Sahin T.
Excellent mais bug logiciel
Magnifique dac qui offre une spatialisation exceptionnelle, un détail et précision grandiose. Par contre bug logiciel, le...
Gilles F.
Apparemment tres bon
J'ai fait le test avec un aimant... La partie connecteur n'est pas ferreuse, la partie qui se soude au cable est...
Très bien !
Peu coûteuse et efficace, tout métal, elle est facile à souder.
Accepte du câble jusqu'à 8,5mm de diamètre.
Bravo !
Customers reviews - There are 20831 reviews.
Hugo Darien O.
RAMM AUDIO S8MC Interconnect Cables RCA OFC Copper 1m This RAMM Audio S8MC RCA-RCA modulation cable offers good quality at a very affordable price. The cable conductors are single-stranded OFC copper. The cable features an aluminum...
best cheap
this should be the first cable when buying first stereo that use to be cheap, this cable is; NEUTRAL
Michael L.
Good - but had a mechanical mistake in the beginning
I measured it roughly and in position 1(on one side only) I had infinity resistance - not good! = means it gives out the full volume in the position of zero volume! It took me approx. half an hour to dismount it and to find the "microscopical" mistake - one plastic-washer was inverted and so the position of the riding contact was ½ millimeter in the wrong position... Now it's fixed and gives me zero Ohm at position one. (-::
Efthymios X.
VIBORG VT08 USB-C 3.1 Connector Gold Plated Ø8mm This VT08 USB-C connector from Viborg is ideal for mounting high-quality USB cables. Its contacts are made of 24k gold-plated copper alloy, ensuring good conductivity and...
Best from what's currently available really, that's it.
DC 9V Jack Filter with Supercapacitor to Jack DC This DC 9V jack filter with supercapacitor allows you to obtain a clean power supply for your Hi-Fi equipment and appliances, thanks to 4 supercapacitors 5F - 3.0V and an...
mise en œuvre
Il sera peut-être utile de l utiliser avec une alimentation réglable pour compenser environ le demi watt consommé par le filtre ,avec un peu moins de courant les appareils pourrait ne pas fonctionner .
indispensable
A acquérir de toute urgence pour tout les appareils DC.
Alexandre G.
FOSI AUDIO P4 Preamplifier The Fosi Audio P4 preamplifier is a compact and versatile solution. With its three stereo RCA inputs, volume control with motorised potentiometer, tone control, gain selection...
petit mais costaud
je regrette juste le peu de place qu'il y a entre les connecteur rca, sinon tout va bien , mon vieil arcam dont la partie preampli etait out le remercie
Emmanuel L.
IBASSO CB19 USB-C to USB-C / USB-A Silver Plated Copper Cable 10cm The DB19 from iBasso is a USB-C cable for a dongle (portable USB DAC or amplifier). It has a USB-A connector for power and a USB-C connector for data transfer. Its 10cm...
Bien utile
Le câble est assez court pour ne pas être gênant, sa fabrique semble solide.
Lajos B.
GLA-XLR Balanced Volume Control Module 20kOhm with Encoder / Display / Remote Control This GLA-XLR volume control module is composed of an encoder, a display and a remote control. This module incorporates a low-distortion chip...
GLA-XLR
A termék a leírásnak megfelelően működik!
A termékre 5 csillagot adnék!
A UPS szállító céget senkinek nem ajánlom! Nem segítőkészek, és háromszor is visszatartották a csomagot arra hivatkozva, hogy a címen nem találtak! Egyszer sem kerestek és a futár elmondta, hogy túl kevesen vannak ezért nem szállítják ki a termékeket.....
Efthymios X.
If you need it, no alternative for the moment, so 5/5
Efthymios X.
At its price, nothing else out there.
Efthymios X.
Good for its price, beggars and choosers as the saying would go :)
Farré P.
SMSL PA200 Amplifier Class D Stereo / Mono Infineon 2x160W 4 Ohm / 1x400W 4 Ohm SMSL unveils its PA200, a singular amplifier somewhere between a power amplifier and an integrated amplifier. The latter is capable of operating both in stereo with volume...
Plus qu'étonnant...que reste-t'iil aux"grands?"
Couplé avec le DAC du CD SMSL PL 200, j'ai installé cet l'ampli SMSL PA 200 avec le streamer N100 de la même marque.
