Thierry b.
Toute la...
remy l.
bon cable bonnes prises
Fr D.
FURUTECH SHAFT BAR MIX-8L4S Extension Rods for NCF Booster These extension rods allow you to offer your Furutech NCF Booster cable holder extra elevation.
Tige très pratique
Très bon complément des Booster, permet de bien adapter à la hauteur souhaitée pour éviter une tension du cable ou du connecteur.
Geoffrey W.
Geoff W
There is no doubt that this amplifier represents great value for money. I cannot fault its sound and it seems solidly built. However the packaging was terrible and it is a miracle that the product survived. Two thin cardboard boxes with a small amount of compressed paper packing in between. The parcel arrive flattened and bashed in at the corners. I have photos. Irresponsible service! Also I paid a lot more for TNT Express international shipping to UK; tracking shows that the parcel arrived at my local depot 3-4 days before it was delivered to me. I would not use TNT again. Good amplifier though.
michel c.
Correction
Jean-Luc B.
LPSU 1000
Super , je recommande !
Grzegorz B.
Very good cable
Jean -Didier s.
Prise murale furutech
Grzegorz B.
Not so sweet.
Grzegorz B.
Not so sweet
I bought this connector with FI-E48. FI-46 is made from satinised aluminum and is light, FI-E48 is made from some steel and chrome coated and is much heavier. Look absolutely different. Inside metal case is thin plastic, where in this thin plastic we screw screws that connect both sides of plug. Very delicate solution if you use thick and rigid cable. In FI-46 additionally we have very small space for unisolated cable, about 1cm, when you use thick cabel, mounting is very difficult. I bought once and never more even if it sound like divine.
Martin B.
Outstanding for the money
Upgraded from HiFiBerry Digi Pro. The increase in sound quality was simply astounding in every aspect. Power supplies are Raspi 4 official supply in the dirty side and a IFi in the clean side. DAC used is that built into the Marantz 6006 amp.
Jean Michel P.
Confirmation IEC de très bonne qualité
A l'écoute ce modèle est vraiment excellent . Excellente définition sans duretés et largeur de spectre étonnante Toutes les vis même le serre câble ont un écrou pour un meilleur serrage . Je regrette juste d'avoir mis avant le modèle en dessous qui bridait mon ampli Denon 1500 AE
Bruno G.
Depuis 25 ans j'utilisais les mêmes
câbles hp entre un ampli marantz thirty et des enceintes kef105. Avec l'installation d'une alimentation ipower pour le petit dac Audiophonics (tous deux recommandables) cela a mis en exergue les limites du câble. Sur les conseils de David, j'ai commandé ce câble hp qui ne m'a pas coûté plus cher que le port. La différence s'est avérée d'emblée flagrante, avec un naturel et un équilibre remarquables. De même sa petite section ne l'empêche pas de contrôler parfaitement le hp de 30 cm . Ne croyez donc pas que la qualité d'un câble est proportionnelle à son prix, en voilà la preuve. Merci David et Audiophonics.
Olivier D.
Câble audio hi-fi
Tres bonne qualité du produit pour réaliser un câble de qualité audiophile.
pascal l.
Un adaptateur tout simplement excellent, il restitue sans perte et fidèlement les signaux, petit et léger...on sent le côté robuste et soigné dès le premier insert....Bravo
Robert D.
Happy
All right.
Robert D.
Robert D.
Robert D.
Happy
Gold is peeled off during pressing.
Robert D.
Happy
Good price, good product.
Robert D.
Happy
Very good product ,fast shipping.I'm still testing the sound.
Jean-Louis C.
Great product! great improvement of sound!
I was not lucky to order just before the covid crisis, so I received it late. Audiophonics were nice to propose alternatives but I waited.
Received a few days ago. I alreday love it. Nice build quality (I ordered also the phase tester just in case). very solid and nice.
In replacement of standard very good distributor. I am using it with an Atoll IN200 driving a pair of Kef R900 and with furutech OCC cables. The sound is more "airy" (can we say that?), and background more dark. The Kef kept the low frequencies but look less boomy. Next investment could be the amplifier who is fantastic now up to 40/100 volume, but not enough strong to drive the Kef after that already decent volume.
alain C.
