Thierry H.
upgradable
Bruno R.
Semble OK
Radek P.
neotech nei 1220
Customers reviews - There are 19384 reviews.
DAYTON AUDIO H812 Horn for compression chamber 800 Hz Dayton Audio horns are designed to operate smoothly until the lowest possible crossover frequency. whIt maintains consistent and predictable dispersion throughout the intended...
Bonne base en un pouce
Je vais la compléter sur les côtés (tout l'arrière) avec des plaquettes de marbre et d'acajou, puis la remplir avec du béton de résine qui va rigidifier et densifier les parois exponentielles. Pour le look, et pour le son.
Joris J.
Male USB-B to Male Micro USB OTG Cable 50cm This high-quality OTG USB cable includes OFC copper conductors and gold-plated connectors (USB-B / Micro USB). In addition, being OTG you will be able to use it to connect USB...
Beter than iFi
I had the iFi 15 cm micro USB OTG with a another quality 50cm to USB-B,
but this cable sounded immediatly more clear and direct, including bass.
Joris J.
VISHAY ERO MKP1837 Polypropylene Capacitor 5mm 160V 0.1μF Vishay's ERO capacitors are polypropylene film MKP capacitors. They offer good performance in a compact size.
Big improvement
I replaced WIMA decoupling caps in my DAC with these VISHAY and ik Made a big difference; more detailed highs, more spacious.
I coulant immediatly hear it but it took a about 10 hours to settle down smooth
RENE R.
PANGEA FIRST SE Phono Cable RCA / RCA with Ground 1.25m The Pangea Premier SE is a high end vinyl turntable cable incorporating a ground conductor is a neat design. It integrates Cardas and OFC Copper conductors, PE insulation and...
cable pangea premier se
super cable d'un rapport qualité prix excellent. Seul bémol qui lui coute une étoile (à mon avis) peu de différenciation sur les fiches.
Le marquage rouge n'est pas terrible, seul ramm fait pire!!!
Michel B.
Unity Gain Buffer Symmetrizer / Desymmetrizer XLR RCA 2x AOP LM4562 2x LM317 This unity gain buffer offers dual connectivity, both unbalanced with stereo RCA input and output and balanced with 3-pole XLR input and output. In addition, it also takes on...
Vraiment bon
Je viens de tester l'appareil au banc d'essais, j'utilise un analyseur de distorsion Hp333A qui date un peu mais qui reste fiable.
Le test porte sur la chaîne complète càd symétriseur, transport du signal via 50m de câble, désymétrisation et mesure. C'est très bon! Le niveau d'entrée max est de +18dbu, la sortie est à +24dbu, ce qui est normal car si le gain du désymétriseur est unitaire le fait de passer d'un signal symétrique vers asymétrique va augmenter le niveau de 6dbu (pour que ce ne soit pas le cas le gain de cet étage devrait être de 0.5). La distorsion est faible, limite de la mesure de mon analyseur, 0.015%, en réalité elle doit encore être bien en dessous. Le rapport signal bruit est plus grand que 100db et j'ai oublié de faire la bande passante mais ce n'est pas bien grave. En conclusion je dirais que l'appareil convient pour des applications professionnelles, vu le niveau qu'il accepte et les performances mesurées. Si vous êtes passionné de hifi il sera aussi du plus bel effet parmi les autres pièces de votre installation.
Antoine L.
J'ai acheté ce combo DAC/ampli pour aller avec un casque Philips SHP9500 pour découvrir l'univers du son Hi-Fi casque... et je ne suis pas déçu!
Produit de bonne finition, très simple à mettre en place. Tous les accessoires sont fournis.
Largement assez puissant pour mon usage, très content de mon achat.
François C.
Stainless Steel Switch with White Light Circle 1NO1NC 230V 3A Ø16mm Silver This 1NO1NC stainless steel bistable switch allows easy integration into your DIY projects. It has a white light circle that visually indicates the status of the button.
Très bien, LED ok sous 5v.
