Arvydas V.
A
Mohammed B.
Im Vergleich zu Mundorf...
Mohammed B.
Eric T.
Switching Power Supply Module 700W +/-55V This LLC switch mode power supply module has a main output delivering ±55V. The resonant circuitry uses a high frequency sine wave, ensuring excellent stability and a...
Fonctionne correctement
Très bonne alim mais un tension auxiliaire donne du 21 V au lieu du 12 V indiqué. Cela surprend mais on s'adapte
Eric T.
Très bon boitier
C'est très bien pensé, un minimum de vis mais il faut réfléchir avant de bien le monter.
Eric T.
Finition impeccable
Très classe comme design
Eric T.
Phono Preamplifier Board Low Noise OPA JRC5532 This phono preamplifier module benefits from a nice design, using two JRC5532 AOPs mounted on DIP8. It is also equipped with two Nover 35V filtering capacitors of 4700µF...
Trop sensible
Sature très rapidement. Faible gain
Anon
expected and received - spatial, clear and detailed reproduction with substance
used in a crossover as bypass for a couple of ClarityCap SA midwoofer-capacitors of a two-way factory speaker (MCap Supreme Classic for tweeter).
fast shipped (less than 4 days) to Germany !
Eric L.
Avec une correction précise des fréquences ce petit vibreur fait des miracles. Je le recommande fortement.
Philippe N.
Très bon condos,utilisé pour du filtrage d'enceintes ou découplage d'amplis à tubes.ils ne rajoutent rien,et n'enlève rien,très bon rapport qualité prix,cela s'entend à l'écoute c'est indéniable.
Andis O.
All in one!
I bought this amplifier because I was looking for a cheap powerful amplifier with a DAC. I have used several SMSL, Topping and Hypex models. This is a great amp with plenty of power and a clean, pleasant sound. The timbre adjustment option is very good. Only at first I couldn't understand how to do it :)) If you are looking for an all-in-one device, there is no alternative at this price! You will definitely pay 2-3 times more to get this sound. I recommend!
Yannis G.
Oh my it's AMAZING
Unbelievable audio transfiguration, I connect it to my desktop pc and a SMSL DA-9 amplifier, guys just buy it, you will listen to another universe with that thing!
Arthur H.
Cable modulation
Bon câble, conforme à mes attentes.
gonzague d.
Bon cable
Très bon câble qualitatif dont la finition est superbe pour un prix correct et surtout pour la qualité du son. Dommage qu'il n'existe pas en longueurs plus courtes.
gonzague d.
Fourche face concave
Belle qualité de fourche, montage facile mais une face est légèrement concave et empêche un bon serrage sur le bornier ( sur des Dali ). Il faut pouvoir serrer très fort et même comme cela la fourche à tendance à tourner sur le bornier. Attention donc si vous êtes amené à déplacer les enceintes selon l'écoute.
Pedro B.
An amazing DAC with a truly sense of presence and naturalness!
Nowadays DACs play an import role in a system, as the new formats like HD PCM, DSD, MQA and streaming services become available. While every other component can stay steady, the DACs are quickly evolving. For a couple of years, almost 15, I’ve have been keeping the Krell CD player, the Krell amplifier, the B&W floor stand speakers, the Rega turntable and Vincent phono preamp, only replacing the music player (streamer) and the DAC. So, I had some DACs from Cambridge Audio, NuForce/NuPrime, Gustard (X16) and Mytek. All different and each with their strengths and weaknesses. With R26 I’ve found a very nice balance for sound stage, detail, transparency, and pace, but the biggest difference is a truly sense of presence and naturalness which is amazing. Using a music streamer based on Rasperry Pi 4 connect via USB 2.0 port, everything works fine too (current R26 firmware version is 1.4), without any issues (from Spotify, TIDAL, Youtube and local music database based on a NAS). The built-in streamer works very well, decoding all formats easily. Tried 2 configurations: 1st With Roon installed on a Synology DS220+ NAS (Intel CPU required) with a local library of music files and everything worked fine too. 2nd using R26 used as a UPnP renderer via mconnect Player Lite, but some improvement is required for this as, occasionally, the first time a DSD file is loaded from the NAS (using DLNA), there are some halts (these files are huge in size). Had 2nd thoughts about the A26 model, also a very praised DAC by critical listeners and reviewers, but there is something in the high processed audio signals from Delta-sigma DACs that make long listening’s easy tiring. In summary R26 is very musical DAC giving great sense of realism, excelling in bringing the emotion of live recorded music. For listening the best results are obtained in Non-Oversampling mode (NOS ON). Last a praise to Audiophonics which sent the equipment fast and very well protect.
