Pavel V.
Very good streamer
Customers reviews - There are 20152 reviews.
Zacharias L.
TANCHJIM ZERO ULTIMA In-Ear Monitors Dynamic 30 Ohm 123dB Jack 3.5mm Tanchjim Zero Ultima in-ear monitors offer exceptional performance at an affordable price. Each earphone features a DMT 4 Ultra dynamic driver with titanium-plated composite...
Good vibrant sond
The parcel has been received in around 1 week using slow delivery to Greece with no problems.
Nice box design and a earphones with a simple pouch they are not a IEM model but standard plug in earphones. The remain design ensures a IEM type of cabling and plug.
Tested in the road rthe same day with a old type DAP they delivered a quite trebly sound as with any other tested earphones so far, The original recordings have lots of treble as like Dolby cassettes in which the Dolby option is not used! Using other more linear recordings the sound is heard very close to the original I hear in my stereo. All fidelity is herd from the lowest possible level compared to the other earphones!
Replacing the buds with comply types added a few db of bass making the sound more vibrant!
István R.
excellent silver cable
The cable is a big surprise for me. I was planning to replace the legendary Siltech SQ-110 Classic MK2, which I have been listening to for 20 years. The list price of the SQ-110 1m pair was 2600EUR. This NEMOI-1220 with DIY assembly at 1/6 of the price slightly surpasses the SQ-110 cable in sound already before burn-in.
A terrible negative is the peeling of the 0.1mm thick clear Teflon insulation covering the square silver conductor.
Jean-Pascal H.
EVERSOLO BTR-12 IR / Bluetooth Remote Control for DMP-A6 / DMP-A6 Master / DMP-A6 Gen 2 / DMP-A6 Master Gen 2 This IR / Bluetooth BTR-12 remote control developed by Eversolo is designed to be paired with all their DMP series devices, i.e. the DMP-A6, DMP-A6 Master Edition, DMP-A6 Gen 2,...
Indispensable pour piloter l'Eversolo pour un prix plus que contenu à mon avis :)
Jean-Pascal H.
EVERSOLO DMP-A6 GEN 2 Streamer 2x ES9038Q2M WiFi DLNA Roon Bluetooth 32bit 768kHz DSD512 The Eversolo DMP-A6 Gen 2 is a HiFi network player that seamlessly combines outstanding sound quality with cutting-edge technology. More than just an audio device, it's a new...
Au Top
Produit au top super qualité de fabrication et surtout audiophile , il doit y avoir des défauts peut être perso je n'en ais pas trouvé et j'ai pris le temps pour donner mon avis, je recommande sans réserve , on ne peut plus dire que les chinois ne savent pas faire merci à Audiophonics également pour leur réponse rapide à tous les questions.
Johan V.
Exceptionnel
István R.
not easy to assemble
This way, you should not expose the plastic body to too much heat, because it softens slightly with heat.
https://www.youtube.com/watch?v=Cnm197OjIaI
This way, after soldering, the + and - poles will not be exactly in place in the plastic body.
However, if you have to solder the shielding as a third conductor, it will be a big pain.
And there is another strange thing. I have to plug the assembled RCA plugs into Aeco ARJ-4045S sockets, but it only fits so tightly that I am afraid that one of parts will break.
https://www.aeco.tw/products/arj-4045s
Paul M.
Excellent speaker cables
These cables tick all the boxes: solid construction, quality cable and nice to the eye. Cannot distinguish an audible difference with more expensive speaker cables. Nicely executed. All you need for happy listening.
Paul M.
Straightforward excellent pre-amplifier
Initially I bought this pre-amp for use with active speakers. Excellent at that. Shortly after that, I bought the accompanying Audiophonics Hypex nCore power amplifier. The combination has now replaced my integrated A/B class amplifier, costing only a fraction of the integrated amplifier. Wish I would have known earlier.
The pre-amplifier has a solid build, with equally solid RCA, XLR and power connections at the back. It's a simple layout, very well executed. The trigger option makes me happy and lazy at the same time.
The sound is, well, indistinguishable. Like there is no pre-amplifier in the signal chain. I really dig that.
