Gerrit G.
Very good DAC , BUT .....!
The USB A to C cable that comes with it is only good for powering the davice , not for data transfer . If used for data ,...
Antonio C.
It’s a no brainer.
Tibor H.
Customers reviews - There are 19038 reviews.
JEROME J.
FOSI AUDIO MC101 Stereo Amplifier 2x TPA3116 Bluetooth 5.3 2x100W 4 ohm With its MC101 stereo amplifier, Fosi Audio unveils a small device at the crossroads of vintage and modernism. The MC101 features Bluetooth functionality, as well as a...
Musical mais...
Du souffle léger et chuintement dans les hauts parleurs avant de lancer musique, mal isolé pour éviter parasitages vers enceintes, a revoir.
Simon S.
Incredible value for money
I normally never write a review but i feel inclined to do so for this product.
I have high sensitivity speakers (Blumenhofer) and thought that only a SET tube amplifier would be a good match, i was wrong.
My 300b died on me and having already put so much money in tubes i thought, time to try something different.
So after consideration and reading on audio science review forum about what makes an amplifier truly good, i choose this amplifier as in blind testing most people couldn’t hear a difference between Ncore and Purify (more expensive) and also between other even much more expensive amplifiers.
So i chose the smallest Ncore as my speakers are very easy to drive.
Listening:
The lower end is much cleaner and more controlled than my 300b was.
Midrange is fine, it hasn’t got the romantic touch of 300b tube but in it’s own right it doesn’t sound worse, just a bit different.
Highs, for class d, where in the past this just wasn’t very good, with Ncore i hear no problems whatsoever.
It just sounds great, and i dare say, for this price INCREDIBLE.
Hats off to Hypex and the original designer Bruno Putzey for making such a great inexpensive amplifier.
In my middle end to high end system it’s no slough.
Highly recommended, if your speakers need more juice, than the NC400 is better i guess.
Patrick d.
Great quality Speaker Cable
This is absolutely great cable for the money
La fin... Excellent rapport qualité prix !
Mauvaises manip clavier qui valident illico le message en cours de rédaction...
Remplacement des AOP NE5532 d’origine par des Burson V5i, puis des OP275 en enfin des oracles II.
Avec ces trois AOP on a enfin des voix timbrées et incarnées, des aigus variés avec du poids et de la matière, des cuivres rutilants, des instruments à corde en vrai bois d'arbre et non en plastique et toujours une bonne dynamique. Disparues les sifflantes et petites duretés/raideurs, c'est nettement plus expressif que les NE5532 qui sonnent un peu secs et monochromes en comparaison.
L'image sonore est globalement mieux remplie avec une largeur correcte, là où elle reste un peu coincée dans les HP avec les AOP d’origine. Avec une préférence envers l'OP275 par rapport au Burson V5i qui est moins homogène.
L'Oracle après 24 heures de fonctionnement non stop est le plus homogène des trois, avec de beaux timbres, un bon équilibre, pas de sifflantes ou dureté, une dynamique bien répartie, Bref un bon niveau de transparence qui rend hommage aux enregistrements. L'image sonore est large avec une bonne profondeur, du relief et les ambiances de prise de son son palpables. Un peu faible en niveau dans l’infra (via la sortie sub).
Bref on peut modifier de façon substantielle le rendu du Fois BT20a Pro en changeant d'AOP. Selon les enceintes associées, on peut arriver à un haut niveau de qualité globale, sans frustration comparé à de nombreux ampli plus classiques et pas ridicule face à mon SE 845 DIY, qui va certes plus loin en tout mais à quel prix.
La qualité en Bluetooth est moyenne, graves écourtés et aigus proéminents à atténuer sur l'ampli.
suite
Bref l'alim à découpage d'origine n'est pas silencieuse sur des enceintes à haut rendement et l'ampli souffle un peu.
Le niveau de la sortie sub est un poil faible en niveau mais ça passe.
Au niveau écoute au bout de quelques jours de fonctionnement, c'est assez surprenant pour une si petite boite et en regard du prix. C'est propre, dynamique, droit, très détaillé, mais un peu sec et monocorde, avec des sybillances et un aigu qui manque de poids et de texture.
L'image sonore correcte mais qui reste un peu coincée dans les HP et ça m
J'ai branché le petit BT20a Pro et son alim 32V/5A à la place de mon SE 845, sur pavillons mid bass + compression qui reproduisent les fréquences entre 150 H et 20 000 Hz, avec 103/105db d'efficacité.
La sortie sub du Fosi alimente un Crown avec deux 15".
