David C.
Avant de...
Niels G.
Solid performer
Miguel O.
Satisfaction totale
Le gain est...
Customers reviews - There are 19668 reviews.
Fabrice M.
Excellent rapport Q/P
En remplacement d´un preampli denon Hc (1000€ il y a 10 ans)
Le d6s est plus dynamique, une meilleure séparation des sons particulièrement sur les voix féminine et à un grave plus nuancé
De plus la partie Bluetooth en LDAC est bluffante
Pour le tarif, foncez!
Henrik E.
Beats the sigma-delta bunch.
Formerly, i made a project with the ESS flagship ES9039 with reclocker, FIR reconstructor, etc, very ambitious. It was OK, the dynamics and clarity superb, but was a bit too... well over the top, so to speak.
I bought two of these R2R-boards, and just used them as replacements for the ESS chip. I had a multi bit DAC some 15 years, and since then I can't really be friends with the sigma delta types.
With these boards it's like coming home - but with the house freshly painted. The typical superb representation of nuances that renders poetry to the listening session is there. But it's even better than the old PCM1704 I had. These new boards have something the PCM1704 didn't have; a CPLD that cancels away resistor mismatch. This is the new brave DAC world. The old sigma delta devices, used for so many years, days are counted. In the future all audiophile DAC's will be this kind of intelligent R2R design, but probably packaged in one chip.
But the images of how to connect the boards are a bit misleading. The single ended OP-amp schematic is not very recommendable.
I'm giving it just four stars, since I don't really have something to campare it with, at least not other brands of the same type.
Jesse D.
Balanced Interconnect Cable Male Jack 6.35mm TRS to Female XLR 3-Pole OFC Copper 75cm (Pair) These affordable cables are balanced 6.35mm TRS Male to XLR 3-Pole Female interconnect cables. They are shielded and the conductors are made...
TRES BONS câbles
Utilisés avec mon DAC TOPPING E70 VELVET: parfaits !
Jesse D.
JUSTE EXCELLENT
Rien a ajouter sauf que si vous recherchez une restitution naturelle alors prenez celui-ci, vous ne pouvez pas vous tromper.
NB: reçu très rapidement après ma commande, je salue AUDIOPHONICS pour sa réactivité, merci beaucoup.
Daniel D.
prise de très grande qualité
Cette IEC legato de même que sa soeur en schuko que j'ai également acheté) ne sont pas donnée. En termes de tarif il y a de quoi hésiter !
Pourtant l'une comme l'autre apporte vraiment un plus au niveau de la transparence sans rien dénaturer ailleurs. Elles sont neutres comme les Viborg cuivre/or/argent mais vont plus loin. Si vous achetez un couple Je conseille de les répartir sur 2 cordons secteurs différents car installé sur un seul le bénéfice de la mise en place de la 2ème prise apporte moins. Dans la formule conseillée on gagne sur chaque appareilet les effets se cumulent mieux.
Selon les câbles elles se marient très bien avec des Oyade C004 ou des viborgs cu/or/argent. Je les conseille sur les CS mur-barette ou sur les sources et préamplis. Si vos améliorations antérieures sont réussies se sera alors "la cerise sur le gateau". Elles sont chères mais ça vaut vraiment le coup sur les très bons systèmes (je n'ai pas regretté mon achat).
J'aurai juste un tout petit bémol. Il est indiqué qu'elles sont plaquées or ce qui est vrai sur certaines pièces métalliques mais les fiches males et femelles ne sont pas d'un doré brillant comme le reste du coup on ne sait pas si elles aussi elles sont plaquées or, j'ai questionné Audiophonics mais n'est pas obtenu de réponse. Il y a donc un doute sur leur capacité à ne pas s'oxyder ce qui à une importance sur le long termes. Musicalement à tous
István R.
First of all, it was a pleasant surprise that compared to the ordered 4m length, there was an extra 0.25m. Thanks. More importantly, I compared this SOST-12 cable with SOCT-12 in the same position and dimensions. The SOCT12 was already a surprising step forward compared to my previous cables, but the silver gave an even more delicate, intimate sound. I can't say anything negative about it, although my sound system is wired with Siltech.
