Maik B.
Maik B.
Fast shipping.
The sound is excellent. Ranked 5th out of many...
Theodoros R.
NICE OPAMP
VERY NICE OPAMP FOR THE MONEY!!
Customers reviews - There are 19109 reviews.
Talmadge I.
Sweet Spot of Class D Power Amplification
I bought this power amplifier to run a pair of difficult to drive but well loved Infinity Kappa 9's. It handles them with aplomb. Zero background noise, a common complaint on prior Class D amplifiers. For 700 Euros shipped, it is a bargain if you don't want to build yourself. The Purifi based amplifiers may put up slightly better specifications, but in my room I can't ask for more than this amplifier deliveres for the price.
Henry C.
Sounds thin so far
I’ve got to say after almost 23hrs in my system the little Aiyima DAC A3 at a price one fifth what I paid for this and only .775 volts per channel of output at the RCA’s sounds much stronger than this one with 2.1volts at the RCA’s per channel. I hope with more time it begins to sound more full bodied on the low end but right now I’m a little disappointed in what was supposed to be something much better than what I had. Maybe that changes with more break in. I hope I does because the two Audiophonics 200 watt purifi amps combined with the Topping Pre 90 preamplifier with the little Aiyima DAC A3 was sounding great! Couldn’t be more satisfied with my other purchases. Crossing my fingers for now.
SERGE B.
ELECAUDIO CH-22G MK2 Power Connector Switzerland SEV 1011 24k Gold Plated Ø17mm This Elecaudio CH-22G MK2 connector is a Swiss J-type mains connector (SEV1011). It features an insertion ring limiting the cable diameter to Ø17mm, as well as an...
Excellente qualité
Très belle fabrication. En remplacement d'une prise assez basique sur un câble d'alimentation "audiophile" d'une marque anglaise réputée pour branchement d'un ampli à lampe à un autotransformateur. Excellent résultat après blindage du câble en question avec disparition des bruits de basse fréquence.
SERGE B.
Très efficace
Utilisé pour blinder un cable d'alimentation "audiophile" d'une marque anglaise réputée à un ampli à lampes. Le bruit de fond de basse fréquence a totalement disparu. En connectant le blindage à la masse aux deux extrémités évidemment...
On lit tout et son contraire à ce sujet mais dans ce cas ce fût concluant.
Gilles S.
Nouvelle vie pour un vieux Yamaha YST-SW50
Possédant un caisson Yamaha subwoofer actif qui a un peu plus de 3 décennies encore fabriqué au Japon à l'époque a récemment perdu la suspension de son haut-parleur. Donc que faire ? Il y a plus de dix ans j'avais acheté un kit subwoofer atohm rafale 38 qui fonctionne toujours à merveille chez audiophonics et très content qu'ils existent toujours... Voilà comment j'ai trouvé ce petit HP ÉPIQUE de Dayton Audio qui remplace depuis peu le HP Yamaha d'origine et je dois dire que le résultat est vraiment terrible ! Je redécouvre mon caisson basse. Très très heureux et merci audiophonics d'être toujours là.
Raphaël B.
Très bon produit, excellent rapport qualité prix
Belle facture, les tensions et courants demandés sont respectés. c'est la deuxième fois que je fais appel à ce service et j'en suis très satisfait.
Raphaël
Filip B.
Should be like must
I purcese it with DC purifier and work for me just great. I sould do this before. Recommendet.
Filip B.
Should be like must
I had quite some problems with USB conection from streamer to DAC, after I purchace this tweek I have no problems any more.
For shure it helps, also for sound, everything is more clear.
Filip B.
Should be like must
This realy works, you can even hear the difference on medium good equipement. I have it for router used for streaming.
Richard B.
Excelente embases
Trés bonne qualité, le produit est solide. Soudures des fils sans difficultés. En remplacement d'embases défectueuses sur une platine vinyle Pro Ject The Classic.
Il était temps...
