Thierry W.
Customers reviews - There are 19595 reviews.
Max N.
DATS
Very fast delivery. The product is of high quality. It costs its money. I did not expect it to be so multifunctional. In general, I am glad that I purchased this device. I advise everyone.Очень быстрая доставка.Товар качественный.Он стоит своих денег.Не ожидал,что он будет таким многофункциональным.Вобщем рад,что приобрел этот прибор.Всем советую.
Thomas v.
IAN CANADA FIFOPI Q2 ULTIMATE Reclocker Module FIFO PCM 32bit 768kHz DSD1024 DoP The  FiFoPi Ultimate  from  Ian Canada  was designed to significantly reduce the jitter of the digital audio signal produced by a Raspberry Pi, before...
Perfect way to transport your audio onto your dac!
This module is the absolute best way to transfer your audio from your Raspberry Pi (or other single board computer). This modules enables you to upgrade the very important clocks (for instance with ACCULUSION clocks). The module is extendable with other products from Ian Canada or can transpass the audio onto your dac via I2S.
Thomas v.
Shrinks good and does not burn.
Good shrink tube! Shrinks perfectly and does not burn when heated with a lighter. Also does not melt when heated with a solder iron.
Thomas v.
Excellent quality solder.
This wbt-0800 4% silver solder is really a must have! The solder flows nice and contains flux. Would recommend this for audio diy equipment.
Olivier F.
Très content
Très content de ce produit. Je viens de Modifier mes enceintes RCF actives avec des HYPEX PLATE AMPLIFIER FA252 calibrés sur les sensibilités du WOOFER et TWEETER RCF. Le Crossover est un LR48, et il me fallait compenser le décalage de phase en FIR. Connecté en input SPDIF de ma carte son MOTU, il ressort en AES/EBU vers mes RCF "MK5" made home DIY, et ce MIDI DSP non seulement me convertit le TOSLINK vers AES, et je peux changer le volume avec le gros bouton PUSH, appliqué le F.I.R, bref contrôler et corriger ma nouvelle SONO/HIFI . Je viens de mesurer avec un micro RTA et REW : phase parfaite même avec mes SUB, avec 2048 taps FIR calculés dans le logiciel gratuit REPHASE comptabile avec les fichiers .bin du mini DSP. très content et en plus livraison rapide et pro :)
Jean-Yves H.
Super ampli/DAC pour casque
Ayant un casque DT 990 PRO haute impédance, il est difficile de trouver un ampli casque puissant ...
Plus de problème avec ce modèle et la musicalité est bien au rendez-vous !
Que du bonheur !
Je recommande.
Luis C.
Bon produit, assemblage facile et avec très bons contacts.
Malheureusement, je l'ai acheté parce que le PI-26Gc était trop long mais, avec une entreé max de 16,5 mm, n'est pas possible d'installer le câble CS-361B.
(Un avertissement d'audiophonics aurait été aprécié dans ce cas)
Christophe P.
Bon potentiomètre
J'ai acheté ce potentiomètre pour écouter ma platine vinyle directement en sortie d'un préampli phono (avec un casque 32 ohms, ça le fait, sachant que j'ai des enceintes actives donc je mets soit le casque, soit les enceintes et pas besoin de préampli et d'ampli en plus. Pour mon DAC c'est pareil;
Il n'y a pas de craquement ou d'interphérence, le niveau est suffisant pour mes oreilles - c'est fort en fait - et le bouton est de bonne qualité. Le son est très bon.
Merci encore une fois à Audiophonics pour l'envoi rapide et soigné.
marc t.
Bon rapport qualité/prix - Service sérieux et efficace
J'écoute la musique en démat, ce mini DAC est parfait pour ce que je recherchais, j'étais en vacances chez les parents où j'ai une petite installation hifi, je voulais écouter la zique de mon mac, (via AUDIRVANA) via cette installation, sans que cela ne me coûte plus que quelques dizaines d'euros, vu ce qui se prépare sur nos futures retraites, il était sage de ne point investir... Je suis TRES satisfait par ce boitier car il est plug and play et fait le taf LARGEMENT pour le prix demandé. C'est pas un son aussi ample et aéré que ce que j'ai avec un DAC de salon mais pour une trentaine d'euros, on va pas demander la lune, non?
Première fois que j'achète chez AUDIOPHONICS, ça respire le sérieux et l'efficace, je reviendrai sans souci, c'est sûr, mais j'attends de voir les annonces du premier ministre avant de me lancer dans des folies pour le plus grand plaisir de ma paire d'oreilles.
Sélecteur de Source
Produit conforme à la description (4 contacts / 3 positions)
Fonctionne bien,
Rien à redire à part un axe un peu court mais ça ne pose pas de problème avec le bouton que j ai choisi :
(https://www.audiophonics.fr/fr/boutons-volume-6mm/bouton-aluminium-axe-meplat-38x25mm-o6mm-argent-p-11812.html)
Marc M.
