yann r.
6 moi utilisation
Michel V.
Musical et costaud !
Customers reviews - There are 19151 reviews.
Hocine H.
Respectable
Ce petit ampli reste correct, même après une 50 aine d'heures d'écoute et alimenté en 48V 7.3A, c'est plat, sans. Je le garde en spare au cas où, mais n'en acheterai pas d'autre. Rien de comparable à un Fosi ZA3.
Michiel W.
Audiophile NAS linear power supply
I use this power supply for my audio NAS streaming to JRiver on my audio PC. The sound effect is more quiteness (as I hoped) but also a bit restriction or less freedom (which is not as I want).
Surprisingly, Spotify sound seems improved, better details and transparent low. Here the NAS does not do anything, it is Spotify running on the audio PC.
The stand-by power consumption is not specified, but it gets above 35 deg C doing nothing, so I am curious how long I am willing to pay the electricity bill.
Nicolas B.
PSVANE EL84 HiFi Series Tubes (Matched Pair) The PSVane EL84 is a high-performance preamplifier/amplifier tube. These tubes are part of the brand's classic standard range, and provide excellent musicality....
A essayer...
Montées dans un ampli guitare bugera v22. Même pas 3h d'utilisation et c'est déjà très très bon. Très beau grain.
Toni S.
BEATECHNIK x LHY AUDIO LPS-A6 220V Linear Power Supply Module for EverSolo DMP-A6 The LPS-A6 linear power supply module has been specially designed to enhance the power supply stage of EverSolo DMP-A6 and DMP-A6 Master Edition network players by replacing the...
Tres bon
The better power supply raised the sound quality of the eversolo
DMP -A6 ME really a lot. I am happy that I bought it. The service was also good.
quel naturel!!!!!!
Bonjour ,cable qui remplace un 250 occ elecaudio sur mes concept20 , il est tres profond,doux, rapide, ouvert , on sent pas les enceintes c est naturel!!!! basse precises et seches! Pour l instant le meilleur cable hp que j ai eu ( qed revelation,mogami ,canare,250 occ, triangle,cabasse, ) a recommander
Didier T.
JANTZEN AUDIO CROSS-CAP Capacitor 400V 30µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
Excellent rapport Q/P !
Adopté sur une correction // des boomers d'une paire d'EPOS Epic 5 en lieu et place de chimiques bipolaires basiques.
En effet, avant de me précipiter sur le changement des polypros en série avec les HP's, j'ai fait le choix de "nettoyer" en premier lieu ce qui est en général considéré à tord comme marginal avant d'aller plus loin.
Pour l'anecdote, les Epic 5 sont raccordées à un ensemble Nuprime DAC9X + STA9X eux-mêmes alimentés par un BADA LB6610.
Les Cross-Cap sont des polypropylènes métallisés (aluminium + zinc) la documentation constructeur ne dit pas s'ils sont non-inductifs.
Le résultat obtenu avec ces Cross-Cap est en l'occurence une sensation de "liant souple et aéré" accru, subtilement huileux avec moins de duretés.
La musique s'écoule avec moins d'efforts, de manière moins "carrée" et moins "in your face", au profit d'une sensation d'élégance tridimentionnelle.
Le ressenti de plus grande noblesse est plus que subtil.
Si je devais résumer mes sensations en quelques mots, je retiendrai "souplesse", "nuance" et "aération".
A ce tarif et dans cet usage-là, je ne lui voit aucun concurrent, seul de possibles manques de place sur les cartes des filtres ajoute un peu de difficulté à leur installation, le résultat valant nettement certaines contorsions d'installation.
Merci Jantzen, mention spéciale à Audiophonics pour ses délais de livraison tjrs aussi spectaculaires.
Didier T.
Adopté sur une correction // des woofers d'une paire d'EPOS Epic 5 en lieu et place de chimiques bipolaires basiques.
Hocine H.
Neutre
Branché entre une box et un streamer Red Holo avec câble RJ45 Viablue et connecteurs Telegartner (longueur 1m), je n'ai pas ressenti de différence avec et sans, donc je le laisse. Pour cela 3* car je reste neutre comme ce filtre sur mon installation. Peut être est-il plus efficace avec des câbles plus long ou alors n'en ai-je pas l'utilité...