Bon à savoir, la LED fonctionne également très visiblement sous 5V. J'avais peur qu'elle se voit mal, mais il n'en est rien. Tant mieux pour tous ceux qui ont ce genre d'alim.
GUILLAUME C.
préampli Riaa
Bonjour, je voulais savoir si toutes les entrées sont identiques ou si l'une d'entre elles possède un préampli Riaa afin de brancher une patine vinyle...
Ce n'est pas le bon endroit pour poser des questions produit.
Et non même chose ici (pas d'entrée phono) ce serait spécifié dans la fiche.
GUILLAUME C.
préampli Riaa
Non aucun préampli phono sur ce produit.
Toutes les entrées sont niveau ligne.
Reynald D.
Très bon transfo utilisé pour une PCB préampli à tube, branché en parallèle même si c'était inutile vu les besoins du préampli en courant.
Pas un bruit etc.Je recommande
LAURENT G.
DIY Aluminum Case Silver Front Panel 260x155x60mm This brushed aluminum case is ideal for the integration of a DIY audio project, such as an amplifier, preamplifier or DAC. Rugged, it will allow you to effectively protect your...
Robuste
Très beau boîtier ,bien fini. Le corps est en alu anodisé brosse,très rigide,l'ajustement est parfait.Très bon rapport qualité prix.
Michel B.
Belle pièce
Magnifique boîtier en alu, un peu gros pour la fonction mais qui inspire confiance. Je l'utilise pour alimenter deux enceintes de monitoring actives Quested dont les entrées sont symétriques, le signal provenant de la sortie monitoring auxiliaire, asymétrique, de la console. Ce symétriseur remplace deux transfos dont les rapports de transformation n'étaient pas tout à fait adaptés. Le son est excellent, meilleur qu'avec les transfos. Je n'ai pas encore eu l'occasion de passer l'engin au banc d'essais mais je prévois que le test sera positif. L'appareil est un peu cher, j'en ai construit un du même genre dans un volume moitié, pour la moitié du prix, il est moins beau, pas moins bon, et c'est sans compter les heures de travail. L'appareil est utile pour les liaisons de grande longueur, si on veut bénéficier de la réjection du mode commun dans les liaisons symétriques. Si ce problème ne se pose pas, ça marche très bien en mettant le point froid à la masse, on peut faire des économies.
Un engin utile pour résoudre le" hum & buzz" dans les installations sérieuses. Autre bon point: sa réversibilité.
Cavacece a.
Really good
I use the ibasso dc04 with tidal or USB audio player pro. Mi iem is campfireaudio. It is good. I' m thinking to sell my dal after this purchase
Albert h.
lecture cd
très bon appareil car je cherchai un ampli ayant les qualités d'un tube sans en avoir l'usure, employé avec préampli à tubes et casque électrostatique Sennheiser unipolaire 2002 de 40 ans et lecteur cd Marantz avec convertisseur 24/192 khz ,avec musiques classique et jazz incroyable les détails
Alexis J.
Splitter HDMI ARC to SPDIF Coaxial Optical RCA Jack 3.5mm DTS Dolby AC-3 5.1 This compact audio extractor will allow you to simply extract the audio signal from an HDMI ARC input stream and then output to Coaxial, Optical, RCA stereo or an amplified...
Ca remplit son rôle !
Parfait pour extraire le son d'une sortie HDMI (ARC) d'un téléviseur ou rétroprojecteur, et l'injecter en optique dans un ampli. Ca marche !
Christophe V.
Un avis mitigé
La marque et son produit sont connus et reconnus.
Mais l'humain ne retient pas que le bon mais aussi le mauvais.
En effet payer plus de 8 euros pour une livraison en 24-48h, n'a pas été une bonne idée.
En effet GLS n'a pas respecter ses engagements.
Livraison avec 1 jour de retard.
Chez GLS cela semble "normale"......
Audiophonics n'y est pour rien certes.
Mais il faut savoir que les services de livraison ne sont pas forcement bon.
andoni g.
works well
i use for conect a meze clasic with balanced 2,5 to a headphone amp with 4,4 and works well, no problem
Thomas F.
