Excellente
Ces bananes sont ce que l’ on attend de bon connecteurs, solide, bien pensé, mécaniquement irréprochable, transparentes et...
super produit rien à dire cuivre pur plaqué argent rhodium
sans regret prenez la même coté male hyper top 2025 merci
Eric C.
Pas un gadget
J'avais des adaptateurs de base achetés dans un magasin d'électronique pour brancher mes câbles RCA sur mon préampli...
Customers reviews - There are 20109 reviews.
Laurent B.
Bonne upgrade
Ils remplacent les tubes de base d'un préampli phono Pro-ject tube box DS2 et le gain est significatif. C'est plus détaillé et j'ai un soundstage bien plus étendu. Les basses sont bien là et les aigus ne me cassent pas les oreilles, bref vraiment content!
Hans B.
It is a real pleasure to deal with audiophonics. Questions are answered immediately. Problems are solved quickly in favor of the customer. Here and there you can find some items a few euros cheaper elsewhere in the net but it is not worth the hassle if something goes wrong.
Now about the amps:
Coming from a UCD400hxr and a purifi ET400 this is my third iteration of a class d amp. It is driven as part of an full range system in a professional environment with dedicated studio acoustics. The mains are cleaned and have private electrical neutral and savety earth lines for the audio gear to bring ground loop noise down.
I always drive class d amps balanced without input buffer using high current preamps that can drive low input impedance gear with ease.
Some comments about the implementation of the modules:
1. When i got the amp I pulled out the opamp and plugged in the dummy opamp hooked it up and let it play while. Coming back i compared it to the ET400 and was surprised that the audiophonics sounded quite veiled in comparison. The quick fix was to pull out the power supply cable going from the input buffer board to the xlr and cinch connector board. Audiophonics decided to make the unbalanced input balanced by using an active circuitry at the xlr and cinch connector board. Obviously the circuitry polluted the signal. Now I got clean sound. (Btw the previous model didn´t use this circuity).
The better fix is to pull out the xlr and cinch board entirely, to buy a xlr connector and solder it directly to the input board using a high quality shielded balanced cable .
2. Opamp implementation: the opamp is introducing more color than I expected. (I compared the op amp level matched in low gain setting to the unbuffered input.) I am convinced that a top notch implementation using a dedicated high end power supply for the opamp would bring down opamp noise down a bit...and price up obviously...As I don´use it I don´t care.
3. To have an opamp socket is nice to have for those customers who like playing around with different thd profiles of different opamps. But with time resistance is building up at the contact points. So plug the opamp in and out from time to time. More important for the same reason: toggle the xlr cinch input switch from time to time (it is not a gas tight relay) and plug in and out the signal cable at the buffer input board. I would like to have these things soldered, including the speaker cables at the buffer board.
4.The power supply is getting quite hot. For better heat dissipation I would prefer that it makes contact with the metal case. The purifi modules itself are running very cool.
5. I can´t comment on the quality of the single ended input in comparison to the balanced one as I have no use for it.
6. I do like the binding posts. They allow for cranking down the calble super tight.
Final words:
The purifi modules are ment to be driven balanced. To provide single ended inputs in my opinion is mainly a marketing decision. Unfortunatly here this decision impacts the purity of the signal when going in balanced.
Fortunately pulling out the power supply cable of the symmetry circuitry is an easy solution as long as you don´t need the single ended input.
In this implementation the modules should be driven without input buffer opamp as they color the sound too much for my taste. You miss out how beautifully clean these modules can sound when the opamp is not installed.
If you like uncolored amps, have an great room with great speakers, great upstream electronics and clean mains power you can enjoy absolutely truth telling amplification for little money. Therefore it is also excellent in revealing minuscule differences when you shoot out upstream gear.
If you are a mixing or mastering engineer these modules tell you everything to make the right decisions, especially in the top end where many amps lack accuracy. If it sounds harsh on these it is harsh and needs to be adressed.
Price of the amps is excellent. It is not worth building one youself. I can whole heartly recommend this purifi build if you go in balanced bypassing the opamp.