Jacques B.
Le plus équilibré et musical de la marque !!
Après quelques autres tests Furutech, je constate que ce TCS31 est très équilibré et le plus musical des câbles secteur de la marque sur les sources. Restitution précise, détaillée mais sans coquetterie ni dureté dans les aigus, avec un grave propre et tenu. Attention cependant aux connectiques associées. Avec les ETI, c'est vraiment magnifique !! Belle découverte.
Pierre-Jean T.
Je ne sais pas
Est-ce ma paire de Tung Sol EL 34 qui ne va pas avec ces tubes ?
Le son me parait trop clair. Sinon livraison rapide.
Karim M.
Un câble fidèle
J'utilise ce câble comme câble d'enceintes et de modulation. sur tous mes essais qui sont nombreux car je m'amuse à récupérer des éléments HIFI vintage pour leur redonner une seconde vie et les offrir à ceux, souvent plus jeunes, qui ne connaissent pas le SON.
Bref, câble transparent, fidèle, surtout, en particulier, je confirme beaucoup d'autres avis, sur des installations qui ont des basses grasses. Ce que j'apprécie c'est sa musicalité, c'est à dire qu'il reproduit bien les timbres et les hauteurs, distinctement et cela permet de suivre des compositions très chargées.
Bonnes écoutes !
Sa qualité et son prix le font tellement oublier qu'on y repense en en rachetant pour de nouveaux set uops.
Simon M.
SMSL RAW-DAC1 DAC AK4191+AK4499EX Bluetooth 5.1 aptX HD LDAC 32bit 768kHz DSD512 MQA-CD The SMSL RAW-DAC1 is a high-performance, elegant DAC based on a combo of AKM AK4499EX+AK4191 chips and a USB XMOS XU-316 interface. These audiophile components enable it to...
Excellent DAC - perhaps where diminishing returns really kick in.
Bass extends down, and highs are pristine. The sound stage is very wide, with good depth depending on the recording. Perhaps best of all is an 'infectious' quality. This is definitely a step from my previous ES9038Q2M equipped units, and ZEN DAC 2. I also tried a Topping Centaurus, and while I can appreciate many liking the presentation, and slight lushness even on broadcast voices in particular, my point is that the SMSL Raw-DAC 1 renders music equally validly ... but different. Extra and varied inputs a bonus.
fabien n.
Reproduction en dynamique, peux être trop ?
Il y aura trop de bass pour certains, fonctionne mieux avec mon marantz 8000 qu'avec mon nad 352 "vintage"
Je conseille pour ceux qui aiment le rythme où même pourquoi pas un dj, il bouge quand même pas mal.
J'aurais aimé des horloges plus haut de gamme et des op-amp dédié pour le velours.
Bref tu en a pour ton argent mais ce n'est pas parfait
Herve M.
LINDY CROMO LINE Gold Plated Male USB-A / Male USB-B 2.0 Cable 5m The Cromo series is the most powerful USB cables manufactured by Lindy. This one relies on a well thought out design and oriented towards a technical reality, to meet a need for...
Pas de couac
Parfait pour l'usage que j'en fait .
Peter G.
IAN CANADA TRANSPORTPI AES Ultra-Low Jitter AES/EBU SPDIF Digital Interface Module Ian Canada's TransportPi AES is an AES/EBU and SPDIF digital interface board. It is the first model to use a 1bit 50Mbps differential driver and a dedicated femtosecond clock to...
Excellent system
I now have a very detailed and rich sounding streamer with a huge sound stage built with this and other Ian Canada boards. I have provided a more detailed and informative review on the Ian Canada PurePi II that will help you if you are considering building your own streamer.
Peter G.
IAN CANADA FIFOPI Q7 II FIFO Reclocker Module I2S DSD DoP Syncrhonous The Ian Canada FifoPi Q7 is the new flagship in the FifoPi family of reclockers. It achieves the best performance in terms of jitter and noise by using a number of...
