Marco R.
7 stelle di Qualità
Freddy A.
un plus
Dominique R.
Top !
philippe l.
Lp
Société très efficace
Envoi rapide
Produit excellente qualité
Rien a redire
Rudy C.
Très bien!
Conforme aux attentes, matériel bien fini et qualitatif. Très bon rapport qualité prix!
Rudy C.
Conforme aux attentes, bon rapport qualité/prix
Desire A.
La quantité
Alors une unité correspond à 1 mètre et donc à 4.5 euros si j'ai bien compris. J'en ai commandé deux unités et je n'ai pas deux mètres de conducteur. J'ai à peine 1 m.
Où est le reste?
Où alors j'ai peut-être mal compris !
Sinon je suis satisfait du produit.
Sherwin D.
Improved my Chord Mojo DAC and USB reconditioner
I bought it to improve the sound of my DAC setup.
Build quality:
Very solid and weighty. The power button has weak spring action (does not bother me).
Delivery time:
Audiophonics sent the unit on the same day. It arrived after 6 working days to neighboring Germany, which is OK but could be better.
Performance:
I bought it to replace the 3A SMPS phone charger I use for my Chord Mojo. Even though the DAC designer says better LPSU should not make a difference, it actually did improve the sound of the mojo - I got deeper and more impactful bass, smoother sound.
As an added bonus this LPSU could also power my USB reclocker from Oehlbach. I was previously powering the reclocker with a Lead-Acid battery that brought big sound improvement. I did not notice sound degradation moving from battery to this LPSU.
Please note that the reclocker needs very little power itself. This is important to keep the power consumption to the LPSU within the specified 2A capacity (a hardworking LPSU generates higher noise).
As you can see I am very happy with this unit.
François G.
Câbles de 1mm de diamètre.
Belle qualité de finition et matériel de bonne facture, l'un des rares modèles qui s'adapte a mes câbles. Je conseille.
François G.
Coffret alu anodisé
Je trouvais le prix un peu élevé, mais vu la qualité de finition et sa facilité de montage, je ne regrette rien et le conseille vivement.
Excellente rigidité et facilité d'usinage pour l'intégration de mes composants.
Enrico F.
It worth the Price
Maybe there is something of alchemy in this plug but it works fine. Greater contrast and silence. Also the scene is deeper.
Włodzimierz K.
MiniDSP DDRC-22D 24/96kHz Stereo Digital Dirac Live The DDRC-22D DSP fits between your digital source and your integrated preamplifier/amplifier, or even between two digital sources. It was designed to radically transform your...
Great DSP. A sound that is tight, refined and very enjoyable to listen to. There is an improvement in the sound stage, an improvement in timbre.
Bonne sonorité
En remplacement de condensateurs défectueux , ils sont parfait , bipolaires , mais beaucoup plus encombrants . Bonne sonorité , sur sortie HP d'un ampli casque classe A
Bertrand B.
ELECAUDIO RC90-REDC
Pendant la soude le plastique résiste bien au chaud.
Je les ai montés sur du sommercable stratos qui fait presque 9mm de diamêtre. Il faut toujours penser à en acheter en nombre pair.
xavier v.
Très correct pour le prix
Bien fini, plug and play, rien a faire a part brancher et écouter. Pas de bruit parasite pour la part mais le son n'est pas non plus exceptionnel. Je l'ai installé dans une radio année 50 en remplacement du système d'origine. Cela suffit amplement pour l'usage dédié (écoute en volume modéré dans un bureau). Couplé a une alim 19v et des HP alpine 4ohm.
Neutre et transparent
Enfin un câble qui n'en rajoute pas,c'est typiquement monitoring.
Peut ne pas convenir à ceux qui aiment l'écoute démonstrative.
Du coup,j'ai tout cablé modulation et numérique en Canare.
Gregory K.
Rien na dire pour le prix
Malheureusement, on ne peut que décrire les impressions extérieures du câble.
Et ils sont en fait assez bons.
En tout cas, tout est à sa place et en ordre.
Vous pouvez certainement l'acheter pour cela, il est plus que correct et vaut le prix.
Je l'achèterais à nouveau.
Gregory K.
Gregory K.
Super et Merci Audiophonics
J'ai acheté l'alimentation de la carte Matrix element H pour l'alimenter et elle fonctionne bien.
De l'extérieur, l'alimentation électrique semble très bien faite et comporte un interrupteur marche/arrêt.
On ne peut pas en voir plus de l'extérieur.
Je n'ai pas ouvert la vie intérieure.
À travers les fentes, je peux voir des pièces de haute qualité.
