Marc C.
Que dire ?
Bertrand j.
neutrik
Ramiro F.
Aliaksandr S.
Simple solution that just works!
Works as expected! The assembly took some 30 min, the system is very straightforward and I got Spotify Connect working in just a few minutes. Scanning files from NAS took a bit longer but also simple. Overall, pretty happy! Good sound!
A couple of smaller issues:
1. Remote does not always work, still figuring out how to configure additional buttons. However, volume and source work fine and that's the most important.
2. TFT screen is not fully off when in screen saver mode. But not too bright to be a problem.
3. Spotify connect plugin can freeze if you switch tracks too often. You have to either restart the raspdac or open the UI and manually restart the plugin. Still figuring this one out.
Leonidas D.
Top product
In combination with my Bluesound node 2i the sound is more detailed , transparent, combined with quality cables , you have a cracking combo with an exceptional value for money ratio , if the same product did have the name Gustard but some other well known European brand name easily the asking price could be over a 1.000 € , fast delivery and secure packaging from Audiophonics bravo for providing such quality products
Jean Claude V.
fiche banane
ses fiches sont idéales dans les borniers isoles acryliques elecaudio bp208
livres par 4
verrouillage et montage facile et de qualité.
prix vraiment raisonnable
Jean Claude V.
fiche banane
fiche banane de qualité, a voir dans le temps
Jean Claude V.
bornier
j avais décide de changer ,mes borniers de mes 3 paires de cabasse pour mettre des fiches bananes, sans percer ou rien transformer et garder les originaux .
ils sont très bien rempli le montage.
Jean Paul E.
incoyable!
Vu le prix très abordable (par rapport aux tarifs des différents câbles HDG de prix stratosphériques que j'ai eus en 40 ans de Hifi) , j'ai tenté l''expérience avec celui-ci en DIY avec fiches Furutech pour m'amuser. Franchement, le résultat est meilleur : même quantité de détails, mais timbres encore plus naturels avec moins de froideur, profondeur inégalée! Arrêtez de vous ruiner en câbles à 5000€. (streamer Black Hole Larosita II + Mac Mini en lecture).
Realiste
Que demander d’autres à un câble?
Une écoute live, vivante et chaleureuse sur mes monitors. Beaucoup de profondeur et choses rare sensations de hauteur dans le son. Les timbres et les harmoniques sont là dans toutes les fréquences. Y’a peut-être mieux mais à combien ? Attention je parles en symétrique.
Eric M.
Le jour et la nuit
En remplacement d'un Mydac, je retrouve la joie de l'écoute. Le maillon faible ne sera plus le DAC mais l'ampli maintenant (NAD 214) et/ou les enceintes (SPENDOR S8), car je passe en mode préamp sur l'ampli de puissance directement. Ecoute stéréo élargie, pas de distorsion dans les aigus, basses tenues et mids superbes. Lecture des DSD en natif. Musical, il l'est, et c'est ce que je lui demande essentiellement ; c’est ce qui me l'a fait préférer même aux AK4499, en tenant compte de la technique, des avis et du portefeuille. Testé sur l'entrée USB avec un PC dédié sous Daphile, le DAC est reconnu d'entrée de jeu. Testé avec l'entrée optique avec un PC sous Foobar et Ableton, no problemo. Une légère différence est à noter entre les 2 entrées sur la tenue et la profondeur des basses (optique plus ferme mais moins ample). Ce ne sont pas les mêmes équipements, les mêmes câbles et les mêmes logiciels de reproduction. Plusieurs filtres FIR sont disponibles, mais non évalués. Packaging OK et livraison dans les 2 jours si dispo !
Martin v.
Great sound, great DIY project, but with some quirks–and a personal learning curve.