If you're looking for a straightforward pre-amplifier or for the combination with a power amplifier, then do not hesitate. Very reasonably priced and very well executed. Listen to your ears, regardless of the price. Recommended!
SHANLING CR60 CD Player Ripper Sanyo HD850 Silver With its CR60, Shanling unveils a relatively compact, space-saving Audio CD player/ripper. The CR60 is based on a Sanyo HD850 laser head and a Philips drive mechanism for smooth...
Belle petite machine
Très bien construit, la qualité est là, silencieux en fonctionnement, bonne mécanique. Un seul point négatif, l'alimentation DC 12V n'est pas fournie avec l'appareil !
EVERSOLO DMP-A10 Streamer ES9039PRO WiFi DLNA AirPlay Bluetooth aptX HD LDAC 32bit 768kHz DSD512 With the DMP-A10, Eversolo unveils its new high-performance network player and DAC. Compared with its predecessor, the DMP-A8, it...
Appareil qualitatif
Appareil très bien construit, design audiophile, dommage ce gros bouton ciselé, pas du meilleur goût. La qualité est là, mais est-ce justifié qu'il coûte deux fois plus cher que le A-8, qui est un très bon appareil, et ayant les mêmes options, et que le A-8 a une connexion I2s, ce qu'a perdu le A-10...
Bref, sincèrement, j'ai du mal à trouver une justification à ces 1500€ de surcoût.
LDOVR TPS7A4700 Ultra Low Noise Regulated Linear Power Supply 1.4V / 20.5V 1A This LDOVR TPS7A4700 regulated linear power supply module provides an extremely low noise level measured at only 4µvrms. Its input voltage range is from 3 to 25VDC or 3 to...
Manque d 'info
Cette carte doit sûrement valoir le coup. Je ne le sais pas car l'opération de montage de la carte de régulation ainsi que le pontage des pins a souder sont délicat a faire pour un neofite en soudure électronique. Prévoir un fer très fin vu le peu d' espace qu'il y a. La mienne n' a pas supporter mon manque d' experience.
Alexandru Ovidiu A.
MUNDORF ACW115BK Wiring Cable Copper / Silver / Gold PTFE 1.8mm² This top-of-the-range Mundorf ACW115BK cabling wire offers excellent manufacturing quality for maximum conductivity. Its conductors are made of high-purity copper, silver and...
Magic
Robert C.
KHOZMO ACOUSTIC Volume Controller / Source Selector 10K + Remote Control Black Both passive preamplifier and source selector, this aluminum and wood finish unit will surely convince you. It is equipped with very high quality components assembled by hand...
En alu et complète avec mute et même un display à 4 niveaux d'intensité lumineuse de l'affichage jusqu'à l'extinction si on le souhaite.
Fourni pour utilisation dès réception avec les piles déjà à l'intérieur (chose rare !).
Fonctionne parfaitement à n'importe quel endroit de la pièce d'écoute.
Seulement les 3 entrées sont sélectionnables sur le Pré.
Vraiment je suis très satisfait et de mon avis il s'agit d'un excellent RQP.
MARC S.
Épatant
Branchements simples, reconnaissance immédiate de l'appareil depuis un smartphone Androïd. Utilisé avec Qobuz, relié en RCA à un ampli Marantz sans entrée numérique. Écoute grâce à des enceinte Jersey Cabasse : c'est exactement ce que je souhaitais. Ça marche parfaitement, la qualité est surprenante. Il semble que le bluetooth, que l'on dénigre beaucoup, progresse bien vite. Merci à Audiophonics qui propose du si bon matériel, minuscule , à un prix très raisonnable et d'une belle efficacité. Reçu dans les délai. Emballage parfait.
Marc A.
Headphone Balanced Cable Jack 3.5mm to 2x Jack 3.5mm OCC Copper Silver Plated 3m This headphone cable features one balanced 3.5mm stereo jack connector and two balanced 3.5mm jack connectors. The cable uses two OCC copper conductors and two...
Mon lecteur réseau Teac NT 505 X possède une sortie casque 3,5mm à 4 pôles. Hors tous les jacks proposés en 3,5mm sont en 3 pôles.