Julien R.
Déçu
J’ai suivi les avis utilisateurs et après les heures de rodage nécessaires et bien c’est pas ça.
Je gagne dans les aigus (précision) mais je perd trop sur les médiums et le grave. J’ai tout de suite remis les mullards (12Ax7). J’ai un ampli Cayin I170 (kt170) il faut un peu de douceur pour calmer la bête. Certainement pas le bon match pour moi.
Marco D.
The Fosi ZA3 is absolutely great if you consider the price tag.
The Fosi ZA3 is absolutely great if you consider the price tag. The build quality is very good and I also like the minimalistic design. The orange power/volume knob and the orange dust covers in the side ventilation are nice details. Inside are mainly components of pretty good quality. One little "complaint" is that I find the volume potentiometer a bit coarse in the low range. That means a small adjustment results in relatively large volume increase.
I use it at home in my setup for the first floor and I also bought it to take with me if I stay in a vacation home for instance. I "need" a certain minimum level of sound quality and these homes in general just have a TV to play music or a very poor stereo. I take my Fosi ZA3, a set of Eltax Monitor 3 speakers and a raspberry Pi with a DAC board on top. In this compact setup the ZA3 does it's job very good in terms of sound quality.
Jean-Charles G.
Superbe fiches
Ces fiches utilisées pour mes câble HP Elecaudio font merveilleusement le travail avec une finition irréprochable, et en plus les gaines Thermo sont livrés avec.
Merci à Mr Aubert pour son conseil.
Jean-Charles G.
Interconnect Cable Female XLR - Male XLR Gold Plated CANARE L-4E6S 0.5m Red This XLR male to XLR female modulation cable has a nice design quality, using a Canare L-4E6S cable. The cable has copper conductors insulated with PE jackets and is shielded...
Câbles fantastiques
Je possède ces câbles de modulation depuis bientôt un mois et ils font mieux que mes Viard Audio silver HD qui valent 800€.
Merci à Mr Aubert pour ces conseils.
Jean-Charles G.
Câble fantastique
Je possède ces câbles HP depuis bientôt un mois et après une vingtaine d'heures de rodage, je confirme que ce câble est extraordinaire au regard du prix.
Je possédais avant des câbles Viard Audio HD 20 qui sont 18 fois plus cher et franchement ces Elecaudio associés à des fiches Viborg font jeu égal voir mieux que les Viard Audio.
Inutile de dépenser plus pour avoir mieux et pourtant mon système est assez haut de gamme.
Merci à Mr Aubert pour ces conseils .
Du simple et bon
Si je ne suis pas totalement accessoire-sceptique, je suis loin d'être accessoire-phile. En ce sens, les bidules vendus à prix d'or me font fuir ; idem pour les câbles d'ailleurs. Par contre, un "bon" câble comme un "bon" accessoire, c'est possible et selon moi fabriqué à partir de matériaux que la raison est capable d'expliquer du fait de leurs qualités reconnues, et dans une proportion raisonnable (le prix le dit vite) - Là je suis preneur. C'est ici le cas avec ces pieds sorbothane. Un matériau dont on connaît parfaitement les propriétés, ici et ailleurs (semelles en sorbothane, etc.), dont on attendra pas de miracle (et c'est tant mieux, je ne leur demande pas de transformer un mauvais appareil en cheval de course) mais qui font parfaitement le taf (appareils bien plus stables dans mon cas) pour un prix tenu. Bref, ne pas se priver !
N.B. très bon traitement de la commande par Audiophonics (rapide suivi, etc.)
christian m.
produit excellent et audiophonics top
bon le produit fait super bien le taf.
mais alors que dire de ce respect des clients qui ce perd ailleurs merci d avoir si bien communiquer audiophonics merci 10/10 pour vous.
Jean Philippe D.
Ampoule Navette à LED Blanc Chaud pour Éclairage Vumètre / Tuner 8V
Service impeccable.