À l'allumage, on entend pendant quelques secondes un petit sifflement qui disparait. À 1,5 mètre EN ENVIRONNEMENT TRÈS CALME, on entend le souffle dans la compression là où mon SE 845 est parfaitement silencieux même à 5 cm.
On proximité du pavillon, on entend faiblement le tiktiktiktik de l'alim à découpage.
Rien de gênant à la position d'écoute, mais l'a
Benjamin B.
Very good, high resolution, high end cable.
Very good! Makes a difference. Price justified. But you have to know: It brings out the highs! If your system is already a bit too bright this cable might not be for you. Tried it with my Hegel amp and my tube amp. Crisp, Clear, Good Resolution, Dynamic. With my Hegel amp the sound becomes a bit too bright but with my el-34 tube amp it makes a crisp dynamic resolving sound. Maybe the base gets a bit less with this cable but the base will be less boomy but accurate and more tight. I think this cable is mostly about resolution in all frequency ranges. Very good I think!
nicolas s.
Le AIYIMA D03 est un très bon amplificateur classe D. Etant mon 4ème, celui-ci est le plus naturel et dynamique. Excellent, même à volume très élevé... Je l'utilise dans 25m2 sur un woofer SBAcoustics + tweeter à ruban + sub. La sortie sub passive est bonne, la sortie USB est largement supérieure à la sortie RCA. Je n'ai pas testé la Coaxiale ni l'Optique.
Comme il est dit dans un autre commentaire et sur certains forums anglo-saxons les basses sont fermes et profondes.
Une précision quand même, en le branchant la 1ère fois je me suis aperçu que les basses étaient poussées à +14db. Le S.A.V d'Audiophonics m'a fait savoir qu'il peut y avoir des modèles dont les réglages ne sont pas remis à zéro suite au contrôle qualité, donc à vérifier si vous évaluez votre D3 au premier branchement.
Bernard D.
Un best-seller
Sans surprise, un excellent produit. La définition aussi bien dans le spectre haut que bas est excellente. La puce AKM du Dac n'est certainement pas étrangère à cet excellent résultat. Très satisfait d'autant que la livraison (vers la Belgique) fut très rapide.
Bravo Audiophonics !
Lennart H.
Audiophonics u-sabre pro dac usb
Super Perfekt
Dace P.
Visuell fiasko
Le son est bon. En revanche, la finition est misérable. Les coutures sont tordues et inesthétiques. J'ai une photo, mais comment la télécharger ? En raison de la mauvaise finition, je ne recommande pas l'achat.
Hugues D.
J'avais pour projet la recherche d'un "petit" ampli mono afin de driver une Triangle Secret LCR7, enceinte encastrable pour en faire une enceinte centrale.
En effet étant mélomane et cinéphile, je me voyais mal passé d'un ampli stéréo à un ampli full home cinéma. Ayant en front une paire de JBL 4312 MK2 et en back des Klipsch RP 600 M, un caisson Klipsch R-115SW le tout relié à un Yamaha RN 803 D, il me manquait pour une meilleure lisibilitée des paroles dans les films une centrale.
Mon choix c'est porté après plusieurs jours de recherche sur la SABAJ A20 qui semblait répondre à mes exigences et je ne suis pas déçu ! Relié en rca Out,
Le son est surprenant de clarté et de puissance ! Vraiment très plaisant à l'écoute en plus du boîtier en alu assez classe, élément important.
Merci à Audiophonics pour les informations claires et détaillées, l'envoi super rapide ! Je recommande !
Anthony M.
Libreelec
C'est le module qui manquait a mon raspberry pour le brancher à mon ampli Yamaha qui ne dispose pas de hdmi mais que d'une simple prise optique toslink.
Pour la configuration de Libre Elec il faut juste configurer le fichier config.txt avec l'overlay suivant (je le précise car je me suis fait avoir car la doc de hifiberry c'est pour un digi pas pro, du coup j'avais le son qui micro coupait toutes les 3s et en léger décalage)
dtoverlay=hifiberry-digi-pro
Mladen K.
ALPS
Very satisfied. Good price, fast shipment.
Excellent pre phono a conseiller
Pour celui qui ne veut pas de prise de tête pour choisir un prérempli phono, celui-ci est parfait pour un système plus que correct.
Merci à Audiophonics pour l'envoi hyper rapide comme d'habitude.
Andrea T.
Utilisé pour alimenter un routeur Fastweb.
Je retrouve une plus grande clarté dans le son avec Qobuz.
Rien de spectaculaire mais quand même perceptible à ce prix c'est fortement recommandé.
Vasileios K.