Seul Audiophonics propose se cable avec ce jack 3,3 4 pôles.
De plus ce cable est de très bonne facture, il est bien souple et il est très beau.
La livraison a été rapide, j'ai pu profiter de mon casque assez vite.
TUNG-SOL 6SN7GTB Dual Triode Tube (Unit) The 6SN7GTB Tung-Sol tube is a double triode tube that benefits from a beautiful design thanks to quality materials. This model has identical characteristics to the 6SN7GTA...
superbe tube .fonctionnent très bien sur un Cayin cs150
.j aimerais savoir si ils sont disponible en quad appairés. Merci pour vos réponses..
Alexandre G.
couplé a un streamer eversolo sur les liaisons symetriques... tout y est!
puissance , details , profondeur et le tout dans une certaine douceur.
chouette!
VIBORG XM203AG Male XLR Connector Pure Silver PTFE Ø11mm Red (Unit) Viborg's XM203AG is a premium XLR male connector, using pure silver contacts to provide maximum conductivity. It also features PTFE insulation and a rugged aluminum body with...
Fiables et belles.
Rien à redire sauf peut-être l'absence de repères 1, 2 et 3.
Donc il faut être très méthodique et concentré pour ne pas faire d'erreur.
A part ça, très bonnes fiches.
VIBORG XM203AG Male XLR Connector Pure Silver PTFE Ø11mm Black (Unit) Viborg's XM203AG is a premium XLR male connector, using pure silver contacts to provide maximum conductivity. It also features PTFE insulation and a rugged aluminum body with...
Fiables et belles.
Fiables et belles.
VIBORG VR106AG Male RCA Connectors Pure Silver PTFE Ø11mm (Set x4) Viborg's VR106AG are premium male RCA connectors, using pure silver contacts to provide maximum conductivity. They also feature PTFE insulation and a rugged aluminum body with...
Peut mieux faire...
Belles, faciles à mettre en œuvre, mais le diamètre n'est pas précis et le serrage n'est pas efficace.
Sur des WBT-0210CuMs, un coup difficile à faire rentrer, un coup ne serre pas bien.
Je ne les recommande pas.
CABLE EXCEPTIONNEL.
Il faut être patient et méticuleux car sa structure est assez complexe.
Le résultat est excellent tant en XLR qu'en RCA.
Sur mon système, l'apport principal est sur la scène sonore et les timbres qui, tout deux, sont très naturels.
On est au dessus du Sommercâble Epilogue.
Robert C.
Beau au regard et qualité des matériaux ainsi que des connexions.
Ecoute : PC Audirvãna Kobuz Dac Chord 2Qute Khozmo ampli de puissance Nuprime AMG SE (spécial édition) colonne Dynaudio Emit 30.
Plus détaillé, plus ouvert et charpenté, plus profond, plus nuancé ou subtil et plus agréable musicalement ; en comparaison du pré Rega Elex R ou Pro-Ject DS2 analogue.
Pas de rondeur exagérée ou de mollesse, cette fois cela reste à la fois fluide, vivant et expressif avec des aigus délicats et sans acidité.
Certainement pas encore la perfection que nous essayons tous de rapprocher, et cela passera probablement pour mon cas par un new Dac. (ce n'est pas ce qui manque chez Audiophonics).
Remerciements à Mr David Aubert pour sa science des conseils et à toute l'Equipe Audiophonics pour la livraison impeccable et plus tôt que prévue (article pas en stock).
Philippe L.
WONDOM AA-AB41163 BEB1 Bluetooth Receiver Module 5.3 LDAC USB Interface DAC ES9018K2M 24bit 96kHz The Wondom BEB1 Bluetooth receiver module, part number AA-AB41163, is a small Bluetooth receiver module featuring a QCC5171 Bluetooth 5.3 receiver chip, an ES9018K2M DAC chip...
Récepteur bluetooth
Distance reception très faible malgré le rajout d'une antenne dédié
Excellente qualité sonore
Jeremy D.