Et il fait ce qu'il doit faire.
Pour le prix, il n'y a rien de mauvais à signaler. En combinaison avec la carte Element H, j'ai reçu une croissance significative.
Ce qui ne peut que signifier qu'il fonctionne comme le pensait Audiophonics et ne peut que les remercier de proposer une alimentation électrique raisonnable et abordable sans le grand vaudou que l'on voit chez les autres fabricants.
J'achète à nouveau et je pense en acheter un autre pour le système téléphonique.
Merci beaucoup à Audiophonics.
Gregory K.
Obligé d‘achtez
Pas avec des écouteurs.
Christian H.
Sparkos exagère un peu, non ?
Christian
Une petite bombe musicale !
Paul J.
Subtle but Significant
Jonathan S.
VA LI DE !
Bon pour conclure :
Pas de souffle !
ATTENTION !
Christian H.
Cordialement,
Christian
Nicolas S.
Formidable, étonnant!!!
J'ai acheté ce petit boitier sur conseil d'Audiophonics. Une petite bombe!! Etonnant tant sur un PC que sur smartphone. Drive même mon HD600 de 300ohms. Rendu plein de vie et de richesse. Seul souci : branchement symétrique obligatoire. Il serait aussi super de trouver un branchement permettant la connexion sur Android tout en chargeant le smartphone et pourquoi pas fournir le 5V du DAC...
Mathias B.
Petit amplificateur
Très bon à petit prix!
Son clair et agréable sans créer de fatigue.
christian b.
Acheté avec bloc stéréo purifi S400ET, je dois dire que cet ensemble est de très haut niveau musical.
Sont au rendez vous une très belle transparence, dynamique, punch,justesse et musicalité assez édifiante. On lève un voile sur le message, qui donne l'impression d'une pureté fabuleuse.
Petit bémol, chez moi cet ensemble tellement pur, souffre immédiatement de la qualité du secteur, qui se matérialise par une dynamique très atténuée, ainsi que les aigus.
À noter qu'il convient également de trouver le sens secteur de chaque appareil.
Une fois cela, si votre système est à la hauteur, c'est sublime.
Christian
christian b.
HATTOR AUDIO THE BIG Unbalanced Passive Preamplifier Vishay SMD Black / Silver This passive remote-controllable preamplifier with dual attenuators with 1% accuracy SMD resistors offers the latest in sound reproduction refinement. Both passive preamplifier...
Christian
Excellent amplificateur
J'ai des enceintes trois voies que je faisait fonctionner en bi-amplification, un FX-Audio FX1002A drivait deux graves Fostex de 20cm et un amplificateur Single Ended à base de deux tubes 6L6GT drivait le couple Fostex/Audax en médium/aigu.
Ayant fait récemment l'acquisition d'une DSP Dayton DSP408 et ayant pu en apprécier toutes le qualités, j'ai décidé de faire évoluer mon système vers la tri-amplification.
Dans un premier temps, j'ai gardé la même configuration mais j'ai remplacé l'ampli à tubes par un FX1002A histoire de voire si ces amplificateurs classe D étaient fidèles à la réputation qui leur collait à la peau, c'est à dire peu musicale et dur dans le haut du spectre.
Objectivement, il n'en n'est rien, le FX 1002A soutient sans problème la comparaison avec l'ampli à tube, ,aucune dureté et manque de musicalité, de plus les 2x60W du FX-Audio donne de l'aisance et d'absence de saturation dans les pointes de niveau, les deux fois 5 W de l'ampli à tubes largement suffisent avec des HP de 93db de sensibilité et à régime normal, mais dès que le niveau augmente et atteint un côté certes déraisonnable, il marquent leur limite.
Cette première étape m'a motivé et poussé à faire l'acquisition d'un troisième FX1002A pour driver mes tweeter.
J'en suis actuellement à la suppression des filtres passif et au recâblage du tout.
Mais ces amplificateurs FX-Audio peuvent en remontrer à beaucoup d'ampli "dit" haut de gamme, j'affirme qu'il peuvent sans problème soutenir la comparaison contre des amplis à tubes ou à transistor les plus chers, compact, pas cher je recommande sans souci cet ampli.
Son seul handicape......................son prix qui aux yeux de certains "audiophiles" le place dans les pas assez cher.............................
Rudolphe D.
Dual Linear Power Supply Module LT3042 5V / 3.3V 1A This linear power supply module with two outputs is based on an LT3042 and a pair of high-performance A1930 transistors from Toshiba. It benefits from the PSRR architecture...
Manque de précision
Les masses des sorties ne sont pas isolées mais bien connectees l'une et l'autre
Rudolphe D.