Patrice L.
ELECAUDIO LI-07GB IEC C7 Connector Gold Plated 24k 3x5mm² Ø15mm This IEC C7 Elecaudio LI-07GB connector is ideal for making quality power supply cables. It uses 24k gold plated copper alloy contacts of 5mm², allowing to obtain a very...
Un produit bien conçu.
Premier achat de cette prise IEC C7 et très satisfait par sa conception. J'ai monté cette prise sans difficultés sur deux câbles Audiophonics Tornado afin d'upgrader l'alimentation de deux caissons de graves SVS SB1000 PRO. Le résultat n'est probablement pas audible, mais je suis assuré que les caissons reçoivent la quantité de courant nécessaire aux appels de puissance. Merci audiophonics pour la qualités de vos produits et de vos prestations.
August E.
Excellent tweeter!
I have installed this tweeter in a pair of PA speakers (Skytec MAX15) that had a piezo tweeter and midrange horn and replaced them with this tweeter (intended use is the living room). The sound is now completely different, everything has vastly improved! To be able to use this tweeter with those speakers I also had to install a crossover because they had none. So I have installed the Monacor DN-1218 PAX crossover to use with this tweeter. I was at first a bit skeptical because of the "dip" you can see in the frequency response graph of the crossover. But I measured (UMIK-1 and REW) the frequency response after the upgrade and it is pretty much linear, especially in the crossover region, absolutely no "dip" and it sounds fantastic! It really allowed the 15 inch woofer to go all the way down in the lows, with remarkable clarity. The switch from piezo to silk dome was also a significant change, but I don't think I have ever heard a more accurate tweeter, I think it is more revealing than the tweeter of the Alesis M1 Active MK2! Overall the upgrade was excellent! So good in fact, that I am now considering using the MAX15 for production purposes as well. In conclusion, this tweeter is highly recommended and it works very well with the Monacor crossover (12dB LP/18dB HP at 2.5kHz), don't be fooled by the "dip" in the graph, it blends beautifully with the tweeter!
Michael Z.
AUDIOPHONICS HPA-INT450ET Integrated Amplifier Stereo Class D Purifi 1ET6525SA 2x450W 4 Ohm Audiophonics is proud to present the HPA-INT450ET. This Class D integrated amplifier relies on a pair of Purifi 1ET6525SA amplifier modules coupled with a Hypex SMPS1200A400...
Überraschend gut
Das war meine erste Erfahrung mit purifi. Der Verstärker ist wirklich gut, und kann leicht mit meiner A/B Endstufe mithalten. Leider ist der pre nicht von der gleichen Qualität. Auch war keine Bedienungsanleitung beigelgt. Deswegen habe ich das Gerät zurückgeschickt.
Pierre H.
4N ou 6N
Tous les avis sur ce câble donnent vraiment envie d'acheter de câble mais ils parlent d'une référence 6N mais le lien est du câble 4N. Je n'ai pas trouvé le 6N en 0.5 mm sur le site est ce que le 4N qui est moins pour en cuivre a les mêmes performances que ce qui est écrit sur le 6N?
Didier C.
Jack DC 12V 5F Supercapacitor Filter This DC 12V jack filter with supercapacitor allows you to obtain a clean power supply for your Hi-Fi equipment and appliances, thanks to 5 supercapacitors 30F - 3.0V and an...
Etonnante petite boite !
J'hésitais à acheter une alimentation linéaire pour remplacer celle d'origine de ma box Orange, mais j'ai voulu tenter ce petit boîtier et n'en suis pas déçu. Placé donc entre la smps de la box et la box (merci les deux adaptateurs 2.5/2.1 bien pratiques fournis avec le filtre
Didier C.
Utilisé entre une livebox Orange et mon streamer Lumin T2, il fait son petit effet. On ressent une progression de la netteté sonore et une mise en place spatiale plus précise, avec plus d'aération. L'effet est plus important s'il est placé en sortie de la box plutôt qu'à l'entrée du streamer chez moi.
Thierry C.