à garder !
ce dac est au coeur de mon système depuis 3 ans
le gros point fort est la connectique hyper complète pur un si petit boitier, et j'utilise tout :
entrées :
toslink optique pour la télé
spdif coax pour mon dap (ibasso dx50)
AES avec un cable XLR/coax 110 ohm pour une platine CD sony à 30 balles
usb avec u pc sous linux
BT pour les podcast depuis un smartphone
sorties
RCA vers l'ampli rotel qui alimente mes petites enceintes Athom
XLR avec cables RCA/XLR vers un caisson athom furtive
tout ça fonction en 2.1
qualité du son
compacité
simple et ergonomique à l'usage (le choix d'entrée auto est pratique)
connectique très complète
usb sous linux
USB pas toujours reconnu sur android (tablette asus pas reconnue)
Gilles G.
Comment magnifier le son sans changer d'ampli.
J'ai acheté un combo DAC / AMPLI audio GD 11 38 Performance. Déjà la qualité d'écoute était exceptionnelles bien que les aigus un peu trop agressifs. En plus je l'ai équipé d'un câble USB Audiophonics Digital Audio qui q déjà considérablement améliorée rendu sonore. Là, je viens de recevoir le câble secteur PANGEA AC-14SE MKII. En fait j'étais toujours sceptique quant à son efficacité sur la qualité du son. Le résultat dés le remplacement du câble d'origine m'a laissé sur le c...Le DAC / AMPLI Audio GD a immédiatement adopté un son organique, les basses sont devenues plus profondes sans perdre de leur précision et les aigus ont pris une chaleur qu'ils avaient pas. Je vous garantis que ce câble secteur transforme votre écoute en bonheur béat pur. Livré dans les temps par Audiophonics dans sa boite rigide bien protégée.
Jonathan M.
Presque parfait
Ce petit ampli numérique ne manque pas d'atouts. Le rendu sonore est excellent (en tous cas avec de petites enceintes bibliothèque Davis), la qualité de fabrication très satisfaisante (construction tout en métal) et la connectique est plutôt complète (pour un appareil de ce type). Last but not least, l'ergonomie est bien pensée et l'ergonomie dispose de réglages basses/aigus permettant d'affiner le rendu sonore. L'appareil souffre néanmoins d'un défaut : la réception BT est franchement moyenne.
Florent L.
Flo
reçu très rapidement merci GLS et audiophonics SUPER barrette qualité au TOP!! Allez y!!
Damon A.
VIABLUE STONE Braided Sleeve Ø13-26mm This Viablue Stone braided sleeving accepts cable diameters ranging from 13mm to 26mm, providing effective protection against mechanical stress. Its fine braiding ensures a...
Not quite what I hoped.
Damon A.
Damon A.
INCROYABLE
Javier M.
Envio recibido.
Rene R.
MOGAMI
Cable très équilibré, restitution vivante transparente, rien a envier a des cables audiophiles aux tarifs exorbitants
Rene R.
Excellents connecteurs
Excellents connecteurs, faciles a souder, bon contact,plus fiables,excellents résultats a l écoute ( supérieurs a la connectique WBT , qui a souvent de mauvais contacts c 'est produit Marketing )
jean francois F.
excellent rapport qualité-prix, belle fabrication et excellent contact. Problème de soudure résolu en soudant à 350 degrés. Franchement au niveau de connecteurs beaucoup plus chers.
Claudine B.
Excellente surprise
Je possède une paire de Cabasse MC40 Majorca (colonne en 8 Ohms) pour sonoriser une pièce modeste (16m²) et après la panne de mon Atoll IN100, j'ai voulu essayer autre chose. L'IN100 est un amplificateur avec un son très neutre mais qui a malheureusement une forte tendance à chauffer. Problème : aucune boutique d'audio à proximité pour faire des écoutes. J'ai découvert par hasard le site d'Audiophonics et j'ai commencé à me documenter sur ces petits ampli assez bon marché finalement.