Very compact, powerful and smooth hybrid class A amp
I have a few headphone amps; some for clarity and details (THX789, Topping A90, ...) and some for richness and warmth - including class A ones (RebelAmp), OTL tube amps (DarkVoice) and hybrids (SMSL T1, Loxjie P20). This MT602 is a very nice addition to the collection. It provides a nice tuby warmth with some smoothness but does not loose in clarity and punchiness. Despite its very small size, the amp is very powerful and drives some demanding headphones quite well. As a hybrid, it is also quite nice for my planar headphones. It works also very well as a pre-amp in the chain. The build feels like quality. In total, the amp is absolutely worth its price.
I exchanged the two Chinese 6J1 tubes (which are not bad) with GE5654s and VOSKHOD 6J1P-EVs. I prefer the Voskhod ones since I feel the bass is more defined with them. Only small issue is that the switch-on delay is not working equally on both channels.
Stephane P.
Ayant un système minimaliste, dont une platine CD avec niveau de sortie réglable directement branché sur un ampli de puissance, je ne me sers que d'un canal du préamplificateur comme réglage de balance (atténuation d'un canal), ayant parfois une position d'écoute excentrée dans la pièce. Un peu bricolo mais ça marche parfaitement.
Stephane P.
Etonnant !
Acheté un peu par curiosité pour bi-amplifier un système entièrement à pavillons sauf l'extrême grave : les quatre canaux alimentent donc l'ensemble sans problème, alimentés en 36V par une alimentation réglable de laboratoire.
Très impressionnant à première écoute, un peu de bruit de fond avec l'oreille collée dans les bas-medium, et curieusement aucun dans les compressions medium et tweeter à compression également. Bien entendu inaudible avec de la modulation en cours.
Bel objet en plus !
philippe d.
Petit boitier qui fonctionne correctement
Qualité sonore acceptable. Voyants rouges trop lumineux. Je l'utilise pour seulement une écoute à bas niveau (ambiance,...) sur mon ampli qui n'a aucun correcteur de tonalité ni loudness, quand la source est trop linéaire. Il répond à mes attentes.
philippe d.
Bon matériel polyvalent
Son plus percutant dans variations brusques, améliorations générales. Cependant, prendre garde au fait que les embouts sont vissés sans freinage. Il ne faut pas trop les serrer mais d'un autre coté, sans frein prévu, ils peuvent se débloquer en tournant à peine. Alors la liaison électrique sera basée sur le passage d'un petit filetage sans serrage. Une rondelle éventail acier ou une rondelle fine en laiton pourrait mieux bloquer ces liaisons.
Jürgen S.
J.S.
I was surprised how professional the ordering/shipping from France to Germany was handled by Audiophonics. Communication in English. Perfect information about state of order. Everything as it should. 5 Stars.
The packaging was functional but not as nice as you would expect it from a big high-end name. For me this is saving money at the right end, as I don't have the place to collect large boxes. 4 Stars.
The product looks much nicer in reality than on the pictures. The complete housing is made of brushed aluminium. Look and feel is solid, and everything you could expect is there. Trigger input, power switch/button at rear and front, well visible LED indication that it is switched on. The box gets warm when running a few hours but not hot. 5 Stars.
I opted for the small stereo board from Hypex because I like the small form factor and don't think a dual-mono solution would be audibly better. The final destination will be in a TV setting, but I made a sound check with my stereo.
My first impressions and comparison with a 5 year old dual-mono class A/B power amp in a 3000 Euro price range: I don't hear substantial differences. Bass is very clean and controlled. Possibly the highs sound slightly recessed on the Hypex amp compared to class A/B, but these differences are subtle and could as well be subjective. I am neither missing soundstage, nor separation or detail. Amazing for the price. 5 Stars.
Equipment: Topping D90 + A90 as source, 3 way LUA speakers (which require a bit of power).
All in all I can highly recommend the amp. Transparent and controlled sound for small money.
GEORGES V.
