FRANCOIS D.
Félicitations !
FRANCOIS D.
Bravo AUDIOPHONICS
Bravo à vous pour la conception de ce produit de très belle qualité !
Fabrice C.
Customers reviews - There are 19138 reviews.
arnaud g.
AC / DC Switching Adapter 100-240V to 24V 6A DC This AC/DC switching adapter can receive an input voltage of 100-240V AC and then have an output voltage of 24V 6A DC. The power supply has a 5.5/2.5mm DC jack connector at the...
Correct
Produit conforme mais reconditionné je pense, car de marque Epson. Câble secteur défectueux (fait disjoncter mon tableau électrique même branché à vide - vu avec le sav)
Thibaut d.
Bonne qualité de fabrication, il est souple et les prises tiennent bien. Pas besoin de mettre plus chère.
Thibaut d.
Pour le prix, c'est un très bon ticket d'entrée pour la correction active. Filtre actif, réglage de niveau et de délai, inversion de phase et correction IIR (attention pas de FIR donc pas de correction de la phase).
Bref c'est du tout bon
Ballocca G.
Accurate and solid construction, pleasant appearance when mounted.
The real dimensions of the footprint are 5.08 and 10.16 mm (0.2 and 0.4 inches).
Ballocca G.
Not the best for its color
Accurate and solid construction, pleasant appearance when mounted, but the left channel should be identified with the white color.
Michalis B.
Great Diy module!
Lets see some things before my review!
If your job is electronics (repairing, service, and more) it is a great idea to buy this very nice module as diy unit, ofcourse because the cost is much lower than a complete unit!
You must be familiar with this type of electronics!
The second thing is that, this module is great and with a rich sound, really very close to CD quality.
One thing that i don't like to much (and believe me IT IS NOT UNIT PROBLEM) is that, the bluetooth source (your mobile phone for example) MUST be as close to the unit for better results!
In other words if this unit sold with an external antenna, i believe that be the very first choice...in low price!
Thanks Audiophonics for your great products!!
stephane j.
tres satisfait !! TRES BON S.A.V / Societe serieuse
Navettes d'un très beau bleu ;
Expédition rapide
S.A.V très sérieux ET a l’écoute de votre demande
MERCI , Audiophonics
borniers RQP
ces borniers sont excellents car même sils sont en laiton et non en CU/Tellurium, ils sont solide, le filetage fait 8 mm de diamètre je les ai monter sur du MDF de 22mm sans problème, j'ai simplement rajouter une rondelle plate large de 8,pour que l'écrou ne soit pas sur le bois,( et détail important non précisé dans la présentation,) sur la partie de serrage il y a une bague libre, pour pouvoir serrer sans couper le câble; ça fait la différence.
Eric w.
ELFIDELITY AXF-107 Power Filter PCI Express / PCI Express 16x The AXF-107 module from Elfidelity is a switch mode power supply filter for computers connected in PCI Express or PCI Express 16x and designed to provide cleaner power to all...
Eric W
Works fine, especially in lower frequencies. Great value for money. Lowers noisefloor (below -50db) neatly. Efficient reduction of 50Hz. hum. Just a clever product, Problemless, easy installation.
Roger P.
Alientek D8
I first tested by D8 with my Headphone: Windows PC -foobar2000 - XMOS USB - Hifiman HE1000. Worked like a charm. Sound quality is pretty impressing, highly resolving, not too harsh though, with almost black background and plenty of headroom even with recordings at lower volumes. Wow! Didn’t expect that at such a price. Any EQ settings do not affect the headphone output, but that's all right.
Next I connected a pair of Dali Rubicons. Not impressed this time, the sound was concealed by a very disturbing hiss, clearly audible at low volumes and still noticeable at middle ones. That’s bad! Renders the D8 completely useless for critical listening, at least with this kind of speakers. To my ears it’s far worse than I expected based on Audiophonics’ warning:
"This amplifier emits a slight breath into the speakers during silent passages in the music. Although the phenomenon is very slight, it is still important to take into account when using desktop speakers with close listening."
So I packed out my toroidal coil (100uH/3A) which I bought just in case, based on the advice of a tinkerer on diyAudio. I unscrewed the box, cut the conducting path at the marked spot, scratched open a solder pad on each side of the cut and soldered two wires onto them to connect the coil to. Closed the box and ahhh! The HISS IS GONE, completely gone! A big THANK YOU to the tinkerer!