SHANLING ONIX ZENITH XST20 CD / SACD / MQA CD Transport Sanyo HD870 With the Shanling ONIX Zenith XST20, Shanling has unveiled a new top-of-the-range CD transport with a luxurious design and high-performance components. In addition to a...
Le problème avec le Gapless que j'ai évoqué précédemment est un problème Hardware, et ne pourra donc pas être résolu par un Firmware, rendant la promesse caduque
Par ailleurs de gros craquements dans les enceintes à la mise en route et à l'arrêt du lecteur. Chez moi cela a empiré avec le Firmware 1.9
Je réduis donc ma note face à la déception vu le prix de la machine
Thierry b.
Toute la bande passante y passe, la clarté, la tenu des notes à très faible écoute, je suis agréablement surpris.
tester aussi sur mon ancienne interface cm6631pro, idem aussi bon que l'amanero 368 sans alim.
Je recommande fortement. ( je conçoi que ce n'est pas le câble seul qui fait ces changement mais il est le pont et le moyen d'amélioration)
Merci audiophonics!
remy l.
Balanced Headphone Cable Male Jack 4.4mm to 2x Male Jack 3.5mm Copper Silver 1.5m This high-end balanced headphone cable uses materials selected for their excellent electrical conductivity. It consists of 8 braided 7N copper and 7N silver conductors, each...
ah 92OO.apport en dynamique,scene sonore,transparence.vaut largement son prix par rapport à d'autre cable de meme categorie
comme ceux de MEZE qui valent presque le double.
bon cable bonnes prises
petit prix petit cable
Court dans le grave et le suraigu,un meduim agressif..a oublier
Ethernet to Optical Fiber Converter (Pair) Jack DC Power Supply These devices are delivered in pairs and convert a 10/100/1000Base-T Ethernet signal to 1000Base-SX/LX optical fiber. This allows the signal to be isolated from the rest of the...
un petit plus
Le prix tout petit s envole quand on a rajouté 2 alimentations 5 volts correctes,un cable rj 45 plaqué argent et un câble optique .
Mais le clignotement des petites les vertes fait tout oublier.
philippe B.
DENAFRIPS ENYO 15TH Balanced R2R DAC 24bit 1536kHz DSD1024 Black The Denafrips Enyo 15TH DAC is an R2R digital-to-analog converter supporting high-resolution audio streams up to PCM 24bit 1536kHz and DSD1024. R2R technology enables Enyo to...
Son presque analogique.
Digne d'une platine Linn avec une bonne cellule à bobine mobile, en plus silencieux et plus détaillé! Je ne regrette pas mon achat malgré le prix élevé pour moi c'est déja du trés haut de gamme, Je doute qu'il y ait beaucoup mieux sans mettre un prix astronomique.
philippe B.
LITTLE BEAR MC3 XLR / RCA Converter Switch The Little Bear MC3 is an XLR/RCA converter switch. It has one RCA and two XLR inputs, and the same applies to its outputs. It can therefore be used as a passive switch or as...
Musical et pratique
La conversion symétrique/asymétrique fonctionne bien dans les 2 sens, ça peut éviter d'acheter des câbles adaptateurs xlr/cinch. L'appareil est transparent au niveau du son. En revanche c'est loin d’être un mini boitier, surtout en hauteur: 8cm! Les faces avant et arrière sont en plastique moulé genre ABS, de même que les socles de prises, c'est pas du Neutrik ni même du Rean mais ça ne s'entend pas, heureusement vu le prix qui ne me parait pas justifié, d’où une étoile en moins.
Robert v.
Banana Plugs Rhodium-Plated Ø8mm (Pair) These affordable Rhodium-plated banana plugs ensure simple, effective connection to the terminal blocks on your speakers and amplifiers. The rhodium-plated contacts...
Beware this plug has a pin in the center of it.
I ordered these to connect my loudspeaker wire to my amplifier by a Rhodium plated plug. I already had connected my loudspeakers with a set of Banana Plug Rhodium Plated OFC Copper Ø5mm. This was a step forward from the gold plated plugs I had before. Very clear and natural.