Selector 4 inputs 3 positions Ø6mm flat axis This 4-pole x3 position mechanical selector allows to switch several signals to a common point. It works in both directions, the IN can also be an OUT. The notches are...
Trop dur
selecteur de qualité mais trop dur à tourner , même avec un boutton de 40mm de diametre
Vid B.
Amazing dac
Really good dac, sonically superb. Also good support from audiophonics team.
jean-baptiste l.
C'est mon troisième... et 5 étoiles
En un an et demi de bons et loyaux services, pas un souci, même si on pouvait douter de la durabilité de la commande manuelle du potar.
Si c'est mon troisième, c'est parce que lorsque les gens l'écoutent, (après s'être tordus de rire en voyant l'aspect de la bête), ils sont suffisamment snuffés pour que je me sente obligé de leur en acheter un en cadeau.
Après avoir alimenté des Cabasse bibliothèque, l'animal me sert désormais sur des colonnes Ellipson (oui môôôôsssieu, j'achète français...sauf les amplis). Bon, c'est un peu plus dur a emmener sur des musiques exigeantes où il arrive que le petit SMSL panique - notamment sur des guitares grunge - mais de toute façon, vu le rapport qualité prix, c'est du 5 étoiles et basta.
Ouvrez bien vos oreilles et fermez la bouche, la Covid ne s'attrape pas par le pavillon
Bien à vous tous
Anne b.
NICHICON KW Electrolytic Audio Capacitor 50V 10000μF The KW series is a range of electrolytic capacitors specially designed for audio use. They offer excellent performance and technical characteristics.
condensateur nichicon
ce n est pas du tout les meme condensateur d origine je vais les employé pour autre chose un peu déçu quand meme
Christian C.
AUDIO-GD A-2 Headphone Amplifier Preamplifier Class A Discrete ACSS 2500mW The Audio-GD A-2 is a Class A headphone amplifier and preamplifier combo that takes advantage of totally discrete analog stages to offer a high quality sound reproduction that...
Bien, mais peut mieux faire
L'absence de notice est un peu gênant, l'utilisation des straps. pour modifier l'équilibre tonal n'est pas très aisé. Sur la position zéro du sélecteur de gain et volume au maximum, une tension parasite de faible amplitude et de 0,5 Hz environ apparait sur la sortie audio. Ce phénomène entraine un déplacement insolite des membranes des boomers. Ce phénomène disparait en sélectant le gain sur 1. Heureusement la qualité sonore est au rendez-vous.
Donal O.
Excellent DAC & Preamp
Great quality DAC with impressive stereo soundstage, simple but flexible menu-based configuration and uncomplicated remote control. Used as preamp, switching between USB (macbook) and TOSlink (TV), to active monitors or headphones (with independent volume control). Unbeatable quality and features at this price point.
Dominique B.
Après rodage meilleure saturation des couleurs, meilleure profondeur, TV oled Philips, box fibre orange, le tout passe par un Yamaha Rx a820
Bruno B.
Coaxial to Optical Toslink SPDIF Digital Adapter Offered at a low price, this simple SPDIF adapter will allow you to obtain a Toslink Optical signal from a Coaxial signal, for example to connect a TV or an Internet box.
Livrer en 48 heures, installation en 3 minutes, super content.
Permet de lier une television TECHWOOD avec une sortie cable SPIDF vers une barre de son SAMSUNG avec une entrée optique.
Je recommande.
Françis S.
Françis S
On peu trouver des prises de bon maintient dans le commerce de bricolage , mais pas avec des fiches qui ne s'oxydent pas dans le temp . Donc, si l'on veux une installation propre , c'est une bonne solution ,qui permet d'être sur de ses contactes .
François-Xavier L.
Alternative pertinente au marché de l'occasion
Je cherchais un intégré pour mon système DIY en tri-amplification active, le marché de l'occasion sur des références d'amplis reconnus m'ayant réservé quelques surprises par le passé...
Sur les conseils d'Audiophonics, j'ai utilisé cet ampli sur la voie médium en substitution d'un NAD C356 Bee révisé. Une fois le réglage de niveau validé à la mesure, et passé quelques jours d'écoute, je dois dire que cet ampli est une grande réussite.