A great dac for the money
I really love the sound and the soundstage . Very natural sound and very good baseline
PIERRE A.
TBIEN
bonne qualité . Envoi très rapide , matériel bien emballé et bien protégé pour le transport
Jacques P.
Expérience client au top
Emballage soigné , installation simple , prise en main intuitive et rapide ; c'est un produit exemplaire au niveau de son interface client et le son est au rendez vous ... Me reste plus qu'à en profiter et découvrir ou redécouvrir plein de musique!
Deividas S.
Deividas S.
Deividas S.
OYAIDE SGBN Banana Plugs Silver / 24 Gold Plated Ø4mm (Set x4) The Oyaide SGBN are high quality banana plugs for high performance speaker cables. They are double plated with silver and 24k gold to ensure perfect signal transmission. In...
Super quality
LAURENT G.
Au bout de 4 mois d'utilisation
Les premières impressions positives se confirment. La transparence de la restitution et la séparation des canaux sont tout à fait remarquables. Les réglages de gains possibles 0, 6 ou 12 dB permettent une grande souplesse d'utilisation en fonction de la nature des sources et/ou des enregistrements. L'association avec un HPA-S 400ET forme un duo dont les performances sonores sont cohérentes avec les mesures et essais techniques que l'on peut trouver sur internet. Cependant, il ne faut pas s'attendre à une restitution systématiquement somptueuse ou flatteuse : les enregistrements sont reproduits sans fard. Les timbres peuvent perdre le charme que peut présenter un ampli à tubes (je le sais pour en avoir un). Mais le gain en terme de précision de la restitution est si flagrant qu'il est impossible de masquer les différences entre les sources numériques (en prenant le format CD comme référence) et les sources analogiques (radio ou phono). Les 30 à 40 dB de transparence supplémentaire qu'offre une source numérique ressort immédiatement.
Laurent G.
Jean-Pierre D.
Rendu très musical, fin et naturel
Je partage ce qui a été écrit précédemment, ayant le 1220 en version RCA monté par Néotech, l'ajout de connecteur argent et les XLR me semble améliorer la qualité d'écoute, c'est encore plus propre et transparent. Ce câble est étonnant, il peut se hisser à un niveau comparable des câbles haut de gamme de Cardas, Tellurium que je connais avec un tarif plus doux.
Pascal C.
bien mais...
j'ai commandé ce petit appareil pour avoir la possibilité de calmer un peu la partie médium de mon ensemble, c'est mieux en diminuant un peu les aigus mais il ne faut pas trop baisser au risque de perdre trop, un réglage pour les médium aurait été plus pertinent et j'ai vu trop tard que ça existait. concernant les lampes je n'ai pas remarqué un son plus chaud qu'avant, après un moment de chauffe par contre la scène sonore s'élargie un peu plus et c'est très bien, le rendu est plus doux. suite à ce que j'avais lu, j'ai laissé allumé une journée, résultat je ne le referai pas, je pensais qu'une fois une certaine température était atteinte l'écoute serait stabilisée ben j'ai trouvé le son encore plus agressif comme si l'appareil ne faisait plus effet, résultat je le coupe en même temps que le reste et ça va mieux. je pense que je testerai les autres tubes. j'ai fait une comparaison sur mon installation avec un autre modèle sans lampes mais avec réglage médium en plus, une catastrophe, medium utile mais même en laissant les boutons sur midi les voix étaient trop en retrait et son étouffé et en activant le bypass quelle claque, le son est redevenu vivant et les voix présentes. j'ai rebranché mon fx audio et c'est bien mieux quand même. les réglages aigus sont bien calibrés, mettre au milieu pour démarrer, le volume est bien aussi calibré pas de mauvaise surprise ( inséré entre un préampli Atoll pr200 et un ampli 3Dlab Nano ) surtout ne pas oublier l'ordre de la mise en route, à l'allumage fx audio en premier et ensuite le reste, et à la fin de l'écoute éteindre tous les appareils en premier et le fx audio en dernier sinon gros bruit dans les enceintes ( et ça fait peur ) .
Pascal C.
après en avoir testé un jeu, j'ai complété aves 8 autres pour relier petit à petit mon ensemble hifi et mon autre home cinéma. j'avais des cordons rel câble moniteur mais ceux-ci je les trouvais trop montant un petit poil agressif et fabrication un peu légère( obliger de mettre un petit coup de pince pour serrer plus sur la rca contrairement aux elecaudio , écoute moins agressive, plus de détails dans le médium et belle fabrication, fiches bien calibrées pour l'insertion dans les rca.
peu naturel ,metallique
Cable neotech cuivre argent mit sur ma play 4 ,son trop metallique ,fatiguant ,je le conseille pour l image ,pas pour le son!
