Carlos Alberto Rodrigues T.
Awesome piece of equipment
Tobie H.
Richard H.
Dawn Pro by Moondrop
Angelo F.
SHANLING CR60 CD Player Ripper Sanyo HD850 Silver With its CR60, Shanling unveils a relatively compact, space-saving Audio CD player/ripper. The CR60 is based on a Sanyo HD850 laser head and a Philips drive mechanism for smooth...
ifi Audio iPOWER Adaptateur secteur / Alimentation Audio faible bruit 9V 2A
Dear Sir I received the Shanling CR60 today and I thank you.May I use the Ifi Audio iPOWER Adaptateur secteur / Alimentation Audio faible bruit 9V 2A (bought from you in 2018)togheter with the Shanling CR60?
Hi,yes the device can support 9V input
Frederic D.
DD BC30XLR XLR Interconnect Cables Stereo Silver OCC Copper Gold Plated 75cm (Pair) DD HiFi's BC30XLR is a 3-pin XLR to 3-pin XLR cable that can be used for all your balanced output connections, such as, for example, a DAC to an amplifier or active drivers. The...
Comme j'aime
Entre mon Eversolo DMP-A8 et mes Topping B200; laissent tout passé, tout! Transparents! Insensibles aux interférences! Parfaits! Pas la peine de payer plus cher selon moi. Merci
Frederic D.
TOPPING Dual Trigger Cable 12V Jack 3.5mm Male to 2x Jack 3.5mm Male for Mono Amplifier 2m This Topping cable is a double trigger cable, specifically designed for use with the brand's B100/B200 mono amplifiers. It consists of a 3.5mm stereo jack connector to 2 3.5mm...
Fait le job! Dommage qu'il n'y ait pas d'autres longueurs, 1m, 0.75m, etc...
Frederic D.
Super efficaces
Permet à mon système de mieux s'exprimer notamment dans les aigus. Rapport qualité prix imbattable
Frederic D.
TOPPING B200 Power Amplifier Mono Discrete 200W 4 Ohm Black The Topping B200 power amplifier is a mono amplifier based on a discrete-component NFCA amplifier circuit. This enables it to achieve a considerable power level while...
Toppingssime
En remplacement de mon excellent Rotel A11 Tribute Edition, ces 2 blocs mono me permettent logiquement de gagner énormément niveau scène sonore mais également sur tous les plans et singulièrement les hautes fréquences, les détails.... C'est mon dernier achat en matière d'ampli; j'ai trouvé! Vraiment sublimes avec mon Eversolo DMP-A8 et mes enceintes Revival Atalante 3.... Il ne me reste que le caisson de basse à faire évoluer. Merci
Dominique D.
FX-AUDIO DAC-SQ6 DAC Headphone Amplifier ES9038Q2M SA9227 32bit 768kHz DSD256 The FX-Audio SQ6 is an affordable DAC and headphone amplifier combo. It benefits from a meticulous design and versatile connectivity for assured integration into the vast...
Très beau son mais ... très capricieux
Le son est excellent, d'une finesse inconstestable, mais,
- sur pc (prise USB), la déconnexion est fréquente, le son est alors coupé.
- sur TV, la reconnaisssance/reconnexion (Fiche Opt) utilisée n'est pas systématique. Ce qui contraint à relancer le décodeur pour avoir le son sur l'ampli (alors que la TV est bien réglée en PCM). La bascule en "Opt" via le commutateur du DAC ne suffit pas toujours. Dommage.
Il est vraiment très très petit et fourni sans alimentation (juste un cable usb)
Alors que sur mon Dacmagic100 de Cambridge, la reconnaissance se fait toujours sans problème sur l'un comme sur l'autre.
Essai CD Ripper
Après le Transport CD je l'ai essayé pour ripper de CD
Aucun problème il fonctionne parfaitement
Très satisfait de ce produit
AUDIOPHONICS JDC-125 Power supply cable Jack DC 2.5mm to DC 2.5mm 1m This cable has been assembled by us in the Audiophonics workshops to allow you to enjoy the quality of the Elecaudio range at a lower cost. The choice of materials has been...
fais le job
KECES P6 Ultra Low Noise Regulated Linear Power Supply 5V / 7V / 9V / 12V + 12V / 15V / 19V / 24V 6A The Keces P6 is a high quality regulated linear power supply that will provide your high-fidelity audio system with a clean electrical signal. The power supply offers a careful...