Eventually, I could start enjoying the music and the quite powerful dynamics of this little baby. Wow! Now I am pleased. The sound is crisp and clear, much better than I could expect from such a miniscule device - both in terms of size and price. Makes me think why the manufacturer did not add a 50 cents inductor to the circuit in the first place. I am not being pedantic here but I have to deduct one star for this.
* https://www.diyaudio.com/forums/attachments/class-d/660221d1517587780-fda-alientek-d8-inductor_placement-jpg
Michel G.
C'est jolis mais bof
Sur le son ce n'est pas plus efficace qu'une grosse prise secteur d'un magasin de bricolage. Par contre ça fait pro.
POINT A AMELIORER : la prise est n'a pas la bonne dimension, elle entre mal et a du mal a tenir, celle que j'ai reçu. Il faut la mettre et plus y toucher.
Michel G.
Un plus indegnable
J'ai un Airtght atm1, une paire de Proac resp. 1.5 et un lecteur reseau Linn akurate ds. Voulant voir si un dac pouvait ameliorer mon Linn j'ai acheté d'occase un petit Dac Chinois (75€), le Mavrick d1. Qu'elle suprise de voir qu'il améliorait nettement mon Linn que j'ai payer 25 fois le prix (à neuf). J'ai vu que lon pouvait upgrader en changeant l'OPA (j'ai découvert ce que c'etait). J'ai acheté celui qui etait recommandé, l' OPA 627 à 6,90€. Et la la claque. Tout était plus 2lisible" et les voix sont plus naturel le. Du coups j'ai voulu allé plus loin. J'ai lu un commentaire sur Audiophinic indiquant que le sparko avait amélioré son le mavrick. Et pour mois c'est aussi le cas, notammanent dans les basses, tout est encore plus maitrisé. Mais le gap n'est pas aussi impressionnant qu'avec l'AOP 627. Je pense que mon dac qui est arrivé à ses limtites. Dans tous les cas il pourra me servir pour un Dac à venir.
Michel f.
Un super dac audiophile pour ce prix
J ai acheté ce dac il y a 2 semaines et que dire presque 4 kilos des composants de premier choix conception audiophile composants de très haute qualité.L écoute est très musicale aéré et avec une pèche d enfer.Mais attention les moindre petits détail son perceptible ce qui veut dire que les mauvais enregistrements sautent aux oreilles .Pour ma part j ai redécouvert mes enregistrements avec beaucoup de plaisir il faut dépenser au moins 2 a3 fois le prix pour avoir cette qualité chez la concurrence Un super achat.
Thibaut d.
DAYTON AUDIO DMA90-4 Speaker Driver Full Range Aluminium 30W 4 Ohm 89.3dB 85Hz - 20kHz Ø8.9cm The Dayton Audio DMA90-4 wideband Dayton Audio DMA90-4 aluminum cone provides excellent performance and low distortion. This speaker can be integrated into many audio projects,...
Installés dans des charges BR en tube PVC, franchement le rendu est vraiment convaincant dans une petite pièce.
patrice f.
précision sur le 3220
en complément de mon avis du 20-02-2020,je précise que je n'ai pas comparé ce câble au SC221 occ ni au 3004
Otto T.
The cherries on the cake!
After having had installed Audiophonics IAN CANADA FIFOPI ULTIMATE reclocker in my Audiophonics DAP/DAC Sabre ES9018 Mk2 100Mhz by sound engineer www.lentusaudio.nl, they advised me to order the 45Mhz and 49Mhz Ultra Low Jitter clocks to replace the standard ones.
The results are extremely good! More rifined highs and lows. Blacks are black (silence is silence).
Listening has become much more relaxed with every kind of music.
Capot aluminium brossé pour Slimline 280 mm .
Très bien pour remplacer la tôle 1mm du boîtier slimline, permet d'y fixer solidement transfos et supports de tubes
Boitier Slimline 2U 280mm
Avec le Capot aluminium brossé 280 millimètres en complément, donne une base solide pour ampli à tubes
Interrupteur 2 Pôles 2 Positions
Très bon switch, par contre il est plus gros que le modèle 1 Pôle 2 Positions.
A prendre en compte si l'on utilise les deux types pour un même projet
Interrupteur 1 Pôle 2 Positions
Je l'ai utilisé dans plusieurs projets ;
Retour d'expérience très positif, solide pas de jeu, contact franc, joli look rétro, aucun soucis avec ce matériel
Kévin C.
J'ai hésité un moment avant de trouver les bons connecteurs et franchement je ne suis pas déçu !
Le fait que l'on puisse visser au lieu de souder est vraiment pratique, seul hic il faut une clef Allen minuscule pour le serrage du câble sur le pico central, j'ai dû me la fabriquer en sacrifiant une clef Allen plus grosse.