I really do enjoy the sound of this DAC! Recently I upgraded my sound system with a pair of Kef LS50 (meta), which already gave a huge step forward in sound staging and detail. As a source, I mainly used a RPi 3 + HifiBerry Digi+ Pro HAT, connected to a NAD D3020 hybrid digital amplifier (S/PDIF), streaming FLACs and Spotify with Volumio. After some research on the web, it became clear to me that the streamer now was the weakest link in my audio system. I therefore decided to give the RaspDAC MINI LCD a try, mainly based on the enthusiastic Darko Audio review of the previous version of the MINI (I had looked at the acclaimed, but much more expensive Volumio DAC, but Darko coudn’t tell the diffecence with the MINI). Was it perhaps for this positive review that the first batch of the MINI LCD version sold out so fast? It took about 4 weeks before the DAC was delivered (but only 3 working days to get from F to NL). Putting the thing together was instructive fun to do (and super easy with the visual guide from Audiophonics). I also like the sturdy build quality of the black box. However, when I gave the DAC a first spin, the sound was ‘OK’, but only slighly better than the Rpi3/Hifiberry combination. There were also a few other issues that tempered my original enthusiasm.
1. Using a standard RPi 3A USB-C power adapter, the system consistenly kept showing yellow flashes on the LCD screen, indicating insufficient juice. This happened both at startup and during playback. The system thus appeared quite unstable, responding with long response delays or even unexpected shutdowns when using the remote control, even spontaneously during the playback of music. Therefore I ordered another custom power adapter from my local Pi store (SOS-Solutions in NL), that was able to generate 4A. Even worse: much more high frequency noise, which also disrupted the S/PDIF input stage from functioning properly. After contact with the supplier, they kindly sent me the low noise Alli 5V 3A mini-USB adapter (also available from Audiopnonics): problem solved! It appears that the system is quite power critical. Another finding: the sound improved dramatically–much more detail and space, compared to the sessions in the previous days using HD reference music. Perhaps a linear PS could even improve the sound further?
2. The system uses a card adapter with a flat cable to guide the communication with the micro-SD card to the back of the box. This did (and does) not work in my setup. First I though this was the result of the power issue, but after switching to the Allo adapter–still dead. I tried the card adapter on other Pi’s: no problem there, so it does not seem to be broken. I now use the RaspDAC with the card inside of the box–no big deal, but if anyone has a suggestion to solve this, I would be interested to find out how.
Overall this has been a very good investment (so 5*) in terms of lessons learned ánd a better sounding audio system. My advice to future buyers is to use only a good quality power adapter of at least 3A with the MINI LCD. First I thought that Audiophonics reason to upgrade the new MINI with a RPi4 instead of RPi3 and swapping the monochrome display for the colour LCD was for the most part cosmetically (b.t.w., the added value of the LCD is –at least to me– rather limited). Now I understand that this could be related to the separate power supply of USB and ethernet connections, which makes the RPi3 potentially noisier in audio setups (particularly after my power issues of the past days…). I applaud Audiophonics for bringing such nice products to market. DIY projects are to educate and learn, so mission accomplished.
Robert g.
robert grzundkowski
heureux d'avoir trouvé ces tubes hifi sur audiophonics , je recommande vivement ce cite pour son sérieux et service après vente super réactif , encore merci
Stefano F.
A great cable!
Very detailed with no emphasis on high frequencies.
Inserted in a chain consisting of streamer Lumin U1 mini - Chord DAVE - Benchmark HPA4 - Abyss 1266 PHI TC with SC Cable. Assembled in RCA configuration on DAVE side and XLR on HPA4 side. Ground shield on both sides. It carries all micro information with great precision, equaling the quality of DAVE's headphone output.
Anne b.
cable haut parleur cuivre argent de tres bonne qualité utilisé sur enceintes kef les basses profondes le médium plus précis vraiment bien pour un cable pas tres cher je conseille vivement ce cable
Gilles A.
Bornier de qualité mais néanmoins un peu cher
Borniers de qualité avec contacts plaqués or, acceptent les cosses de connexion sans problème. Néanmoins on peut se demander si leur prix est justifié compte-tenu de la fabrication en plastique. Attention à assurer un écartement suffisant lors du perçage du châssis car leur diamètre extérieur est important, plus que des borniers plus classiques.
Pierre S.
Encore un excellent produit Audiophonics !
Encore un excellent produit Audiophonics, l'assertion constituant, de fait et à l'évidence, un parfait pléonasme ;)
Plus sérieusement, ce sélecteur de sources très bien construit remplace, bien utilement, un sélecteur de sources Dynavox qui aura tenu moins de quelques mois avant que le knob de sélection de sources commence à faire des siennes (perte d'une voie sur l'une des deux positions possibles).