Pratique et fonctionnel
Utilisé pour alimenter sur des consomation de moins de 500 mA avec un transfo 2x6v c'est parfait et effectivement très propre à l'écoute
Juraj P.
Parnica Juraj
Good day
we can change the order and pay the difference
well thank you
amend for
MUNDORF MCAP SUPREME EVO SILVERGOLD OIL Capacitor 800V 6.8µF ---2ks
Rudolphe D.
Description à revoir
Pas possible de sortie des tensions inférieurs à 5vdc contrairement à ce que vous indiquez
LA solution parfaite pour un lecteur réseau évolutif
La qualité audio est remarquable. Mon lecteur CD Denon, pourtant très qualitatif à l'époque, fait désormais bien pâle figure lorsque l'on compare le rendu d'un CD et celui de sa version dématérialisée (via ExactAudioCopy). La précision des voix et des instruments, l'étagement des plans et la spatialisation des sources sonores, l'absence totale de souffle dans les passages de faible intensité sonore sont exceptionnels.
Mon lecteur de CD dispose d'une sortie SPDIF coaxiale pour y raccorder un DAC externe et il est vraiment dommage qu'Audiophonics n'ait pas équipé son lecteur d'une entré SPDIF (comme pour le RaspDAC Mini), d'autant que la carte DAC conçue par Audiophonics dispose d'une embase SPDIF IN. Ce raccordement en face arrière serait d'une grande utilité puisque comme beaucoup, je ne dématérialiserai pas la totalité de mes CD. C'est d'autant plus regrettable que le driver de la carte, désormais supporté nativement par le noyau Rapsberry OS, permet de sélectionner l'entrée SPDIF (ainsi que de contrôler matériellement le volume et de sélectionner l'un des 7 filtres de reconstruction prédéfinis de l'ES9038). Il est en outre complètement exploité par Moode Audio que j'ai installé après avoir examiné plusieurs autres solutions. Audiophonics devrait proposer une option ou un kit pour sa carte DAC incluant une embase SDPIF de même esthétique que les embases RCA ainsi qu'un connecteur pour le PCB avec la dizaine de centimètres de câble nécessaire.
La carte DAC est une mise à jour de la version décrite sur le site. Certains composants ont été miniaturisés (microcontrôleur Nuvoton), d'autres ont disparu (convertisseur Mornsun). L'espace gagné a permis l'installation d'un relais qui désactive les sorties audio en l'absence de signal. L'étage d'alimentation a été largement revu sans qu'il soit possible d'identifier certains composants nouvellement utilisés (dont le convertisseur DC/DC).
L'absence d'écran, de télécommande IR et autres périphériques spécifiques (dont l'utilité est en fait assez contestable pour un lecteur réseau piloté par une interface web déportée) est ici un vrai atout puisqu'il est possible d'installer les dernières versions des logiciels de lecture sans devoir les adapter à ces matériels à chaque nouvelle release. Le boitier intègre en revanche une carte d'alimentation "ATX like" qui permet d'allumer ou d'éteindre le matériel par l'appui du bouton en face avant (comme pour tous les autres matériels audio), ou de l'arrêter/le redémarrer par logiciel. Ce dispositif est indispensable pour couper proprement l'alimentation sans risque de corruption du système ou de la carte SD. Les scripts d'initialisation, d'arrêt ou de rédémarrage et quelques indications sont disponibles sur github via le site d'Audiophonics mais ils mériteraient d'être mis à jour (cf. utilisation d'un overlay pour la prise en compte du bouton poussoir par exemple) et accompagnés d'un vrai tutoriel.
Si l'on considère son prix, cette offre d'Audiophonics est vraiment compétitive. Pour ce qui est du délai, je me suis inquiété de l'attente d'un mois annoncée à la commande puisque le produit et certains de ses composants n'étaient pas disponibles, mais à tort : le lecteur est arrivé en temps et en heure.
Rudolphe D.
Moyen
Regulateur monté lt1084 au lieu du lt1083 annoncé
Pierre F.
Jean-Claude F.
Gustav W.
Guido M.
Thanks Audiophonics!
Robert M.
Michel G.
Bof
Dragoslav R.
DIY Box / Case 100% Aluminium 260x311x90mm Silver Pannel This aluminum-grade case with a thick 8mm faceplate is perfect for designing class D preamplifiers, DACs or power amplifiers for a professional quality finish. This box comes...
Dragoslav
Thanks Audiophonics
Jean-marc B.
Apport non négligeable
Jm,
Jean-marc B.
Vaut vraiment la peine
Jm,
Jean-marc B.
