Robert g.
Pascal H.
Frederic V.
Utilisée pour alimenter deux convertisseurs TP-Link mc 200 cm créant un pont optique ,le résultat est impressionnant. Je suis très satisfait .
Cet ensemble me sert à faire fonctionner un Grandinote Volta.
KONSTANTINOS L.
Great service by Audiophonics, good product.
Paul H.
Good step up from a Pi 4, lowered the noise floor and released more musical goodness.. Needs a while to fully open up, I'm using in conjunction with the Shanti LPSU. Just power up/down and leave switched on/off for 20/30 hours, no music playing.
Paul H.
Excellent value for money, very low noise.
ChrisC H.
Amazing Streamer DAC combo
I've comparing between Allo setup and Volumio Primo. I am glad I blind folded myself and gave RaspDac LTE a try. I-Sabor ES9038Q2M is no shame (Thanks to Audio Science Review). The chip is not all there is to it. Thanks to AudioPhonics, the separated power supply fixed Raspberry Pi 3B+'s shortcomings. The noise level is impressively low.
Sound quality is great although sound stage is not as full as my Schiit modi 3 + Vali 2 combination. However, the sound quality is high in crisp, accurate, and crystal clarity.
The Volumio setup is not been very kind. At boot up Volumio would recognize I-Saber ES9038Q2M but you won't get any sound. You need to first turns off D2I setting and reboot. After reboot the driver again won't recognize correctly. You need to ignore "Output Device" first, but manually choose DAC to ES9028Q2M, then reboot again. I am sure this is not faults of AudioPhonics. It's more of the Volumio software bugs.
Jean L.
Excellent à tous points de vue
Mais esi il vraiment supérieur à un vulgaire câble électrique de même diamètre acheté à 2 Euros le mètre à Bricomarché....?
Faites l'essai.....
Maxime C.
Boitier très beau mais finitions moyennes
En ce qui est de la qualité apparente du boitier, il n'y a rien à redire, le boitier est très beaux, très soigné et parait très robuste.
En revanche, lors du montage, certaines choses se compliquent, pour ma part il manquais certaines vis, et certains perçages n'ont pas été fait assez précisément ce qui fait qu'il est impossible de visser certaines vis.
Cette imprécision engendre aussi le fait qu'une fois monté, le boitier est bancale.
Pour finir j'ajouterai que les dimensions ne sont pas celles indiquées et diffèrent de 10mm quand à la longueur intérieure, posant problème lorsque l'on souhaite faire du design de carte à l'avance.
Malgré tout ces défaut, cela reste un excellent boitier audio, très beau et très facile à monter. il est juste un peu dommage de rencontrer ces "imperfections" au vu du prix.
Thomas C.
FANTASTIQUE
super DAC au rapport qualité/prix incroyable.
Beaucoup de gain ce qui permet d'avoir de la réserve pour l'ampli.
Je peux profiter de mon abonnement Qobuz en haute résolution sans souci et avec un grand plaisir !
Plug and play sous windows 10 ...
Merci encore Audiophonics pour le traitement et le suivi de la commande.
Jean Marie F.
Utilisée en sortie d'un Mac mini avec Audirvana.
Pas besoin de drivers sous Mac, reconnue de suite.
Excellente sonorité via un Dac Diy a base de 4399.
Un son détaillé et analogique, pour le prix c'est miraculeux !
Je recommande ce produit.
Anthony V.
Automatic Input Selector 4 Stereo RCA Inputs This module automatically switches between 4 stereo sources. The selection of sources is carried out fully automatically from a signal of at least 0.2V.
Inutilisable
On entend un clic à intervalle régulier dans le sélecteur quand aucune source n'est active.
Encore pire, une fois branché à l'ampli, le clic est amplifié et s'entend dans les enceintes.
C'est un comportement normal apparemment.
Honnêtement, je ne vois pas dans quelle situation ce comportement pourrait être satisfaisant.
Jean L.
Cäble tout à fait remarquable qui mérite largement ses cinq étoiles...