Acheté pendant le confinement j'avais décidé de tester le changement du câble secteur sur mes électroniques. Plutôt sceptique vis a vis de l'apport d'un tel composant et aussi peut-être impressionné par sa section énorme je l'avais remisé dans un carton et oublié jusqu'à ce que je récupère un supra lorad récemment. Essayé immédiatement sur ma source, un Cyrus cd6se il apportait une grande ouverture, transparence accrue au détriment de la matière et accentuait son equilibre montant. Donc dans la foulée j'ai essayé cet elecaudio monté avec des Viborg tout cuivre pour conserver la continuité du matériau. C'est très différent, l'écoute est plus posée, plus mate et n'apporte aucune brillance, aucun effet démonstratif qui n'est pas pour me déplaire. Au final difficile de dire qui fait quoi dans l'assemblage câble connecteur et d'apporter un avis définitif. Le ressenti est bon pour le prix mais attention au mariage sur un système déjà sombre ou trop feutré. Sinon je ne met que 4 étoiles car la mise en oeuvre est assez difficile, ce câble ce plie certes mais de la a dire qu'il est souple... Je ne suis pas d'accord. imaginez un petit tuyau d'arrosage derrière votre meuble et vous comprendrez. Je pense aussi que pour pas beaucoup plus cher il existe des modèles plus qualitatifs y compris chez elecaudio. J'ai maintenant envie de les essayer... A suivre.
Cheung T.
MUNDORF ACS1250GY ANGELIQUE Wiring Cable Copper / Silver / Gold 2.5mm² Grey Mundorf ACS1250GY ANGELIQUE is a high-end wiring cable with conductors made from a mix of copper, silver and gold for maximum conductivity. This model,...
Excellent cable
This is an excellent cable for high end audio. Although it is mentioned to have 50 strands of 0.25mm wire, I can only find 48 strands in 5 bundles, 3 with 10 strands and 2 with 9 strands, making me a bit difficult when I needed to split the wires for different applications
Pascal A.
Exceptionnel
Je l'ai acheté ici il y a quelques mois. Incroyable. Rapport qualité prix bousculant beaucoup de references beaucoup, mais alors beaucoup plus cher. A acheter sans retenu.
Pavol B.
Good but not perfect.
I bout this cable for making a jumpers - 0,6cm long. After more than 100hours burning, i have to say this - smooth, warm, less dynamic and less clear. I check them like this - i swithed speaker cable between terminals, what will be. When signal runed directly - that drivers been fast, clear, dynamic, expresive. When signal runed by jumpers, everything geting slower, less volume, less details, less dynamic, and etc. As if i put there 100m long cables or etc. Unfortunately, for my using, not good. After i made jumpers from Kimbre Kable - 24T, and this is totaly different, totaly opposite.
Vladimir p.
MULLARD GZ34 Rectifier Tube (Unit) The Mullard GZ34 tube is a high-end direct-heated rectifier diode. It is the re-edition of Mullard's most popular rectifier tube ever. Its purpose is to extend the life of other...
One of the very best rectifiers
This the second time I order MULLARD GZ34, it gives me what I want - wide soundstage, good separation, clean sound, exactly my cup of tea. One of two best rectifiers for HiFi along with GL in my opinion.
Vladimir p.
perfect DAC for my ends
Got XDUOO MU-604 Balanced DAC in two days!
It is just what I expected it to be. It is connected to tube amp x7, I love the sound it gives (lossless files) - slightly different but as clear and clean as from turntable or CD player+ Vitalizer mk2T. Plus I can tailor the sound to my liking. I love it! Highly recomended!
Jože F.
SYLPH AUDIO D100 P02 PFFB Amplifier Module Class D Stereo TPA3251 2x125W 4 Ohm The Sylphaudio D100 P02 Class D amplifier module is designed to deliver high-quality sound, including exceptional midrange clarity and transparency. It is based on a TI TPA3251...