Au vu de la qualité de construction du sélecteur de sources Audiophonics, il m'étonnerai beaucoup qu'il me soit nécessaire d'avoir à m'en séparer prochainement.
Bravo - one more time - Audiohonics ;)
Gilles A.
Beaucoup trop léger
Ce produit est indispensable pour monter un transfo toroïdal en position verticale et ainsi gagner de l'espace dans le châssis. Le matériau est hélas beaucoup trop mince et donc pas assez rigide pour supporter un transfo de 300 VA de diamètre 120 mm pesant plus de 3 kg. Le problème a été « résolu » en plaçant une cale sous le transfo pour le soutenir et éviter qu'il ne se balance lors des transports.
Pierre C.
Impressionnant
Résolution, précision, attaques, et une certaine douceur, pourtant déjà possesseur d'un Chord Mojo, d'un Ifi Xdsd, je suis enchanté par cette petite boîte.
Christian O.
canare une référence
Ce câble de modulation est une heureuse surprise. Il représente la quintessence des câbles que j 'ai possédés par le passé. Sa simplicité de conception en fait (comme le dirait Léonard de Vinci) sa sophistication suprême. Il véhicule la musique avec un rendu holographique. Dorénavant, je jugerai les autres câbles à l'aune du Canare. Je le recommande.
Ričardas D.
Changed to XDUOO XD 05 BASIC. I listened with the Edifier S2000MKIII, AKG K371, BQEYZ Spring2.
Subjective opinion: the sound is softer, more balanced. The whole range is kind of longer, the edges (low and high) have become stronger and more detailed. I recommend you give it a try.
Thank you
Ričardas D.
XDUOO XD05 BASIC Portable Headphone Amplifier DAC AK4490 XMOS 32bit 384kHz DSD256 xDuoo presents with its XD-05 Basic a small, affordable yet extremely powerful portable headphone and DAC amplifier. Indeed, low price doesn't always rhyme with economy of means...
Great sound.
Quickly delivered to Lithuania. The store has fulfilled the order in compliance with all term obligations.
Thank you
Juan N.
LITE AUDIO A28D Boîtier 410x100x330mm Noir
Rapport qualité/prix imbattable, bonne finition, solide et rigide.
Et en bonus, le boîtier est livré avec les prises RCA, la visserie, l’interrupteur, la diode Led, les pieds et la prise ICE.
Idéal pour du DIY.
Juan
Juan N.
Transformateur R-CORE 30VA 9V-0-9V 0.2A + 9V 0.2A + 6.3V 2A + 240V 0.05A
J'ai déjà utilisé des transformateurs R-CORE, Jamais déçu.
Très bonne qualité, idéal pour l'alimentation de préamplificateur audio.
Juan
Juan N.
Transformateur R-CORE 30VA 2x12V
J'ai déjà utiliser des transformateurs R-CORE, Jamais déçu.
Très bonne qualité, parfait pour l'alimentation de préamplificateur audio.
Juan
Sébastien T.
Indispensable :-)
Bien que destinés aux électroniques, ces plots à bille sont actuellement sous mes enceintes… Excellents résultats ! Tout gagne en propreté, la scène sonore s'ouvre… Je recommande vivement l'expérience !
terry l.
hifo 2000 case
great value, well made, ideal for projects!. terry.
Philippe A.
j'utilise ces fiches depuis plusieurs mois, j'en suis très content, sauf pour un exemplaire où une des petites vis de serrage s'est cassée lors de l'installation, il m'a fallu recouper le câble et en utiliser une autre fiche neuve.
Philippe A.
produit correct
Suite à installation et paramétrage sur mon système, le fait de passer du mode passif au mode active, plus de clarté et surtout aisance supplémentaire dans la reproduction musicale.
Philippe A.
suite au branchement dès réception, apparemment le message sonore à l'air plus propre comme débarrassé de certaines micro anomalies. Connecté sur dsp-408 Dayton Audio.
Martin V.
TOPPING A50S Balanced Headphone Amplifier Preamplifier Black With the A50s, Topping offers a high quality headphone amplifier and sedentary preamplifier combo, integrating both balanced and unbalanced connections. Its optimized circuits,...