Toutefois, sacrilège !....Est il supérieur à un vulgaire câble électrique de mêmes dimensions acheté à deux Euros le mètre à Bricomarché ...
Faites l'essai.....
David D.
The perfect economical amplifier
I made a little 2.1 system, for home purposes, and this amplifier is the perfect solution for the crossover between the sub and the satellites, just plug and play
David D.
It's simple, Works!
For little projects, It's enough
un regal pour mes oreilles
j ai choisi ceux en argent au lieu des cuivres occ..et bien je ne sais pas si s etait pas le bon materiau l argent pour les basses..mais quel choc.toutes la bande passant du bas vers le haut sont magnifiés. plus de details de dynamiques.les basses sont tres degraissées juste se qu il faut..rapide .et sa descend tres bas.mes enceintes sont données a 28her et 26kh..et bien sais beau..detaillé et transparence ameliorée..je ne rescent plus l envie de bi amplifié mes enceintes deja avec se resultat je doit faire peur a mes voisins..pour 57.5 euro sais un vrais cadeau bonux..comme dirait coluche..merci pour le services colis arrivé en suisse en moins d une semaine bien embalé et il sont beau et bien contruit..une plus value certaine pour les petites bourses..
Henri F.
Allo usb Signature + Alim Allo Shanti. Un couple hors pair !
Tout d’abord je tiens à remercier les équipes d’Audiophonics pour leur soutien technique sans faille. Car oui moi qui suis néophyte au monde des lecteurs réseaux (bien que j’en ai écouté) et de l’environnement linux j’ai eu besoin de leur aide pour sa mise en œuvre et ils ont répondu à chaque fois présent. Je suis passé à la solution Moode audio (gratuite) car elle a bonne presse et un tuto clair est disponible sur leur site pour son installation ; du coup je ne tourne pas sur Dietpi. L’allo USB signature est alimenté avec l’excellente alim Shanti et j’utilise aussi l’excellent câble 1877PHONO THE MAJESTIC USB Câble pour le relier à mon dac Audio GD D77. Je lui ais raccordé mon DD externe en USB ou se trouve toute ma discothèque locale et un bon câble réseau pour la connexion à la box. Je pilote le tout via mon smartphone Android ou mon PC portable. Tout d’abord et dès les premières écoutes ce qui m’a frappé c’est la transparence du signal, la précision hors paire, la dynamique qu’il en ressort. Aussi bien en lecture locale qu’en streaming qobuz via bubble upnp. C’est remarquable. Sur ce modèle Allo a fait un gros travail sur la sortie USB qui alimente le dac et cela s’entend. Jamais je n’avais entendu sur mon système une telle qualité (au casque ou enceintes). Ce petit streamer dépasse grand nombre d’autres solutions dites haut de gamme et alimenté avec le Shanti il devient à mon sens très très difficile à battre. L’ensemble allo usb signature et alim Shanti forment un couple hors pair et au rapport qualité prix (468 euros) qui me semble en tout point imbattable. Au grès des écoutes ce sentiment ne fait que se renforcer. C’est très musical, clair, précis, les instruments sont tous à leur place, meilleur équilibre, la qualité des timbres est bien sure au RDV mais sans aucun artifice. Tout est plus naturel. Comme le dit si bien l’expression, un voile c’est levé et tout apparait plus clair. Je tiens aussi à dire que j’utilisais auparavant un PC portable totalement dédié et optimisé pour l’audio (logiciels JPLAY FEMTO, FIDELIZER PRO, PROCESS LASSO, AUDIRVANA, AMARRA LUXE…), boitier reclocker régénérateur signal USB IDEON AUDIO MK2. Alors oui j’obtenais ainsi de très bons résultats, mais avec ma nouvelle solution je constate que ça va plus loin, j’y prends beaucoup plus de plaisir à écouter ma musique en ne me posant plus de question et à un moindre cout. Je précise que je possède un système hifi plutôt haut de gamme (matériel + câbles secteurs et modulations de très bonnes qualités, multiprises filtrés…) qui ne laisse rien passer et qui donc permet la comparaison de manière nette. Voilà j’en ai fini avec mon avis un peu long mais peut être qu’il permettra à d’autres personnes de se faire une idée plus précise sur ce fantastique appareil et de ses possibilités.