Commandé lundi de Liège, reçu le vendredi.
Un ami ma montré sur mon ampli Marantz les lampes à changer.
Pas bricoleur, j'ai tenté le coup et commandé les lampes.
Je les ais monté en 5 minutes, mon ampli a retrouvé son éclairage d'origine de 1974. Il est superbe.
Merci, je recommande.
Gérard F.
AUDIOPHONICS PULSAR Male USB-A to Male USB-B Cable Silver / Gold Plated 1.5m The Audiophonics Pulsar USB cable, thanks to a precise and meticulous design, using high-end materials, ensures a stable and clean signal transmission for high quality sound...
100% satisfait !
Rapport qualité /prix exceptionnel !
J'avais besoin d'un câble de qualité pour relier mon MacBook au Dac Chord Qutest , ce câble usb monté par Audiophonics est une très bonne surprise !
Qualité des timbres, neutralité exemplaire, acoustique des lieux d'enregistrement, tout est là!
Que vive la musique !
Bravo, je recommande !
Remy F.
Très bonne qualité au meilleur prix
Entièrement satisfait. Livraison plus rapide que prévu avec le réapprovisionnement. Merci Audiophonics
François H.
JANTZEN AUDIO ALUMEN Z-CAP Capacitor 100V 5.6µF Jantzen Audio Alumen Z-Cap capacitors are based on the Silver Gold Z-Cap series with a more neutral and musical tonal presence. This Aluminium Polypropylene series provides a...
Jantzen Audio Alumen Z-cap
Excellents condensateurs qui rivalisent à l'écoute avec des concurrents nettement plus chers !
Dejan V.
raffiné
Une meilleure dynamique, de meilleures basses, médiums et aigus ne fatiguent pas et sont moins durs et ne crient pas.
Un ton complètement naturel.
Dejan V.
ça vaut le coup ça vaut le coup
Monté avec des bouchons Viborg aux premiers bruits la mandibule touchait le sol. On dit qu’il faut des heures de travail pour montrer ses vraies couleurs.
Je n'ai pas beaucoup d'expérience avec les câbles, mais ce fil "fait" un meilleur son.
Benjamin P.
Amazing sound quality, fast delivery!
It is absolutely amazing what these class-d (Hypex) amplifiers can achieve nowadays. Compared to my class a-team this is even better and for a fraction of the price. At first, I could not believe what I heard, how the amp just absolutely “controls” my speakers, but after one week I am sure this is just wonderful. I think I need another one!
Petri P.
So good!
Amazing sound!
Hocine H.
Incroyable
Le temps d'attente en valait la peine car ce streamer transpire de qualité.
Un appareil comme je les aime, sobre, il n'y a pas de boutons, d'écran, sauf l'interrupteur ON/OFF.
Toutes les entrées possibles sont présentes et, un détail pour moi qui est important, les dispositions de ces entrées sont toutes alignées, pas de connecteurs de travers, qui est un gage de qualité de fabrication.
Pour la première écoute, on est conquis, c'est spacieux, fluide, grandiose, le meilleur streamer dans cette gamme de prix et au delà, c'est mon avis bien entendu.
Il mérite 5*, mais, oui il y a un mais, quand vous êtes novice, il n'est pas aisé de le faire fonctionner car il n'y a pas de doc livrée avec, il faut la télécharger, pas de problème, le problème, c'est que la doc ne correspond pas à 100% au software du RED, même après MAJ.
Donc voici ce qu'il faut faire, si cela peut aider.
1) Le RED est livré avec une carte Micro SD.
Insérez la carte et brancher le RED sous tension et au réseau (câble RJ45). Une led rouge apparaitra sur le devant, attendre que celle-ci passe au vert (quelques minutes).
2) Recherchez l'adresse IP du RED à l'aide de votre routeur, box ou IP Scanner (gratuit en téléchargement).
Utilisez ensuite un navigateur et entrer l'adresse IP, la page d'accueil est simple, quelques petits réglages et le choix de la diffusion, Tidal connect, Roon Ready, HQPlayer etc...