Excellent AMP
For size this is amazing amp, in power it can not compare to normal speaker amp but it drives my dt770 pro amazingly and when there is nothing playing there is dead silence. I love audiphonics and this amp.
Achille m.
Punte eccellenti
Veramente convenienti e performanti queste punte coniche, molto belle da vedere e molto efficaci per quanto riguarda la loro azione disaccoppiante. Consigliate
Joshua Y.
Excellent rapport qualité prix ! Se soude facilement. Parfait pour réaliser ses propres câbles coudés quand on manque de place à l'arrière de nos appareils
Joshua Y.
Excellente fiche Jack. Se soude très facilement. Idéale pour les gros câbles et les câble style scindex.
Laurent C.
Câble phono 1877
Par encore installé mais en tout cas c est beau
Ça va le faire c est sur..
Laurent C.
Câble phono 1877
Par encore installé. Mais en tout cas c est beau
François G.
Coffret 2000 Galaxy
Coffret répondant parfaitement a la description, seul "bémol", pour fixer les capots en tôle supérieur et inférieur, les vis tête fraisées de M3x6 sont trop justes, elles ne prennent que de 1 où 1,5 filet dans l'écrou et heureusement qu'il y en avait en supplément car j'ai deux vis où le filetage s'est arraché.
J'ai donc pris des vis standard du commerce M3x10 (que j'avais dans mes tiroirs) et j'ai réalisé au tour un diamètre de 2mm sur une longueur de 2,5 mm et le montage est parfait a présent.
Il faudrait que des vis tête fraisées M3x7 soient fournies, mais hors standard...
Raphaël S.
J’ai acheté ce dac pour le brancher à un raspberry avec alim shanti sur un ampli classe d et une paire de klipsch cornwall.
Des les premières minutes j’ai été conquis. Que ce soit via Bluetooth ou par le raspberry les qualités de ce dac sont indéniables.
En fait c’est le premier dac qui me satisfait autant.
Que ce soit sur les voix, le grave, la spacialisation, la transparence,.... il est bon partout.
Et ce n’est que le "petit" modèle en akm4499. Prochain upgrad, le a22.
Merci audiophonics
Eric j.
Câble RCA
Câble arrivé rapidement, de bonne qualité. je recommande
Excellentissime tout simplement
Tarif contenu et qualité au maximum, j'utilise ce type de connectique pour sa facilité a souder les conducteurs.
Ces Kle ont aussi des caractéristiques audiophiles excellentes .
L'achat sans erreur a ce niveau de tarif.
Résultat audio parfait
Défaut, pas trouvé.
Dominique G.
ALLO SHANTI
Alimentation développée pour le streamer Allousbridge.
Très silencieuse et indispensable pour exploiter pleinement le streamer. Juste un petit reproche, une sortie 5 volts sur châssis type aviation aurait été parfaite pour mettre un câble de qualité.
Excellentes prise coudée
Très facilement démontable et orientable dans toutes les positions.
Le connecteur IEC idéal lorsqu'il faut orienter la prise.
Qualité; Top
Défaut; RAS
denis c.
idéal pour mon kit son de modèle réduit , avion enverg 1600mm. légers, dimensions réduites, puissance juste ce qu'il faut et une bande passante conforme à mes attentes. dommage que le +et - n'est pas repéré, mais avec une pile on retrouve.
Particulièrement bon
Je l'utilise dans une enceinte DIY entre 300 - 3khz.
Très linéaire dans l'axe et hors axe.
Capable de fonctionner en charge close.
Excellent, pas de coloration.
Rendu très naturel.
Gustavo O.
Excelent
In my 18m2 room this sounds great, neutral, amazing bas.
Glynn C.
Works really well even with other USB cleaning and rec locking devices are used.
Glynn C.
Good quality inlet that improves sound quality.
AUDIO-GD R-7HE 2021 MK2 Balanced DAC R2R FPGA I2S HDMI Amanero 32bit 384kHz DSD Accusilicon Audio-GD is developing its HE range, composed of its most top-of-the-range products. They benefit from the longest design and testing period since the brand's inception. This...
