didier N.
ok
Benoit d.
Robert C.
It is difficult to...
Customers reviews - There are 19629 reviews.
Goran D.
Pack Topping E50 Balanced DAC + L50 Balanced Headphone Amplifier + TCT1 Jack 6.35mm Cables Silver This Topping pack is composed of a balanced DAC E50, a balanced headphone amplifier L50 and cables Jack 6.35mm TCT1 allowing the connection of both devices. This set will allow...
E50/L50
I'm overjoyed
Goran D.
IBASSO DX170 Digital Audio Player DAP 2x CS43131 Bluetooth 5.0 aptX LDAC WiFi Android 11 Blue iBasso offers with its DX170 an excellent audiophile DAP. This one benefits from a careful design, using quality components, allowing to provide a faithful, precise and dynamic...
DX170
Fantastic
Goran D.
MOONDROP ARIA In-Ear Monitors IEM Dynamic 10mm 122dB 32 Ohm 5Hz-36kHz Moondrop's Aria in-ear headphones combine balance, transparency, richness and a wide sound stage. They integrate a dynamic 10mm transducer within a double magnetic cavity, with...
Aria
Nice, very nice
Ben L.
Essential to truly set up your Wondom JAB amps!
The amps work fine out of the box, but you get an almost infinite amount of options if you use the programmer, it is easy to get lost in SigmaStudio exploring all the different modules!
It is in my opinion an essential addition to any Wondom or Dayton Audio DSP/amp with DSP!
Note: with the JAB5 you won't have the Miumax Bluetooth phone app as an option, but the Miumax/Wondom PC UI desktop program works perfectly with most of them
SigmaStudio works with all of the DSP amps with an ADAU chip
Ben L.
WONDOM JAB5 AA-JA33286 Amplifier Module Class D Bluetooth 5.0 DSP ADAU1701 4x100W 6 Ohm The JAB5 is an integrated 4-channel audio amplifier board with Bluetooth 5.0 (aptX HD support) and DSP ADAU1701, offering a true all-in-one audio solution. It delivers 4x100W of...
Relatively small, yet powerful!
Awesome amplifier, for it's size you'd never expect it to get this loud (if you supply it with a high enough voltage, it needs power to create power, preferably 34V!)
Easy to set up a pair of channels in bridge mode, it literally has banana plugs for it.
That makes it very easy to make a 2.1 setup or a 3 way active speaker (sub/low, midrange, tweeter), or 2 2-way bi-amped speakers
it isn't super quiet so on high efficiency drivers you'll definitely hear some white noise
The default program in SigmaStudio the amp comes with has a low volume cutout, so under a specific volume it wont play
Thanks to the inbuilt DSP you can very easily tune it to your room or even improve the overall response
using REW (Room EQ Wizard) and a measurement mic you can measure the response and save it, which you can then import in Sigma Studio to have it as flat as possible, after that you can apply your own EQ and have it tuned to your preference dependant on what a kind of sound you want.
Aristotel Eduard G.
Good quality linear power supply
I had ordered this linear power supply 5V 2A for powering a WiiM pro streamer. I replaced the original charger with this power supply. Very good quality I can say that the streamer is sounding very good and detailed. After a month of using I recommend this product. Delivery was a big surprise, I got the package in RO in 48 hours after ordering !
Doris G.
A07 pro + NJR MUSES 8920 AOP
Excellent résultat. Un son pur comme je n'ais jamais entendu.
2ème avis ( astuce )
J'ai obtenu le meilleur résultat en le posant sur le plateau caoutchouc ; gain en détail et dynamique flagrant ; un kif à l' écoute ! la surépaisseur ne gêne apparemment pas la lecture mais je n'aurai peut être pas osé avec une platine de plus grande valeur ; à essayé pour les curieux …
sans compromis ...