Excellent system
Amazing sound coming from my streamer built with this and some other Ian Canada parts. Really detailed and rich. See my longer review of the Ian Canada PurePi II for more information.
Peter G.
IAN CANADA PUREPI II Ultracapacitor / Batteries Dual Power Supply Module for Raspberry Pi 5V / 3.3V Ian Canada's PurePi is a compact audiophile power supply module specifically designed for Raspberry Pi based systems to improve sound quality. The PurePi integrates a 5V...
Excellent system
Along with a RaspberryPi 4 and the other Ian Canada products, FIFOPi Q7 II, TransportPi AES, this makes an excellent streamer. Very detailed and rich, balanced sound across the frequency range. It is easy to assemble and programming the Raspberry Pi with Ropieee is straightforward. The YouTube Gabster channel helps with this and this video is a good place to start: https://youtu.be/Tc_QfRTbb6U?si=dLAMcCxoA9bha-cP
Yoann L.
AUDIOPHONICS HC Trigger Home-Theater to HiFi system switcher 12V The Audiophonics HC is a home-theater trigger whose primary benefit is to save you the trouble of changing cable connections between your hi-fi system and your home-theater...
Top!
Fonctionne parfaitement entre un pré ampli cinéma et une installation hi-fi. Très simple pour les branchement. Aucun bruits dans les enceintes. Parfait. Comme toujours, audiophonics au top !
Antoine S.
Un réel bon en avant
En remplacement d'une Hecate en sortie d'un Streamer USBridge.
Les 1ères écoutes ne sont pas très riches, mais passé quelques heures tout change.
J'ai nettement gagné sur tout les aspects de la scène sonore, l'image 3D est métamorphosé, tout a plus de matière, plus précis, plus juste, la scène s'est agrandie et je découvre plus de détails, de plus la gestion de la dynamique est bien meilleur.
L'ajout de cette interface au prix non négligeable dans mon système, m'a apporté un réel gain, je suis plutôt très satisfait :-)
LHY AUDIO LPS-A8 230V Linear Power Supply Module for EverSolo DMP-A8 The LPS-A8 linear power supply module, developed by LHY Audio, has been specially designed to improve the power supply stage of EverSolo DMP-A8 network players by replacing the...
Qualitatif
Aussitôt reçu, aussitôt installé dans mon lecteur Eversolo A-8, Le module respire la qualité, c'est livré avec les outils, et les gants blancs. 10 minutes pour le mettre en place est largement suffisant, c'est à la portée de n'importe qui. Au niveau de l'apport qualitatif à l'écoute, sincèrement, je n'ai pas senti de différence audible, mes oreilles ne sont peut être pas à la hauteur.
Vidéo d'installation sur Youtube
LUC B.
Un super câble made in Japan !
La réputation de ce câble n’est plus à faire, c’est un excellent rapport qualité prix, le diamètre externe reste raisonnable ce qui le rend utilisable avec beaucoup de prises différentes jack, CINCH XLR etc.
Personnellement je l’utilise principalement pour confectionner des cordons guitare et accessoirement en Hi-Fi.
Un seul regret : il n’est disponible qu’en noir.
michel m.
USB Dongle Bluetooth 5.2 Transmitter aptX / aptX HD / aptX LL / aptX Adaptive This Bluetooth 5.2 USB transmitter dongle will allow you to broadcast audio streams wirelessly, from a computer for example, and in high quality, thanks to the use of a Qualcomm...
Dongle
Ce dongle est performant sur W11. La connexion reste stable sur les 4 mètres qui le séparent de mon ampli.
Il privilégie le protocole APTX HD au maximum, car mon récepteur Bluetooth sur l'ampli ne peut pas accepter l'APTX Adaptive mais accepterait le LDAC.
AUDIOPHONICS devrait ajouter un dongle LDAC au catalogue .
Mais bon, mes FLAC restent très largement "écoutable"
Lionel E.
Soudage nécessaire
il faudra couper les pattes des AOP Sparkos SS2590 et réaliser les soudures des 6 pattes de celui-ci sur l’adaptateur…soit 12 soudures pour faire un AOP double à partir de 2 SS2590 PRO…
Not plug and play
Bruno L.