Trois fois 5*
Voila mon chalenge ; alimenter ces trois éléments:
1 préampli phono MOON 110 en 24V
2 switch CHORD en 5V
3 LIVEBOX ORANGE en 12v
Le gain sur ces trois éléments est au delà de mes espérances et ce sur tour les paramètres sonores.
En plus c'est très rentable comparé a l'achat de trois alim de qualités similaires (SBOOSTER).
Le câble SECTEUR est un RAAM AMADEUS 5 avec prise secteur VIBORG OR (je suis fan de ce câble).
Julien L.
DAYTON AUDIO EPIQUE E150HE-44 Speaker Driver Subwoofer DVC MMAG Carbon Fiber 200W 8 Ohm 83dB 30Hz - 4000Hz Ø14cm Combining excellent performance with a reasonable price, the Epique E150HE-44 Carbon Fiber Diaphragm subwoofer sets a new standard for versatility, distortion and response for...
Subwoofer epique 5"
Produit envoyé très rapidement et bien emballé.
Toujours un plaisir d'acheter sur audiophonics.
SHANLING ME600 In-Ear Monitors Dynamic IEM 16 Ohm 100dB 12Hz-40kHz With its ME600, Shanling unveils dynamic in-ear monitors featuring no less than 5 diaphragms per earhone. Their 16-ohm impedance and 100±3dB sensitivity make them easy to drive.
SHANLING ME600
SHANLING ME600 - you will receive a nicely made box, after opening the headphones are placed in foam padding, there is also a large number of ear reductions, a cable with a 4.4mm jack connector in a nice case, there are also sound filters. After connecting to the Cayin N3 Ultra player, which has a classic tube sound mode, the sound pleasantly surprised me, the headphones are sufficiently dynamic, from low frequencies to the highest tones. The power is more than sufficient, the headphones are very precisely made, the cable is pleasantly flexible. Even after prolonged listening, the headphones fit well, they are not tiring. For the price, a good choice.
Clement L.
SOMMERCABLE MERIDIAN SP215 FG Speaker Cable OFC Copper Shielded 2x1.5mm² Ø 8mm This Sommercable Meridian SP215 FG speaker cable offers excellent performance in terms of conductivity. It features OFC copper conductors and triple shielding in aluminum foil...
Uniquement pour installation
Gaine peu esthétique, très rigide.
Alain R.
Outil indispensable du DIYeur
J'ai plusieurs tailles de ces cloches de découpe, elles sont géniales.
Je découpe aussi bien l'acier, l'aluminium que le bois.
Il faut tourner à la bonne vitesse, ni trop vite, ni trop lentement.
Dans l'acier et l'alu, un peu de lubrification améliore grandement la coupe. Cette cloche de 50mm fera un trou à l'arrière d'une enceinte bibliothèque pour un évent de 50 mm ext.
Jean-Luc L.
Le nivarna
J’ai mis longtemps pour me décider, tellement de choix, les prix. Et à force de lire tous ces retours positifs sur ce dac, j’ai donc passé le cap.
Il a aujourd’hui 150 heures de fonctionnement et c’est une merveille, chaque écoute est une douceur musicale dans le bons sens de terme, une richesse et un respect des timbres, faut il encore avoir les éléments l’entourant qui soient à la hauteur de ce monstre d’efficacité.
Je ne peux que conseiller ce dac .
Bertrand V.
Petit DAP au son étonnant pour son prix !
Si vous voulez du son de qualité (à mes oreilles) au meilleur prix et que vous n’êtes pas rebuté par une interface rudimentaire et quelques bizarreries (classement des fichiers et parfois des titres dans les fichiers), ce DAP devrait vous satisfaire.
Son utilisation est très intuitive, les commandes se trouve facilement à l’aveugle (DAP dans la poche) et il semble plutôt solide.
Il est léger et discret, bref en nomade il est parfait pour moi.