Verdict unanime (de ma part, et de la famille présente : une sensation accrue de clarté, de séparation des couches instrumentales, et une sensation de puissance bien réelle. Très belle image ! Cet ampli remplace un couple préampli -- ampli Ayre K5X Evo et V5 Evo dont je n'ose vous dire le prix ....! Merci à Audiophonics pour les conseils avisés et....une livraison éclair avec un parfait suivi DPD. Mais que demander de plus?
Mon système : SMSL PA200, + SMSL N100 + SMSL PA200 + enceintes Unison Research Max Mini. Câblage : modulation
Note : J'avais commencé chez SMSL avec un Dac M7...que je ne peux me résoudre à revendre, tellement il donne en terme de fluidité, de justesse des timbres. Utilisé sur mon second système.
Gérard M.
Très bien mais trop cher.
Super qualité, pratique, mais quand même trop cher...
Gérard M.
DAYTON AUDIO H6512 Wave Guide High Frequencies 16.5 x 30.5cm This horn allows you to tune a high-frequency driver to your listening space without distortion thanks to its unconventional geometric shape and low expansion rate. It ensures...
Très bon.
Moulage correct, insert fileté en laiton, aspect très propre.
Seul regret, le finition de la gorge n'est pas top, à reprendre avec une lime douce.
Gérard M.
WONDOM PS-BC12112 BCPB3 Battery Management System Module 5x Lithium 18650 The Wondom BCPB3 is a battery management and protection module, taking advantage of the performance and reliability of the previous models while offering more battery...
Utilisé pour alimenter un préampli phono.
Bien mais gaffe au court-circuit. Set de câbles indispensable.
Gérard M.
esthétiquement parfaite, assez extensible. Je recommande.
Gérard M.
Rien à redire... c'est de l'huile.
Gérard M.
Pour câbler un platine vinyle Lenco 75 - bien.
Gérard M.
Super rapport qualité prix.
Gérard M.
Farré P.
SMSL N100 Streamer WiFi AirPlay DLNA Roon 32bit 768kHz The SMSL N100 audio streamer is a small network player developed by SMSL in partnership with Volumio, supporting all its functions such as Tidal, Qobuz, SHOUTcast, Pandora, Roon...
Simple, et...très efficace.
Après de nombreuses tentatives infructueuses (coupures, difficultés d'appariement etc) avec différents matériels, j'ai jeté mon dévolu sur ce N100. Faisons simple : c'est parfait. Reconnu instantanément, et après un premier titre de mise en place, j'ai pu bénéficier d'un écoute limpide, sans interruption aucune. Couplé avec le DAC du CD PL 200, raccordé au nouvel arrivant : l'ampli SMSL PA 200. Verdict unanime (de ma part, et de la famille présente : une sensation accrue de clarté, de séparation des couches instrumentales, et une sensation de puissance bien réelle. Très belle image ! Cet ampli remplace un couple préampli -- ampli Ayre K5X Evo et V5 Evo dont je n'ose vous dire le prix ....! Merci à Audiophonics pour les conseils avisés et....une livraison éclair avec un parfait suivi DPD. Mais que demander de plus?
Mon système : SMSL PA200, + SMSL N100 + SMSL PA200 + enceintes Unison Research Max Mini. Câblage : modulation VoVox et enceintes : DNM reson LSC.
Pascal B.
HuntKey AC/DC Switching Power Adapter 100-240VAC to 48V DC 10A for FOSI AUDIO This AC adapter takes a 100-240VAC input voltage and provides a 48V DC output voltage for a maximum current of 10A, i.e. 480W power.
Attention: adaptateur adapté aux appareils Fosi mais pas de marque Fosi. Sinon rien à signaler: fonctionne bien, pas de bruit parasite et il me semble que l'adaptateur est plus compact que celui de marque Fosi.
Eric E.
E70 Velvet : c'est tout bon
J'ai acheté ce dac en étant principalement guidé par ma préférence pour les puces AKM. C'est mon premier Topping.
Le son est clair et détaillé, précis et lumineux. Les plans sonores sont bien définis. Les basses sont propres et fermes, les voix sont belles et naturelles, les aigus sont impeccables. Je ne trouve pas de défauts, que des satisfactions. Ce dac me paraît très réussi. J'en suis tellement satisfait que j'en ai acheté un deuxième exemplaire sans aucune hésitation la semaine suivant mon premier achat.