FURUTECH ADL ID-35L Jack 3,5mm to Jack 3,5mm 0.15m Furutech has adapted its know-how in terms of conductors and connectors in a cable dedicated to nomadic HIFI. This interconnect cable features 3.5mm metal jack connectors...
Jm,
Jean-marc B.
WBT-0102Ag RCA Plug Nextgen Pur Silver 75 Ohms Ø9mm (Set x4) The RCA connectors WBT-0102Ag allow the design of high-end finished cables thanks to a high quality design optimized for performance. The contacts are made of pure silver with a...
Montage plus que délicat
Sur quatre connecteurs, j’ai dû en jeter deux parce qu’une des deux pattes d’encrages s’est cassée par deux fois lorsque j’ai voulu désolidariser la partie plastique pour exécuter le soudage, qui n’est pas réalisable sans cela.
De plus on ne peut pas utiliser un câble supérieur à 8 mm de diamètre, au delà si le câble rentre bien jusqu’à 9 mm, il n’en ressort pas ce qui est selon moi problématique pour souder.
J’ai quand même pu fabriquer un câble numérique pour relier un lecteur DC à un DAC. J’ai utiliser un câble Furutech de 8mm de diamètre, j’avais aussi pris un Neotech de 8,4 mm mais cela ne passait plus et de toute façon comme je l’ai mentionné ci-dessus deux connectiques étaient dégradées donc je ne l’aurai pas monté dans tous les cas.
Niveau sonore, bien que non rôdé il y a bien une plus value dans ce nouveau câble SPDif.
Bref, sur le principe les connecteurs sont de bonne qualité, mais en pratique une faiblesse au niveau des pattes de démontages les rendent inopérants ce qui est inacceptable au vu du prix.
Jm,
Pascal V.
Excellent ampli
Je cherchais un petit ampli en remplacement provisoire de mon ampli principal qui était tombé en panne et pour un deuxième petit système par la suite. A 139 €, je ne prenais pas de risque et je voulais tester la classe D.
L'écoute est étonnement agréable, précise sans trop de dureté. L'ampli peut amplifier des JBL 4412 sans problème. J'ai eu du NAD, Myryad, Rotel et cet ampli est quasiment au même niveau pour un budget bien moindre.
L'entrée analogique RCA sonne très bien, l'entrée USB permet la lecture de fichiers jusqu'à 384 kHz/32 bits, en 192 kHz/32 bits c'est déjà suffisant, l'entrée bluetooth limite la lecture à 48 kHz/16 bits.
Je vous conseille des fiches banane pour la connexion HP car les prises sont assez serrées. La sortie SUB est un vrai plus et fonctionne bien.
Les preset EQ ne servent à rien, les corrections de graves et aigus sont possibles et permettent un boost dans le bas ou le haut sur des enceintes qui en auraient besoin.
Bref, pour un 2ème "petit" système, c'est l'ampli idéal.
Michael A.
Potentiometer Axis Extension Kit 300mm Ø6mm This 300mm long potentiometer extension kit is ideal for your DIY projects and assemblies, allowing you to place the potentiometer close to the circuits in order to limit the...
Bonne qualité de fabrication.
Kit de bonne qualité de fabrication et d'assemblage. Il m'a permis de déporter un potentiomètre de volume sur un ampli Luxman LV112 dont le potentiomètre d'origine compacte ne se trouve plus.
Michael A.
Bon cable à petit prix
Utilisé pour du câblage interne, le cuivre et le blindage sont de bonne qualité. Il se dénude bien. Parfait pour des petites longueurs.
Carlos M.
Excellent DAC, mais Audiophonics n'a pas envoyé le même jour
J'ai acheté le Topping E30 pour remplacer le D10 parce que j'avais besoin d'un input optique et je suis très content. Un DAC incroyable pour le prix!
Le seule problème de mon achat était le service d'Audiophonics. J'ai acheté avant 11am et ils on envoyé seulement le jour suivant, pas dans le même jour!
Rémy V.
Excellent Produit.
Matériaux de qualité. Système de serrage des câbles performant (2 vis de qualité et de longueur idéale pour le serrage de câbles de petite ou de forte section). Clé de serrage fournie. Possibilité de connecter une autre paire de banane à l'arrière (bi-câblage par exemple).
Bref ce sont des bananes chères, mais de qualité et bien conçues.
Seul point à faire attention : l'orientation des bananes. Une fois celles-ci mises en place, vue leur forme, si les bornes + et - de l'ampli sont proches, et les bananes mal orientées, elles peuvent se toucher et la partie inclinée n'est pas isolée.