Pack Fosi Audio ZD3 DAC + ZA3 Amplifier + ATAudio King Wolf XLR Cables 50cm With this pack, we offer you a set comprising Fosi Audio's ZD3 DAC and ZA3 amplifier, as well as a pair of ATAudio XLR cables to connect the two devices symmetricall. A package...
Depasse mes esperances
Le meilleur compliment que l'on puisse faire à cet ensemble, c'est de se faire oublié. La musicalité est remarquable. Des les premières minutes d'écoute, on oublie tout sens critique pour se laisser envouter par la musique. Couplé avec des petites Dali Oberon 1 le mariage est parfait, C'est à ce genre d'appareil que l'on peut voir les progrès effectués sur les amplis classe D et les DAC d'entrée de gamme. Une belle offre d'audiopnonics,
Olivier L.
Très musical et techniquement très performant
Au prix où il est proposé, ce AP310 est une véritable aubaine. Parfaitement silencieux, doté d’une bande passante stratosphérique et d’une dynamique sans faille, beaucoup de détails et de profondeurs s’expriment à travers une palette de timbres très enjoués. C’est un appareil à la fois très musical et très performant sur le plan technique ; Les entrées et sorties symétriques sont rares sur cette gamme de produits. Et que dire de la possibilité du réglage de gain, de la commande de volume numérique précise et sans aucun bruit parasite ? Je suis comblé. Seule ombre au tableau, étant possesseur d’un ampli casque, je regrette la cruelle absence d’une sortie fixe (rec-out) qui m’obligera à utiliser un doubleur RCA ou un câble adaptateur XLR-RCA en sortie pré-out, solution peu élégante...
FURUTECH NCF BOOSTER-SIGNAL-L Flat Support for Cables and Connectors Furutech's NCF Booster Signal L, a version of NCF Booster Signal, is a cable and connector holder designed to improve cable and connector performance. Having been a real success...
2eme avis ( y a du mieux)
suite à mon précédent avis mitigé j'ai testé cet article sur ma chaine secondaire moins optimisée . Situé sous la fiche iec du cable d'alimentation de l'ampli le son se révèle plus net mais sans aseptisation comme constaté sur mon système principal . 4 étoiles dû au prix pas en adéquation avec le résultat .
RENAUD C.
Bel article
De beaux boutons pour la façade de mon pré-ampli DIY. Serrage à vis 6 pans creux très professionnel. Audiophonics toujours au top
spiderman !!!
Tres jolie gaine et de bonne qualité. son rendue rappelle la combinaison de l' homme araignée.... a part le bleu...
superbe gaine
cette gaine est d' une qualité remarquable . Elle ne s'effiloche que tres peu, solide, confortable et facile a travailler 20/20.
En plus elle est trezs jolie.
Szilard S.
MINIDSP FLEX HT Audio DSP Processor 2x8 Channels SHARC ADSP21489 XMOS HDMI ARC eARC The miniDSP Flex HT is part of the miniDSP Flex range of advanced audio processors. This device is a 2x8-channel, multi-channel DSP processor featuring...
Flex HT the audiophile nirvana!
I bought it on December 18, 2024. It arrived in Hungary very quickly. I replaced a Lexicon MV-5 processor. The bass is much more restrained, not so fluid and expansive. The active switching also works very well in it, I use LW-R 24db/octave filters. The crossover frequencies are 100Hz/4KHz. I don't use Parametric EQ for now, maybe when I buy the Umik-1 measurement microphone. It would be nice to buy a Dirac live license for it, but for now it's very expensive for me, almost the price of the device. There are power stages for each speaker, for each speaker, I use these now, all class D: AUDIOPHONICS MPA-S125NC ; Douk Audio TPA3116 ; Wondom TPA3255. I'm going to order these two power amps from Audiophonics now: O-NOORUS D1 Class D Amplifier TPA3255 PFFB. My dream is to get one of these power amps: AUDIOPHONICS HPA-H250NC Power Amplifier 6 Channels NCore NC252MP. This MiniDSP Flex is a real big gun, a game changer, the DAC in it is also very good, this is also confirmed very well by the Audio Science Review. I recommend it to everyone who would like to build a truly audiophile system with active switching. I use 2x3 way speakers with it, each in pairs: Dayton Audio PT2C-8 Planar Tweeter ; Tang Band_W5-2143 Midrange; SICA 12 PF 3 Sub. The fronts are open baffle, and the subs are closed! Thank you Audiophonics!