Music
After AB class, this amp is opening new dimensions.
Christophe r.
C'est font leur boulot il simple et efficace attention banane ou fourches obligatoire car atypas de trou pour câble juste dénudé. C'est borniers sont bien construit dans un cuivre qui semble de qualité mes bananes tienne dedans sont bronché et pas un pette de jeux .... Hautement recommandé pour le prix
Kacper C.
Surprising.
At this price, in my opinion, there is no better. There is everything it should be, space, depth, detail or excellent control of the speakers.
Laurent D.
Son précis et equilibré MAIS !...
Manuel très incomplet et surtout ne gère pas la lecture continue entre les morceaux lorsque les pistes sont prévues pour s'enchainer les unes à la suite des autres. Le lecteur, dans ce cas, rajoute en permanence quelques secondes de silence. Ennuyeux !
Espérons qu'un firmware corrige ce défaut. Plus ennuyeux encore, il n'est pas dit que ce défaut ne se trouve pas dans le modèle supérieur à 1300 euros tout de même. Attention donc !
Joy O.
iFi Audio LAN Silencer
This product brought my Eversolo DMP-A6 to live in a way I could not have imagined. I would highly recommend this product to anyone. The enhancement to my audio listening experience since I installed one of this is very pleasing.
JEROME J.
FOSI AUDIO MC101 Stereo Amplifier 2x TPA3116 Bluetooth 5.3 2x100W 4 ohm With its MC101 stereo amplifier, Fosi Audio unveils a small device at the crossroads of vintage and modernism. The MC101 features Bluetooth functionality, as well as a...
Musical mais...
Du souffle léger et chuintement dans les hauts parleurs avant de lancer musique, mal isolé pour éviter parasitages vers enceintes, a revoir.
Simon S.
Incredible value for money
I normally never write a review but i feel inclined to do so for this product.
I have high sensitivity speakers (Blumenhofer) and thought that only a SET tube amplifier would be a good match, i was wrong.
My 300b died on me and having already put so much money in tubes i thought, time to try something different.
So after consideration and reading on audio science review forum about what makes an amplifier truly good, i choose this amplifier as in blind testing most people couldn’t hear a difference between Ncore and Purify (more expensive) and also between other even much more expensive amplifiers.
So i chose the smallest Ncore as my speakers are very easy to drive.
Listening:
The lower end is much cleaner and more controlled than my 300b was.
Midrange is fine, it hasn’t got the romantic touch of 300b tube but in it’s own right it doesn’t sound worse, just a bit different.
Highs, for class d, where in the past this just wasn’t very good, with Ncore i hear no problems whatsoever.
It just sounds great, and i dare say, for this price INCREDIBLE.
Hats off to Hypex and the original designer Bruno Putzey for making such a great inexpensive amplifier.
In my middle end to high end system it’s no slough.
Highly recommended, if your speakers need more juice, than the NC400 is better i guess.
Patrick d.
Great quality Speaker Cable
This is absolutely great cable for the money
La fin... Excellent rapport qualité prix !
Mauvaises manip clavier qui valident illico le message en cours de rédaction...
Remplacement des AOP NE5532 d’origine par des Burson V5i, puis des OP275 en enfin des oracles II.
Avec ces trois AOP on a enfin des voix timbrées et incarnées, des aigus variés avec du poids et de la matière, des cuivres rutilants, des instruments à corde en vrai bois d'arbre et non en plastique et toujours une bonne dynamique. Disparues les sifflantes et petites duretés/raideurs, c'est nettement plus expressif que les NE5532 qui sonnent un peu secs et monochromes en comparaison.
L'image sonore est globalement mieux remplie avec une largeur correcte, là où elle reste un peu coincée dans les HP avec les AOP d’origine. Avec une préférence envers l'OP275 par rapport au Burson V5i qui est moins homogène.