Pedro B.
An amazing DAC with a truly sense of presence and naturalness.
Albert L.
Exemplaires dans la transmission audio
Deux paires acquises pour relier les 4 sorties médiums et aiguës d'un processeur numérique aux entrées d'un amplificateur 4 canaux. Le but étant d'améliorer la qualité de transmission des signaux dans ces zones de fréquences précises. Ce fut le bon choix, car ces câbles ont corrigé un problème de saturation : pics d'impulsion atteignant la limite réglée, mesurée par le vu mètre du processeur numérique. Depuis le son est moins agressif, plus claire, dynamique sans distorsion ni saturation désagréable lorsque l'impulsion maximale imposée est atteinte sur ces voies respectives.
A noter que la différence de couleur des câbles n'est pas le seul moyen de les repérer. En effet, la texture des gainages n'est pas la même. Le câble gris étant moins lisse mais aussi légèrement moins souple que le rouge, le repérage peut donc se faire également au toucher. Des détails certes, mais cela peut avoir son importance dans certains cas. C'est un fait, mais à vrai dire sans relation avec le conducteur et les connecteurs RCA, de choix, qui assurent neutralité et transparence des signaux audio. Une paire de câbles de modulation RCA performants, exemplaires dans cette gamme de prix.
Francois P.
Ces AOP Vivid simples ont remplacé avantageusement des AOP OPA627 et OPA828 (AOP très réputés) sur mon Streamer DAC Cocktail X45 Pro.
Meilleure aération, meilleure tenue du grave, scène sonore plus tridimensionnelle. Bref. Satisfait de l'achat!
Un must au rapport qualité/prix redoutable ! !
Je utilise ce pré Audio GD Master 19 depuis env 2 mois mais je voulais prendre du temps avant de poster un avis sûr.
Que dire d'autre que:
Formidable préamplificateur !
Rapport qualité/prix difficilement, voire impossible à dépasser !
Réalisation audiophile et qualitative au top !
Très bien fabriqué, mise en œuvre et finition sans rapport avec le coût.
Tous les Know-How et astuces audiophiles réellement efficaces sont bien présents ici et l'on sent que les concepteurs connaissent ce qui permet de bien "sonner".
Je confirme aussi que cet appareil se bonifie durant premières 80 à 100 heures. (Rodage)
En tant que qu'ex pro et ex journaliste de revues hifi j'en ai possédé une bonne vingtaine dont des plus réputés; et bien ce préamplii ligne est comparable aux meilleurs voire même mieux que la plupart vu entre autres l’extrême soin apporté aux étages de sortie ici en pure classe A sans contre-réaction. Rare et exceptionnel sur le plan de la musicalité (même si moins "éclatant" aux mesures"); et... cela s’entend vraiment.
Sa neutralité et sa transparence sont exceptionnelles et à même de révéler la faiblesse des autres maillons !
Si les éléments périphériques autour du Master 19 évoluent, (ampli, enceintes, source), il suit en confirmant ses performances ; il ne semble limité que par la faiblesse éventuelle des autres maillons. "C
"Cerise sur le gâteau: Audiophonics le livre avec une superbe télecommande en métal massif qui est ailleurs optionnelle à plus de 50 €.
Bravo !
PS: Je ne suis pas payé par Audio-GD
HAUTEMENT RECOMMANDE !
CB
THIERRY S.
Bien mais
Produit correct, mais pas facile à serrer. par manque de méplat sur le devant de la prise
THIERRY S.
Trés bon rapport qualité prix
la construction est sérieuse.
Le "touché" est agréable pendant la commutation.
Patrick J.
Good tool to smart up your old amplifier
I bought the trigger to make my existing amplifier smart in combination with a Sonos port. Does exactly what it needs to do.