IFI AUDIO iPOWER ELITE AC Adapter Active Noise Cancelling 24V 2.5A The iPower Elite iFi Audio AC Adapter hides state-of-the-art technology under its sturdy extruded aluminum chassis to provide your audio device with a clean and stable power...
Parfaite évolution
j'étais relativement septique sur l'amélioration de l'alimentation de mon enceinte connectée JMR AGAPE, je possédais jusque là le filtre secteur ipurifier de la marque, mais le résultat est au dessus avec l ipower elite seule, silence de fonctionnement, tout est plus net plus précis plus agréable, ca fait de la musique, je découvre enfin mon enceinte et le plus bluffant c'est que tous les bugs et coupures de connexion ont disparus, incontournable pour profiter pleinement de son système!
Alexandre C.
TOPPING A30 PRO Headphone Amplifier NFCA Black The Topping A30 Pro is a high quality NFCA headphone amplifier that will delight lovers of headphone listening. With two headphone outputs at different impedances and a...
Une merveille
Que ce soit sur un dac TDA1541WW Nakamichi DAC101 ou sur un Sabre ESS9018 Breeze modifié, câbles Isoda 08, casque Sony MDR CD3000, cet ampli est non seulement d'une puissance extreme mais aussi d'une transparence et d'un silence sans égal.
Quelles que soient les modifications en amont il les restitue immédiatement avec naturel et richesse de timbre, dynamique sans faille et image sonore ultra précise.
Cyrille S.
SMSL PL100 CD Player CS43131 Black The SMSL PL100 CD player is the perfect way to enjoy your CD collection. It's essentially based on a CS43131 DAC chip and a PLL (Phase-locked Loop) circuit for sound...
Bon transport
Je cherchais un transport de petite taille avec un son correct pour le placer à coté d'un ampli FDA Sabaj, le résultat est correct, peut-etre moins de corps que mon vieux lecteur Pioneer mais c'est tres défini, je n'ai pas testé le DAC interne, sinon branché sur un DAC SMSL SU-1 et des enceintes de monitoring ça marche bien, c'est cohérent, on est pas sur un vieux lecteur Philips ou Marantz, c'est neutre.
Stian L.
AUDIOPHONICS HPA-S450ET Power Amplifier Class D Stereo Purifi 1ET6525SA 2x450W 4 Ohm The Audiophonics HPA-S450ET power amplifier is based on a Class D architecture, using a pair of Purifi 1ET6525SA amplification modules, a Hypex SMPS1200A400 power supply and an...
A very good and powerful amp
Delivers clean and high gain without any colouration or distortion. It is what I wanted. Only negative is a slight power on pop noise and the screws are of low quality and it looks like they could start to rust just by breathing on them.
Paul C.
TRUTHEAR X CRINACLE ZERO:RED In-Ear Monitor IEM Ø10mm/Ø7.8mm 17.5 Ohm 117.5dB 20Hz-40500Hz With the Zero RED, Truthear has once again teamed up with Crinacle, renowned for its expertise in IEM, to offer a new version of the fruit of their previous collaboration. These...
D'une remarquable qualité
Excellents écouteurs, tant par leur qualité de construction que par leur son. Les embouts en mousse fournis avec isolent également bien.
Jean Louis d.
AIYIMA A70 2.1 Channel Amplifier TPA3255 2x185W 4 Ohm AIYIMA's A70 is a 2.1-channel Class D amplifier featuring quality components. In fact, it incorporates a TI TPA3255 amplifier chip combined with two NE5532 AOPs for an output...
ALIMENTATION
l'ampli est bon mais l'alimentation est une daube , celle si perturbe beaucoup le rendu , j'ai installer une autre alimentation est la ca marche très bien
A H.
OMG
I got: seat at the mixing desk
I paid: the bass
And I love this
Lennart H.
Eric H.
Expandable Braided Nylon Sleeve 6-12mm Gray This grey braided nylon sheath will effectively cover your cables and give them greater mechanical resistance. This has an adjustable diameter from 6mm to 12mm.
Bon rapport qualité prix : fait le job !
Eric H.
Très bon câble sur tout le spectre
Amène de la clarté et pleins de détails deviennent plus apparents.