L'Oracle après 24 heures de fonctionnement non stop est le plus homogène des trois, avec de beaux timbres, un bon équilibre, pas de sifflantes ou dureté, une dynamique bien répartie, Bref un bon niveau de transparence qui rend hommage aux enregistrements. L'image sonore est large avec une bonne profondeur, du relief et les ambiances de prise de son son palpables. Un peu faible en niveau dans l’infra (via la sortie sub).
Bref on peut modifier de façon substantielle le rendu du Fois BT20a Pro en changeant d'AOP. Selon les enceintes associées, on peut arriver à un haut niveau de qualité globale, sans frustration comparé à de nombreux ampli plus classiques et pas ridicule face à mon SE 845 DIY, qui va certes plus loin en tout mais à quel prix.
La qualité en Bluetooth est moyenne, graves écourtés et aigus proéminents à atténuer sur l'ampli.
suite
Bref l'alim à découpage d'origine n'est pas silencieuse sur des enceintes à haut rendement et l'ampli souffle un peu.
Le niveau de la sortie sub est un poil faible en niveau mais ça passe.
Au niveau écoute au bout de quelques jours de fonctionnement, c'est assez surprenant pour une si petite boite et en regard du prix. C'est propre, dynamique, droit, très détaillé, mais un peu sec et monocorde, avec des sybillances et un aigu qui manque de poids et de texture.
L'image sonore correcte mais qui reste un peu coincée dans les HP et ça m
J'ai branché le petit BT20a Pro et son alim 32V/5A à la place de mon SE 845, sur pavillons mid bass + compression qui reproduisent les fréquences entre 150 H et 20 000 Hz, avec 103/105db d'efficacité.
La sortie sub du Fosi alimente un Crown avec deux 15".
À l'allumage, on entend pendant quelques secondes un petit sifflement qui disparait. À 1,5 mètre EN ENVIRONNEMENT TRÈS CALME, on entend le souffle dans la compression là où mon SE 845 est parfaitement silencieux même à 5 cm.
On proximité du pavillon, on entend faiblement le tiktiktiktik de l'alim à découpage.
Rien de gênant à la position d'écoute, mais l'a
Benjamin B.
Very good, high resolution, high end cable.
Very good! Makes a difference. Price justified. But you have to know: It brings out the highs! If your system is already a bit too bright this cable might not be for you. Tried it with my Hegel amp and my tube amp. Crisp, Clear, Good Resolution, Dynamic. With my Hegel amp the sound becomes a bit too bright but with my el-34 tube amp it makes a crisp dynamic resolving sound. Maybe the base gets a bit less with this cable but the base will be less boomy but accurate and more tight. I think this cable is mostly about resolution in all frequency ranges. Very good I think!
nicolas s.
Le AIYIMA D03 est un très bon amplificateur classe D. Etant mon 4ème, celui-ci est le plus naturel et dynamique. Excellent, même à volume très élevé... Je l'utilise dans 25m2 sur un woofer SBAcoustics + tweeter à ruban + sub. La sortie sub passive est bonne, la sortie USB est largement supérieure à la sortie RCA. Je n'ai pas testé la Coaxiale ni l'Optique.
Comme il est dit dans un autre commentaire et sur certains forums anglo-saxons les basses sont fermes et profondes.
Une précision quand même, en le branchant la 1ère fois je me suis aperçu que les basses étaient poussées à +14db. Le S.A.V d'Audiophonics m'a fait savoir qu'il peut y avoir des modèles dont les réglages ne sont pas remis à zéro suite au contrôle qualité, donc à vérifier si vous évaluez votre D3 au premier branchement.
Bernard D.
Un best-seller
Sans surprise, un excellent produit. La définition aussi bien dans le spectre haut que bas est excellente. La puce AKM du Dac n'est certainement pas étrangère à cet excellent résultat. Très satisfait d'autant que la livraison (vers la Belgique) fut très rapide.
Bravo Audiophonics !
Lennart H.