However, some mods needed...
The port in my amplifier is of the C13 format without ground. It seemed that the trigger did not stay quite straight in (horizontal) and occasionally lost contact. Resolved by using some electrical tape to make the plug a little thicker. Therefore one star less.
Opted for shipping via dpd to the Netherlands, this took about 3 business days. Package was nicely packed and not too oversized.
René A.
Trop top !
Excellent rapport qualité prix. Toutes les fonctions sont là et les performances sont audibles.
Design chinois, peut-être mais le résultat est au meilleur niveau et représente une sacré concurrence à des marques haut de gamme
Ravi de mon achat
Jean-Louis M.
achat conseillé
avis très positif après 3 semaines d'utilisation (écoute sur casque et ampli STAX): je ne vois pas de défaut, c'est dynamique, fluide, bien timbré et la scène sonore est très bien construite dans toutes ses dimensions.
J'ai comparé à plusieurs reprises à un autre DAC quatre fois plus cher acheté il y a quatre ans. Résultat : le nouveau venu est meilleur.
C'est dire les progrès enregistrés par les DACs (ou au moins certains DACs) en quelques années.
A signaler aussi que le produit me semble bien fini.
Claude S.
Un rapport qualité/prix excellent
Ce DAC fourni une qualité de son exceptionnelle, grace à des composants de haut niveau, une conception moderne, une réalisation de qualité, il ne s'embarrasse de fonctions inutiles, il présente donc un taux de distorsion et un rapport signal sur bruit très faibles et cela s'entend sur ma chaine HiFi dotée d'enceintes Martin Logan ESL électrostatiques et d'ampli et préampli Classe A. Le son est d'une pureté exceptionnelle. Même les non-initiés sont séduits.
François G.
TANG BAND W5-1611SAF Speaker Driver Full Range 28W 8 Ohm 90dB 60Hz-20kHz Ø12.7cm The Tang Band W5-1611SAF is a 12.7cm diameter full range driver, ideal for integration into compact loudspeakers. It features a robust polypropylene diaphragm supported by a...
Un très bon large bande
Un copain m'a fait découvrir ce petit haut parleur qui a une très belle restitution du bas médium entre autre.
Je l'utilise dans des enceintes bibliothèque en 2 voies avec un tweeter AMT, après essai en clos et bass reflex, c'est la deuxième solution que j'ai retenue, en clos il y a un manque dans le grave et il faudrait rajouter une troisième voie.
En utilisation en 2 voies, on a un gain sur la définition, détails, ... en comparaison sans tweeter.
Un excellent haut parleur que je recommande vivement.
Excellent et surprenant
Un petit "machin" à 40€ bluffant de qualité. Tient la dragée haute à des produits valant x fois son prix !!!!!
Simple de mise en route, zfficace
Thomas M.
it wrorks very well
Absolutely no problems with win 10, asio driver and connections.
Martin B.
Good improvement for a Musical Fidelity MX DAC
I had ordered your Linear power supply 5V 2A for powering a Musical Fidelity MX DAC (power consumption 5.18 V 0.89 A).
(It had been recommended in HiFi magazines to replace the MF "Wall Wart" switching power supply by a quality linear power supply, because it would improve the sound).
Before ordering , I checked this statement (using a linear laboratory power supply) and (to my surprise) indeed the depth, width, separation of instruments in the soundstage improved remarkably (of course using a good HiRes recording e.g. Katie Mulua No 8 acoustic recording (96/24 WAV) from www.HiRes Audio.com.
I checked the Musical Fidelity Wall Wart Switching Power supply and it indeed appeared to have a lot of noise extending from the KHz regime all into the Mhz regime ( I used a 100 Mhz BW Tektronix 465B scope to investigate this ).
NB The lab supply had only noise (1 mV pp) , in the regime of higher than 20 MHz.
In view of the encouraging results with the lab Power Supply I ordered yourAudiophonics Linear Low Noise 5V 2A power supply with equally good results.
(significant increase of breath and width of soundstage and separation of voice and instruments).
Checking by oscilloscope revealed a noise free DC below cut off of 20 MHz and only one small sine noise (1 mV PP) at approx 35 MHz .