Eric M.
Très bons connecteurs
Ces connecteurs assurent un très bon contact côté cable comme du côté ampli (un yamaha n'acceptant que les fils nus en ce qui me concerne ) ils son solides et bien isolés.
Christophe P.
Après être tombé sur des commentaires dithyrambiques au sujet de certains amplificateurs Class T comme feu le regretté Poppulse T180, poussé par la curiosité je passe commande de ce cet ampli Sure/WONDOM doté d'une puce TA2024.
Je reste un peu inquiet et dubitatif quant à la faible puissance annoncée en 8 ohms...10W...c'est peu...! Je crains que cela grille les bobines de mes enceintes à petit feu.
Mais je ne suis pas un adepte de Heavy Metal avec le curseur poussé à fond, j'écoute avant tout de la musique acoustique, essentiellement du Jazz dans toute sa diversité, instrumental, vocal, de la musique cubaine...etc. J'aime entendre vibrer les cordes de contrebasse, sonner le cuivre du trombone, claquer les peaux des congas...
J'ai couplé notre petit ampli au buffer à lampes Fx-Audio Tube 01que j'avais commandé avec, il apporte beaucoup de gain, et là au fil des heures d'écoute, ce petit ampli se révèle être une vraie merveille. La scène sonore est aérée, détaillée, équilibrée à tous les niveaux du spectre. A mon humble niveau, mais doté pour le moins d'oreilles exigeantes, on atteint à une vraie qualité audiophile.
Maintenant reste la question de la durabilité, mais seul le temps permettra de le dire...
Une petite question à Audiophonics: peut-on espérer le retour d'amplificateurs Class T dotés de la puce TA2020 réputée également pour sa musicalité? D'avance merci.
Thomas C.
Bel adaptateur
belle qualité, RAS avec HD600
Thomas C.
bon câble
Il inspire confiance, bon câble
Thomas C.
rapport/qualité prix excellent
RAS, rapport qualité/prix excellent
Thomas C.
Un vrai ampli !
Je confirme tout ce qui a été écrit à son sujet ... bientôt en test avec d'autres lampes de préampli ... juste pour "voir" ...
Myrielle m.
super produit
Cette adaptateur Pangea C5 Cryo est compatible avec le nouveaux écran iMac pro XDR la qualité passe un niveaux supérieure avec un bon câble alimentation un mot sublime merci .
Christophe V.
Pas terrible
Connexion dans la prise de l’appareil approximative n’offre pas un bon contact,au niveau son elle est assez claire dégraissant légèrement le grave avec des sans grande matière.
Hormis la prise en aluminium on est loin de la qualité de connexion et sonore d’une Furutech
Frederic N.
Ces boutons sont de très bonne qualité et magnifique
Michalis B.
Nice Acrylic terminal blocks
Not only beatiful (because are they) these very strong terminals!
For example, if for any reason give more power to tight the body screws.....nothing bad happens!
Excellent choice!
vincent L.
Au top !
Fonctionne super bien. Pratique avec son alimentation usb 5v et sa sortie Jack 3.5. A peine démarre qu'il est déjà reconnu par le périphérique. Très content de cet achat. Merci audiophonics
Vincent G.
"LE" Filtre 2 voies stéréo
Utilisé comme filtre actif sur une sono maison, c'est parfait!
Avec le plugin 2x4 advanced Il y a tout ce qu'il faut pour une enceinte 2 voies:
+ 2 filtres crossovers par sortie (Low pass / High pass)
+ 5 equaliseurs paramétriques par voie d'entrée
+ 5 equaliseurs paramétriques par sortie
+ 1 contrôle de niveau par entrée
+ 1 contrôle de niveau + inverseur de polarité + retardateur + compresseur/limiteur par sortie
Ça sonne propre, ça fait ce qu'on lui demande. On peut presque tout corriger. Avec le micro de mesure Dayton UMM-6 (j'imagine que le UMIK est bien aussi) et REW on peut aussi tout mesurer et vérifier la pertinence des corrections. LE TOP!