But these BFA Banana Plugs I bought now have a pin in the center. You can see it on the picture if you look closely.
My Linn amplifier has also a pin in the center of the loudspeaker terminals. So it doesn't match. A male to male connection. I have send them back.
Très bien à petit prix.
Petit prix pour une fiche de bonne qualité.
Se marie parfaitement avec le câble Sommercable Albedo à prix contenu et également de très bonne qualité sonore.
Merci Audiophonics.
Bonne qualité.
Merci Audiophonics.
Très bien.
Protège bien les fiches rca femelles pour un tout petit prix.
Ne vous en privez pas, merci Audiophonics.
Heat-shrink tubing 3:1 Ø12.7mm Transparent (1m) Thermo-retractable sheath with a ratio of 3: 1, internally equipped with an adhesive layer ensuring better support on any type of surface (plastic, rubber, metal ...)
Super qualité.
De bien meilleure qualité que les thermo-rétractables chinoises trouvées sur Aliexpress.
Celles-ci sont bien épaisses, bien collantes et bien solides.
Merci Audiophonics !!
Heat-shrink tubing 3:1 Ø9.5mm Transparent (1m) Thermo-retractable sheath with a ratio of 3: 1, internally equipped with an adhesive layer ensuring better support on any type of surface (plastic, rubber, metal ...)
Super.
Toujours excellent.
Très bon câble de liaison pour tout élément hifi.
Un peu en-dessous du Sommercable Epilogue mais à 8 fois moins cher.
Se monte aisément avec les fiches rca Amphénol à petit prix et à très bonne qualité aussi.
Livraison express comme toujours, merci Audiophonics.
Lages Duran F.
SMSL PL200T CD Transport USB XMOS 32bit 768kHz DSD512 MQA-CD The SMSL PL200T is a high-performance, versatile CD transport. It's based primarily on a P.A.S.S. (Precision Access Servo System) playback system developed by SMSL, plus an XMOS...
Smsl pl200 t
Excelente, muy feliz
Gracias
thomas d.
HIFIMAN MINI SHANGRI-LA Electrostatic Headphone Amplifier The HiFiMAN Mini Shangri-La amplifier has been specially designed to drive electrostatic headphones. Its amplification stage uses two MOSFET transistors...
Ampli neutre.. transparent et musical
Couplé à un casque stax L700 et 007 magique
Seuls défauts le poids et la chaleur ...bon j'étais au courant ..
Pour reguler la t°... jai rajouter un ventilo a l'arrière 6×6 style imprimante 3D
Jan W.
WIIM ULTRA Streamer DAC ES9038Q2M Headphone Amplifier Bluetooth 5.3 WiFi 6E 32bit 384kHz The WiiM Ultra sets a new benchmark in the world of audio streamers, thanks to a design conceived to deliver an unrivalled audio experience. It lets you enjoy your music library...
Amazing Streamer/DAC/Preamp
My Chain:
(1)Pro-Ject RPM 1 w/ AT VM95SH
(2) Wiim Ultra
(3) Audiophonics AP300-S250NC
(4) Canton B100
Got the Wiim Ultra in a bundle with the AP300 power amp and I am blown away by what you receive for your money!
The setup, room correction, and so on was done in minutes and it sounds very good out of the box. For phono I needed to push the trebles because the bass was too much, but for tidal the automatic room correction is very good.
It is nice to see the cover art and the phono pre is very nice to have and not too bad for what you pay here!
Can recommend the Wiim, especially with the ap300!
Chafi M.
Fosi audio box5
Super petit preampli phono j'ai une cellule MM ortofon 2m red, j'ai mis le réglage sr 48db, ourahh mon volume est enfin plus élevé la qualité sonore est au rendez-vous détaillé scène sonore bien pleine, bref gain également total sur la qualité sonore , preampli peut cher mais avec une grande qualité, pourquoi investir plus cher!!!!j'ai une patine Technics SL 1500C reliée à mon ampli intégré SPEC 777EX
je conseil ce petit preampli , il sonne vraiment bien grâce à ses composants de haute qualité notamment les petits condos nichicon!!!!