Mais sinon qualité de finition au top et ce qui est bien c'est que l'on peut serrer sur la sortie source ou ampli la fiche donc une fois mise et serrer la connexion est parfaite et pas de risque d'arrachement.
Je recommande chaudement ce produit pour ceux voulant faire leur câble RCA eux-mêmes
Frederic J.
Simplest possible solution to separate power from signal, nicely made, works perfectly, delivered fast. I will shop here again. Thanks!
Christian F.
Top Seller
Very Fast Shipping and Top Quality Product
Thanks
Dominique M.
Superbe découverte que ce câble
J’ai acheté ce câble pour une liaison amplificateur enceintes,sur la recommandation d’un ami l’ayant acquis récemment.Ayant essayé beaucoup de câbles,même très cher,5000€ par exemple,je l’ai commandé pour voir en comparaison de mon Furutech actuel.Branché par l’intermédiaire de fourches et bananes la première impression fut mitigée!Le furutech étant branché sans bananes je tentais une écoute dans ces conditions,et là,surprise ,ce câble est étonnant,sa qualité en dehors d’un équilibre et d’une dynamique sans faille,est une aération du à une impression de moindre distorsion ,subjective bien sûr ,mais l’écoute est d’une précision jamais entendu sur mon système.Voila un achat que je ne suis pas près de regretter.Si j’avais pu j’aurais mis 10
Julien P.
Pratique
Simple et accessible. Impacte à la mesure la forme de la courbe de fréquence dans les basses. réduit un peu une légère bosse d'impédance dans les medium (Profondeur de l'enceinte ?)
Ne vole pas, ne se désagrège pas.
Julien P.
Bornier costaut
Et un peu trop gros à mon gout. Sur une petite biblio ça prends de la place !! Mais ceci dit c'est du solide et si on prend la peine de faire une feuillure, ça finit bien l'enceinte
Julien P.
Dommage pour le tout plastique (face avant, bornier) et attention à la soudure de ne pas faire fondre l'attache :)
Distorsion qui remonte sous les 2200hz, mais une coupure à 2kHz en LR24 fait très bien l'affaire !
Attention de ne pas trop lui en demander en terme de puissance, rapport à la disto, mais pour un salon 40m2 c'est parfait !
Julien P.
DAYTON AUDIO DC130BS-4 Classic Speaker Driver Midbass Shielded 30W 4 Ohm 92dB 55Hz - 4000Hz Ø14cm Dayton Classic woofers are designed for 3-way construction as low-midrange speakers, but can also be used as subwoofers. Their versatility means they can be used in both closed...
Fait bien le taf :)
Pour une petite biblio à pas cher, fait très bien l'affaire. La distorsion remonte malheureusement assez facilement dès 1500hz, mais une coupure franche type LR4 peut maitriser ça.
Son petit diamètre est parfait pour une directivité propre et un raccord autour de 2kHz.
L'extension dans les basses n'est pas folle, mais en surlitrant ou en baissant la Fs de l'event, on obtient une jolie courbe "façon clos" qui va très bien une fois posé sur une étagère proche du mur arrière.
Un bon soldat selon moi ! Voir le projet tritix MT (anglophone)
Julien P.
Pratique et propre
Feuilles très pratiques à découper (Cutter + ciseaux) ça permet d'avoir l'isolation bien ajustée à la forme de l'enceinte. J'ai complété la colle avec de la néoprène en spray de peur que la plaque ce détache. Ceci dit j'aurais pu l'éviter car le poids du goudron n'est pas si important que ça.
Très content de mon achat, ça donne une finition superbe à l'intérieur de l'enceinte !
Damien P.
Du lourd
Un vrai upgrade de câbles par rapport aux classiques de grandes marques à prix équivalent. Conquis par la qualité des connecteurs, j'ai acheté 4 paires de des Elecaudio rc-901 pour monter des stratos maison. Un régal
Damien P.
Joli
Beau petit câble court, plutôt fin. Prix compact pour une valeur sûre.
Damien P.
Female Jack 3.5mm Stereo 4 Pins Connector Gold Plated Ø4mm (Unit) This connector will allow you to design your own 3.5mm audio jack cables. This one benefits from gold plated contacts, ensuring both good electrical conductivity and resistance...
Moyen
Pas le top niveau qualité, mais il faut faut dire qu'il n'y a pas beaucoup de choix question prise femelle à ce niveau de prix. Utilisé comme interconnexion "originale" de câble de masse pour pouvoir permuter rapidement entre deux différents câbles de platine vinyle "maison".