Le premier fonctionne sur une association Quad/Infinity , l'autre sur Nad/B&W, le résultat est hautement satisfaisant sur ces deux installations.
Hubert K.
JANTZEN AUDIO COMPACT MKT 001-8190 Axial MKT Capacitor 160V 82µF Jantzen Audio's Compact MKT capacitors are made from the highest quality metallized polyester film available. Jantzen Audio has succeeded in making these capacitors more compact...
Parfait condensateur utilisé dans un filtre passif; a priori meilleure tenue dans le temps que des chimiques à quasiment les mêmes prix. 5% de tolérance c'est dans la moyenne supérieure dans ces prix. Enfin, les faces supérieures et inférieures planes facilitent leur placement (je les colle au support de fitre). Question "écoute": ben... RAS, à valeur capacitive parfaitement égale il n'existe pas de différence audible entre quelques condensateurs que ce soit (pour filtrage passif en tout cas).
PSVANE CV181-TII HiFi Tubes Double Triode (Matched Pair) The PSvane CV181-TII is a high quality dual triode tube used in voltage amplifier circuits. It can replace the 6N8P and 6SN7GT tubes, and offers excellent performance.
Une révélation
Après de longues heures de recherches, car le monde des lampes ou tubes , est un monde ou on trouve très peu de vrais articles sur les produits. Donc après bien des recherches la Psvane cv181 sortait du lot . PSVANE une maison qui donne le ton dès le visuel de l’emballage des tubes. A l’intérieur vous avez deux fiches techniques des mesures des tubes . Tubes d’une finition exemplaire. Ces tubes sont venus remplacer des tubes 6SN7 entrée de gamme de chez Psvane sur un ampli Cayin CS845A. Dès les première notes, la différence est flagrante, une image sonore tridimensionnelle superbe, une définition dès registres magnifique, des graves voluptueux et profonds. Quand ils auront leur heures de rodage, comme tout tubes, il vont se délivrer encore plus et sonneront encore mieux.
Conclusion, des tubes qui valent chaque centimes de leur prix.
A titre d’information le tube CV181 remplace n’importe quel tube 6SN7 et 6SN8 d’origine sur votre ampli , si bien sûr ce celui-ci en est équipé.
Gionatan R.
Bello ma fragile
Mi piace molto questo eccitatore. Per le dimensioni che ha il suono è buono, però i due punti di connessione sono molto fragili e si spezzano facilmente.
Bello ma da migliorare.
François G.
FOSI AUDIO DAC-Q5 DAC ES9018K2M Headphone Amplifier TPA6120 24bit 192kHz Compact, versatile and affordable, the Fosi Audio DAC-Q5 brilliantly takes on the role of DAC and headphone amplifier. Ideal for a desktop installation, it will fit just as well...
Par contre, plusieurs défauts d'interface sont un peu pénibles au quotidien :
1. Pour éteindre, il faut appuyer 3 secondes sur le bouton de sélecteur de canal. Plusieurs fois, j'ai cru éteindre mais faute d'appui assez prolongé, j'étais juste passé de USB à coaxial. Un commutateur serait tellement plus pratique !
2. La led bleue qui indique que l'appareil est sous tension est enfoncée dans le boîtier. Si on regarde le boîtier de dessus, on ne voit pas la lumière. Combiné avec le point précédent, c'est encore plus gênant.
3. Cet ampli chauffe beaucoup plus, même sans connexion, que mon précédent ampli casque.
Samuel A.
TONEWINNER AT-7300HD AV Processor / Home-Theater Preamplifier Dolby Atmos 13 Channels 7.2.4 The Tonewinner AT-7300HD is a 13-channel audio/video processor and preamplifier, ideal for home theater integration in configurations up to 7.2.4. It supports all current audio...
What a surprise!!!