J'ai attendu plusieurs mois avant d'émettre un avis ; le temps d'un bon rodage . Ce câble est très sensible à l'environnement . Au début j'avais un son très détaillé mais un peu dur ; en remplaçant les pieds de mon cd par des pointes les détails était toujours là mais avec un grand naturel . Scène sonore large ; on entends tous sans agressivité ; présence sonore réaliste mais pas caricaturale . Cable pour mélomane ; attention câble sensible qui pourra valoriser les défauts de votre système ; à associer avec des éléments de bon niveau .
Pascal B.
Remplacent des match point 300 ssc sous mes Egglestonworks Fontaine signature . Il n’y a pas photo entre les deux ! Les contrepointes Audio Bastion X pad ont permis d’augmenter la richesse du message sonore de manière très significative . deux jours après la mise en place , une musique plus présente , des extinctions de notes qui s’allongent , en bref ce que j’attendais ! J’envisage d’équiper mon meuble des pieds titan de la même marque !
Pierre s.
Problème chauffe
Cette alimentation est excellente. Néanmoins, branchée à ma box et NAS (tous 2 donnés pour du 12V/5A), elle chauffe beaucoup avec un seul appareil branché (box) et le capot devient même brulant avec les 2 appareils connectés. Le SAV Audiophonics m'a aimablement répondu en me disant que c'était normal mais un an après son utilisation, je me demande si elle n'a pas simplement de mal à alimenter les 2 appareils en même temps. Du coup, je me contente de la seule box branchée...
Rodolphe L.
Modules avec du potentiel
Point négatifs:
- Pourquoi diable des modules en miroir ? Pratique quand on met les deux amplis dans un seul coffret. Mais pas pratique quand on fait deux coffrets. Quid de la stricte équivalence des modules ?
- L'aigu pas assez précis à mes oreilles, balance subjective tonale trop grave ? Peut être lié à la classe de fonctionnement ?
Points positifs:
- Le double mono a une image sonore très aéré et précise dans les basses et médiums.
- La tenue des hauts-parleurs est bonne dans le grave. Mes deux 12" par enceinte sont bien pilotés dans les graves.
Par curiosité pour écouter car il y avait le schéma qui montre une contre réaction en courant et pas de condensateur sur le circuit de contre réaction et en plus des circuits cascodes. Je m'attendais à de meilleurs aigus, trop métallique à mon goût, mais c'est peut être lié à la classe de fonctionnement des transistors de sortie, qu'on ne les fassent pas plus travailler en classe A ? Possible avec de plus gros radiateurs...
Du potentiel donc !
Andoni G.
Good plug
Look solid with good gold plate
Best plug for price
Andoni G.
Good plug
Easy yo handle and Solid ay barca un price
Sebastien D.
Remplace aisément daphile que j'utilisais avant, certe c'est un coup à l'achat comparé à daphile qui est un logiciel libre mais c'est tellement plus confortable, le son du dac interne est magnifique et niveau encombrement c'est qd même agréable d'avoir tout en un, j'ai un abonnement qobuz et un SSD 4to déjà rempli de 2,5 to de flac et DSD encodés en DTS 5,1 et SACD 2.0 et 5.1, tout y passe même les "ISO" c'est le top, que demander de plus à part peut-être pouvoir installer toutes les apk intéressantes du play store? En fouillant bien on arrive à en avoir mais il faut des appli qui ne demandes pas de compte Google... Allez j'y retourne
Fantastique amplificateur
je viens d'acheter d'occasion cet ampli "chinois".....
eh bien ils savent faire de très belles choses.....
cet ampli fait fonctionner à merveille mes onkyo D302D pour lesquelles je cherchais un ampli capable de bien les driver.....des possesseurs de ces enceintes disaient qu'elles ne pouvaient rien donner à bas volume....avec l'audio gd leur théorie se casse la figure....une main de fer dans un gant de velours....c'est d'un naturel confondant !!! une fluidité à faire pâlir nombre d'amplis à lampes....l'équilibre entre les registres est parfait et les timbres sont justes !!! je n'ose imaginer ce que peut rendre son grand frère le master 10 mkII....pour tout vous dire l'écoute est aussi agréable que celle que j'ai pu faire de blocs mastersound à base de 845 associés au pré-ampli phl5.....cet ensemble vaut 20 fois le prix du precision 2 !!!!