Damien P.
Bon produit (bis)
Très belle qualité pour le prix, pas aisé à souder vu la taille (mais c'est logique sur ce diamètre de jack)
Damien P.
RAS
Juste un avis pour la mise en oeuvre : facile à dénudé, fil de qualité (utilisé pour réaliser un câble de masse "deluxe")
Damien P.
C'est du lourd
Précis, costaud, bien emballé, matériau de qualité, ce ne sera pas le maillon faible d'une interconnexion de câbles RCA.
Damien P.
Belle qualité, mais pourquoi aussi petit ?
Ayant besoin de fiches femelles de qualité, le choix était plutôt réduit. Cela dit, le système modulaire de viablue n'est que marketing : il ne faut pas espérer remplacer l'embout femelle par un embout mâle juste avec un tour de tournevis, les soudures se font directement sur l'embout... Quant à la taille, pourquoi pas un petit centimètre de plus, cela faciliterait grandement à la fois la soudure et le placement du câble : le dénudage des différentes sections (gaine extérieure, tresse et fil(s)) doivent se faire au millimètre pour que tout s'emboîte correctement, car les petites vis torx ne pardonnent rien. Je conserve les 4 étoiles pour l'aspect général qualitatif, la précision et la solidité du matériel
Damien P.
Qualité, qualité, qualité
Utilisé pour réaliser deux câbles pour platine vinyle, il respire la qualité. C'est vrai que séparer la tresse de l'isolant vert est un peu pénible mais pour le reste que du bonheur. Le câble central est fin (c'est ce qui faut pour un câble phono) mais très bien sécurisé. La rigidité du cuivre à gros cristaux est perceptible lors de la mise en oeuvre. A l'écoute, c'est vrai qu'en l'absence de second blindage, à écoute à volume maximal sur bruit de fond à vide, l'oreille collée au tweeter, on entend une légère pollution du bruit "numérique" ambiant, mais c'est totalement imperceptible en condition d'écoute musicale. Associé à des fiches RCA Elecaudio RC-901, pour lesquelles le diamètre est parfait, même pas besoin de gaine.
Damien P.
Pratique et de qualité
Idéal pour des configurations nécessitant un faible diamètre, c'est quand même bien de la qualité "viablue". Utilisé pour supprimer le câble soudé d'une platine Projet Debut et le remplacer par une courte terminaison RCA femelle (modèle viablue) et nouveau câble maison.
Damien P.
Bon matos
Fiche lourde qui respire la qualité. Système de vissage bien pensé. La soudure au niveau point chaud est très aisée mais il est vrai beaucoup moins évidente pour la masse (tresse de blindage). Cela dit la géométrie permet ... de se passer de soudure de masse ! En vissant directement sur le bout de tresse, on s'assure d'un contact idéal. La seconde vis permet de bloquer complètement le câble. Résultat très qualitatif avec du stratos.
Damien P.
Oui mais... non
Pas vraiment de l'avis des autres. J'ai fait mon "écolage" de soudures de RCA sur ce modèle pas cher. Surfaces microscopiques, l'enfer pour gérer la deuxième soudure lorsque la première est faite (blindage puis fil ou l'inverse, c'est kifkif), manque d""adhérence" de la soudure (surtout argent), mode de blocage du câble basique et aléatoire (ne convient pas avec le câble CANARE de 6mm, trop gros avec l'embout, trop fin sans). Mon avis : passez votre chemin, il y a mille fois mieux pour quelques euros de plus.
Peter S.
FIIO BTR5 2021 Balanced Headphone Amplifier DAC Bluetooth 5.0 Receiver 2x ES9219P CSR8675 XMOS 32bit 384kHz DSD256 MQA The FiiO BTR5 2021 is a compact, portable headphone amplifier, offering excellent design quality and versatility for enhanced listening at home or on the go.
First impressions
Hi!
Just tried with tidal + bluetooth + audeze LCD2C headphone. The sound is big, detailed, loud, maybe a bit dark. The stage is open, but the mono in front of me is not very clear. (It's hard to beat the Quad ESL57 speakers in this.)
I don't really believe that compressed bluetooth can be good, but it sounds way better than anything bluetooth.
I wonder what the symmetrical output can produce, altough I don't know wher I will get a good quality 4 pin 2.5 mm minijack...
Lars S.