Anthony C.
KECES P8 Ultra Low Noise Regulated Linear Power Supply 9 / 12V 8A + USB 5V 1A The Keces P8 is a high quality regulated linear power supply that will provide your high-fidelity audio system with a clean electrical signal. The power supply features a neat...
Génial
Cette alimentation est génial, je viens de faire un bon en avant assez important niveau qualité audio sur mon lecteur réseau Antipode S30 grâce à elle, plus de dynamique, du silence en fond, un son plus naturel franchement je ne regrette pas mon achat et c’est en rodage en plus, je recommande fortement, jeté les alimentations à découpage et à deux balles qui sont si bruyantes et qui peuvent polluer les autres appareils aux alentour
Fabien B.
Fabien B.
Fabien B.
Fabien B.
Fabien B.
Magnetic Holder for Screws and Metallic Objects Ø110mm This magnetic holder is ideal for holding screws and metal objects, so that they are held securely and are not lost. The container has a diameter of 110mm for a depth of 20mm.
Fabien B.
Fabien B.
Très bon rapport qualité prix. A quand une version coudée sur Audiophonics?
Hocine H.
Bonne qualité, mais il manque un truc.
Connecteur de très bonne qualité, le soucis c'est que les pins sont trop proches du corps du connecteur, et comme il n'est pas fournit avec une protection isolante, celui-ci peut entrer en contact avec le point chaud si votre soudire est un peu trop épaisse.
Ce qui m'est arrivé, du coup j'envoyais du 48v sur le coffret de mon alimentation et par malchance, lors d'un changement de câbles RCA, un des connecteurs RCA est venu faire contact sur l'alimentaion, résultat, alimentation grillée, et carte d'alimentation de mon DAC grillée. Ceci est de ma faute, mais je trouve dommage qu'une marque comme Viborg n'ait pas pensé à ce genre de détail. Donc n'oubliez pas d'y ajouter un petit morceau de gaine thermo pour isoler le tout.
Hocine H.
BURSON AUDIO V7 VIVID PRO Dual OPA (Unit) As an evolution of the V6 VIVID, the V7 VIVID Pro stands out for its clarity, precision and high dynamic range. It is particularly recommended for...
Magnifique
Ces Op amp sont extraordinaires de clarté, de précisions, de dynamisme, une réelle bouffée d'air frais dans la musique. C'est bien construit, solide et se plug et deplug facilement. Très bon achat, d'ailleurs j'en recommande une autre paire.
Hocine H.
Respectable
Ce petit ampli reste correct, même après une 50 aine d'heures d'écoute et alimenté en 48V 7.3A, c'est plat, sans. Je le garde en spare au cas où, mais n'en acheterai pas d'autre. Rien de comparable à un Fosi ZA3.
Michiel W.
Audiophile NAS linear power supply
I use this power supply for my audio NAS streaming to JRiver on my audio PC. The sound effect is more quiteness (as I hoped) but also a bit restriction or less freedom (which is not as I want).
Surprisingly, Spotify sound seems improved, better details and transparent low. Here the NAS does not do anything, it is Spotify running on the audio PC.
The stand-by power consumption is not specified, but it gets above 35 deg C doing nothing, so I am curious how long I am willing to pay the electricity bill.
Nicolas B.
PSVANE EL84 HiFi Series Tubes (Matched Pair) The PSVane EL84 is a high-performance preamplifier/amplifier tube. These tubes are part of the brand's classic standard range, and provide excellent musicality....
A essayer...
Montées dans un ampli guitare bugera v22. Même pas 3h d'utilisation et c'est déjà très très bon. Très beau grain.
Toni S.
BEATECHNIK x LHY AUDIO LPS-A6 220V Linear Power Supply Module for EverSolo DMP-A6 The LPS-A6 linear power supply module has been specially designed to enhance the power supply stage of EverSolo DMP-A6 and DMP-A6 Master Edition network players by replacing the...
Tres bon
The better power supply raised the sound quality of the eversolo
DMP -A6 ME really a lot. I am happy that I bought it. The service was also good.
quel naturel!!!!!!
Bonjour ,cable qui remplace un 250 occ elecaudio sur mes concept20 , il est tres profond,doux, rapide, ouvert , on sent pas les enceintes c est naturel!!!! basse precises et seches! Pour l instant le meilleur cable hp que j ai eu ( qed revelation,mogami ,canare,250 occ, triangle,cabasse, ) a recommander
Didier T.
JANTZEN AUDIO CROSS-CAP Capacitor 400V 30µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
Excellent rapport Q/P !