Christophe M.
Super câble mais….
Je vous avouerais que en recevant mon colis avec le câble et des prises NCF je flippais grave car là ça commençait à chiffrer. J’ai eu l’expérience du tcs31 qui n’a pas été convaincant . Aussi, après avoir monté le tout minutieusement, je le branche sur mon Dac rien ne ne se produit…Je commençais à changer de couleur. J’essaie avec mon préamplificateur Yamaha c5000 : moins bien que le Thunder d’Audioquest. Ma dernière cartouche etait mon conditionneeur secteur qui avait un câble Gigawatt de base. Et alors là, c’était le grand spectacle. Hyper detaillé très beaux timbres un grave propre espace sonore très large (on repousse les murs) . En résumé génial mais avec un conditionneur secteur ou une barrette point final.
Pierre Yves P.
Bonne embase solide
Bon produit, dommage que la photo montre 5 poles à 180 ° soit inexacte, les poles du modèle fourni sont bien à 240°
Nasser A.
Magic Box
Je cherchais un convertisseur de qualité à un tarif accessible pour épauler mon lecteur réseau Wiim Pro. En parcourant les tests et avis sur Internet je suis tombé sur ce modèle qui fait l’unanimité chez les audiophiles avertis.
Le boîtier ne paye pas de mine avec ses dimensions réduites et son côté austère mais la construction a l’air solide.
La connectique est suffisante pour mon utilisation avec des entrées Usb, optique et coaxiale. Pour ma part, l’entrée Usb sert au branchement à une prise secteur. Si c’est le cas pour vous aussi pensez à commander un chargeur+câble usb-c/usb-c non fournis avec l’appareil. Seul le câble usb / usb-c est présent dans la boîte pour le branchement à un ordinateur.
En ce qui concerne le SON je ne m’attendais pas à une grande amélioration par rapport à la conversion du Wiim Pro et surtout à mon précédent convertisseur Audio GD valant 10 fois plus cher.
Dès les premiers morceaux la surprise est totale : une sensation de présence accrue, une scène plus précise et une belle transparence. L’écoute est donc très naturelle sans coloration particulière et avec du détail.
J’ai préféré la connexion coaxiale à l’optique, un peu plus organique à mon oreille.
La plus-value est réelle sur mon système. Je confirme donc la très bonne réputation du SMSL SU-1. Ce petit boîtier est tout simplement étonnant surtout au vu du prix. Je ne regrette pas mon achat et ne suis pas près de changer.
Cinq étoiles, sans réserves.
Frédéric S.
Un poil trop de jeu
Attention diamètre interne de 5.6 certaine prises mâle se déconnectent trop facilement.
Jean-Marc H.
Après 9 ans passé en compagnie d'un Audio-gd NFB 2.32, je ne voyais pas d'autre alternative que de le remplacé par un autre Audio-gd
Comme stipulé dans d'autre commentaires, en terme rapport performance prix, difficile faire mieux. Neutralité, nuance et restitution précise, mais plus analogique que chirurgicale...Donc plus naturel sont au rendez-vous. Il y avait déjà de ça dans mon ancien DAC et c'est pour cela que je suis resté chez ce fabricant.
Jean-Marc H.
Très bon tube
Utilisé depuis un peu plus d'un an sur des bloc mono (DIY) en push-pull, j'en suis très satisfait. Elles ont remplacé des Gold Lyons KT88 avec beaucoup de bonheur. Un son plus claire, plus aéré et un gain significatif en transparence. J'appelle "transparence" neutralité. Le matériel s'efface derrière la musique. La réserve en puissance permet de voir loin, en durée de vie, car elles encaissent mieux les montées de courant intempestive lors de la mise en route par exemple et accessoirement permettent un choix d'enceinte plus étendu ; plus de 60W par bloc dans mon cas, je peux leurs coller du HP à faible rendement sans arrière pensée.