Ville E.
BURSON AUDIO V7 CLASSIC PRO Dual OPA (Pair) As an evolution of the V6 Classic, the V7 Classic Pro now achieves ultra-low noise levels while retaining the sparkling highs that are the strength of its predecessor. Overall,...
Relax your class D amp
Bigger soundstage, more natural timbre. Singer a bit closer. These are all properties that this opamp provides. Tradeoff is a little less attack in the mids. The performance from the bands turns from metronome-oriented highschool band to seasoned veterans playing together for fun. Relaxed, engaging, fun. Provides some smokiness to live jazz trios, this thick air that exists in jazz cafes.
Anastasios D.
ATAUDIO L-4E6S Male USB-A to Male USB-B Cable Gold Plated OFC Copper 0.75m This ATAUDIO USB cable offers both high quality and luxurious design. It consists of a four conductor structure made of braided OFC 6N copper with excellent conductivity,...
Nice quality cable!
Nice quality cable!
Anastasios D.
Nice quality cable!
Nice quality cable!
Anastasios D.
Quality build!
Nice quality build PSU with good connectors. Packed nicely and shipped fast!
Anastasios D.
AIYIMA A07 Class D Amplifier TPA3255 2x225W 4 Ohm The Aiyima A07 is a small, simple, powerful, efficient and affordable Class D amplifier, ideal for setting up an audio system that requires a lot of power input. It embeds a...
Surpisingly good!!
I was looking to buy something cheap to replace my meridian 556 amp until it's fixed. I have the B&W 685 speakers (first edition) and this amp sounds so clear and detailed. I think it lucks some power compared to the meridian even with the "Switched Mode Power Supply 100-240V AC to 48V 7A DC". It is loud but I think it cannot drive the speakers with power compared to a transistor amp. But it is loud and clear, so I give it 5 stars for the money!
The service and experience from audiophonics is one of the best I had, very fast shipping and very good packaging! Thank you!!
Jean-Pascal H.
Filtre secteur
Mes appareils sont enfin protégés le wattmètre est très pratique pour connaitre la consommation réel de chaque appareil , merci top
Jean-Pascal H.
Cable Secteur
Câble d'alimentation très bien réalisé à un prix qui me convient merci Audiophonics
Anastasios D.
Nice sound!
Very good device. I am connecting it through Coax, Toshlink and USB to my old AudioGD DAC19MK3 and it sounds beautiful. Unfortunately I cannot test the I2S yet, but I might modify my DAC to accept it. The service and experience from audiophonics is one of the best I had, very fast shipping and very good packaging! Thank you!!
David T.
Après neuf mois d écoute, aucun changement. Amplificateur de premier choix
Kentarou T.
IAN CANADA HDMIpi MKII Transmitter I2S / DSD / DoP to HDMI This module allows you to recover the outgoing digital audio stream of the GPIO port of a Raspberry Pi (or one of its HATs) and send it to the balanced LVDS format on an HDMI port.
Great Product
I am using HDMIpiMkII (RaspberryPi5 GentooPlayer) and Musician Draco with i2s transmission. I have used Topping and RME products in the $200 to $1,000 range, but the sound quality is completely different from those. It is very smooth and has high resolution, and I want to listen to it forever. It took a little effort to get the sound to come out, so I will summarize the settings.
(1) HDMIpiMkII: Jumper Switch S1 settings
DIP1: ON DIP2: ON DIP3: ON DIP4: OFF (master clock is not output)
The initial state is all OFF, and i2s signals are not output from the HDMI terminal, so you must set it.
