sans gravité. Après une réclamation, Audiophonics m'a immédiatement répondu en me proposant un échange ou un remboursement. On ne peut que les féliciter pour la qualité de leur service après-vente !
Concernant l'appareil, il n'a pas amélioré de façon spectaculaire le son de mon Minidsp mais celui-ci n'est peut-être pas sensible aux alimentations. Je vais l'essayer sur mon Lümin D2!
Audiophonics est réellement une société en qui l'on peut accorder toute sa confiance. Thierry
Laurent z.
LUDIC ORPHEUS Power Cable Schuko Type E/F to IEC C15 24k Gold Plated OCC 6N Copper Shielded 1.5m Ludic unveils with the Orpheus a high-end Schuko Type E/F to IEC C15 power supply cable, using high quality materials to ensure excellent transmission quality. This cable has a...
Rapport qualité prix exceptionnel
On en a réellement pour son argent d’abord pour la qualité de fabrication puis pour l’amélioration sonore. Tout reste équilibré en gagnant en silence. Grande douceur sans perdre en définition. Mention spéciale pour le grave complètement libéré mais sans lourdeur. Seul point négatif, câble très rigide. Ne pas hésiter à prendre une petite longueur supplémentaire. Ça aide. Comment d’habitude servie audiophonics au top
Laurent z.
Avis rectifié…
Après 3mois d’utilisation, je les change pour des MULLARD.
J’ai changé les tubes de puissance EL34 PSVANES PH par des TUNG-SOL KT120. Histoire de goûter au deux monde…
Grosse claque quand même ! Les EL 34 ne sont pas à jeter, non non ! C’est une toute autre approche de la musique c’est tout. Je les garde car un jour ça va me démanger de les remettre en service.
Mon intuition me dit que les tubes de préamplificateur introduisent quelques choses dans l’équilibre obtenu. Donc pas d’autre solution que de les changer pour en avoir le cœur net.
Oui mais prendre quoi ?
Il y a tellement peu de littérature sur le sujet.
Ces PSVANES méritent totalement leurs 5 étoiles.
Ce qui les défini le mieux c’est la générosité.
Dans les timbres, dans les harmoniques, dans la puissance.
Le passage sur les MULLARD m’a fait ressentir une perte de puissance.
Par contre je trouve que le mariage avec les tungsol est pas idéal car il fait déborder d’harmoniques en tout genre les tubes de puissance.
Un superbe tube, à considérer sur des associations de moindre puissance.
Laurent z.
Cadeau à ce tarif
Découplage efficace immédiatement perceptible sur mon ampli à lampes et très pratique à positionner. À ce tarif rien à ajouter
Laurent z.
PANGEA PREMIER XL BALANCED Balanced Interconnect Cable XLR-XLR Copper Cardas 1.5m (Pair) This Pangea Premier XL Balanced XLR-to-XLR modulation cable features exceptional workmanship. It features Cardas Grade one copper strands with PE tube...
Belle surprise
Ce câble n’est pas donné mais qu’est-ce qu’il est bon…. Équilibré, défini, doux mais pas éteint. Une belle ampleur de la scène sonore et…. quel poids sur les notes. J’adore l’album de Liane Foly « Crooneuse » mais parfois un peu sec voire dur, et la ça passe tout en fluidité. Vraiment très musical. J’adore…… et comme d’habitude service audiophonics au top
Laurent z.
Vous pouvez reprendre le commentaire que j’ai posté pour pour le aesir mais encore plus silencieux et un peu plus « nerveux « . Bande passante impressionnant dans le grave.. J’adooooore
Laurent z.
LUDIC AESIR Power Cable Schuko IEC C15 UP-OCC Copper Gold Plated 1m The Ludic Aesir is a high quality power cable. It integrates patented UP-OCC Drawn® Copper conductors, allowing to obtain a high purity monocrystalline structure (higher...
Pascal A.
Attention, l'enveloppe extérieure est très souple et tendre. Elle se denude très facilement. Allez y doucement. Sonorité neutre, bonne transparence.
Alex C.
Very good quality but it affects the sound. I prefer the cooper version.
Alex C.
good quality box
good quality box