Dhafer D.
Excellent DAC
Acheté il y a 6 mois pour monter en gamme à partir d'un excellent smsl d300, il faut dire que le saut en qualité sonore se fait sentir dès les premières minutes. Tous les registres sont présentés d'une façon aérée, précise et dynamique.
Avec un ampli casque topping L30 neutre et un casque Sennheiser HD660S, je retrouve réellement un plaisir d'écoute que j'ai perdu et recherché depuis quelques temps.
L'interface est très fournie et fluide; Bonne télécommande.
je ne regrette pas mon achat.
Jürgen M.
Software not good!
I don‘t recommend from point of Software. The hardware seems to be fine but the device operation lead into disappointment. The first issue is a jumping volume sometimes you change the input. Mainly if you switch to the Pi input. It jumped to 100% which is annoyingly loud. The second issue is that none of the Pi distributions worked as expected. I tried all three. Some show issues withe second display, some cannot read from my Synology NAS and the playback via Pi is not that stable as expected. The only stable App was Picoreplayer which obviously cannot drive the second display without sophisticated programming and Linux knowledge. Good hardware with bad software is not worth that amount of money!
Hi,
This is obviously indeed not the product for you and we understand your frustration.
This DIY kit is intended for people capable of ensuring manual assembly and having the computer bases necessary to modify the software solution at leisure and according to their needs.
The images we offer are only intended to serve as an example and we are not the developers.
Picore is indeed one of the most stable and lightweight solutions available on Base PI and is 100% compatible with this hardware solution (yes indeed the second screen does not display anything by default).
Do not hesitate to contact our after-sales service staff if you wish to return it for a refund.
Burkhardt P.
Great solution
The item is for me a great solution for hearing SACDs in stereo (mostly with headphones) directly from my Cambridge Audio 752 BD through the Holo Audio May without any conversion to PCM.
In the May you've to set the I2S to ALT2 and then it's working without any problems.
Jean claude C.
Pangea
Après réception de mon câble PANGEA AC-9SE MKII, j'ai pu le mettre en place tout de suite sur mon Ampli Audio Analogue , j'ai été surpris par autant de détail ainsi que l'espace autour des enceintes . Je pense avoir eu une nette amélioration qu'aucun câble de modulation sur mon système jusqu'à ce jour.
Il n'est même pas encore rodé ?
Une belle trouvaille à ce prix bravo Audiophonic.
George B.
Perfection
Product arrived in Australia within 7 days of ordering and performs exactly as expected. Subwoofers now turn on and off with the Amplifier. Will definitely recommend to my audiophile friends.
RENE R.
FURUTECH
SUPERBE CABLE QUE J'UTILISE AVEC UN CASQUE AKG702.
L'AMELIORATION APPORTEE EST IMPORTANTE ET TRANSFIGURE COMPLETEMENT CE CASQUE.
QUELLE TRISTESSE DE VOIR A QUEL POINT LES FABRICANTS METTENT DES CABLES DE "MERDE" SUR LEURS PRODUITS, QUELLE HONTE!
JE METS EVIDEMMENT 5 ETOILES POUR CE CABLE.
François M.
Remarquable
Ce câble monté en symétrique avec les connecteurs de la même marque a remplacé l'Epilogue pourtant très bon.
Il s'avère plus transparent et encore plus fin sans aucune fatigue auditive. L'Epilogue a sur les fréquences élevées cette petite insistance qui s'avère un peu fatigante à la longue sur des Klipsch Heresy 3.
Peut on encore faire mieux que ces Nemoi 1220 ?
Erreur de jeunesse. Attente de l'age adulte
Avant le DMP A6 je streamais avec un PC et l'éversolo Z8.
