Efthymios X.
If you need it, no alternative for the moment, so 5/5
Efthymios X.
At its price, nothing else out there.
Efthymios X.
Good for its price, beggars and choosers as the saying would go :)
Customers reviews - There are 19473 reviews.
Alexandre L.
Sort un flux digital de bien meilleure qualité que la sortie optique intégrée à mon Macbook 2015 que je croyais pourtant déjà excellente.
Jean-Marc C.
CAIG DEOXIT F5S-H6 Fader Cleaning and Lubricating Spray 182ml DeoxIT F5S-H6 spray precisely lubricates and cleans control knobs and moving contacts such as potentiometers, faders, switches and other control mechanisms.
Le produit répond parfaitement à l'usage annoncé.
Le réglage du "débit" est un plus indéniable pour les composants à accès difficile.
David A.
TOPPING A90 DISCRETE Discrete Balanced Headphone Amplifier Preamplifier Black Topping returns with the A90 Discrete, an improvement of the previous A90, this time equipped with discrete components. Both a headphone amplifier and a preamplifier, it...
Superb
I purchased the A90d to take over preamp duties on my Eversolo A8.
I use Dynaudio evoke 20 which are 6ohms. The output from the A8 to my audiophonics Ncx600 was a little low.
The difference adding the A90 was amazing. Now the Dynaudio’s could sing!
More spacious and detailed with tight bass.
Very pleased and highly recommended!
Dominique L.
DL22
Parfait. Facile à installer . Correspond bien à mon besoin.
Wiesław P.
Useful thing
The extractor did its job. You don't have to spend a lot of money on fancy HDMI i2S cables, because it works on inexpensive, well-made cables. The extractor allows you to extract DSD files from SACDs (finally!). You can connect it directly to a Blu-ray HDD or SSD and listen to music saved in DSD without using a computer. The only limitation is that you can only play DSD64 files, the higher ones, at least for me, are played in 176kHz pcm. And the power supply is necessary, because supposedly power goes through HDMI, but there are problems. So the power supply is a must.
Laszlo T.
Umik1
Gyorsan megérkezett a mikrofon, tökéletesen lehetett a Dirac Live-hoz illeszteni és a Bluesound Icont kb fél óra alatt beállítottam. Nagy mikrofonállványt szerinem mindenki vegyen hozzá, ha nincs otthon.
Stephane D.
SMSL PO100 2024 USB Interface XMOS XU316 to SPDIF Coaxial / Optical Toslink 24bit 192kHz DSD DoP64 Silver SMSL unveils its PO100 2024, a digital interface USB to SPDIF coaxial / optical Toslink. This is based on an XMOS XU316 interface and a CK-02 clock circuit, it supports up to...
Parfait pour un smartphone Android et +
Je l'utilise associé à un smartphone Android, HiBy en app de lecture, une petite config pour le passer en bitperfect, et me voila avec lecteur de fichier efficace pour pas cher.
Cette interface fonctionne sans soucis avec un DAP HiBy R8 et R5 et certainement d'autres DAP.
La qualité sonore dépendant surtout du DAC auquel il sera relié, je ne m'étendrai pas dessus.
Felix D.
LOXJIE A40 Class D Amplifier Infineon MA5332MS USB Bluetooth 5.1 Subwoofer 2x165W @ 4 ohm With its A40, Loxjie has unveiled a powerful and versatile Class D amplifier. It can deliver up to 2x165W @ 4 ohm thanks to its Infineon MA5332MS amplifier chip. Moreover, the...
Une claque MONUMENTALE !!
Acheté pour ressusciter une paire de dual cl 490, de modestes 3 voies biblio de 1979, pour une écoute principalement dématérialisée et vinyle. Je l’ai choisi par rapport au SMSL pour son entrée phono mais ils ont la même puce d’amplification et la même puce DAC. C’est une fois branché, avec l’ensemble du câblage neuf, que ça s’est produit : une claque MONUMENTALE dès les premières écoutes !! La puissance parait inépuisable, on peut corriger les aigus et les graves très facilement, le son envahit une grande pièce à vivre avec une facilité et une clarté déconcertante. Pour son prix, cet ampli est juste incroyable !