3) Impossible pour le moment, malgré la MAJ d'utiliser tous les services en même temps, si je suis sur ROON, je dois aller sur la page web pour changer l'utilisation sur HQPlayer ou Tidal, si je veux utiliser les utiliser, idem pour le reste, c'est un peu ennuyeux. Donc du mono service. Ou alors je m'y prend mal.
4) La carte Micro SD doit toujours rester insérée dans le RED pour fonctionner.
Bref, les qualités de ce streamer compensent largement ces petits défauts, et encore un petit point, le code ROON fournit avec le RED, pour une utilisation gratuite de ROON pendant 2 mois, ne fonctionne pas car déjà utilisé.
Une personne s'amuse à copier ces codes ou les codes sont périmés car ROON me dit, "Already used".
Olivier C.
FOSI AUDIO LC30 Audio Selector Switch for Amplifiers / Speakers vu-meter Yellow With its LC30, Fosi Audio unveils an amplifier and speaker selector. In other words, it allows you to switch easily and quickly between two power amplifiers and two pairs of...
Du plus bel effet
Je ne l'ai acheté que pour mettre un vu mètre, et c'est parfait vintage old school bien un truc de vieux comme disent mes gosses.
Les réglages sont simples, luminosité adaptable, les aiguilles synchro avec le son, tout est parfait !
Excellent, 3 fois!
Un module excellent dès les premières heures d'écoute.
Si le fer à souder est un problème, achetez la version atelier assemblée par Audiophonics : un must à prix contenu !
Alain S.
Superbe qualité
Mais pas évident a câbler. Les contacts sont sûr et francs.
Alain S.
Fantastique
Utilisés pour remplacer deux NE5532 dans mon vieux Marantz CD 50.
Les notes s'enchaînent avec une sorte de lien et le haut du spectre est plus aéré. Le médium est plus chaud et la dynamique a augmenté. L'aération générale est meilleure. Bon investissement !
léo p.
Très bien pour le prix, une des deux vis d'une fiche tournait dans le vide et je n'ai pu l'enlever. Sinon permet de bien serrer mon cable de section 4mm2.
léo p.
J'ai acheté cet ampli en remplacement de mon Aura Vita tombé en rade. Pour le prix il est très bon pas de problème pour alimenter mes colonnes trois voies acoustic energy. Je trouve que l'aigu est un peu "acide" et manque de charme mais encore une fois pour le prix c'est très bien. Quand mon Aura sera réparé il servira d'ampli de bureau. Envoi très rapide et soigné de la part d'audiophonics.
Brice C.
Fabrication de qualité
Super produit qui vaut son prix!
Suite a un changement d'ampli mes cables 4mm passaient difficilement sur les borniers d'ou la necéssité de passer au banane. Je craignais une perte de qualité sonorre comme on peux le lire parfois mais il n'en est rien. Ces fiches sont vraiment neutres et ne ternissent en rien le spectre.
J'en recommanderais bien volontier pour ma seconde installation!
Brice C.
A recommender pour tout les budgets serrés, super rapport qualité prix. Lorsqu'on le denude ce cable inspire confiance, je l'ai utilisé avec et sans banane et il respire la solidité!
Tout le spectre est limpide, utilisé avec du Denon et B&W j'en suis très satisfait et je l'ai même commandé de nouveau pour ma seconde installation.
Henry G.
Fonctionne parfaitement avec le logiciel REW.
Très bonne qualité de fabrication, fichier d'étalonnage propre a chaque appareil disponible sur le site du fabricant et aussitôt accepté par REW.
Gilles J.
Absorbeurs OREA Bordeaux
Utilisés depuis 4 mois sous un support d'ampli de puissance (qté=3).
Conception et fabrication excellentes, design élégant, produit performant. Très satisfait de cet achat
Câble USB de très haute qualité
Je viens de recevoir ce câble très rapidement (merci Audiophonics) , aussitôt installé!! Le résultat auditif s'avère très positif. L'écoute semble équilibrée et extrêmement musicale quelque soit le type de musique...Bref pour un prix encore raisonnable c'est réellement un vrai plus pour une installation. Pour moi c'est le meilleur câble USB que j'ai acheté et : ceci est très important Audiophonics offre le meilleur prix.