L'impression générale sur ce modèle est plutôt bonne. Il n'a pas le niveau de finition extérieure de l'IN100, et c'est bien normal compte tenu du prix, mais reste tout à fait honnête. L'important de toute manière se porte sur la restitution sonore... Soyons clair, cet ampli est un poids plume face à mon ancien ampli, tout juste la moitié de sa puissance et de sa taille. Ma plus grande crainte était qu'il ne puisse pas driver la paire d'enceinte faute de puissance, et d'avoir un rendu sonore castré dans le grave à cause d'un manque de réponse sur des parties un peu punchie. La première écoute arrive et c'est vraiment bien... Neutre, très précis dans le haut medium et les aigus mais brouillon dans le grave. Plusieurs heures de rodage plus tard, le grave est de plus en plus présent, et surtout je n'ai pas besoin de monter à plus du tiers de sa puissance pour avoir un volume sonore agréable.
En conclusion, je suis vraiment bluffé par ce petit ampli. La restitution sonore est très proche de l'Atoll IN100 avec un son très neutre et texturé, pour ne pas dire identique, et il offre une bonne puissance de sortie sans chauffer de façon excessive. On pourra regretter l'absence d'une sortie casque qui en ferait une vraie alternative aux gros ampli.
Indispensable sur les BOX et le reste
J'avais déjà acheté une de ces alim pour alimenter la carte USB de mon ordi via le Dac...avec grand bonheur.
Tous mes appareils sont branchés sur des blocs secteurs filtrés AUDIOPHONICS avec des plugs ifi Audio AC iPurifier Filtre secteur actif.
Et comme un âne, et le mot est faible, je n'avais pas remplacé les alim de la FREEBOX.
C'est fait...et croyez moi, c'est par là qu'il faut commencer pour la musique dématérialisée, car c'est par là que tout arrive.
Comment dire, avant c'était trés bien et maintenant c'est trés bien mais en mieux.
Cristian M.
Affordable end-game
This is a seriously beefy amp that offers performance of many times more expensive amps. I don't have a matching DAC yet (still using a cheap one) but I believe the increase in power offers a bit more dynamic range and slightly cleaner sound. So in essence it sounds like an amp should sound. Neutral, powerful, dynamic.
Arthur S.
Best amplifier I've had the pleasure of owning
This is Topping's statement amplifier as a response to the THX AAA amps like the 789 and the 887. On high gain, the A90 is as clean as those but more powerful. On low and medium gain, it is a lot cleaner than the THX ones, essentially beating the $3000 Benchmark HPA4. This is a BARGAIN. I also really like the smooth, big knob. It's perfect :)
About the sound. You can push any headphone without any distortion, especially the bass is really impressive. I use low gain for IEMs and low gain maxed, or medium gain, for dynamic and planar headphones. The sound is sublime, I can't fault it in any way.
Tech wise, it is based on a common texas instruments amplifier, but with composite feedback that essentially nullifies practically any and all distortion. It sounds simple but no one has achieved this performance so far, especially at this price.
Finally, it supports SE in SE out, SE in BAL out, BAL in SE out, BAL in BAL out. The power is internal, it has two separate power supplies for each channel, again really impressive considering the price point of this amplifier. This gives the unit some heft, as well as saving you from any bulky supplies in the power outlet.
sang c.
very good....
sang c.
very good.....
good service..
sang c.
very good.....
Bonjour, je cherchais une carte usb ou hdmi pour un pc daphile...... Le choix pour l'hdmi est limité à la Pink Faun qui n'était pas mon budget. J'ai donc commandé la Matrix. Installé sans problème. Allumé. Ecouté.
Grande différence avec le port usb de la carte mère, tout en finesse, les instruments bien à leurs places. Les graves ne coulent pas. J'ai l'impression d'avoir un nouveau dac bien superieur et je me demande comment j'ai pu m'en passer.
Du coup j'ai commandé un nouveau dac de la même marque.
Héee oui ça n'a s'arrête jamais.
Jérôme V.
Très bon câble, bien fabriqué, très souple vu son diamètre, les différents isolants sont très faciles à découper pour le montage sans couper celui d'en dessous. Si j'avais du budget, j'en reprendrai 50m pour toute la maison :D
Jérôme V.
Jérôme V.
Jérôme V.
Jean Michel P.
Excellente prise IEC
Raphael M.
compact et fonctionnel
André M.
Borniers WBT-0703Cu
Patrick L.
Bertrand B.
Super connecteur