Audiophonics u-sabre pro dac usb
Super Perfekt
Dace P.
Visuell fiasko
Le son est bon. En revanche, la finition est misérable. Les coutures sont tordues et inesthétiques. J'ai une photo, mais comment la télécharger ? En raison de la mauvaise finition, je ne recommande pas l'achat.
Hugues D.
J'avais pour projet la recherche d'un "petit" ampli mono afin de driver une Triangle Secret LCR7, enceinte encastrable pour en faire une enceinte centrale.
En effet étant mélomane et cinéphile, je me voyais mal passé d'un ampli stéréo à un ampli full home cinéma. Ayant en front une paire de JBL 4312 MK2 et en back des Klipsch RP 600 M, un caisson Klipsch R-115SW le tout relié à un Yamaha RN 803 D, il me manquait pour une meilleure lisibilitée des paroles dans les films une centrale.
Mon choix c'est porté après plusieurs jours de recherche sur la SABAJ A20 qui semblait répondre à mes exigences et je ne suis pas déçu ! Relié en rca Out,
Le son est surprenant de clarté et de puissance ! Vraiment très plaisant à l'écoute en plus du boîtier en alu assez classe, élément important.
Merci à Audiophonics pour les informations claires et détaillées, l'envoi super rapide ! Je recommande !
Anthony M.
Libreelec
C'est le module qui manquait a mon raspberry pour le brancher à mon ampli Yamaha qui ne dispose pas de hdmi mais que d'une simple prise optique toslink.
Pour la configuration de Libre Elec il faut juste configurer le fichier config.txt avec l'overlay suivant (je le précise car je me suis fait avoir car la doc de hifiberry c'est pour un digi pas pro, du coup j'avais le son qui micro coupait toutes les 3s et en léger décalage)
dtoverlay=hifiberry-digi-pro
Mladen K.
ALPS
Very satisfied. Good price, fast shipment.
Excellent pre phono a conseiller
Pour celui qui ne veut pas de prise de tête pour choisir un prérempli phono, celui-ci est parfait pour un système plus que correct.
Merci à Audiophonics pour l'envoi hyper rapide comme d'habitude.
Andrea T.
Utilisé pour alimenter un routeur Fastweb.
Je retrouve une plus grande clarté dans le son avec Qobuz.
Rien de spectaculaire mais quand même perceptible à ce prix c'est fortement recommandé.
Vasileios K.
A great dac for the money
I really love the sound and the soundstage . Very natural sound and very good baseline
PIERRE A.
TBIEN
bonne qualité . Envoi très rapide , matériel bien emballé et bien protégé pour le transport
Jacques P.
Expérience client au top
Emballage soigné , installation simple , prise en main intuitive et rapide ; c'est un produit exemplaire au niveau de son interface client et le son est au rendez vous ... Me reste plus qu'à en profiter et découvrir ou redécouvrir plein de musique!
Deividas S.
Deividas S.
Deividas S.
OYAIDE SGBN Banana Plugs Silver / 24 Gold Plated Ø4mm (Set x4) The Oyaide SGBN are high quality banana plugs for high performance speaker cables. They are double plated with silver and 24k gold to ensure perfect signal transmission. In...
Super quality
LAURENT G.
Au bout de 4 mois d'utilisation
Les premières impressions positives se confirment. La transparence de la restitution et la séparation des canaux sont tout à fait remarquables. Les réglages de gains possibles 0, 6 ou 12 dB permettent une grande souplesse d'utilisation en fonction de la nature des sources et/ou des enregistrements. L'association avec un HPA-S 400ET forme un duo dont les performances sonores sont cohérentes avec les mesures et essais techniques que l'on peut trouver sur internet. Cependant, il ne faut pas s'attendre à une restitution systématiquement somptueuse ou flatteuse : les enregistrements sont reproduits sans fard. Les timbres peuvent perdre le charme que peut présenter un ampli à tubes (je le sais pour en avoir un). Mais le gain en terme de précision de la restitution est si flagrant qu'il est impossible de masquer les différences entre les sources numériques (en prenant le format CD comme référence) et les sources analogiques (radio ou phono). Les 30 à 40 dB de transparence supplémentaire qu'offre une source numérique ressort immédiatement.