L'effet stéréo est d'une toute autre mesure par rapport au NAD. C'est la différence majeure, avec une tonalité moins portée sur le bas médium et beaucoup plus de détails à l'écoute.
Autre bonus : l'encombrement réduit (je pourrais presque en mettre 3 pour l'encombrement d'un ampli hi-fi classique...).
Enfin, je n'ai pas constaté de chauffe ni de ronronnement au niveau transfo.
Recommandé !
Michel B.
Minuscule
A l'ouverture de la boîte on est surpris par la petite taille de l'appareil, il est vraiment minuscule! La qualité de fabrication est pourtant bien là. Cependant, pas la moindre trace d'un quelconque mode d'emploi. Il n'y a pas non plus de chargeur, seul un câble USB permet de raccorder une alimentation en provenance d'un port USB. L'appairage bluetooth se fait en posant le téléphone sur le boîtier, après avoir pris la précaution de mettre sur ON la fonction NFC du téléphone. Procédé extrêmement simple et rapide. Le son est parfait, un autre bon point est la rétrocompatibilité avec des appareils non équipés de codec aptX dernière génération. L'ampli casque est moyen.
En résumé, bon appareil, pratique. Tout a fait recommandable.
François G.
JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 8.2μF Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system to reproduce every nuance, every...
Condensateur Jantzen audio superior Z-cap
Condensateur de qualité utilisé sur un filtre d'ordre 2 pour des tweeters Heil AMT.
Je recommande.
GUSTARD U16 USB Digital Interface ES8620 SPDIF AES/EBU I2S HDMI LVDS Accusilicon 32bit 384kHz DSD512 The Gustard U16 is a high-end USB digital interface that integrates very high quality components into an intelligent architecture optimized to deliver exceptional sound...
Interface remarquable
Cette interface numérique s'avère efficace et la liaison USB convertie en AES/EBU est tout simplement excellente. Mon DAC a gagné en musicalité. J'avais besoin de cette interface car j'utilise un DAC qui ne possède pas de liaison USB mais seulement des liaisons toslink , coaxiale et XLR AES/UBU. Cette interface apporte vraiment un grand plus sur le message musicale.
Fabrice S.
restaurations ampli
très satisfait
Fabrice S.
LJM stereo Loudspeakers protection 15A Protection module for speaker
restaurations ampli
très satisfait
Fabrice S.
restaurations ampli
très satisfait du double module simple à mettre en œuvre
Michael A.
Preamplifier Volume Control OPA2604 This preamplifier is both simple and efficient, and benefits from a robust and high-performance design that provides high-quality, transparent and accurate audio reproduction.
The simplicity of being!
Well, 180 € is worth a game, alternatively you can still test something with a few OPA's that are out there, that was the background for my purchase decision. But what I have unpacked there was really stunning. Purely subjectively seen / heard plays completely in a different league than what you would expect here, very clear and detailed, huge foundation of structure, I know that sounds like hi-fi magazines but otherwise I can not describe it. It plays with a very high output voltage, on a UcD 180 brutal and on a KT 94 SE tube to kneel down, Incredible that it is here in a 180 € preamplifier, I know only from very high-priced equipment. Currently it runs with 1x V6 Vidid and 4x NJR Muse 8820 Dual J-FET for me a dream!
ATOHM S250-X ICE POWER Amplifier Module Class D Subwoofer 220W 4Ω The Athohm S250-X Ice Power is a Class D amplifier module for subwoofers offering excellent technical performance and great musicality. It is capable of delivering a power of...
bon achat
Je possède un caisson de la marque final. Le module de 300 w ayant décidé d'arrêter de fonctionner au bout de 15 ans, j'ai longtemps hésité à acheter un nouveau caisson. Finalement j'ai opté pour celui-ci et je suis vraiment satisfait. Par contre j'ai règlé le curseur sur "closed" et ça change vraiment tout côté dynamisme. ( hp de 26 cm de diamètre.)