(2) Musician Draco: Set i2s mode to Mode5
The lamps [1X] and [4X] at the bottom right of the front panel should be lit. The mode setting method is described in the user's manual (i2s PIN configuration of DRACO).
(3) Connecting HDMIpiMkII to Musician Draco
I use ECDH-HD14SS03BK (made by ELECOM).
équilibre parfait
Salut ,comme j ai changé d enceintes et platine vinyle , je trouve le cable ludic d un realisme incroyable! Le couteau suisse des cables HP pour moi ,franchement pour faire mieux faudra mettre tres cher! recommander vivement
la reine de la rapidité ,finesse!!!
Bonsoir , j ai testé ma schuko 004 sur mon ampli nuprime , vondita oyaide ,iec 004 , a la place d une FI38r ,resultat plus de vitesse,precision, transparence ,finesse, super aigu! petit bémol elle degraisse un peu . Franck
Paul M.
Compact, XLR out and balanced sound: all I need!
I use this DAC for conversion duties between my TV and active speakers. Happy to say that it ticks all the boxes for me. XLR out, solid build, foolproof and logical operation and most importantly: a detailed and balanced sound. It does not outperform the dac in my audio set (and it shouldn't at just 10% (!) of the price of the audio dac), but it would make me rethink the audio dac should I have to purchase that now. Recommended!
joel p.
TONEWINNER TY-1CD CD Player DAC ES9028 The Tonewinner TY-1CD CD player benefits from attractive aesthetics and quality components for superior CD playback performance. It features an ES9028 DAC chip as well as...
lecteur cd tonewinner ty-1cd, surpris !
colis reçu rapidement et bien emballé, merci d'avoir respecté ma recommandation sur ce point particulier.
Je suis agréablement surpris par la qualité de fabrication et la finition de ce lecteur.
A l'écoute, je redécoudre mes cd du point de vue de la musicalité, très analytique, procure un espace sonore en 3d encore amélioré par rapport à mon ancien lecteur british.
Avec des cd de bonne facture (qualité audiophile) j'apprécie tout son potentiel et qui pourra que s'améliorer après une période de rodage.
Bref, pour l'instant je suis très satisfait de cet achat ! très très bon rapport qualité prix !
Josep s.
XDUOO XD05 PRO Portable Headphone Amplifier DAC ES9039SPRO XMOS XU316 32bit 768kHz DSD512 MQA 8x With the XD05 Pro, xDuoo unveils a high-performance, robust and versatile portable DAC / headphone amplifier. It features high-quality components such as an ESS ES9039SPRO DAC...
XDUOO XD05 PRO
Envio rapido,muy bien empaquetado,web seria y muy de fiar.
El amplificador/dac,excelente en construccion,prestaciones,conectividad y gran calidad de sonido,es una maravilla en relacion calidad/precio!
Alain S.
DAC TOPPING DX3 PRO+
excellent DAC, correspond a mes attentes, HI RES enfin disponible sur mon installation HI-FI.
Son de très bonne qualité.
Uwe G.
Topp Kabel
Ein Kabel ohne Kompromisse.
Konfektioniert mit Kupfer vergoldeten Steckern ein Muss.
Alexandre L.
Cable de très haute volée
Acheté en remplacement du câble de ma multiprise Furutech TP60E (Audiophonics Stealth excellent cable pour 100E).
La clarté apportée est incroyable j'ai l'impression d'avoir un nouveau DAC ! Neutralité conservé avec plus d'extension des aigues, très cohérente et aucunement agressive ni incisive.
Pas d'extension dans les basses mais plus de précision et de slam. Pour le médium il était déjà incroyable dû au rhodium des prises mais il vient le rationaliser et pousser encore la barre pour atteindre une justesse jamais entendu !
Monté avec IEC Oyaide C004 et Schuko Furutech FI-E38(R).
Au passage le câble est balèze mais est suffisamment flexible pour une installation correcte. J'en rachèterai sans hésitation pour un cable d'ampli dans le futur !
David S.
What an awesome surprise. This is just great.