J'ai testé le A6 qui a un super son (le A6 est meilleur que PC+Z8) et son look superbe.
Avec l'ancienne configuration, un seul bouton de la télécommande me permettait de passer d'une source à l'autre.
Avec le A6 ... c'est pas possible.
Mais dès qu'un firmware corrigera tout ça, je re-achèterai le A6 qui repart chez Audiophonics pour l'instant.
Tout est ici :
https://www.homecinema-fr.com/forum/source-dematerialisee-haute-fidelite-et-dac/everso-dmp-a6-collecte-des-bugs-pour-la-team-zidoo-t30127125.html
Pierre P.
Cable USB LINDY
Très bien envoi rapide et article conforme.
Sinon pas grand chose à dire sur un câble qui fait son job
Olivier A.
ATOHM S500-MK2-X ICE POWER Class D Amplifier Module Subwoofer 500W 4Ω The Atohm S500-MK2-X Ice Power is a Class D amplifier module for subwoofers offering excellent technical performance and great musicality. It is capable of delivering a power of...
Déçu
En remplacement d'un module klipsch R115 400w. Prix très élevé au regard du rendu en deça de celui du module d'origine. Pauvre en connectiques et en fonctionnalités par rapport aux modules de marques concurrentes. Le comble, pour 550€, pas même une fonction veille !!! Avec 10w/heure de consommation résiduelle minimale, il ne faut pas manquer de jouer les contorsionnistes pour actionné à l'aveugle l'interrupteur entre le dos de l'appareil et le mur.
Je regrette mon choix.
La marque nous fait parvenir sa réponse et des suggestions suite à votre avis produit par email (que nous vous avons transmis via notre messagerie).
Dans l'attente de vous lire.
Erwin S.
Works, but has a design flaw that can be overcome
The description says that the DAC can be used for I2S or S/PDIF signals and that switching can be done with jumper J3. Since I wanted to connect both types of input, I connected J3 with a toggle switch on the front of my Amp. S/PDIF signal from my CD drive and I2S from a Raspberry Pi and a HifiBerry Digi-Pro hat. Roon installed on the RPI. CD playing, with J3 closed worked well. As soon as an I2S signal is also send to the DAC, it switches to I2S, regardless of the position of J3. Also after switching off the I2S signal, it remains locked on I2S. Service desk of Audiophonics waved me away, saying basically that this is the way this DAC works. To me this is a design flaw that needed a resolution, which I have found. When switching to S/PDIF (closing J3), the I2S / BCK connection between the RPi/HifiBerry to the DAC needs to be interrupted. I use a dual toggle switch to do that, works well now. So first 5 stars with just CD, then to 1 star for not working as expected and finally to 3 because of the design flaw. For the money though a good sounding DAC with the option to upgrade the OPA to a better one. Greetings.
Patrick D.
FIIO BTA30 PRO
Bonsoir a tous,
je confirme l"avis de José, un temps "d'adaptation pour la mise en phase sur l"ensemble du système" est nécessaire.
Sur mon système le tout numéric via un "Mac Bouque Aéré" couplé en acquisition à une carte son en externe toute simple, une Esi 22 usb, il confirme [en source directe] ce que j'attends du numéric pour une restitution analogique via des enceintes 4 voies pas forcement évidentes à driver... à mon humble avis, dans une gamme qui à coup d'AOP surmultipliées et de marketing d'assemblage promus en tête de gondole il a forcement sa place.
Allez pour une fois je me lache ;
Un Big Up!
Audiophonics, qui au fil du temps, sait m'accompagner au fil musical de ma passion. Merci à Vous!
FIIO FT3 Circumaural Open Dynamic Headphones Ø60mm 350Ω 102dB 7Hz-40kHz Fiio offers with the FT3 headphones an aesthetic and performing model, revealing a musical and dynamic sound reproduction with an ergonomic and very modern design. The frequency...