Awesome value for money
I‘m using the tone board (Signal-Input via USB) in combination with a JDS Labs Atom Amp and different headphones (AKG K702 and diverse Beyerdynamic) – CD quality music of all kinds of genres (CD player and Tidal Hifi). My decision to buy the tone board was based on the awesome measurements at audio science reviews. I have not been disappointed, the sound is very good and all in all this is a superb DAC considering value for money (I was not expecting such a good performance for just around 100€).
I’m glad that I found audiophonics.fr, otherwise I would be waiting for my tone board for another few weeks
super produit
Les fiche banane WBT cuivre pur il sont magnifique pour des câble section 10mm très bien merci !
Fortuné M.
Parfait !!!
Facile à souder, très bien conçues, elles m'ont permis de remplacer des embases soudées sur circuit imprimé qui étaient dorées sur la masse et en métal à ferrer les ânes pour le point chaud.... Avec un prix modéré, je recommande
David J.
Waouww
Incroyable !
Je pèses mes mots mais je suis ébahi par la qualité de ces jumpers !
Je les ai mis en remplacement de jumpers Atlas Hyper3.5 (qui ont basculés sur mes surrounds pour le HC) sur mes colonnes Monitor Audio Bronze 5.
Les graves sont vraiment plus présents, nets et détourés ; Il en est de même sur toute la bande passante qui semble, du coup, vraiment plus large, plus fluide et aérée...
Le potentiel de mes enceintes s'est enfin dévoilé !
Je n'aurais jamais cru que le simple changement de jumpers pouvais apporter une telle différence d'écoute.
A tous les sceptiques concernant la qualité des câbles, je vous conseille de tester ces câbles ! Vous ne le regretterez pas...
Je redécouvre ma musique, et j'envisage sérieusement l'achat des câbles HP de chez Phono1877.
Merci Audiophonics de proposer des produits aussi qualitatifs...
David J.
Praticité
Ce sélecteur de source me permet d'éviter de débrancher et de rebrancher mes différents câbles provenant d'amplis HC et Hifi en fonction de celui que j'utilise avec mes colonnes.
C'est un produit simple mais très efficace !
Câblage OCC, plaqué argent : il n'y a aucune perte dans la qualité du signal qui y transite...
Je recommande fortement cet accessoire !
Merci Audiophonics pour la qualité du matériel fourni (rapport qualité/prix génial) et pour la rapidité de la livraison.
cable HDG pas trop cher
j'ai fais un commentaire sur ce câble avec des connecteurs RCA cu/te elecaudio TE-RC 90 G; ce cable a donc deux paires en cu OCC,plus une masse en tresse, j'ai choisi la paire rouge et noir pour la phase et les jaune et bleu pour la masse,ça n'a pas d'importance,inverser si vous voulez jaune et bleu pour le point chaud,par contre ne dissociez pas les paires ,le résultat est mauvais. voila allez du courage,et bonne écoute. pi.r
RCa HDG
pour avoir déjà utilisé ces RCA en cu te,d'excellente qualité,mais un peu compliqué au niveau de la masse. j'ai trouvé une solution, sur la bague, séparée du corps de la masse, un coup de pince coupante au milieu, et après j'enlève un bon millimètre, et avec une pince je plis les deux parties coupées vers l’intérieur,pour faire passer le fil de masse,( ça fait comme un V) et pouvoir le souder, sans qu'il dépasse du corps,afin de pouvoir visser le capot.et comme ça tout passe sans problème. j'ai fais un câble avec ces RCA et du câble WM audio AC-02 en cu/occ. ce câble a deux paires,rouge et noir,et jaune et bleu; j'ai choisi les rouge et noir pour le point chaud,et les jaune et bleu pour la masse. la tresse de masse du câble je ne l'utilise pas coté CD et je la soude avec la paire de masse a l'arrivée,coté ampli.( bien sur attention au fil qui pourrait être en contact ou il ne faut pas). après brancher et se régaler; la définition la clarté des détails,l'image sonore,entre les enceintes et en profondeur,est très bien pas de projection, les musiciens ne sont pas sur vos genoux, mais bien a leur place; pour avoir fait un câble avec les mêmes rca,et du neotech 3004, je trouve ce câble proche,en rendu sonore. bien sur ça demande un peu de peine mais le plaisir final en vaux la peine,n'hésitez pas, RQP excellent. pi.r
Yvan L.
Pas mal
En accord avec les autres avis, il suffit juste de faire attention car elles sont très bien.
Yvan L.
Super câble !
Après avoir déplacé une de mes enceintes de 10 mètres et j'ai commandé ce qu'il manquait , et le résultat et à nouveau parfait,