Peter P.
3E AUDIO A7 MONO Class D Mono Amplifier PBTL 1xTPA3255 1x260W 4 Ohm 3E Audio, a recognized player in the DIY world, now offers a Class D mono amplifier incorporating audiophile Hi-Fi components. The A7 Mono amplifier is based on one TI TPA3255...
Very highly recommended (with a small caveat)
This is definitely a one-of-a-kind class D amplifier
Stays cool (unlike other PFFB amplifiers), superb sound quality (check out the measurements on audiosciencereview and archimago's site)
The reason for the 4 stars is that it has an auto-standby feature that cannot be adjusted or switched off. This is really annoying and for me this is a bug, not a feature
CASPAR P.
très bon connecteurs
monté avec NEOTECH NEI-3004G ( excellent cable )
assez faciles à monter, très bien usinées, excellent résultats
CASPAR P.
Ecxellent
Sonne très bien dès le branchement.
C'est clair, spatialisé, détaillé, des basses quand il y en a, respecte très bien les enregistrements.
monté avec RAMM AUDIO 30891-RT
Utilisé entre Atoll MS120 et Naim Supernait3 avec JMR Cantabilé jubilé.
J'ai hâte de l'entendre vieillir un peu
Christian E.
Deux en série avec le tweeter sur un filtre passe-haut du 3eme ordre. Après quelques heures de rodage, c'est parfait :)
RENAUD C.
EXICON ECX10P20 Transistor MOSFET (2SJ162) Exicon MOSFETS have been specifically designed for high power linear use. They offer high voltage capability, high slew rate and low distortion, making them the ideal choice for...
Excellent MOSFET pour le Projet 101 Elliott Sound Products. Merci Audiophonics
RENAUD C.
EXICON ECX10N20 Transistor MOSFET (2SK1058) Exicon MOSFETS have been specifically designed for high power linear use. They offer high voltage capability, high slew rate and low distortion, making them the ideal choice for...
Un bon achat
Michel T.
GUSTARD X26III DAC 2x ES9039SPRO NOS Streamers LAN Roon Airplay UPnP 32bit 768kHz DSD512 Silver Gustard's X26III is a balanced DAC and streamer based on two top-of-the-range ES9039SPRO DAC chips, offering accurate conversion of PCM up to 32bit 768kHz and DSD up to DSD512,...
Gustard x26 lll
Super produit. Livraison rapide merci audiophonics
la rapidité et transparence !
Bonsoir ,schuko 004 sur mon alimentation via phono limetree, le son en resulte par une tres grande rapidité,un son precis, transparent, fin, basses serrées, peut etre un poil manque de largeur . Un super schuko
SILKLINE LITY I Integrated Amplifier Class AB 2x115W 4 Ohm With its Lity I, Silkline unveils an integrated amplifier capable of delivering 115W @ 4Ω and 75W @ 8Ω. This makes it ideal for medium to large rooms. This class A/B...
Hautement musical si…
Très bon montage et de qualité de réalisation.
Là où il pêche est par son coffret de tôles fines et vibrantes !
Pas bon du tout, cela a réellement une influence sur le son. Bilan, on démonte et on place des absorbeurs là où il faut. Dedans et dessus.
Une fois fait, ça sonne mate quand on tape dessus, le transfo ne balance plus ses vibrations partout. Et là, enfin, on peut apprécier toutes les qualités de cet excellent ampli à base de transistors bipolaires.
Rodage obligatoire d'une vingtaine d'heures pour l'entendre aussi chanter pleinement.
Bref, les Classe D ne sont pas pour moi, je reste fidèle à la classe A ou AB et ici, vu le prix, cet achat est une belle découverte.
Philippe f.
Petit avis rapide.
Ce produit respire la qualité de fabrication.