Andreas K.
IBASSO AMP14 Korg Nutube Amplifier Module for DX320 / DX300 DAP Black This iBasso AMP14 amplifier module is specifically designed to accompany the brand's DX320 and DX300 DAPs. Each module is hand tested and calibrated at the factory to provide...
Great improvement
Sound quality of DX320 improved significantly, actually without tube flavour, but in precision as well as in plasticity.
Frank F.
ISOACOUSTICS OREA GRAPHITE Vibrations Absorber Isolator Ø40x27mm (Unit) IsoAcoustics' Orea series of vibration absorbers eliminate unwanted vibrations and provide greater sound clarity and accuracy. The Orea is ideal for use with electronic devices...
Isoacoustics Oréa Graphite
A bien amélioré le rendu du boitier électronique ( alimentant le câble de modulation LEGATO FINEZZA ) léger et posé directement au sol.
Contre toute attente cela s'est avéré bien supérieur en plaçant 4 graphites directement sous les pieds du boitier électronique.
Merci à AUDIOPHONICS d'avoir choisi ISOACOUSTICS.
RENAUD C.
Un ampli OP de très haut niveau
Totalement silencieux, sans distorsion, entrée FET, slew rate exceptionnel, et la capacité de piloter un casque ou des câbles de liaison exigeants. Remplace l'excellent 5532 avec succès
Olivier G.
J'avais déjà un BL-Muse-03 dont j'étais très content.
Le BL-MUSE-01 PRO+ est très discret et fonctionne très bien.
Aucun problème de connexion.
Jean Pierre Ernst B.
Great product
The amp just arrived. Well packed. Well finished. Very good looking product.
Just out of the box the sound is truly astounding compared to my old ADAU1592 based small amp. No more issues with treble. Good solid bass. A lot more detail. Wider and deeper sound stage.
Thanks to Mr. Putzey for such a good design and thanks to Audiophonics for making it available at such a good price.
Great product for a small system with reasonable power needs.
Arvydas V.
JANTZEN AUDIO CROSS-CAP Capacitor 400V 6.8µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
Ok
Arvydas V.
Good, but the tolerance could be smaller. One capacitor had 9.5mkF instead of 10
Arvydas V.
good capacitors
Elena M.
Mixed feelings plug
The sound is little bit closed for my taste, but overall good. My main criticism is very loose fit on MF-M5si amp. Cheap Norstone Arran plug fits much tighter, and its the same case even with freeby suplied stock cable. Was expecting much more from Oyaide
Claude T.
IAN CANADA TRANSFORMER I/V Passive I/V Stage Module The Ian Canada Transformer I/V is an I/V transformer module operating in purely passive mode, without any feedback or active components. It doesn't even need a power supply....
Bonne config
L'ensemble
- Monitor Pro contrôleur.
Apporte un plus vraiment agréable dans ma configuration.
Bien brancher le monitor sur le GPIO du DAC et mettre le volume à 0db… sinon par défaut il est à -40db et donc pas de son.
Claude T.
IAN CANADA DUAL MONO MKII DAC ES9038Q2M HAT Raspberry Pi / I2S & SPDIF / PCM DSD Ian Canada 9038Q2M dual mono DAC HAT is a very high level of DAC for Raspberry Pi. It uses two chips ES9038Q2M SABRE 32-bit each working in mono.
Bonne config
L'ensemble
Claude T.
IAN CANADA MONITORPI PRO Control Center and Signal Analyzer with Display for Raspberry Pi Ian Canada's MonitorPi Pro is a powerful integrated control center and universal OLED display for all types of Raspberry Pi-based audio applications. To install the MonitorPi...
Bonne config
L'ensemble
Giuseppe C.
SOMMERCABLE MERIDIAN SP225 Speaker Cable OFC Copper FRNC 2x2.5mm² Ø8mm Meridian Sommercable SP255 is a two-conductor speaker cable. It is a cable developed to offer excellent mechanical strength and therefore ensure increased durability thanks to a...