Un conseil : télécharger le dernier firmware : https://xduoo.net/firmware-download/
Yves B.
attention à la petite gaine transparente fournie
la petite gaine transparente fournie avec la fiche jack et son capot vissable n'est pas de la gaine thermorétractable comme on aurait pu s'y attendre. Donc inutile de chauffer dessus pour enserrer vos connexion avant de visser le capot. Vous ne réussirez qu'à la ratatiner! Tout le reste est sans reproche. Bonne soudabilité, bons contacts
Christophe M.
Moyen
J'ai ce câble depuis longtemps et je n'ai pas plus l'utiliser en raison du poids des connecteurs qui sont très lourds, beaucoup trop lourds. Ils viennent faire travailler dangeureusement les prises USB des machines sur lesquelles le câble est branché...
Patrick v.
Great machine.
I ordered the CR60 to pair it with my Auralic Aries G1 to listen to and upsample my CD collection. In "ripper" mode the CR60 was immediately recognized via a USB cable and I can now upsample my CD collection to 352.8k without any problems. Together with a 12V linear power supply this is a perfect combination. And what a sound quality! Thanks Audiophonics for the fast delivery and service.
Chafi M.
DD TC35M2 Adapter DAC Headphone Amplifier USB-C Male to Jack 3.5mm Female 32bit 384kHz The TC35M2 from ddHiFi is a portable DAC and amplifier for headphones. The latter is equipped with an ESS ES9603Q amplifier chip, delivering 2x45mW of power at 32 Ohm, capable...
DDTC35M2 adaptateur dac
Bien reçu mon produit commandé vendredi 15/11, reçu en colissimo jeudi 21/11/24, bravo.
J'ai acheté cet adaptateur pour mon smartphone, associé à ma plate-formeTidal et mon casque beyerdynamic DT 770 Pro X édition limitée, il fait super bien le job, la qualité de son est sublime mon casque fait 48 ohms. Je vous le conseille.
Cdt.
Johannes g.
BURSON AUDIO V7 CLASSIC PRO Dual OPA (Unit) As an evolution of the V6 Classic, the V7 Classic Pro now achieves ultra-low noise levels while retaining the sparkling highs that are the strength of its predecessor. Overall,...
Rien à dire !!!
ou plutôt si, tout bonnement excellent, en tout point.
détails, dynamique, scène sonore, tout est là mais en mieux.
Comparé à un double op Muzgaudio, qui est trés bien lui aussi, dans un préamp/ampli casque DIY (Whammy), mais que le burson surpasse totalement.
Donc en résumé je suis ravis de cet achat et ce n'est pas un avis sur un coup de tête ça fait 2 mois que je l'écoute.
Carlos N.
JANTZEN AUDIO C-COIL 000-6305 4N Copper Toroidal Coil 12AWG Ø2mm 5.6mH 0.07 Ohm Jantzen Audio's C-Coil Toroidal Coils have very low electric resistance and excellent heat tolerance. They can thus withstand high power without overheat-induced distorsion....
S'est du très lourd
Bonjour, j'ai acheté cette bobine pour modifier le filtre de mes Elipson Prestige 4i, j'avais déjà auparavant changé tous les condensateurs par des modèles allemand haut de gamme et il me restait à changer la self de grave. Grosse claque auditive, des graves propres avec un sous grave de toute beauté. Même la région médium et aigu est changé avec une transparence hors norme. 950 gr s'est du très lourd pour 5,6 mH mais plus aucune sensation de saturation. Je recommande fortement et en plus la résistance interne est très très faible. Mon ampli à triode 845 apprécie.
Francois W.
FX-AUDIO 502E-L Class D Amplifier CS8673E Bluetooth 5.0 2x65W 4 Ohm Silver The FX-Audio 502E-L offers an efficient, compact and low-cost amplification solution. Taking advantage of a high-efficiency Class D architecture, its amplifier stage uses a...