Vincent G.
Pas mieux, imbattable à ce prix!
J'avais déjà la version asymétrique. En mode symétrique c'est pareil, en mieux pour la sono!
Martijn v.
Not as described
The only reason I bought an Allo Digione board for Rpi at Audiophonics and not some other supplier was because Audiophonics also sells this case. I think the see through acryl looks awesome. So I was pretty dissapointed when I opened the package and the case was not seethrough acryl with a dark shine, but just plain old black. BLACK, totally black, no see through whatsoever. If I had known this I would have looked elsewhere. So only 2 stars just because it's a case, but i'm pretty dissapointed with Audiophonics for selling a product that realy differs from the picture advertised above...
Bernard T.
Matériel de bonne qualité et conforme au descriptif.
Maximilien V.
Jack de bonne qualité, mais peut être pas évident à souder
Ce jack est de bonne conception et parfait pour remplacer celui que mon fils a abîmé.
Cependant, je trouve que la connectique à souder n'est pas évidente ; peut être du à mon manque d'expérience.
Bref, c'est soudé et cela fonctionne : il est parfait pour moi !
Maximilien V.
Chauffe rapide et repose fer inclus
Ce fer à souder chauffe rapidement.
Un repose fer est inclus.
On regrettera juste la pointe qui manque de précision mais qu'il est possible de changer facilement.
Françis S.
Françis S
Pascal A.
Umik-1
bruno m.
bornier
tres bon produit, respire la qualité bon rapport qualité pris.
Thierry B.
Produit conforme
Pas de problème pour ce produit bon marché.
Hubert R.
excellent cable
Pascal C.
je redécouvre ma musique
J'ai acheté il y a environ trois semaines deux câbles ethernet de 1 mètre AUDIOPHONICS. Le premier va du nas à la box et le second va d'un CPL à mon lecteur dématérialisé LINN Majik DS. Après 48 heures de rodage, j'ai redécouvert mes CD dématérialisés. Depuis ils ont fonctionné une centaine d'heures et je suis stupéfait du résultat. J'avais des Audioquest 1.5m Pearl à 29€ pièce et c'est le jour et la nuit. La finition des AUDIOPHONICS est excellente. Les prises RJ45 sont vraiment de qualité. Le câble est un peu rigide mais respire la qualité. En ce qui concerne le son: Les aigus files plus haut et ne sont plus crispés et criard. Le médium est plus beau, plus précis et les voix sont plus détachées. On entend bien les différents instruments, J'arrive à bien les situer. C'est moins brouillon surtout à volume élevé. Les basses sont plus profondes et mieux tenues, plus précises, moins brouillons. La musique a pris de l'espace autour des enceintes. J'ai vraiment pris une claque et pourtant j'ai un système qui fonctionnait très bien avant (AMPLI LINN AKURATE, PRE AMPLI MAJIK, ENCEINTE LINN EXPEK) mais là j'ai vraiment vu une grande différence comme si la musique se libérait, avec une meilleure fluidité, moins de crispation. J'ai d'ailleurs acheté un troisième cable du même type pour l'installer entre la box et le premier CPL. Je suis pas sur que cela m'apporte grand chose en plus mais au moins toute la ligne est de qualité. Je suis agréablement surpris du résultat et je recommande ces câbles qui sont d'un excellent rapport qualité prix. Bien à vous.
Gaetan L.
Simple à installer
parfait pour résoudre des question d'orientation en fonction de sa prise murale. Par contre attention aux vis qui fixent les câbles dont l'empreinte est fragile. Merci à Audiophonics de m'avoir envoyer une vis gracieusement rapidement !
Gaetan L.
Pratique !
Un peu de difficultés à installer le pilot, mais maintenant que tout fonctionne c'est parfait.
Robert G.