Fabuleux
Par rapport à mes Audio-R1 "maison" (cartes DA-8 / Amanero et alimentation maison), le progrès est consdérable;
On ne se pose aucune question avec le R7-HE 2021. Tout sonne naturel. Dynamique exceptionnelle, silence entre les notes, scène sonore large et profonde, on s'y croit.
Tous les petits défauts d'écoute que je pouvais ressentir avec mon R1 et mes DACs précédents ont disparus.
Classique, Jazz, rock, tout est splendide. Plus le disque est beau, plus l'écoute est somptueuse.
On a qu'une envie; s'assoir, écouter des disques encore en encore.
Produit exceptionnel.
Pierre S.
Vraiment très bien
Je l'utilise pour alimenter mon HD réseau Synology, c'est vraiment très bien, ça a apporté une nouvelle dimension dans la profondeur du son et dans sa définition, qui était déjà très bien avec mon streamer DAC Lumin T2.
La bête fait son poids, beau boitier de belle construction, le tout à l'air vraiment très fiable.
IVAN M.
A éviter
Voilà bien longtemps que je n’avais pas acheté un appareil aussi décevant.
4 principaux problèmes :
- avec le gain réglé sur "0", je ne peux finalement l'utiliser qu'avec mon Sennheiser HD570. Avec les autres casques (ATH-MSR7 B et SONY MDR-1A M2), le son est trop fort même avec le volume réglé au minimum ;
- même avec le Sennheiser, au début de la course du potentiomètre, il existe un déséquilibre gauche/droite
Apparemment ifi aborde ce sujet dans sa FAQ mais à propos d'un autre modèle. Je pense toutefois que l'analyse de doit pas être très différente pour le Zen CAN
https://ifi-audio.com/faqs/channel-imbalance/
- à l’exception du potentiomètre, toutes les autres touches branlochent. Ce n'est pas très gênant mais désagréable et renforce encore l’impression d’avoir un appareil complètement camelote entre les mains. Lorsque j'avais reçu le colis, je pensais qu'avec ces cliquetis métalliques, l'appareil était en pièce détachée dans la boîte (ce qui n’était heureusement pas le cas)
- le souffle est important, même avec le gain sur "0". Un peu surprenant quand même pour une société qui commercialise l'iEMatch par ailleurs.
L’objectif était utiliser mon 'ATH-MSR7B en symétrique, et c’est totalement raté.
Caractéristiques alléchantes sur le papier, et assez inattendues pour un prix aussi faible, mais in fine, cet appareil ne tient pas du tout ses promesses.
Frank j.
singxer su2, is a good digital interface, for usb
good sound, high resolution, and is soft in sound in high, good midrange
you get details, with as well as a little more 3d.
I have a neumann 310a studio monitor.
they reveal everything in the sound.
running my hifi system, with dac from gustard x20pro
with earth and power cable put ferrite core on
gives something extra to, singxer su2 power supply, clean power
Cedric M.
BURSON AUDIO SOLOIST 3X PERFORMANCE Headphone Amplifier Preamplifier Balanced Class A A vastly improved version of the original Soloist, released in 2015, Burson Audio's Soloist 3X takes up the concept of the original Soloist, including fully discrete circuitry,...
Little Big Amp
Après quelques semaines d'utilisation maintenant, je dirais que le Soloist 3X est un ampli puissant, précis et énergique. Mais ni les basses ni les aigus ne sont exagérés.
La profondeur de la scène sonore, la clarté et l'impact sont tous des points forts du 3X.
C'est un très bon couple avec mon casque (Kennerton "Gjallarhorn) qui tire profit de ce dynamisme et de cette clarté.
La dissipation thermique est très efficace, et l'ampli reste tiède même après des séances (de rodage) d'une dizaine d'heures d’affilée.
Compter 20-30min de chauffe pour atteindre un son son optimum.
Ça valait vraiment le coup d'attendre :)
Équipe Audiophonics toujours au top!
Mitigé sur ampli Fx Audio
J'ai essayé ces tubes sur mon FX Audio FX270PRO à la place des 6k4:ben j'ai pas aimé,le son est comme voilé sur le medium aigu,grave en retrait...peut être un rodage assez long à prévoir ???
Quand j'aurais reçu le petit DAC de FXAUDIO,je referais des essais plus approfondis.
Je reposterais un avis pour vous donnez mon ressenti