I've had the tonewinner AT-7300HD for about 3 weeks now. I've paired it with the Tonewinner AD 7300 PA+ power amplifier and my Cabasse baltic5 front stage / Cabasse i03 surround speakers and 4 x Bowers and wilkins PV1D subs. Set up was straight forward and easy to do I used the XLR balanced connections as these provide a cleaner signal pathway when compared with unbalanced connections. Coming from an all in one AVR to separates I wasn't sure what to expect. After set up and after running the tonewinner room correction programme, I have to admit that sonically I was impressed. The sound stage was more wide and dispersed than what the AVR produced. The Bass was tight and controlled. The midrange pronounced and clear without being overly bright and the upper register clear, concise and attenuated. Whilst not the most intuitive set up UI, it does the job given it's basic nature. If anything it was easier to navigate than it's more modern counterparts. Connecting my audio visual peripherals to the AT 7300 HD was a breeze. This is where the simplicity of the UI set up interface really came into its own. You're able to delve into a multitude of settings for each connected audio visual piece of equipment. HDMI switching between sources is fast and stable without any discernable lag, although initially the signal from my 4K TV (loewe) would inexplicably drop and the AT-7300HD would indicate no signal status for that particular source. After many hours trouble shooting and researching the issue online. I once again delved into the tonewinner manual for this product. The issue was the CEC functionality built into the AT-7300HD. Tonewinner suggests that this should be disabled to avoid strange behaviours like I was experiencing. Once done I've not had a repeat of the dropped signal. The remote control for the unit works well and without issue. Nothing fancy and does the job. There is an app which can be used. Connection is via Bluetooth. Whilst connection can be tedious and a little hit and miss. Once connection is achieved the app works flawlessley. The build of the AT-7300HD is superb. All aluminium chassis with glass front display panel. It matches the aesthetics of the AD 7300PA+ beautifully. It's understated and simple design stand out. It's operation sublime despite the occasional querks. If your looking for a processor that is affordable and operationally and feature wise punches above it's weight. Then you owe it to yourself to give this unit consideration.
Frederic A.
Fonctionne bien. Les 2 Câbles XH 3, a remplacer (Avis perso)
Cordialement.
Olivier A.
LUDIC HEIMDALL Filtered Power Distributor 8 Sockets Aluminum Silver The Ludic Heimdall filtered power distributor effectively eliminates any unwanted interference from the power grid or other connected devices. It thus allows your devices to...
complément à précédent avis
je reviens sur mon avis précédent car le déphasage évoqué provient du câble secteur acheté pour remplacer celui d'origine et non du filtre.
Par ailleurs, certaines prises ont beaucoup de mal à être extraites des prises shuko.
Olivier A.
AUDIOPHONICS HPC4 Speaker Cable OFC Copper 2x4mm² This Audiophonics HPC4 speaker cable has two conductors, both made of 511 strands of OFC copper to ensure optimum conductivity. The transparent PVC jacket makes the cable both...
pour offrir de jolis bons gros câbles Audiophonics à vos enceintes....à prix raisonnable.
Olivier A.
ATAUDIO KING WOLF RCA Interconnect Cable 6N OFC Copper Shielded Gold Plated 1m (Pair) These ATAudio King Wolf RCA cables feature quality construction with OFC 6N insulated copper conductors for excellent signal transmission. The braided copper shielding...
bon rapport qualité prix
bon produit, blindage et matériaux de qualité à prix raisonnable.
Olivier A.
des réserves
Voyant rouge de phase/terre qui ne s'éteint jamais quelque soit les phases, les prises ou la mise à la terre effective.
Par ailleur le système de prise n'a pas de détrompeur pour les prises de terre donc on ne peut pas savoir si on respecte la phase. Fabrication en aluminium brossé de très bel effet avec élégant voltmètre (hélas, peu lisible à distance).
Pas suffisamment expert pour apprécier l'apport technique de ce filtre à une installation.
Olivier A.
LINDY CROMO LINE High Speed HDMI 2.0 Cable Triple Shielding 24k Gold Plated 1m Lindy's Cromo Line represents the brand's range of high-performance HDMI 2.0 High Speed cables. These cables have triple shielding and tinned copper conductors with a...
peu qualitatif
fabrication du corps de la prise en plastique léger peint couleur argenté. Placage des connecteurs très léger. ce câble'inspire guerre la qualité.
Olivier A.
fais le job très bien
bonne fabrication et bon prix. simple et efficace
Alexandre W.
Pas cher mais pas grand chose...
Fonctionne très bien, simple et efficace.
Par contre il n'y a pas d'aigu c'est un peu frustrant...
Peter H.
FURUTECH GT2 NCF USB-A Male / USB-B Male Cable Silver Plated OCC Copper 1.2m With the GT2 NCF, Furutech offers a USB-A to USB-B cable with a silver-plated OCC copper conductor and triple shielding. This cable also benefits from the NCF technology...