Excellent ampli
J'ai ajouté cet ampli FX audio associé avec mes Bose acoustimass 5 série 3, le son est nickel, dynamique, pas agressivite pour un ampli classe d, je trouve le bouton de réglage du volume un peu juste au niveau puissance presque aux max mais dans ensemble c'est très bien et hyper correct vu son prix, franchement rien à dire
Christian C.
le couteau suisse
Cet appareil m'avait été recommandé par un ami suite à un problème avec ma carte son. Cet appareil est très simple d'utilisation. Je m'en sers pour les mesures d'impédance et des paramètres T&S des haut-parleurs et il s'avère extrêmement efficace et d'une excellente précision. Je m'en sert aussi pour la mesure des self et des condensateurs avec une grande facilité et il me donne des résultats de mesures complets avec tous les paramètres associés (RSE, facteur de qualité...). Le logiciel gratuit à télécharger est très complet et pratique.
Jean-Michel j.
TRES BON TUBES
Monté a la place des Electro-harmonix sur le JADIS JA 200 avec les psavanes enECC82 (car je n'ai pas trouvé de ECC82 mulard sur le site),formidables différence des la mise en route aigu,medium et basse avec beaucoup plus de détail et de clarté.Livraison rapide merci Audiophonics
Jean-Michel j.
trés bon tubes
Monté sur le jadis JA200 a la place des elctro-harmonix avec des mulard pour les ECC83.dés la mise en route formidable différence avec beaucoup plus de détail dans les aigus et les basses.Livraison rapide.Merci aidiophonics
Jean-Michel j.
TRES BON CABLE
Monte avec des fiche XANGSANE XS-T1061,très bon câble vraiment pas cher,Aucune différence avec mes câble kimber heros 10 fois plus cher livraison rapide.Merci audiophonics
Jean-Michel j.
TRES BON CONNECTEURS
Monté avec du câble CANARE L-4E6S STAR QUAD,rajout de scotch autour de la gaine pour compenser le diamètre du câble et pouvoir le fixé dans le connecteur,très bonne qualité,reçu rapidement.Merci audiophonics
Pascal L.
TOPPING MX5 Amplifier Merus Class D NFCA XMOS Bluetooth aptX HD 2x55W 4Ω 32bit 384kHz DSD256 Silver The Topping MX5 is a combo amplifier and headphone amplifier with integrated DAC ESS ES9018. Particularly versatile and powerful, it benefits from a Bluetooth reception thanks...
Belle petite machine.
Après un peu plus d'un an de service, aucun souci, ampli suffisamment puissant avec des enceintes de rendement moyen et une pièce d'écoute de 20m2, belle surprise pour mon premier ampli classe D.
Stephane N.
Branché en lieu et place de l’entrée usb sur un Audio GD nfb 3, le son est excellent, beaucoup de détails.
Convient très bien à des câbles résolutifs, Nordost heimdall pour ma part.
Très satisfait de cet achat.
Stéphane
Didier T.
Un très grand cru !
Intercalé entre ma Box et mon Node 2i, de dernier injecte son stream dans un Nuprime Dac 9SE amplifié par un bloc stéréo Nuprime STA 9X (le tout alimenté via un Bada 6610, box incluse).
Sans véritablement m'attendre à quoi que ce soit de particulier, sa mise en service m'apporte un énorme supplément d'humanité assorti de textures fluides, chaleureusement liquides et "fouillées" dans le très bon sens du terme.
A l'opposé des câbles qui exhibent des détails "en veux-tu en voilà pour faire high-end", celui-ci le fait avec un raffinement de grande classe.
Les messages musicaux deviennent "palpables" et sont délestés de leurs côtés "intellectuels".
Bref, un apport spectaculaire au rapport Q/P inversement proportionnel à son "pouvoir musical" !
Un coup de maître !
Didier
Christoph S.
AUDIOPHONICS HPA-DM500NIL Power Amplifier Class D Dual Mono Nilai500DIY 2x500W 4 Ohm Hand-assembled in our workshop in France, the Audiophonics HPA-DM500NIL power amplifier is a high-performance Class D dual-mono model, based on the new Hypex Nilai500DIY...
Surprisingly good
Drives my loudspeakers with ease and precision. Better than expected experience.
Alessandro C.
IAN CANADA PUREPI II Ultracapacitor / Batteries Dual Power Supply Module for Raspberry Pi 5V / 3.3V Ian Canada's PurePi is a compact audiophile power supply module specifically designed for Raspberry Pi based systems to improve sound quality. The PurePi integrates a 5V...