Après quelques jours d'utilisation, j'obtiens un son plus plein avec des détails supplémentaires . Ce n'est pas le jour et la nuit mais une fois que vous le retirez, il y a bien une différence . Il est donc resté ! Merci encore à audiophonics pour sa rapidité et la qualité de ses emballage .
Rainer E.
Verbesserung
Verbessert jedes Gerät (wenn Sie ein halbwegs vernünftiges Netzkabel verwenden)
Sichtbar und hörbar. Je nachdem !
Rainer E.
Sehr empfehlenswert!
Bei mir ist dieses Kabelmodell schon seit mehreren JAhren in Gebrauch. Sie wollen es höherwertiger ? Das dürfte schwierig werden. I
Konfektionieren Sie es (unbedingt mit hochwertigeren) Furutech Cinch Steckern und sie werden zufrieden sein.
In dieser Preisklasse bekommen Sie nur noch ein gebrauchtes Tellurium Black Cinch Kabel, das klanglich ebenfalls in dieser Liga spielt, aber in Bezug auf Klarheit und Auflösung nicht ganz das Niveau dieses Furutech Kabels erreicht.
Rainer E.
Sehr gut!
Diese Furutech FT-903 (G) Cinch Buchsen kamen bei mir im Zuge einer umfänglichen Revision einer Endstufe (Pioneer M-22) als Ersatz für die serienmäßigen Cinch Buchsen dieses Endverstärkers von Pioneer aus den späten Siebziger Jahren zum Einsatz.
Gleichzeitig wurden auch die LS Terminals sowie das IEC Inlet dieses Verstärkers durch Furutech Artikel ersetzt.
Alle jeweils in der Gold (G) - Ausführung.
Insgesamt hat sich der Austausch dieser Dinge als akustisch sehr vorteilhaft ausgewirkt:
Nach einem mehrwöchigen "Burn - In Prozess" zeigt sich das Ergebnis als harmonischer, deutlich verzerrungsärmer, wärmer und gleichzeitig transparenter. Ohne Reduzierung der Dynamik. Eher im Gegenteil. Die Dynamik ist sehr schnell (wofür diese Class A Endstufe aber ohnehin bekannt ist.) Was "fehlt" ist der vorher leicht "blechern" anmutende Beigeschmack.
Welche dieser positiven Auswirkungen jetzt explizit auf die Cinch Buchsen zurückzuführen ist, bzw. in welchem Ausmaß, kann ich natürlich nicht genau benennen.
Dies ist in diesem Fall auch ein Summenergebnis.
Da ich aber mit anderen Furutech Artikeln dieser Art an anderen Geräten sehr ähnliche, vergleichbare Ergebnisse erzielt habe, glaube ich sagen zu können, dass grundsätzlich auch diese Cinch Buchsen so charakterisierbar sind.
Lassen sie sich also von niemandem (auch nicht von einem Techniker) erzählen Cinchbuchsen machen keinen Unterschied. Sie tun es....!! Vielleicht nicht an einer ganz einfachen Stereoanlage, aber je besser/hochwertiger sie in der Wiedergabe sind, umso mehr kommt es auf jedes kleine Detail an. Und dann auch DEUTLICH hörbar.
Wo die Techniker recht haben, ist natürlich, dass zuallererst alle technischen Aspekte wie z.B Welligkeit des Netzteils usw, Austausch von Bauteilen aufgrund von Alterung oder
Defekten Priorität hat.
Jean-Louis R.
bon connecteur
bon connecteur, j’ai été surpris par le contact trés franc que l’on sent lorsqu’on insére la prise. C’est bien contruit. Le connecteur est massif et lourd, malgré tout il tient en place sans support.
Pour le son difficile de se prononcer par rapport à un connecteur pur cuivre.
Jean-Louis R.
NEUTRIK NL2FXX-W-S Female Speakon Connector Ø12mm The Neutrik NL2FXX-W-S is a robust 2-pin Speakon connector, ideal for designing professional-quality cables. It incorporates a proven locking system to ensure reliable...