Jean-Pierre L.
FX-AUDIO D802E FDA Amplifier STA326 Streamer WiFi DLNA Bluetooth 5.0 Multiroom 2x80W / 4 Ohm Silver The E version of FDA D802 amplifiers from FX Audio now includes WiFI (DLNA) connections to complement Bluetooth connectivity.
edit du 20/12/20 - défaut WIFI corrigé
après échange rapide aux frais d'audiophonics, j'ai reçu un modèle parfaitement fonctionnel, connexion WIFI immédiate, merci au support !
je confirme le plaisir constant à écouter de la musique via cet ampli, donne vie même à des MP3 moyens. Ecoute aussi bien sur des colonnes de bonne sensibilité que des bibliothèques. puissance largement suffisante.
pas mal en deux canaux spdif mais
j ai branché l extracteur entre une box upc tv et un dac audio gd r28.. sortie sur câble vialube tos link et branché sur une interface digital ifi.. ensuite un autre câble tos Link vialube au dac.. sais bon.. sais pas non plus le must. Mais le sont obtenu passe plus que bien pour écouté les chaines musical. Super sur mezzo hd..les film écouté avec se système prennent une dimension comme au cinéma. j ai des enceinte qui descende vraiment a 27hrz et sa s entant ;-)sans bavure et bien serrée. j ai amélioré encore avec le branchement r de ma box avec un pangy cuivre pl argent acheté ici..et un isolateur galvanique de qualité médical branché entre le modem et la box upc acheté en allemagne avec optimisation audio inclue pour moins de 100fr ch. Qui dit mieux. ..sais excellent.. surtout sur les émissions enregistrées en streaming.. l isolateur galvanique apporte un plus qui se ressent .. plus fluide plus net plus calme.. les graves sont bien tendue et descende bien plus bas avec énergie.. conclusion se petit extracteur ne paye pas de mine. Mais bien optimisé.. il étonne. valeur des matériels inclus l extracteur.380 fr ch douane comprise.. le prix d un switch audio bien connu ;-)
Lennart L.
Super product and quick delivery from Audiophonics.
Very good and easy to use digital eq/filter. Very good sound.
To bad it´s discontinued from the manufacturer.
Easy business and quick delivery to Sweden from Audiophonics. //Space1999
eric p.
première écoutes
merçi à AUDIOPHONICS pour la rapidité et la communication..EP
eric p.
DIP Extractor Clamp for Printed Circuit Board This clamp will allow you to simply extract the DIP components from your printed circuit boards without degrading them.
première écoutes
très bonne pince pour les opa et merçi a audiophonics pour la rapidité et le service.
eric p.
première écoutes
bonjour, je viens juste de les montés ,le son est plus propre on gagne en ouverture , les aigus sont plus fin les basses plus ferme sur mon matériel ,jais également mis un fusible sr orange .
Patrice M.
USBridge Allo signature
Après plusieurs échanges avec un technicien d'Audiophonics, j'ai choisi ce lecteur. Je l'ai associé avec l'alimentation Shanti. Associé au dac je dois dire que ce lecteur est excellent. Le système sous Volumio est simple à faire fonctionner. J'ai recyclé un vieux smartphone en guise de télécommande. Le lecteur est relié directement à ma box via un cäble RJ45 Cat 7.
Patrice M.
Dac SMSL SU-9
J'avais dématérialisé mes disques CD en Flac via Foobar 2000, et je cherchais un DAC afin de lire les fichiers sur mon ensemble Hifi.
Après analyse, je me suis penché sur ce DAC. Il est excellent. Le son est clair et détaillé. l'aiguë n'est pas agressif, le grave est très propre sans trainage. Les voix sont restituées avec beaucoup de réalisme. Beaucoup de micro détails sont présents. Je suis très satisfait de mon choix.
Dragan K.
soft and squashy :)
If you are worried about vibration affecting your component this is a simple and effective fix. It's like floating your component on pudding :) The pads are sticky and grip firmly on the surface bellow.