DuHaut de gamme á petit prix
J ai utilisé ce câble pendant plus de quatre ans . La curiosité m a amené à vouloir essayer d autres câbles puisque d un systeme comprenant enceintes biblio je suis passé à des enceintes colonnes. Après pas mal d essais avec des câbles de marque á un prix raisonnable, je suis revenu au mogami 3103. Ce câble est vraiment le maillon indispensable à mon systeme et restera sur le haut du podium dans la catégorie petit budget. Mon rega brio peut s exprimer sans retenue sur ma paire de Dali Zensor 7.
Claude d.
super sav
bonjour,
suite à une erreur de ma part j'ai renvoyé la commande.
Dans la demi-journée, l'argent a été recrédité sur mon compte.
Merci audiophonics
claude
laurent d.
Très bonne facture. Alimente mon Mac mini (avec le kit uptone pour l’intérieur du macmini) et la freebox mini 4K. La différence est très importante, je ne peux plus m’en passer. Le son est bien meilleur. La différence la plus importante est tout de meme au niveau de la Freebox! Et le son est meilleur par rj45, directement de la freebox à l’ampli (h390) qu’en passant par le mac mini (rj45 puis usb). Donc la bonne formule c’est de mettre des alimentations linéaires bien amperées ET de supprimer au maximum les intermédiaires.. La freebox reste le maillon faible, pas facile à remplacer.. l’ajout d’un switch audiophile entre la freebox et l’ampli pourrait encore améliorer le son, selon un dossier test lu récemment. Apres peut etre qu’il y aurait des gains à réaliser en mettant de meilleurs cables sur l’alim achetée ici.
david b.
ARYLIC COBBLESTONE WiFi Receiver AirPlay UPnP DLNA Multiroom 24bit 192kHz The Arylic Cobblestone is a WiFi receiver that allows you to easily and efficiently stream your files from your network, smartphone/tablet or your favorite streaming services....
L'efficacité liée à la simplicité
Simple d’utilisation et efficace il ne faut néanmoins pas lui demander des performances extrême. il faut l'associer à du matériel plutôt de bonne facture pour avoir un plaisir sonore digne d 'audiophile et de mélomane. Cependant je cherchais une solution simple et efficace sans passer par google chrome, et donc , sans allumer ma télé, ce petit matériel esthétique de sir quoi fait le job a merveille. Il a le mérite d’être à la fois beau mais aussi sa petite surface faite d'une matière proche du velours ajoute à l’expérience sonore et visuelle une expérience tactile intéressante.
Tout ceci dans un petit objet.
Alimentation Audio gd
Premières impressions :
Utilisée pour alimenter un buffer (PASS B1)
J'utilise les sorties 2x 9v en série pour sortir 18VDC
Subjectivement les résultats sont bons
(il faudra que je mette un petit coup d'oscillo pour voir la propreté du DC délivré)
Concernant cette alim
Le pcb est propre avec des composants de bonne facture
Des potentiomètres multitours permettent d ajuster finement la tension de sortie (avec une bonne réactivité)
NB La tension de sortie chute un peu lorsque les transistors de sortie sont chauds
(Cela est dû à l'absence de contre réaction voulue par le constructeur)
Comme mon montage accepte de 18 a 24 v
Je l'ai réglé pour l'instant a 19,1 v à l'équilibre thermique ...
Le transfo d alim est un 2x15 (de 12 a 18v recommandé )
Enfin pour la dissipation thermique, je l ai fixé sur les perforations d aération d un boîtier hifi2000
Patricio A.
Un excelente DAC !!!!!
He recibido hace dos días este maravilloso DAC que me tenía sin dormir esperando su llegada, actualmente estoy mus satisfecho con ALO BOSS DAC V1.2 el cual es muy bueno y tiene una potente salida.
Al principio me costo tiempo y frustracion el setup de I-SABRE ES9038Q2M, lo instale usando un RasppBErry Pi 3B+ & PiCorePlayer 6.0, escogi el DAC Audiophoincs Q2M del menu de DACS y todo bien, una vez configiurado LMS y PCP sobre WiFi lo apague y lo lleve al lugar donde estaría definitivamente ubicado, pero al encender el aparato se recalentaba mucho y se reiniciaba.. lo deje para el día siguiente y me di cuenta que era falta de potencia de la fuente de poder, le conecte a la fuente de poder propia de RaspBerry 5V-3A, le agregue unos disipadores de calor y funciono perfectamente, me la he pasado escuchado varias horas y debo decir que es un DAC espectacular, un sonido
cristalino sin excesos en BASS ni TREBBLE me gusto mucho más que el ALO BOS DAC 1.2 que es excelente y tiene más potencia de salida.