Excellent upgrade from Supra Excalibur
I have owned this cable for a while now and compared it against Supra Excalibur, the original Supra USB, Oyaide neo d+ Class S, and Neotech Neub 1020. I haven't heard the old Furutech GT2 version without NCF, but from what I've read from others this is a significant improvement over Furutech's old USB cable.
Comparing directly against the other USB cables I mentioned it's most similar in style to Supra Excalibur, but also a clear upgrade in quality. Supra Excalibur has a firm style of sound that emphasizes slam and punch. It's also a bit flat in soundstage quality compared against the other cables. The most common complaint about Supra Excalibur is that it's excessively firm and as a result feels unnatural and somehow dead and sterile. I think Furutech GT2 NCF delivers everything that's good about the Supra Excalibur while fixing all the flaws. It's not a small difference, as I think the perceived upgrade in sound quality matches the price, ie it's 2x the cost for what easily sounds like 2x the sound quality. Let's say that Supra Excalibur adds 80% firmness the original sound, then Furutech GT2 NCF dials it down to maybe 15% extra firmness. You get more physical presence and punch, but without overdoing it. The reference I'm using here is Neotech Neub 1020, which emphasizes the air more but also might be a bit too laid back and gentle. The Furutech GT2 NCF feels roughly similar in quality, but different in style as it give you extra physicality. For most people I think the Neub 1020 will be better, and it also feels better for my audiophile brain to be using pure silver conductors instead of silver plated copper used by the Furutech GT2 NCF. But I can't deny that the GT2 NCF sounds amazing, and I think the NCF technology is effective in cleaning up problems in the signal. I think Furutech have done a great job with this cable. The quality of sound matches the price. I think on some systems this will be clearly better than Neub 1020, so you should seriously consider it. Because I use USB reclockers I'm using both Neub 1020 and GT2 NCF in my system with great results.
David R.
Fait le taf
Comme dit dans le titre. J'en ai pris deux pour relier un DAC SMSL PS100 et un lecteur BLU-RAY Sony, cela fonctionne très bien et ils prennent en charge l'HDMI ARC. (pas testé en E-ARC)
Seul (petit) bémol, ils ne sont pas très flexible, la gaine nylon doit y être pour quelque chose. A considérer si vous comptez leur faire prendre des chemins sinueux.
David R.
Ethernet Cable RJ45 Cat 6 Shielded 5m This 5m long RJ45 Ethernet cable is ideal for quality network connections. Its high quality S/FTP (PiMF) design allows a very good transmission quality, considerably reducing...
RAS
Les connecteurs sont de très bonne qualité, fait bien le job!
David R.
Du bon travail!
Comme d'autres clients, acheté pour relier la tv à un ampli hifi.
Je n'ai pas comparé avec d'autres appareils dans ces circonstances, mais la puce Sabre fait du bon boulot. J'ai testé en optique et HDMI ARC, je préfère le son en ARC, mais c'est bien sur un avis personnel.
Le téléviseur (HISENSE) a été récalcitrant pour repérer le Dac et il m'a fallut plusieurs hard-reset pour que cela fonctionne.
Patrick v.
FIIO E-STICK Battery for FiiO KA17 / QX13 The FiiO E-Stick is a portable battery designed for use with the brand's KA17 and QX13 DAC headphone amplifiers. This portable battery offers up to 5 hours of autonomy.
Robustesse ?
Ca semble intéressant associé au QX13 pour quelqu'un ne cherchant que la liaison filaire à un smartphone (si on préfère le BT il y a le BTR17). La batterie séparée c'est bien car ça permet de la remplacer facilement, mais est ce que l'attelage est robuste ? Ca semble tenir juste par l'USB et il n'y a pas d'étui prenant Dac et batterie ensemble...
Christophe P.
Bof mais est-ce une question de goût ?
J'ai acheté ce câble Mogami 3106 pour remplacer celui d'origine pour le casque AKG K-702. Je ne suis pas du tout convaincu car, en dépit d'un rodage naturel pendant de nombreuses heures, il manque toujours de relief, d'étagement et de clarté entre les instruments, j'ai gagné des basses mais au détriment des aigus (il y a une sorte de tassement). Le reste du matériel est câblé en Mogami 2549 (préampli Micromega Mygroov, ampli Myzic, y compris une vieille platine JVC L-A55 avec cellule AT-540VM... conclusion je préfère le son du câble d'origine qui a malheureusement tendance à torsader... Question de goût, d'incompatibilité de matériel, de RCA et de mini-XLR ? Merci à Audiophonics pour l'excellent service.