Laurent G.
Jean-Pierre D.
Rendu très musical, fin et naturel
Je partage ce qui a été écrit précédemment, ayant le 1220 en version RCA monté par Néotech, l'ajout de connecteur argent et les XLR me semble améliorer la qualité d'écoute, c'est encore plus propre et transparent. Ce câble est étonnant, il peut se hisser à un niveau comparable des câbles haut de gamme de Cardas, Tellurium que je connais avec un tarif plus doux.
Pascal C.
bien mais...
j'ai commandé ce petit appareil pour avoir la possibilité de calmer un peu la partie médium de mon ensemble, c'est mieux en diminuant un peu les aigus mais il ne faut pas trop baisser au risque de perdre trop, un réglage pour les médium aurait été plus pertinent et j'ai vu trop tard que ça existait. concernant les lampes je n'ai pas remarqué un son plus chaud qu'avant, après un moment de chauffe par contre la scène sonore s'élargie un peu plus et c'est très bien, le rendu est plus doux. suite à ce que j'avais lu, j'ai laissé allumé une journée, résultat je ne le referai pas, je pensais qu'une fois une certaine température était atteinte l'écoute serait stabilisée ben j'ai trouvé le son encore plus agressif comme si l'appareil ne faisait plus effet, résultat je le coupe en même temps que le reste et ça va mieux. je pense que je testerai les autres tubes. j'ai fait une comparaison sur mon installation avec un autre modèle sans lampes mais avec réglage médium en plus, une catastrophe, medium utile mais même en laissant les boutons sur midi les voix étaient trop en retrait et son étouffé et en activant le bypass quelle claque, le son est redevenu vivant et les voix présentes. j'ai rebranché mon fx audio et c'est bien mieux quand même. les réglages aigus sont bien calibrés, mettre au milieu pour démarrer, le volume est bien aussi calibré pas de mauvaise surprise ( inséré entre un préampli Atoll pr200 et un ampli 3Dlab Nano ) surtout ne pas oublier l'ordre de la mise en route, à l'allumage fx audio en premier et ensuite le reste, et à la fin de l'écoute éteindre tous les appareils en premier et le fx audio en dernier sinon gros bruit dans les enceintes ( et ça fait peur ) .
Pascal C.
après en avoir testé un jeu, j'ai complété aves 8 autres pour relier petit à petit mon ensemble hifi et mon autre home cinéma. j'avais des cordons rel câble moniteur mais ceux-ci je les trouvais trop montant un petit poil agressif et fabrication un peu légère( obliger de mettre un petit coup de pince pour serrer plus sur la rca contrairement aux elecaudio , écoute moins agressive, plus de détails dans le médium et belle fabrication, fiches bien calibrées pour l'insertion dans les rca.
peu naturel ,metallique
Cable neotech cuivre argent mit sur ma play 4 ,son trop metallique ,fatiguant ,je le conseille pour l image ,pas pour le son!
Anthony C.
KECES P8 Ultra Low Noise Regulated Linear Power Supply 9 / 12V 8A + USB 5V 1A The Keces P8 is a high quality regulated linear power supply that will provide your high-fidelity audio system with a clean electrical signal. The power supply features a neat...
Génial
Cette alimentation est génial, je viens de faire un bon en avant assez important niveau qualité audio sur mon lecteur réseau Antipode S30 grâce à elle, plus de dynamique, du silence en fond, un son plus naturel franchement je ne regrette pas mon achat et c’est en rodage en plus, je recommande fortement, jeté les alimentations à découpage et à deux balles qui sont si bruyantes et qui peuvent polluer les autres appareils aux alentour
Fabien B.