Most likely this will be damped in the DAC itself, anyhow.
All in all , a recommendation, of an item in which initially I did not believe in!
BTW one cautionary remark:
The Musical Fidelity MX DAC is critical with over -and under voltage (inbuilt power protection).
I had to increase the 5V DC voltage of the Audiophonics slightly with the trimmer potentiometer at the back ( to 5.19V).
Reason:
Initially the MF MX DAC did not work at all with the power supply (only power LED lit, but otherwise dead).
Increasing the voltage (1/4 turn ) solved this and kicked the DAC into life.
Anne b.
condensateur mundorf 10000uf 63v
montage condensateur mundorf 10.000uf 63v sur ampli tuner kenwood vraiment bien ca change le son le rodage n est pas encore fait tres satisfait du produit tout simplement
PATRICK D.
Cable de bonne facture, la qualité est au rendez-vous.
PATRICK D.
Signal faible
Je déconseille ce produit qui fonctionne mais avec une énorme perte de niveau qui le rend inutilisable pour une utilisation de qualité. Test effectué sur plusieurs appareils. L'achat d'un autre convertisseur a réglé le problème.
Peter P.
Peter P.
High Quality product
Claude V.
AUDIOPHONICS BT60W PRO HiFi USB DAC Amplifier Infineon MA12070 Bluetooth 2x55W 4 Ohm Audiophonics offers you a revised version of the compact but no less excellent BT60W amplifier with its PRO version. On the menu of improvements: an increase in power and sound...
Je l'utilise depuis plus de 2 ans avec des enceintes DAVIS EVA ayant comme source un PC relié en USB et je suis toujours étonné de la qualité sonore de l'ensemble pour un petit budget
Antonio C.
Excellence
Qoui dire: en quelques jours seulement ce DAC est en train de prendre le dessus sur mes autres appareils. Le lecteur de CD Prima Luna passe par là, le préamplificateur Conrad Johnson n'est que rarement utilisé. Je branche le RME DAC directement sur l'amplificateur de puissance (un CJ Première 140 à tubes) qui alimente mes haut parleurs passifs (des vieux Sonus Faber Guarneri). J'ai pu faire quelques ajustements pour une écoute agréable pour mes oreilles. Je le connecte aussi à mon téléphone Android et à un iPad et je vais bientôt compléter la chaîne avec un streamer WiiM qui sera connecté via coaxial ou optique (pour ne pas utiliser le DAC interne du streamer). Un changement important pour mon écoute a été la capacité de reproduire bien la musique même a des niveaux sonores plus bas: la musique reste audible sans devenir un bruit de fond comme c'était le cas auparavant. Il y a encore pas mal de paramètres à découvrir et essayer. Entre temps, c'est une belle réussite, bravo!
GERARD V.
media sun
Excellent câble pour un prix correct.
Meme approche de son plus que satisfaisant sur mon système.
À recommander dans cette gamme Cuivre/Argent.
Merci audiophonics, envoi parfait comme d'habitude.
Nikolaos R.
Very good build quality. It works very accurately and has a great antique finish! It added value to my build.
Laurent B.
Après le Raspdac mini, j'ai choisi l' Evo-sabre pour le câblage de mes HP Genelec (Symétriques) .
Un régal de précision, image stéréo bien définie.
J'ai rajouté un radiateur (Geekworm Raspberry Pi 4 Embedded Heatsink with Fan) pour le raspberry (sans le ventilateur) il s'adapte sans problème .
Patrik L.
The cable is missing a separate conductor between RCA sleeve and XLR pin 3 to avoid ground hum.
Patrik L.
Note that XLR pin 3 is connected to the RCA sleeve and not left open.
Jean-Claude P.
soundcare version sans filetage
Je suis très content de mon achat. Avec ma platine Atoll cd50 cela marche à merveille. Le son est précis sans être froid comme parfois avec le cd, avec un côte feutré et on peut même dire moelleux (cela provient peut-être aussi de mon ampli). En tout les cas le résultat est très supérieur qu'avec des pieds beaucoup plus chers que j'ai eu l'occasion d'essayer auparavant. Merci Audiophonics pour le prix imbattable et pour la livraison parfaite.
Joris J.