Je recommande son achat
Tanel P.
Nicely flexible
It's thick and green like a garden hose, looks good :) Easy to work with and very flexible indeed.
AIYIMA A80 Integrated Amplifier Class D Bluetooth 5.1 TPA3255 2x120W 4 Ohm With its A80, Aiyima unveils a small integrated amplifier packed with audiophile features and components. It's primarily based on an ESS9038Q2M DAC chip and a TPA3255D2...
Complet
Après un mois d'usage, je dirais : "Conforme au descriptif" : formule passe-partout pour confirmer qu'il s'agit d'un produit de qualité " à composants audiophiles", sans point faible significatif, surtout pour le prix, et pilotant efficacement, excusez du peu, des DYNAUDIO emit 50 (raisonnablement, hein, sans chercher à faire trembler les murs non plus ! ) avec l'alimentation d'origine, et ce dans mon salon de 25 m2 ; je n'ai donc pas besoin de prendre l'adaptateur secteur doublant la puissance. Merci Audiophonics pour l'info et surtout pour ne pas pousser inutilement à la consommation...
Cet ampli est aussi efficace en vinyle sur entrée analogique qu'avec le lecteur réseau sur l'entrée optique...
Je recommande donc aussi bien cet ampli Aiyima 80 qu'Audiophonics...
benjamin b.
SUPER
Je viens de m'ennuyer de repartir du compteur électrique, de retirer l'ancien 1,5mm2 standard et de dédier la ligne uniquement à l'audio (il n'y a avait toutefois que quelques luminaires en plus de la hifi sur cette ligne) Avant installation, le câble avait "tourné" quelques dizaine d'heures. Verdict :
C'EST LE JOUR ET LA NUIT :-) :-) :-)
si vous installez plusieurs prises murales : ne coupez pas le fil sans isolant. Celui-ci sert à faire la continuité avec la feuille isolante / de blindage.
Je l'ai soudé et gainé au fil de terre côté compteur électrique
très satisfait !
Giovanni B.
Purchase
Dear Sir, my package will arrive as soon as everything is available, or will you ship what is already in stock first? Let me know, thanks.
Juha K.
This amplifier could be described as very versatile for different music genres. Purifi has never disappointed my own ears. This does everything without adding or removing anything from the sound, however, being a little on the warm side. The treble is not dry as is typical for class D, it has nice details and brightness. The bass is also not a little dry as is typical for class D, it has nice thickness and meat, but still perfectly controlled. Overall, the sound has a nice "loudness". Physically very sturdy and high-quality housing. The adjustable gain is a big plus. The only small minus in my opinion is that the connectors on the back (speaker and RCA) are quite close to each other. If you use spades, there may even be a small risk of short circuit! However, there is no danger if you use balanced XLR connectors. This does not affect the number of stars. One of the best power amplifiers in its price range.
Eric H.
NEOTECH DG-202 RCA Connectors Plug OFC Copper Gold Plated Ø9mm (Set x4) These Neotech DG-202 RCA connectors, sold in packs of 4, benefit from rigorous design and high-quality materials. They are made of OFC copper plated with a thick layer of gold,...
Fiches RCA de qualités
Très bonnes prises RCA de très bonnes qualités.
Le seul bémol c’est la soudure de la masse sur le corps qui n’est pas évidente: ils auraient pu faire une « encoche » comme sur leurs autres prises RCA plus chers .
Eric H.
MUNDORF MLYTIC AG Capacitor 25V 22000μF These capacitors have been specially developed for small power amplifiers or preamplifiers. This new product replaces the M-Lytic SI series. The "Glue-On" output pins made of...
Excellents condensateurs
3ème commande, pour mes amplis: super sonorité
Pierre-Jean T.
Tung
Un son plus détaillé et limpide. Content.
André G.
Tweeter Dayton en complément du tweeter en facade
Ce tweeter qui est léger et ne paie pas de mine s avère etre clair non agressif et propre, il s intègre bien dans ma configuration en bi actif et rehausse l aigu en fusionnant avec le médium aigu. Pour 36€ c’est une aubaine
Stéphane K.