I was completely caught off guard by this. I bought it more out of curiosity than anything else, quite certain of a return. Well, the Digirescue is not going anywhere. With a 5v IfI IPower 2 power supply, the sound of out of the reclocked coax tap was much improved compared to the sound obtained from my Elac ds s101g previously. But after connecting the Digirescue to my Keces P3 lps upgraded with a SR Orange fuse, the sound coming out of of my Rotel 1592 mk ii just exploded…it is way above anything I could expect. For me the lps is a must do upgrade. The imaging, the depth and width of the soundstage, the dynamics, and musicality, have just gone from adequate to really, really good. I know it probably sounds silly to use such an expensive lps with a component at this price point, but if you already have a power supply and are thinking about upgrading your streamer, just give this a go, you might have a surprise. I was not expecting anything given there weren’t many reviews, but I’d give this a 6/5. Well done audiophonics! I guess Ian Canada stuff is really that good. I’d recommend using good cables as well, totally deserving of them.
Pedro Jose T.
A 10 for Audiophonics logistics
In less than 36 hours my order was at home (Palma de Mallorca), a record. So congratulations to the Audiophonics logistics team.
I'm not going to talk about the sound characteristics, or the finishes, since other buyers have already done so and I fully agree with their observations, a fully recommendable amplifier if you are looking for quality-price and with a small footprint for your desk.
I just want to comment on how nice it looks with that red LED light that comes out from the inside through the ventilation slots and that I don't think anyone has mentioned. I also want to comment that I thought it would get hotter, but it has been working for about 4 hours (volume at 40%) and it is practically cold and moves my 84.5 db sensitivity speakers without problems.
Rainer E.
Top !!
Nachdem ich bereits mehrere andere DACs ( Gustard x26 Gustard R26 und einen Questyle) ausgiebig in meiner Kette getestet hatte und die Firma Gustard fast ausgeklammert hätte, bin ich mit dem Gustard A26 hochzufrieden.
Dieses Gerät liefert eine sehr natürliche, authentische Wiedergabe mit ebensolchen Klangfarben, sehr guter Auflöung und einem ganzheitlich überzeugenden Gesamteindruck.
Klanglich habe ich nichts zu bemängeln. Ich kann damit Musik hören, ohne ständig da und dort mehr oder weniger Defizite verbessern zu wollen. Zuhören ohne Stress ohne in verrundeten Wohlklang abzugleiten.
Den Streamer habe ich nicht ausprobiert, da ich direkt über Macbook Pro und Audirvana höre.
Ich habe eine Hifi - Tuning Feinsicherung in der Gold Ausführung installiert, bzw. gegen die serienmäßige Feinsicherung ausgetauscht. Netzkabel ist das Furutech FP-3TS20. Auch dieses ist sehr empfehlenswert. Leider - wie so vieles - deutlich im Preis gestiegen.
Zurück zum DAC: Dieses Gerät ist in dieser Preisklasse absolut empfehlenswert und vielen anderen - auch R2R DACs überlegen.
Hätte ich den A26 nicht, würde ich wahrscheinlich den A26 schauen, oder dem Gustard X30.
Aber......die Nachfolge der aktuellerern Geräte ist noch lange kein Grund unzufrieden zu sein.
Hören Sie sich den A26 an, wenn sie die Gelegenheit dazu haben!
Die eingangs erwähnten Geräte lässt er locker hinter sich. auch den vielerorts hochgelobten RME DAC.. Ganz zu schweigen von allem was günstiger als Fertiggerät erhältlich ist.
Dimitar M.
SMSL PL100 CD Player CS43131 Silver The SMSL PL100 CD player is the perfect way to enjoy your CD collection. It's essentially based on a CS43131 DAC chip and a PLL (Phase-locked Loop) circuit for sound...
Excellent!
Great little CD player!
Very nice looks, decent remote control and superb sound quality! I first tried it with the optical out into my Aune X8 DAC with Sparcos Op-Amp. Sounded great.
After that I decided to try the onboard DAC and it sounds almost as good as my external DAC, that costs 4 times the whole CD player!
Overall, I am very pleased with it!