THIERRY C.
Balanced Regulated Phantom Power Supply Module 48V 5V +15/0/-15V This regulated phantom power module is ideal for powering a microphone at 48V DC. The module has the particularity of also providing additional outputs at 5V and 2x15V. The...
Bien complète
Si vous réalisez une table de mixage, cette alimentation dispose de toutes les tensions utiles pour la faire fonctionner.
+/- 15V pour l'audio, +5V pour de la logique de commande TTL ou microcontrôleur & +48V pour l'alim Phantom des micros électrostatique.
Lors de mes développements perso, elle me permet tester mes circuits en ayant toutes les tensions sous la main.
THIERRY C.
POUR NEUTRK CHASSIS SERIE A
Ce modèle 22mm est l'outil idéal pour percer les Neutrik Chassis type A.
Pour la série D, il faut prendre la cloche 24 mm
Eric T.
BEATECHNIK x LHY AUDIO LPS-A6 220V MK1 Linear Power Supply Module for EverSolo DMP-A6 Gen 1 The LPS-A6 linear power supply module has been specially designed to enhance the power supply stage of EverSolo DMP-A6 and DMP-A6 Master Edition network players by replacing the...
ALIMENTATION LINEAIRE POUR DMP A6
Je viens d'installer l'alimentation linéaire pour mon
Eversolo DMP A6 Master génération 1.... le résultat est immédiat !!
l'amélioration est vraiment importante. tout est plus détaillé et précis sur tout le spectre sonore. je ne comprend pas ceux qui disent le contraire... je recommande vivement. le seul bémol c'est le prix puisque au total cet appareil m'est revenu à 1600 euros alors que le génération 2 est toujours au même prix que le génération 1 avec une nouvelle alim.
j'espère que cette mise à jour place mon appareil au même niveau que la génération 2.
Tibor M.
SMSL PO100 2024 USB Interface XMOS XU316 to SPDIF Coaxial / Optical Toslink 24bit 192kHz DSD DoP64 Silver SMSL unveils its PO100 2024, a digital interface USB to SPDIF coaxial / optical Toslink. This is based on an XMOS XU316 interface and a CK-02 clock circuit, it supports up to...
This verdict comes after just few hours of listen. I will be comparing it to straight usb input on my Topping e70 velvet dac. I got the po100 connected to pc with iFis iDefender and iPurifier 3 and powered with iPower X 5v then coax to mentioned dac.
Music plays now a lot more effortless, more fluid, all instruments and especially voices are now cleaner and more present.
Definitely worth it. Peace :)
David H.
TANG BAND W8-1772 Speaker Driver Full Range 30W 8Ω 95dB Ø22.38cm Tang Bang's W8-1772 full-range driver offers extensive sound reproduction thanks to its 22.38cm-diameter diaphragm. It has a power handling capacity of 30W, a paper diaphragm...
Sav audiophonics
Petit problème à la livraison
Vraiment merci
David H.
Mariusz N.
TOPPING RC-22 Aluminum Remote Control This remote control from Topping is made of aluminum, making it robust and aesthetically pleasing. It is compatible with many of the brand's devices.
RC 22 Topping E70
Aluminium,czuć go w ręku,dobrze wykonany,dodany wkrętak do 3 wkrętów,to super bo wkrętu są bardzo .Działanie jest takie same jak pilota RC 15 czyli trzeba (celować) w Daca,ale wygląda i trzyma się go dobrze,polecam jak jesteś wymagający. Co do przesyłki,pierwsze moje zamówienie z Audiophonic i jestem zadowolony,towar zapakowany dobrze,zapewne nowy(nie po zwrocie),i szybka dostawa.Info o zakupie na e-mail ,wszystkie informacje o przesyłce dokładne,faktura itd,polecam sklep ,zamawiałem do Polski
Deeble T.
Great upgrade
Installed in a Transport Pi Digi that sits on top of an Isolator Pi III with the Pure PI PSU. RPi 3 running Gentoo Player and Diretta.
Adding the SC Pure clocks significantly improves all areas. I most noticed vocals, it removes that digital taint.
When I first got my Sennheiser 800S I really didn't enjoy them. After 'fixing' the digital transport I love them.