IAN CANADA PUREPI
Incredible power system for Raspberry PI and for ES9038 + FIFO Q7 II. Allows you to obtain a very clean power supply. Great work at a low cost. I am very satisfied
Alessandro C.
IAN CANADA SHIELDPI PRO Multifunction Board EMI Shielding / Power Supply Filter for Raspberry Pi Ian Canada's ShieldPi Pro is not only a universal EMI shielding module for Raspberry Pi, but also a high performance power supply filter, ON/OFF control button and GPIO...
IAN CANADA SHIELD PRO
It works very well and is certainly a clear improvement of the power supply of the raspberry PI as well as being an excellent shield for EMI. I am very satisfied.
Alessandro Catalano
Alessandro C.
IAN CANADA TRANSFORMER I/V Passive I/V Stage Module The Ian Canada Transformer I/V is an I/V transformer module operating in purely passive mode, without any feedback or active components. It doesn't even need a power supply....
Great Audio stage that allows you to play digital music with the sweetness of analog. I am very satisfied
Alessandro C.
IAN CANADA FIFOPI Q7 II FIFO Reclocker Module I2S DSD DoP Syncrhonous The Ian Canada FifoPi Q7 is the new flagship in the FifoPi family of reclockers. It achieves the best performance in terms of jitter and noise by using a number of...
Developed and built at very high levels that allows the DAC ES9038 DUAL Mono II to express itself even better allowing you to reproduce the musical message in an excellent way. Very very satisfied.
Alessandro Catalano
Alessandro C.
IAN CANADA MONITORPI PRO Control Center and Signal Analyzer with Display for Raspberry Pi Ian Canada's MonitorPi Pro is a powerful integrated control center and universal OLED display for all types of Raspberry Pi-based audio applications. To install the MonitorPi...
A real control center very well made and easy to use. I am really satisfied
Alessandro Catalano
Alessandro C.
IAN CANADA DUAL MONO MKII DAC ES9038Q2M HAT Raspberry Pi / I2S & SPDIF / PCM DSD Ian Canada 9038Q2M dual mono DAC HAT is a very high level of DAC for Raspberry Pi. It uses two chips ES9038Q2M SABRE 32-bit each working in mono.
IAN CANADA DUAL MONO MK II ES9038Q2M
Developed and built at really high levels that allows you to process digital audio at the highest levels. I am really satisfied.Dac Studied and built at really high levels that allows you to process digital audio at the highest levels. I am really satisfied.
Alessandro Catalano
Didier T.
Excellente surprise... si on lui donne le temps de s'épanouir !
2 mètres de CS-361B exploités en entrée d'un BADA 6610 alimentant ma box, mon Node 2i (via carte PD Creativ + bloc Shanti) et mes Nuprimes Dac 9X & STA 9X).
Ce CS-361B est très déconcertant pour ne pas dire décevant durant les premiers instants, contribuant à une courbe de réponse "en cloche", très centrée "medium" avec un effet bouché et sans vie aux deux extrémités.
M'appuyant sur les précédents avis, et s'il commence à se réveiller entre 40 et 50 heures, j'ai laissé sous tension l'ensemble des maillons durant près de 100 heures (non sans streamer en boucle) avant d'envisager avis "sérieux".
Arrivé à ce terme, le résultat est fait d'ouverture, fluidité aération sans aucune dureté : c'est très convainquant !
Au-delà de sa très belle texture sur les voix (déjà mentionnée par ailleurs), mais pas que, je lui trouve surtout dans mon cas une homogénéité, pour ne pas dire une intégrité tonale sur l'ensemble du spectre : je constate qu'aucun segment du spectre particulier n'est favorisé au détriment d'un autre.
Guitariste possédant mon propre studio avec plusieurs (jolies) guitares (et leurs amplis), batterie et clavier, mes tympans m'invitent à rendre à ce câble secteur ce qui lui revient, c'est à dire sa capacité à éclairer (étirer ?) la restitution sans écraser la dynamique.
Au contraire, je trouve qu'il contribue très probablement à faire vivre les micro-détails avec subtilité sans rien dénaturer.
De telle sorte qu'il me donne la sensation d'être sinon immergé au milieu des musiciens, du moins au premier rang du concert en pouvant savourer l'effet tri-dimentionnel du spectacle musical proposé.