Si on regarde le signal sur une charge résistive de 8ohm le résultat semble catastrophique, bruit énorme sur 1/4 du signal (à la fréquence de découpe 650khz). Cela est du au manque de filtrage, mais il est inutile de filtrer plus car les HP ne sont pas des charges résistive.
A l'écoute le son est bon il supporte la comparaison sans problème avec le FSDD 120 (ampli classe AB à VMOS) que j'ai monté en parallèle.
Frederic S.
Joli
Se marie très bien au MOGAMI W3103. Petite astuce pour un enfilage aisé; placez un tube conique devant le câble ( avant d'un stylo dans mon cas ).
Robert G.
La connexion des entrés n'est pas très pratique, mais tout le reste est bien. J'ai regardé l'amplificateur à l'oscilloscope la bande passante est largement supérieure à la bande audio il passe 30khz sans distorsion et l'écoute correspond aux mesures.
Frederic S.
Très bien dans mon cas
Venant du Sommercable Orbit 240, le passage au w3103 a été très bénéfique sur mon système: Little Dot Mk III en préamp / Nuprime STA 9 vers Elipson Planet L. Tout est plus équilibré, dense, plus aucune fatigue et cerise sur le gâteau; une scène plus large et profonde.
Jesper B.
ELFIDELITY AXF-102 ULTRA External USB 3.0 Power Filter for PC The Elfidelity AXF-102 Ultra is a USB power filter for PCs. In particular, it allows progressive multiband filtering of the power supply and dynamic compensation of all...
From good to great!
Adding this device the music opened up and sounds more natural and engaging. Soundstage is deeper, wider and clearer, especially I noticed voices that before were a bit compressed now widened and became more balanced and natural. The whole sound is more like a high res picture with rich colors would be to the eye, but for your ears - just a great upgrade to my system!
I noticed it could run without an extra 5v feed, but with a quality 5v power it really made a difference, especially as my DAC is fed 5v via the USB cable now coming out of this USB power filter.
I now stream music from a Mac Mini with Audirvana (program) running Tidal Master Quality, via this Elfidelity AXF-102 ULTRA USB power filter feeding it with 5v from an iFi iPower, then to the SMSL M300 DAC, then via the FX-Audio Tube-00J Limited preamp powered with iFi IPower 12v, and then to Emotiva Stealth 8 active speakers on stands with an extra 2*9,5 kg granite stone weights on to make the speakers not move when playing.
Then of course there are good cables between each of these devices to make the sound great.
If you stream music via USB and you have a quality to high end stereo you can expect to get a good and, at least in my setup, noticably better sound!
remy e.
tissus tout a fait correct pour mon utilisation
Correspond a ce que je recherchais un tissus masqué derrière une grille métallique, entre les hauts parleurs et la grille
Holger B.
Préamplificateur équilibré RCA XLR
Tout d'abord, je viens d'Allemagne et j'utilise le traducteur Google pour la traduction (allemand-français)!
J'ai acheté ce préamplificateur car mon lecteur réseau Atoll MS120 n'a qu'un étage de sortie analogique satisfaisant. Avant cela, j'ai reçu des conseils de M. David Aubert, qui m'a recommandé cet appareil.
Les performances de ce préamplificateur sont plus que très bonnes! La clarté du son est tout simplement fantastique! Une richesse de détails, une basse profilée ...- Génial!
Pour moi, ce préamplificateur est de loin le meilleur que j'aie jamais eu avec moi, et pour un prix de 399 euros!
Pour les personnes qui préfèrent le son neutre, ce préamplificateur est le bon!
Un grand compliment au constructeur!
BRUNO B.
look HDG !
vraiment enchanté par ces câbles, finition exemplaire look HDG affirmé ! et que dire a ce tarif là ! rien ,je ne m'attarderais pas sur le rendu ! sujet a polémique ,donc pour moi ,cela me conviens donc c'est le principale !
au tarif proposé et finition , n’hésitez plus !
MICHEL B.
La qualité de fabrication (un vrai 75 ohms) et le résultat sonore sont au rendez-vous.
CANARE est excellent !