La atención de Audiophonics es muy profesional y cordial a la vez, la tecnología Europea es excelente.
Muchas gracias por todo, seguramante estaré comprando más componentes para mi equipo DIY ideal.
Atte.
Patricio Almeida
Ecuador.
Jari S.
Very good binding posts for it's price, well very good in any terms. Accepts bare wire, forks and bananas. Has a good soldering option for internal wire and has good insulation. Might feel a bit loose parts when not installed in place, but are solid after they've been put together and tightened. Have bought them already several pairs and will buy more in future.
Serge P.
Magnifique !
Grâce à cet amplificateur classe A, j'ai redécouvert mon vieil Sennheiser HD 565. Totalement transcendé ! Et quelle musique ! Très large scène sonore avec beaucoup d'aération entre les divers instruments. De la profondeur aussi un étagement des registres bien tenu.
Le message fourmille de détails, on perçoit très nettement les bruits de salle, les respirations et chuchotements. Les enregistrements Hi-Res (24/192) sont restitués avec un tel réalisme que très vite on oublie le casque pour se laisser aller totalement au gré de la musique qui nous emporte.
Une autre chose importante que ce K214 V2 m'a confirmée de façon plus claire encore, c'est la nécessité de "ripper" au plus vite mes meilleurs CD et les mettre sur disque dur (musique dématérialisée), car associé à un bon DAC USB (E-MU 0202 "euphonisé"), puis branché pour comparaison en sortie d'une platine CD renommée, je vous l'assure : c'est la gifle !
Patricio M.
Excelente DAC
Mi primera experiencia en el mundo de los lectores de red (para disfrutar de Qobuz) fue un sistema RPI con un dac is2 iQuadio. Buscando algo más de calidad pasé a un Auralic Mini. El sonido mejoró pero nunca estuve completamente satisfecho con su manejo a través de dispositivos Apple para oír Qobuz. Quería volver a probar algo en el mundo RPI y a la facilidad de manejo de BubbleUPnP, sin sacrificar prestaciones sonoras y me decidí por esta pequeña joya. Más transparente que el Iquadio y algo más relajado en altas frecuencias que el Auralic Mini. Excelente integración con MoOde ya que puedes acceder a los filtros predeterminados en el PCM5122. He visto una evolución claramente favorable desde las primeras versiones de MoOde que probé hace un tiempo. No uso Volumio ya que el manejo de las playlists es insoportablemente lento pero también suena muy bien. Lo tengo todo alimentado con una alimentación lineal comprada aquí. Recomendación total.
Davide D.
XLR caps
Excellent quality at the right price. For those who love hi-end accessories
Davide D.
RCA caps
Davide D.
Furutech 8n Connector
Unquestionable superb quality of Furutech
Davide D.
Perfect Weight Record
This 1877Phono weight record is perfect. Satin and soft touch surfaces, nice to look at. Recomended for wood or black turntables
Bruno P.
Gaine Tressée Rouge Viablue
C'est la seconde fois que j'achète cette gaine.
A la première utilisation, j'ai eu un peu de mal mais au final après avoir fait 20 mètres de câble (XLR, AS3, RCA, Coax...), cette gaine est facile d'utilisation.
jean patrick P.
silencieux
Je m'attendais à mieux suite à ce que j'ai lu sur différent forum . Silencieux : oui
puissant : non
champ sonore rétrécit
je l'utilise avec un plenue L avec casque Denon AH-D9200 qui est que 24 ohms et mon plenue L à un champ sonore plus large et surtout plus puissant .
Car au-delà de la moitié de son volume il commence à crier plutôt que d'assurer ...
Pour amplifier un smartphone çà va .
mais son son est propre , pas de distorsion , quand même agréable mais pas audiophile car même le plenue L avec le casque Denon n'est pas audiophile . Ne vous fier jamais à ce que les gens comme moi puisse dire , essayé là si vous le pouvez . Valable pour tous les matériels .
jean patrick P.
Male Jack 4.4mm to 2x Male XLR Cable Gold Plated 1,5m This 1.5m long cable consists of a 4.4mm male jack connector and two 3-pin XLR connectors. Taking advantage of a high quality design optimized to offer very good conductivity...
franchement
Qui a eu l'idée de faire un câble symétrique avec deux câbles séparer , c'est chiant à manipuler et à ranger . J'ai pas d'autre câble pour la comparer , je doit dire qu'il fait son boulot .
jean patrick P.
c'est bien
fait son boulot mais la fiche 4.4 mm de mon casque semble rentré trop facilement . pas assez serrer .
Gilles H.
Casse tête
Belle fabrication, restituton en fonction du câble choisi, robuste, peu encombrant, excellent prix.
Mais un casse tête à démonter et à remonter, un enfer. Simplissime sûrement pour la deuxième, mais que de temps et d'agacement pour y arriver, je déconseille ++ . Il existe une version supérieure et montée... Plus jamais ça.