Trés bon connecteur
Trés bon connecteur, le montage a été délicat avec un câble diametre12mm. J’ai du supprimer des lamelles du presse étoupe pour pouvoir visser la derniere partie du connecteur.
La vis btr de serrage des fils agit sur une plaquette qui pince les fils, ça permet un bon contact.
Pratique et esthetique, les aigūs sont légérement plus détaillés en comparaison de bananes pur cuivre.
Pour le prix, ça vaut le coup de tester.
Alain R.
JANTZEN AUDIO COMPACT MKT 001-8130 Axial MKT Capacitor 160V 18µF Jantzen Audio's Compact MKT capacitors are made from the highest quality metallized polyester film available. Jantzen Audio has succeeded in making these capacitors more compact...
Compact et performant
J'ai utilisé ces condensateurs Jantzen MKT pour le filtre passif d'une paire d'enceinte bibliothèque de 8 litres. J'avais donc besoin de composants de petite taille mais sans trop rogner sur la qualité. J'ai choisi ces condensateurs pour les 4 condensateurs du filtre.
Leur gros avantage est leur compacité. Le fait qu'il soit plat permet aussi un meilleur agencement.
Et à l'écoute, ces enceintes sont super.
Allez y les yeux fermés et en plus, les prix n'ont rien à voir avec des MKP haut de gamme. A t'on les oreilles pour entendre la différence ? J'en doute, il y a tellement d'autres éléments perturbateurs.
Alain R.
JANTZEN AUDIO COMPACT MKT 001-8120 Axial MKT Capacitor 160V 15µF Jantzen Audio's Compact MKT capacitors are made from the highest quality metallized polyester film available. Jantzen Audio has succeeded in making these capacitors more compact...
Alain R.
JANTZEN AUDIO COMPACT MKT 001-8090 Axial MKT Capacitor 160V 8.2µF Jantzen Audio's Compact MKT capacitors are made from the highest quality metallized polyester film available. Jantzen Audio has succeeded in making these capacitors more compact...
Alain R.
JANTZEN AUDIO COMPACT MKT 001-8050 Axial MKT Capacitor 160V 3.9µF Jantzen Audio's Compact MKT capacitors are made from the highest quality metallized polyester film available. Jantzen Audio has succeeded in making these capacitors more compact...
Gerard a.
Preamplifier Module Volume Control / Input Selection MUSES72320 This preamplifier module, integrating both volume control and input selection functions, is beautifully designed to ensure excellent performance. It is equipped with the latest...
Volume analogique
Parfait pour remplacer un potar de volume en supprimant les aop.
Livraison et communication très bonnes comme d’habitude
TRISTAN A.
Produit de qualité
Suite à un changement de meuble hifi, je cherchais un produit de plus petite taille que mon filtre secteur Bada LB-5600. J'ai choisi cette barrette conçue par Audiophonics en me basant sur la réputation du site et sur les avis clients. Ce produit respire vraiment la qualité et cela se ressent à l'écoute. Je suis vraiment satisfait de mon achat.
TRISTAN A.
Produit de qualité
Emilio L.
Excellent ampli !!!
Reçu 3 jours après la commande, et testé tout suite après avec un streamer/dac/preampli Yamaha wxc-50 et mes chères enceintes Triangle Lyrr 222 (93dB de rendement et 8 Ohms). Le réglage de gain à 20dB est correct pour mes besoins. Très transparent, il fait ressortir beaucoup de détails dans tout la gamme spectrale. L'écoute n'est pas de tout fatigante il convient bien au classique, jazz, pop, rock. Bref, le LPA-S450ET tient tous les promesses qui apparaissent dans le descriptif d'Audiophonics. Rien à ajouter de plus. Je recommande cet ampli.
Grand merci à David Aubert d'Audiophonics pour m'avoir aiguillé sur cet ampli.
Philippe R.