Surprisingly powerfull
The build in amplifier of my old Monitor Audio Radius 360 subwoofer died. In stead I connected the driver unit directly to this little amplifier. (so I used the sub as a passive subwoofer). Powered by a 6 ampere 24V SMPS:
Surprise: bass sounded deeper, less boomy/muddled and more powerfull than with the original build in amplifier of the subwoofer!
Thanks to audiphonics.
pascal P.
Adapter Impedance Transformer SPDIF Coaxial 75Ω to AES/EBU 110Ω This adapter and impedance transformer will allow you to convert a 75Ω SPDIF coaxial signal into a 110Ω AES/EBU signal and thus to connect devices with these...
Utile ?
J'ai acheté ce transfo pour connecter la sortie 75 ohms de mon MiniDSP SHD à l'entrée 110 ohms de mon Behringer DCX 2496. C'est moins bon qu'avec un simple cordon coaxial vers AES/EBU. Pourquoi ? Je ne sais pas si le transfo est en cause ou si mon DCX est un "faux 110 ohms" et du coup sature.
Part ailleurs l'appareil semble bien construit et sérieux. Cependant, mauvaise surprise quand j'ai vu qu'il fallait lui adjoindre une alimentation 5 V ce qui est mal pratique et ajoute des frais.
N'utilisez pas de cordons coax vers AES. cela existe bien mais ne correspond à aucune norme et ne respecte pas l'impédance nécessaire.
Ce produit est actif et dispose d'une batterie interne, il est en effet nécessaire de le recharger.
Florent D.
Je recommande fortement
Parfait pour la transmission numérique.
Remplace un cable bas de gamme (entre lecteur et DAC), avec ce cable Audiophonics
tout est en place, les basses sont enfin là, la restitution est transparente, medium bien placé.
Tous ces pulses et bits arrivent maintenant 'dans le bon ordre':75ohms de bout en bout c'est ce qu'il faut.
Le prix du câble est justifié, moins cher que d'autres marques réputées, justifié au vu du résultat et de la qualité de construction.
Merci Audiophonics
Christian R.
Des améliorations très audibles
J'ai acquis cette alimentation pour mon streamer Node 2i tweaké par une carte polonaise. Par rapport à l'alimentation fournie avec la carte, l'amélioration apportée par l'Allo Shanti est immédiate, et encore plus audible après un rodage de quelques heures. Des micro-informations sont plus nettes, l'ensemble du son est plus doux. C'est la meilleure alimentation que j'aie acquise chez Audiophonics jusqu'à présent.
Rinze B.
Power Supply
Very good power supply for the price. I thnk you can buy better ones but not for this price. It is a very good combination with my music server. I am very pleased with it and would recommend this.
Rinze B.
ATAUDIO SQ-7 Angled Power Connector Schuko Gold Plated Ø19mm ATAudio's SQ-7 angled Schuko power connector features superb build quality and will allow you to design high-end power supply cables that perform and look great. Its transparent...
Good quality for the money
This connector is strongly build and has even an angle positioning integrated. I am very pleased with this connector. I would recommend this also to others
Hervé T.
Active SPDIF Optical Toslink Switch 3 to 1 This SPDIF switch has three inputs and one output in Toslink optical format. It allows you to multiply the number of sources for the same output, and to easily select the active...
Switch qualitatif
Bon matériel, conforme à la description, fonctionne bien, aspect qualitatif, tout métal. Bon rapport qualité/prix
Hervé T.
SMSL SU-9n DAC ES9038Pro USB XMOS Bluetooth 5.0 32bit 768kHz DSD512 Little brother of the SMSL SU-9, the SU-9n is a modified version, with all the characteristics of its model, but this time without the support of MQA files, of the Bluetooth UAT...
DAC très performant
Très bon DAC. Utilisé avec un bloc de puissance Audiophonics HPA S400 ET, le couple s'entend à merveille. Le couple surpasse un ampli intégré de renom que j'avais de la même gamme de prix et ça s'entend!
Bon rapport qualité/prix.
Hervé T.
Super Ampli
Très bon matériel, à la fois puissant et précis. Son clair et détaillé, graves percutants et vifs. Utilisé en gain moyen en XLR. Écoute addictive!