Surtout, il ne me donne pas envie de découper les décibels en quatre sur "mon aigue ceci, mon medium cela et mon grave machin" : cet ELECAUDIO CS-361B me donne tout simplement l'effet de contribuer à faire passer la musique avec sincérité.
Et, oui, comme le bon vin, il faut lui donner sa chance sans "sur-réagir" dès les première minutes...
Pour conclure concernant sa construction, je lui trouve bcp d'atouts techniques et sa mise en oeuvre, si elle demande un minimum de rigueur et de précaution, ne présente aucune difficulté.
Enfin, sa relative souplesse (ou raideur, c'est selon), ne pose pas de difficulté particulière dans son ergonomie.
Didier
Thierry L.
RK
Le meilleur câble que j'ai trouvé pour faire une installation audiophile à partir du disjoncteur. Facile à travailler dans les murs (3.3mm2) avec une très bonne qualité de cuivre. La qualité du blindage assure un excellent silence de fonctionnement des appareils. A recommander ***
Jean-François B.
Que dire de plus, ce produit est excellent et de très haute qualité. Installation facile et utilisation ultra simple. Bravo !
Philippe H.
AUDIOPHONICS OBSIDIAN Interconnect Cable RCA-RCA Pure Silver 0.75m (Pair) Optimal audio signal transmission without any defects is what we offer you with the Audiophonics Obsidian premium RCA interconnect cable. Its pure silver conductors and...
Une ouverture remarquable …
J'ai attendu 10 jours de rodage quotidien pour partager cet avis ; je suis allé vers le "tout argent" à reculons, sur la seule confiance en M Aubert. Et j'en suis juste ravi ! Comme prévu, ce câble est bien du côté "ouverture / rapidité / détail", mais sans aucune dureté comme je craignais, au contraire : je trouve que le gain très conséquent en définition se fait sur toutes les fréquences, dans une forme de plénitude inattendue, avec un étagement des plans superbe … Et le plus étonnant, c'est dans la zone haut-médium : ce qui fâche régulièrement, les chuintantes des voix ("s", "ch"), le violon ou le saxo alto passent avec une aisance rare. L'impression subjective est que la rapidité est non seulement dans l'attaque mais aussi (surtout ?) dans l'extinction de note, comme si l'énergie était bien là, mais sans surcharger la reproduction … Aspect peu évoqué concernant les câbles argent, le grave est impressionnant, en clarté et impact (réglage du sub à refaire !). Bref, je suis conquis par ce câble, dont le rapport qualité/prix frise l'insolence. Merci M Aubert pour votre clairvoyance
Tres bien
Colis reçu rapidement
Premières impressions très bonnes
Pour l'instant je ne m'en sert que comme transport est c'est nickel.
Impression d'un appareil aboutit et de très belle esthétique
Pour accéder a un transport CD a ce prix est a conseiller.
Stéphane V.
Après une longue période de rodage, la justesse, la spontanéité de cet appareil impressionnent. La scène est bien plus large qu’avec les autres amplis casques essayés ou conservés (même bien plus chers). Il n’y a pas de duretés, les placements sont aisés à repérer, les timbres sont expressifs et posés. Cela aide beaucoup pour la composition musicale. Il aide aussi à bien choisir l’ampli opérationnel du Dac, quand c’est possible. Cet ampli casque a été livré avec des OPA 2604 (après réassortiment) plutôt que les Muses 8920 annoncés : mieux ou moins bien, je ne sais pas, en tous cas c’est très beau.
Je continuerai à demander conseil à l’équipe d'Audiophonics pour d’éventuels compléments ; d’autres amplis opérationnels ou d’autres câbles.
Le Dac et l’ampli sont reliés avec un câble symétrique Canard, TRS 6,35 M vers XLR M. La sortie est reliée au casque pour l’instant avec un câble asymétrique Syrnarn.
Je tiens à dire que le produit ne me gène pas sur le plan de la radiosensibilité : ce qui est une aubaine. Merci !
François M.
TOPPING D50 III DAC 2x ES9039Q2M XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD512 Silver Topping's new D50 III desktop DAC has been updated to deliver even better performance than its predecessors. It now features two ES9039Q2M DAC chips and an XMOS XU-316 USB...