Tout d'abord le "packaging" est tout simplement impeccable.. Les accessoires fournis avec le casque sont de première qualité,
que se soit la connectique (XLR 4, Pentaconn 4, jack 6.5 mmm) ou les oreillettes supplémentaires, le sac en tissu et la petite valise de transport ainsi que le câble de 3 m, tout cela respire une excellente fabrication.
Venons en à l'écoute ! Et bien cela fait maintenant plusieurs heures que j'écoute diverses musiques, classique, jazz, blues etc...et pour l'instant je suis satisfait, la bande passante est très étendue, l'aigu est bien maitrisé, le médium parfaitement en place et le grave est vraiment bon avec une belle diversité. Les instruments comme la contrebasse ou le violoncelle ont du corps. La musique électro a du punch.. Bref le casque est bien équilibré. L'image stéréophonique est large mais sans excés. Maintenant le casque réagit bien aux divers enregistrements, si c'est mal enregistré le casque n'arrangera pas les choses par contre si l'enregistrement est de qualité le casque saura lui rendre grâce. Ceci est l'apanage des bons casques!!
Attention toutefois vu l'impédance de 350 ohms, il faut un ampli costaud pour tirer le maximum, ce casque n'est pas nomade, c'est un casque d'écoute pour la maison. Il a besoin de puissance pour s'exprimer au mieux. Après 3 heures d'écoute d'affilée, pour ma part je n'ai ressentie aucune fatigue, ni échauffement aux oreilles dûs aux coussins. Le port est agréable malgré un poids respectable.
Au regard du prix, de sa qualité de construction et des accessoires fournis est on peut dire un grand merci au constructeur qui a réussi à sortir un casque remarquable à la portée de nombreux mélomanes pas forcément fortunés.
J'ai une très longue expérience de l'écoute au casque, puisque j'ai commencé en 1966 avec un casque Sansui et ensuite j'ai possédé un casque électrostatique Micro Seiki en 1972 et ensuite des casque Stax, Grado, Sony audio techniqua etc... etc...
A l'heure ou les fabricants de casques partent dans délires coûteux et pas toujours à la hauteur (Je sais il en faut pour tous les goûts!!) je trouve cela rassurant de voir que pour une somme raisonnable on peut avoir du matériel de qualité qui offre grandement satisfaction.
Albert L.
Pas convainquant
Le son subit une nette dégradation en passant par ce montage, et cela sur les 4 entrées. Un son saturé comme une station radio FM pas tout à fait sur la bonne fréquence. Un léger mieux après avoir changé le circuit intégré amovible par un équivalent sous la main, mais sans plus.
Un casque au rapport qualité/prix remarquable
HUBERT L.
Très belle découverte
J'ai dû remplacer les 4 tubes JJ KT90 d'origine de mon ampli (plus d'offre en KT90), et après avoir hésité avec des Gold Lion Genalex KT88, j'ai finalement jeté mon dévolu sur ces KT120, et je ne regrette pas. Gain en puissance, bien sûr, mais surtout en détails, avec des aigus présents , mais jamais fatiguants (malgré mes HP KLIPSCH RF7 MKIII), des médiums très bien servis et un grave profond à souhait. Bref, je recommande vivement ces TUNG SOL KT120 !!
Robert D.
Very Happy
The DAC sounds great, with details I haven't heard with my previous DAC. The streamer interface is very nicely designed and following an automatic software update, the unit patched into my network and was playing music within 5 minutes. Thank you Audiophonics for exceeding expectations, for the low price and quick shipping.
Gianfranco P.
Wonderful
I purchased this board after watching some videos where DIY streaming projects were presented. I am an enthusiast with white hair now, but I still like to experiment especially with Raspberry units, which with in pi4 model have made a significant step forward also in terms of pure performance. What can I say: the board is wonderfully engineered and equally well assembled. When listening, I noticed an increase in sound definition and a greater stage with incredible separation between the various instruments, especially percussion (which I love). In short, a top product, which does not at all disfigure with my other products costing 10 times more such as the Rose Hi-Fi RS-250 or the Auralic Aries. Money definitely well spent, especially when paired with the Pure Pi and the Tranport PI (with AES/EBU connection that I use to connect with my m2Tech Young MKIII DAC.