Il suffirait seulement d'avoir un vrai schéma de démontage et de câblage fourni ...
PS je suis une personne calme et minutieuse.
Gilles H.
Rune très belle surprise
J'ai écouté et suivi les avis des autres et je ne le regrette pas !
Accouplé à mon tuner analogique DENON TU 500 : plus d'ampleur, un peu plus de definition et une chaleur supplémentaire modérée, naturelle. Une sonorité légèrement plus ronde de bonne aloi. Je vais associer ces futures prises avec l'or des rack d'alimentation pour avoir une cohérence sonore meilleure . Essayer c'est l'adopter.
Gilles H.
Un réel plus
Associé à un ampli hybride (Kora 90) il apporte une amélioration audible à tous les niveaux. Je le trouve équilibré, rien à retirer à ce prix.
Il est nettement superieur à la version sans "cardas" du modèle C7. Il n'est certes pas extraordinaire mais pour le prix il est imbatable. Le premier pas assuré dans l'univers dispendieux des câbles d'alimentation pour ceux qui doutent.
Grégory L.
Bon DAC mais !!
J'ai acheté ce DAC pour remplacer ma vielle carte son pensant améliorer la qualité sonore de mon systeme hifi, mais je me reprouve avec un sifflement quand je le branche en USB. La solution: installer un filtre USB a 149 £.
Est-ce-que un filtre a 149£ réglera le problème ???, ou bien branche en optique sur ma veille carte son, mais ce n'était pas le but.
Je ne dit pas que le problème vient du DAC, mais je ne m'attendais pas a ce genre de souci.
Je met 4 étoiles pour la qualité du DAC et aussi pour l’écoute du service technique de Audiophonics .
C'est un problème récurrent sur les PC dotés d'alimentation à découpage.
Votre demande a été transférée au SAV (si l'interface est en cause elle sera changée).
BRUNO B.
tres bon petit DAC !
Bonjour, je reviens a ce que j'ai écris sur lui !
on peut très bien le brancher via Coax numérique sur une platine CD mais si comme moi, c'est un lecteur DVD, il faudra le configurer via le menu du DVD et la le son serra transmis ! donc véritable couteau Suisse le DAC 3 , je recommande, encore merci a vous !
Ivan B.
Great service and fast delivery from Audiophonics. Right out of the box the dac sounds well, waiting for it to burn in to show its real potential. Will post in a few weeks...
Emmanuel D.
Bluffant!
Surprenant petit ampli Full Digital! Le son produit est de très bonne qualité: bien défini, dynamique et équilibré. La puissance est suffisante pour une pièce de taille moyenne. Il propose plusieurs entrées qui fonctionnent toutes très bien (bluetooth, AUX, USB). Associé à de bonnes enceintes, le résultat est bluffant! Seuls bémols: pas d'écran, et peu de réglages d'égalisation, mais à ce prix... (D'ailleurs, la marque propose d'autres modèles qui pallient ces petits manques)
Luc D.
transfiguration de mon ampli
J'en ai pris deux pour remplacer les lampes de mon ampli basse Fender Bassman 500 (des grooves tubes). L'ampli en est transifiguré, J'ai acces à de nouveaux réglages: son équilibré, bien étagé, basse propres avec un growl réjoussant, ca respire. Quelle bonne idée!
Très bien !
Bonne qualité, simple à mettre en oeuvre !
Qualité correcte
Qualité correcte, conforme à la description.
Finition irréprochable, belle qualité, rien à reprocher.
MONACOR XLR-804/P Male 4 Poles XLR Connector Ø9mm The XLR-804/P from Monacor is a simple 4-pin male connector with a quality design. Indeed, the connector body is made of metal and ensures very good resistance, and a rubber tip...
MONACOR XLR-804/J Female 4 Poles XLR Connector Ø9mm The XLR-804/J from Monacor is a simple 4-pin female connector with a quality design. Indeed, the connector body is made of metal and ensures very good resistance, and a rubber...
Qualité correcte, juste la Led qui éclaire un peu fort, c'est tout.
Qualité correcte
Produit de bonne facture, attention à ne pas trop chauffer lors du soudage.
Qualité correcte
Qualité correcte, ne pas trop chauffer quand même lors du soudage.
Cosses très qualitatives, rien à redire.
Bon câble
Bonne qualité, malgré une certaine rigidité qui pourrait gêner dans certaines utilisations.
Câble de qualité, et très souple parfait pour mon utilisation.
Rien à reprocher à cette alimentation de très grande qualité, qui fait son boulot mieux que bien.
Martial B.
Article correspondant à mon besoin, mais un des composants avait été oublié d'être soudé.
Attention chez vous lors du contrôle de conformité à la réception !