ELECAUDIO LI-07GB IEC C7 Connector Gold Plated 24k 3x5mm² Ø15mm This IEC C7 Elecaudio LI-07GB connector is ideal for making quality power supply cables. It uses 24k gold plated copper alloy contacts of 5mm², allowing to obtain a very...
Piètre qualité.
Un produit vraiment basse qualité. Btr cassée au premier démontage. direction la poubelle
Jean-francois L.
3E AUDIO A7 MONO Class D Mono Amplifier PBTL 1xTPA3255 1x260W 4 Ohm 3E Audio, a recognized player in the DIY world, now offers a Class D mono amplifier incorporating audiophile Hi-Fi components. The A7 Mono amplifier is based on one TI TPA3255...
A7 mono
Superbe ampli, je les préfères à mes anciens fosi v3 mono. Livraison rapide au Canada. Avec le support de 3e audio j’ai réussi à régler le problème du auto-standby trop sensible. Maintenant c’est parfait.
Jerome C.
RAMM AUDIO SA-15 Speaker Cable OFHC Copper Shielded 2x 1.65mm² The Ramm Audio SA-15 is a speaker cable offering quality design at an affordable price. It consists of two OFHC copper conductors with a cross section of 1.65mm² (15AWG),...
Utilisé en câble secteur bipolaire
Utilisé en câble secteur bipolaire, deux mètres de longueur avec un connecteur secteur schucko basique (ici Sommercable ) et un connecteur C7 que j'avais en stock.
C'est un réel bonus pour mon Lecteur DVD hdg (sur DAC externe) pour la partie audio à l'écoute de CD , son plus charnel un petit bonus en présence et séparation Stéréo.
Une optimisation "budget" très appréciable.
Le câble se "réalisera" (rodage) en une vingtaine d'heure
David C.
HIDIZS MERMAID MM2 In-Ear Monitors IEM Dual Drivers Magneto-Static / Dynamic PEK Black The Hidizs MM2 are in-ear headphones offering very good audio performance for an immersive and convincing listening experience. A sound quality associated with a resolutely...
Extra!!
Certes je poste mon avis avec 2 ans de retard! Ces petits écouteurs intra sont d'une qualité exceptionnel par rapport à leur prix de vente. La possibilité de pouvoir changer les filtre en fonction de ses goût et vraiment génial, de plus leur rendu acoustique dépasse mes attentes pour type de casque. Bref une petite pépite qui n'est malheureusement plus proposée à la vente au moment ou je me décide enfin à donner mon avis....
Nicolas P.
Ampli purifi
Cela fait seulement 2 jours que j ai reçu mon ampli purifi et donc tjrs en rodage.
La claque, il exploser en tout point mon ancien ampli pourtant 3 fois plus cher...
Je n' ose Imaginer dans quelques heures ce que cela va me donner...
Tout y est, à la bonne place, avec une précision extraordinaire.
Tout est sublimé.
Je suis super content de mon achat et certainement le dernier ampli que j achète.
Merci audiophonics pour donner la possibilité d avoir une amplification aussi bonne, à si peu cher en comparaison.
Markus W.
Speaker Terminals Rhodium Plated Ø19mm x 65mm (Pair) These speaker terminal blocks offer excellent design quality at an affordable price. Their contacts are made of rhodium-plated alloy copper, ensuring...
Good quality
These binding posts are very cost-effective. Build quality is massive contrary to most of the comparable products in this price range.
Patrick v.
TOPPING B200 Power Amplifier Mono Discrete 200W 4 Ohm Black The Topping B200 power amplifier is a mono amplifier based on a discrete-component NFCA amplifier circuit. This enables it to achieve a considerable power level while...
Magnifiques !
Les 200 sont d'une qualité de fabrication irréprochable, très beaux et élégants.
Vous trouverez une scène sonore vraiment très large et d'une clarté à couper les souffle, avec des détails jamais entendu avant. Ils sont extrêmement précis, donc aussi très révélateurs de la qualité d'enregistrement.
Absolument plus que satisfait de mon achat, finalement Internet avait raison!