RQP exceptionnel
La qualité des dacs ne cesse de s'améliorer.
Utilisé sur ses sorties symétriques(meilleures que les asymétriques) il a remplacé avantageusement mon "vieux" Bel Canto 3.7 et tout ça pour 229 €. L'écoute avec une excellente alimentation à découpage MONACOR est remarquable.
Seule contrainte en symétrique, il faut se confectionner un câble Jack 6.35 vers RCA ou XLR. A moindre frais avec du canare L-4E6S on peut se fabriquer un très bon câble de modulation.
J'avais envisagé dans un premier temps le modèle D90 III mais il est 5 fois plus cher.
Seules différences majeures avec le d50, une alimentation faisant partie du produit et donc non remplaçable, le MQA et des sorties symétriques en XLR au lieu des jacks. Mais rien de plus musicalement parlant je pense.
claude D.
AUDIOPHONICS HPA-H250NC Power Amplifier 6 Channels Class D Ncore NC252MP 6x250W 4 Ohm The Audiophonics HPA-H250NC is a 6-channel Class D power amplifier based on three Hypex NCore NC252MP modules. This version is aimed in particular at audiophiles and home...
Ampli class D
j'ai attendu un moment pour donner mon avis.
Ce qui ne va pas : à quoi sert l'inter M/A l'appareil est toujours sous tension sifflement dans les tweeters dès la coupure du bouton M/A , j'ai été obligé de mettre une barrette avec inter M/A
A par ça le son de cet appareil est magnifique un pur régal pour moi le meilleur amplificateur que j'ai eu jusqu'à présent et j'en ai eu beaucoup classe AB, classe A et tubes mais jamais de class D.
j'écoute de la musique maintemant je me pose plus de questions
claude D.
SILKLINE ZUKI I Balanced preamplifier / DAC 32bit / 192kHz USB XMOS Silkline's Zuki I combines the functions of preamplifier and DAC . The preamplifier function has a balanced and unbalanced output and a v oltage gain of 12dB ....
Préampli
Très surpris par ce préampli convertisseur avec un très bon son
Acheté pour un second systeme, mais branché sur mon installation principale à haut rendement juste pour voir, aucun bruit très beau mariage avec mon ampli NCORE 6 canaux en amplification active à haut rendement
Incroyable à ce prix. Merci AUDIOPHONICS pour trouver des produits de cette qualité et toujours aussi rapide pour l'expédition et le suremballage.
Ravis de mon achat
Krešimir F.
MOONDROP MOCA Dynamic True Wireless In-Ear Monitor IEM 20Hz-20kHz Grey With the Moca, Moondrop offers us wireless in-ear monitors equipped with a dynamic 10mm driver with a ceramic and titanium nitride membrane, ensuring a sound experience that is...
Very solid sound and build quality
It's probably the best buy in this price category. It has very clear and transparent sound and solid build qualility.
Fast and reliable order processing and shipping.
Aleksandar C.
Fantastic headphones
I can safely say that these headphones will gain cult status. Great sound, the bass is excellent, which I like the most. From the equipment you get with the headphones themselves to the quality of construction and comfort. For this money, you can't do better. You even get a lot more. All recommendations for this model.
And of course I would like to thank the people from Audiophonics, for the quick realization and sending of the product.
Le magicien !
Pfuuuu, c'est raffiné, spatial, chaud, la musique coule sans stress, la trompette de Clark Terry est dans mon salon comme jamais ...et pourtant monté avec de simples Amphenol. C'est une belle découverte pour moi qui connaissais déjà et appréciais le 3004 et le nemoi 3220. Tout est remis en question...Et merci Audiophonics pour toutes ces pépites que vous proposez. Un audiophile connecté.
Raymond L.
Hub USB 2.0 OTG Micro USB USB-A This USB hub has a total of 4 ports: 2 female USB-A connectors and 2 female Micro USB connectors. The interface is via a male Micro USB connector, ideal for connection to a...
Erreur de Cde
Sans doute bien mais je me suis trompé dans le modèle. Il me fallait le hub normal a 4 branchements. R.L.