Neutralité
Grace aux conseils de David j'ai pu réaliser mes câbles HP après de nombreuses hésitations , j'ai enfin trouvé le câble le plus neutre pour mon système ( ampli Atoll Am200, enceintes ELAC FS 408.2 ) ce câble: le RAMM Audio Amadeus 5 Mk2, transparence dans les graves, les médium ainsi que dans les aigus.
Merci encore pour votre gentillesse et votre patience.
Philippe Ropert
Câbles chers, certes, mais qui apportent beaucoup à la restitution.
Encore en rodage, mais déjà beaucoup de sérénité dans le rendu sonore avec des timbres à la fois pleins et doux, particulièrement dans le haut du spectre.
Si, votre bourse vous le permet, n’hésitez pas.
Lionel B.
3E AUDIO A7 Class D Stereo Amplifier PBTL 2xTPA3255 2x250W 4 Ohm 3E Audio, a recognized player in the DIY world, now offers a Class D Stereo amplifier incorporating audiophile Hi-Fi components. The A7 amplifier is based on two TI TPA3255...
Excellent ampli !
Commandé un jeudi, reçu le lundi suivant, nickel ! Ce petit ampli est un vrai bijou de puissance et de contrôle des enceintes qu'il alimente. Si en plus il est fiable (on verra à l'usage, je ne l'ai installé qu'hier !), alors mon setup audio ne va plus bouger pendant un bon moment ! Seuls bémols:
1- l'ampli a été livré avec un cordon secteur pas adapté au bloc d'alim (2 broches au lieu de 3), j'ai dû prendre un cordon secteur avec la terre qui trainait dans un tiroir...
2- l'ampli est équipé d'un système d'auto-off/on avec des valeurs seuils discutables: en écoute à faible niveau, l'ampli s'éteint tout seul au bout de 5 min comme s'il ne recevait aucun signal, dommage pour une utilisation comme ampli de puissance avec bypass du contrôle de volume du A7. Pour contourner le problème, il faut atténuer en baissant le potard de volume de l'ampli, et augmenter le niveau de sortie du pré-ampli qui est avant.
Moyennant cela, l'ampli est génial et super bien adapté pour driver des enceintes de faibles impédances.
Robert C.
MUNDORF MRESIST SUPREME MRES20-3.9 Resistor 20W 3.9 Ohm The Mundorf MResist SUPREME resistance range offers products of exceptional quality. Having a real impact on the sound restitution, these resistances allow to obtain finer...
Excellent component
Excellent component, great value. Clears the details and lifts the transparency up to highest level in crossover application.
Robert C.
MUNDORF MRESIST SUPREME MRES20-4.7 Resistor 20W 4.7 Ohm The Mundorf MResist SUPREME resistance range offers products of exceptional quality. Having a real impact on the sound restitution, these resistances allow to obtain finer...
Excellent component
Philippe J.
Fait le job parfait pour le prix
Philippe J.
Bon contact électrique très bonne prise
Philippe J.
Idéal pour un PC pour le prix fait le job très bien
Richard P.
Son attachant
Pas agressif, un peu rond. On se sent bien comme devant sa cheminée un soir d'hiver.
Il délivre un son bien attachant.
Sur mon système bien sûr...
A essayer vu le tarif.
Emmanuel A.
Connecteur digne d’une grande marque
Ce modèle n’a rien à envier à certains modèles de grande marque bien au contraire, la liaison est parfaite et le cuivre et d’excellentes qualités
sébastien w.
Ce câble est bien dynamique, beau grave et bas médium.
Il met juste légèrement les aigus en arrière .
Il me fait pensé au câble secteur Furutech T 31 ( vert ) pour ses timbres .
sébastien w.
Lampe avec une bosse de le médium et des bases dynamique .
Sonorité chaude mais les aigus reste cristallin.
sébastien w.
AECO ARP-1512G RCA Connectors Tellurium Copper Gold Plated Ø11mm (Set x4) These high-quality aeco ARP-1512G RCA connectors, sold in packs of 4, benefit from a rigorous design using top-of-the-range materials. The contacts are made of high-purity...
Un petit compliqué à souder .