Complicato
Duro e rigido come un tronco. È un cavo che richiede molto spazio e, nella maggior parte dei casi, in casa non abbiamo una stanza dedicata all’hi-fi. Diventa complicato, soprattutto se deve passare dietro a un mobile, dove serve un minimo di flessibilità. Come suona? Finché si tratta di rame puro (ovviamente), suonano tutti bene.
Kevin S.
PANGEA AC-14SE MKII Power Cable Triple Shielding Cardas Copper / OFC 3x2mm² 1m Based on a mix of sale strands and Litz wires, this cable is especially designed for your audio sources. The Pangea AC-14SE MKII cable is specially designed for source...
Utilisé pour éviter les interférences courant fort / courant faible au niveau du panneau arrière de mes élément hi-fi.
Attention comme souligné par un autre utilisateur, la phase et le neutre sont inversés et mon ampli ne sait pas fonctionner, une inversion au niveau de ma prise murale a été nécessaire.
Paulius S.
RJ45 Ethernet Connector Cat8 Shielded Ø8mm This Cat8 standard metal RJ45 connector lets you assemble your own Ethernet cables without the need for special tools. It accepts cable up to 8mm in diameter and has gold-plated...
Very Useful
Nothing to complain.
Paulius S.
SOMMERCABLE MERCATOR CAT8.1 Ethernet Cable OFC Copper 8x0.32mm² Ø8.2mm This Sommercable Mercator Cat 8.1 Ethernet cable has 8 conductors of 0.32mm² each (22AWG) with double tinned copper braid shielding. This cable, sold by the metre, will...
Very Good
I like this cable and price very much.
Thierry S.
Vraiment bien
Merci David, pour votre patience , et , disponibilité, je craignais que ce petit ampli ne fasse pas le poids, en kilo c est certain, face à mon Classé Audio, et bien, il est costaud le petit, le son est vraiment très bon, le conseil était fort avisé.
Terrific cable
I don't know how Neotech improved on the NEP 3001 hybrid, but this cable is astonishing at the first listening. As another user said, super levels of transparency and wider, deeper sound stage.
In 2 words- buy it!
Tomasz C.
TOPPING DX5 II DAC 2xES9039Q2M Headphone Amplifier X-Hybrid Bluetooth 32bit 768kHz DSD512 Silver With the DX5 II, Topping presents the direct heir to its famous DX5 DAC and headphone amplifier. This new version features a host of changes, improving on its predecessor in...
Some people would call my change to this DAC/Amp a downgrade as I come from a Audio-gd D28.38 to this. However, this little DAC/Amp combo has so many more features, such as being able to use the device without a computer or other source connected to it.
For the headphones I normally use Denon D2000 and Focal Clear MG, this has plenty of power both single ended and balanced.
Sound-wise after listening to it for a few days, it sounds transparent to me, nothing seems out of place from other equipment I normally use. So all-in all I am very happy with it.
Connectivity-wise, it also has balanced out, which I use with a set of active speakers, which also works very well.
Being class D is also a huge plus as the Audio-gd device I had before could run a bit toasty even when not in use.
Take this with a grain of salt as these are just initial impressions, but so far I am not disappointed.
arnaud m.
Exelent
La fonction de calibrage du caisson est très efficace et m’a enfin permis de coupler mes enceintes avec mon caisson.
Seul la fonction calibrage de la pièce m’a semblé pas très pertinente lors de mes essais en dénaturant la personnalité des enceintes.
Jean-Louis R.
CXG E60S Adjustable Soldering Iron with Stand 60W 500°C Ø7mm The adjustable soldering iron CXG E60S offers a power of 60W, allowing to reach a maximum temperature of 500°C. Its ceramic heating element ensures a constant temperature...
ne chauffe plus assez
Jean-Louis R.
VIBORG XF-202G Female XLR Connector 3 Poles Gold / Silver Plated Pure Copper Ø11mm Black (Unit) Viborg offers with its XF-202G a high-quality 3-pole XLR connector. Its contacts are indeed designed in pure Copper with triple plating Copper OFC, Silver and Gold, to ensure...