A Thank You to my friends at Audiophile who had all the products delivered to my residence in Italy in just 48h.
ELECAUDIO DCT-2.5G Male Jack DC 5.5/2.5mm Connector Tellurium Copper Gold Plated 3µ This DC 5.5/2.5mm Elecaudio DCT-2.5G connector will allow you to design high quality power cables, ensuring a clean transmission of the electrical signal to your HiFi device....
Voix superbes
Des belles voix
Ça chante bien
Le plus cher et le meilleur
Ça chante bien très bien
Banana Plugs Gold Plated Lockable Ø9mm (The pair) These affordable banana plugs allow a quick and easy connection to the terminals of your speakers and amplifiers, while ensuring an optimized contact. The contacts are...
Big banana
On peut en mettre du câble !!! J'ai relié 2 *4mm y'a encore de la place. Système de blocage efficace. Belle qualité de fabrication.
Johnnie M.
Fantastic!
This power amp is just absolutely fantastic! The build quality is much nicer in real life than what the pictures can express! I picked this NCx500 based version over the Purifi 1ET400A, because the Hypex module is more or less exactly the same module, but improved on. The sound quality is amazing, the power and control is almost unimaginable! I can highly recommend!
Jean-Christophe H.
Problème de blindage ?
Fonctionne normalement, pas encore testé en Hi Res.
En revanche, très fort grésillement dans le train (TGV) ... un problème de blindage ?
Luc D.
Je ne recommande pas ce produit
Ce produit :
- Colle très mal
- Est fragile car il se perce facilement
- Est très cher pour 94X20 mm
Donc je ne le recommande pas, je pense qu'il vaut mieux, si possible, utiliser du Kapton.
Luc D.
HYPEX UCD400HG HxR Mono Power Amplifier Module 400W The UCD amplifiers in the HG range are high-end versions of the UCD180ST and UCD400ST amplifiers. They are available in 2 versions: UCD180HG and UCD400HG. They're perfect for...
J'ai utilisé 2 modules UCD400HG pour remplacer les 2 modules identiques de mon Micromega AS400 qui donnaient des signes de faiblesse après 12 ans d'utilisation.
Sans surprise je retrouve la sonorité originelle de mon AS400, c.a.d un son neutre, détaillé, transparent et dynamique. Ces modules permettent d'avoir de vraies basses sur des enceintes difficiles à driver et gourmandes en courant, telles mes Martin Logan Theos dont l'impédance peut tomber à 0,7 ohm.
Avec une bonne alim, un bon préampli et un bon refroidissement (c'est de la classe D mais 400 W cela chauffe !), ces modules peuvent donner beaucoup pour un prix très raisonnable. Seuls petits bémols : la diode bleue d'un des modules s'éteint lorsque l'ampli est chaud alors que le module semble parfaitement fonctionner, et puis je m'aperçois que j'ai payé chaque modules 6 € plus cher que leur prix actuel.
Cédric R.
Fait le job et bien.
Premier cable de cette marque. Il est branché sur une barette Viborg. Je reste sceptique quant à l'amélioration qu'il apporte, j'ai l'impression d'un mieux sur tout le spectre.
Jean Philippe L.
No country of origin
Just came back from Japan Osaka and brought a pair of these connector but a bit disappointed on the packaging nothing is written Made in Japan.
Not on the boxes, not on the connectors even not on instruction manual.
But the products look very nice, well you have to trust with whom you buy!!!!
Bryant D.
Very unsatisfied
The unit I received makes a high-pitched noise whenever the screen is on (40 seconds each time a button is pressed). Feedback from Audiophonics is that this is normal and they are unable to offer any sort of remedy. So overall, I cannot recommend such a low quality product.