Sinon le son un propre et détaillé
sébastien w.
Prise de bonne qualité .
Beaucoup de détail et transparente
sébastien w.
Le Must
Les meilleur prise de la gamme de chez Furutech .
Transparente ,silence, placement des instruments, autorité....
Meilleur que R .Charlin , viborg et autre. ( qui sont aussi de très bonne factures )
A monté sur câble de la même marque N 32 uniquement
FI -50 NCF rhodium tendance à faire brillé le système mais
l'ouverture et profondeur grandiose.
FI- 46 NCF le TOP !!!!!!!!!!
FI -E38 G donne une sonorité chaude aigu soigneux
FI -E11 Cu donne un son dynamique ,pétillant et poil
coloré ( comme lors du rodage de tube )
Mon ensemble audio est hybrid.
Pascal j.
ATAUDIO FLAGSHIP RCA Interconnect Cable Silver Plated OCC 7N Copper Double Shielding 1.5m With the Flagship, ATAudio offers a RCA interconnect cable with an exceptional design at a reasonable price. The special design consists of three silver-plated 7N OCC copper...
J'ai acheté ce câble très récemment et je 'ai relié entre ma platine vinyle REGA P6 ( haut de gamme ) et mon ampli Cayin JAZZ KT 88, un des meilleurs amplis à tubes à moins de 2000 euros. ( Enceintes colonnes DAVIS ACOUSTICS ou TRIANGLE AUTRALES EZ, j'ai le choix.... )
Je vous passe le détail des autres câbles ( alimentation, enceintes )
J'en suis aux premières écoutes, le résultat me parait déjà excellent...Il faut juste que mes oreilles s'habituent à la restitution sonore, mais il me semble que ce sera rapide tellement c'est très bon...
Rôdage du câble ? Euhhh, je ne savais pas que le cuivre, métal inerte, fût-il OCC, devait être rodé....( demandez au Pr Ohno, inventeur de la technologie OCC )
La seule chose qui ait besoin d'un rodage, ce sont mes oreilles qui découvrent une nouvelle restitution sonore.
Je recommande vivement ce câble.
Mais ce n'est que mon humble avis....
Andrzej B.
LOXJIE D60 DAC Headphone Amplifier ES9039MSPRO Bluetooth 5.1 32bit 768kHz DSD512 MQA-CD Black With its D60 DAC / headphone amplifier, Loxjie offers a modern, high-performance device, carefully designed and equipped with audiophile components. It incorporates an...
Loxjie D60 - excellent DAC/Headphone Amp
Very transparent and neutrally sounding DAC. I use it with headphones Hi-Fi Man Sundara Closed Back edition via balanced connection and as a source I use WiiM Mini connected via Optical link. I am very satisfied with the sound.
As regards funcionality it has all important digital inputs including I2S and outputs (including headphone balanced XLR) and bluetooth connection with high quality codecs (LDAC and Aptx HD). The only drawback I noticed is very poor stability of bluetooth connection when using highest bit rate of LDAC codec (900 kbs). The are frequent drop outs so it needs to be switched to lower bit rate (606 kbs) or use different audio codec like AptX which works fine. Everything else works perfectly.
It is also very good for the price. I can truly recommend it.
The ordering, payment and delivery process at Audiophonics was perfect. I was really satisfied.
Paulius S.
Excelent
Naturally sounding, beautifully constructed connector.
Michael D.
FURUTECH LAN-8 NCF PLUS Ethernet RJ45 Cat8 Cable S/FTP 2.5m Furutech LAN-8 NCF Plus is a beautifully designed Category 8 RJ45 Ethernet cable with S/FTP shielding for high-speed signal transfer. This new generation of Furutech LAN-8 NCF...
PLUS-Update better than expected!
I already had the previous version LAN8 NCF and liked it very much. Sometimes, it was a little too ‘upfront’ for me. At least in my HIFI chain, the Plus version is much better. More musical, more substantial, more spatial, more neutral in a positive sense, but still with high resolution and transparency. Well done Furutech.