Adopté sur une correction // des boomers d'une paire d'EPOS Epic 5 en lieu et place de chimiques bipolaires basiques.
En effet, avant de me précipiter sur le changement des polypros en série avec les HP's, j'ai fait le choix de "nettoyer" en premier lieu ce qui est en général considéré à tord comme marginal avant d'aller plus loin.
Pour l'anecdote, les Epic 5 sont raccordées à un ensemble Nuprime DAC9X + STA9X eux-mêmes alimentés par un BADA LB6610.
Les Cross-Cap sont des polypropylènes métallisés (aluminium + zinc) la documentation constructeur ne dit pas s'ils sont non-inductifs.
Le résultat obtenu avec ces Cross-Cap est en l'occurence une sensation de "liant souple et aéré" accru, subtilement huileux avec moins de duretés.
La musique s'écoule avec moins d'efforts, de manière moins "carrée" et moins "in your face", au profit d'une sensation d'élégance tridimentionnelle.
Le ressenti de plus grande noblesse est plus que subtil.
Si je devais résumer mes sensations en quelques mots, je retiendrai "souplesse", "nuance" et "aération".
A ce tarif et dans cet usage-là, je ne lui voit aucun concurrent, seul de possibles manques de place sur les cartes des filtres ajoute un peu de difficulté à leur installation, le résultat valant nettement certaines contorsions d'installation.
Merci Jantzen, mention spéciale à Audiophonics pour ses délais de livraison tjrs aussi spectaculaires.
Didier T.
Adopté sur une correction // des woofers d'une paire d'EPOS Epic 5 en lieu et place de chimiques bipolaires basiques.
Hocine H.
Neutre
Branché entre une box et un streamer Red Holo avec câble RJ45 Viablue et connecteurs Telegartner (longueur 1m), je n'ai pas ressenti de différence avec et sans, donc je le laisse. Pour cela 3* car je reste neutre comme ce filtre sur mon installation. Peut être est-il plus efficace avec des câbles plus long ou alors n'en ai-je pas l'utilité...
Julien R.
Déçu
J’ai suivi les avis utilisateurs et après les heures de rodage nécessaires et bien c’est pas ça.
Je gagne dans les aigus (précision) mais je perd trop sur les médiums et le grave. J’ai tout de suite remis les mullards (12Ax7). J’ai un ampli Cayin I170 (kt170) il faut un peu de douceur pour calmer la bête. Certainement pas le bon match pour moi.
Marco D.
The Fosi ZA3 is absolutely great if you consider the price tag.
The Fosi ZA3 is absolutely great if you consider the price tag. The build quality is very good and I also like the minimalistic design. The orange power/volume knob and the orange dust covers in the side ventilation are nice details. Inside are mainly components of pretty good quality. One little "complaint" is that I find the volume potentiometer a bit coarse in the low range. That means a small adjustment results in relatively large volume increase.
I use it at home in my setup for the first floor and I also bought it to take with me if I stay in a vacation home for instance. I "need" a certain minimum level of sound quality and these homes in general just have a TV to play music or a very poor stereo. I take my Fosi ZA3, a set of Eltax Monitor 3 speakers and a raspberry Pi with a DAC board on top. In this compact setup the ZA3 does it's job very good in terms of sound quality.
Jean-Charles G.
Superbe fiches
Ces fiches utilisées pour mes câble HP Elecaudio font merveilleusement le travail avec une finition irréprochable, et en plus les gaines Thermo sont livrés avec.
Merci à Mr Aubert pour son conseil.
Jean-Charles G.
Interconnect Cable Female XLR - Male XLR Gold Plated CANARE L-4E6S 0.5m Red This XLR male to XLR female modulation cable has a nice design quality, using a Canare L-4E6S cable. The cable has copper conductors insulated with PE jackets and is shielded...
Câbles fantastiques
Je possède ces câbles de modulation depuis bientôt un mois et ils font mieux que mes Viard Audio silver HD qui valent 800€.
Merci à Mr Aubert pour ces conseils.
Jean-Charles G.
Câble fantastique
Je possède ces câbles HP depuis bientôt un mois et après une vingtaine d'heures de rodage, je confirme que ce câble est extraordinaire au regard du prix.
Je possédais avant des câbles Viard Audio HD 20 qui sont 18 fois plus cher et franchement ces Elecaudio associés à des fiches Viborg font jeu égal voir mieux que les Viard Audio.
Inutile de dépenser plus pour avoir mieux et pourtant mon système est assez haut de gamme.
Merci à Mr Aubert pour ces conseils .