Sélecteur acquis pour utiliser 2 amplis. L’appareil est de très bonne fabrication, robuste et bien assis sur ses 4 pieds
Andrea M.
Arrived quickly, it works fine
Andrea M.
Very happy
Everything in order, well built, solid and easy to assemble
Andrea M.
Very happy
The product is exactly as described, it is really well designed and well built, everything was perfect.
NICOLAS B.
Cables qualitatifs
Je n'ai pas de comparaison possible puisque j'ai changé tout mon système hifi. En revanche, ces cables sont très bien conçus, plutôt esthétique et suffisamment souple pour les faire passer derrière mon meuble. J'ai commandé les Audiophonics mogami 3103 pour comparer à l'occasion. Pour le moment, je suis très satisfait de ce que mon oreille non avertie entends :P
NICOLAS B.
Top !
Cables de bonne facture, ça respire la qualité.
Ayant changé toute ma chaine hifi, je n'ai pas de comparaison possible. Si ce n'est que l'ensemble, y compris ces cables me donnent entière satisfaction à l'écoute.
NICOLAS B.
Mon commentaire rejoint la majorité des avis. Mes Focal 936 K2 peuvent s'exprimer librement. J'ai totalement changé de setup donc je n'ai aucune comparaison possible.
NICOLAS B.
Une belle surprise
C'est mon 1er préampli à tube donc pas de comparaison possible. En revanche, l'ajout de ce préampli a clairement ajouté de la chaleur et une certaine rondeur lorsque j'écoute mes vinyles et j'avoue que c'est plaisant. Je ne suis pas audiophile donc je ne saurais expliquer ce que j'entends mais j'apprécie la musique qui en ressort. N'est ce pas là l'essentiel ?
J'ai commandé un tube plus qualitatif selon les préconisations de certains utilisateurs, je laisserais mes impressions dans un prochain commentaire si j'arrive à distinguer une différence notable.
Daniel V.
Daniel V.
It is an overall excellent device (SMSL AO300), well thought out with a wide range of connection options to the source and end components of the apparatus.
In terms of sound, I am satisfied with its clean, natural sound on both analog and digital connections. Speakers used are B&W CDM-1 + Dali SW-8; on the headphone output there is an excellent combination with 1MORE Triple Driver Over-Ear headphones (slight modification - removal of 2/3 layers of foam above the drivers).
I wanted (ordered) a black version, a version with a silver front panel arrived. . . :-)
Eric K.
ampli casque
Super son . Utilisé avec connexion symétrique casque Audio technica
Eric K.
MUSES8920
Très bon sur ampli en remplacement de APO 5532
Eric K.
cable 4mm2
très bien pour mes enceintes colonne.Merci à Audiophonics
Robert W.
TOPPING D50 III DAC 2x ES9039Q2M XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD512 Silver Topping's new D50 III desktop DAC has been updated to deliver even better performance than its predecessors. It now features two ES9039Q2M DAC chips and an XMOS XU-316 USB...
DAC sounds realy nice
Only remote control (BT) seems to disconnect after a while and when Press a Button IT reconnects in around 15 Seconds and have to Press Button again to send Funktion.
Janez R.
Six Stars
In short, I had problems with first amp (left channel wouldn't turn on sometimes), waited too long for replacement one, with which I encountered some weird beeps from speakers - but found the cause with patient help from M. Sav. (poor wire sorting in the back of amp).
Now it is all perfect.
Congratulations to incredible Audiophonics team!!!
The sound is amazing, however, the curiosity of what 7040 and even 9040 are capable in terms of SQ, was only boosted by 400 Purifi amp module integrated into Audiophonics amp.
Thank you, Audiophonics.
Sebastien D.
IEC C13 to IEC C14 Power Cable Extension 3x0.75mm² 0.5m This IEC C13 to IEC C14 extension cable enables you to extend a mains connection by plugging in another mains cable. The cable features OFC copper conductors with a...
Une rallonge quoi
